TTEATLJANF-40.000000
    TAITIEN(泰艺)
    SMD7050_4P_EP
    有源晶振 40MHz SMD7050_4P_EP 2.8V~3.3V
TTEATLJANF-40.000000 数据手册
TT Type < for Stratum 3 > 7.0 x 5.0 mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package. - Stratum 3 (Overall ±4.6ppm including 20 years aging.) - CMOS and Clipped Sine wave (without DC-cut capacitor) output optional. TYPICAL APPLICATION - Stratum 3 - Femtocell, Base Stations RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) [TOP VIEW] [BOTTOM VIEW] 7.00±0.20 5.08±0.15 #3 4.00±0.15 #2 #2 #1 1.40±0.15 Pin# 0.7±0.12 1.90±0.20 1 2 3 4 4.20 0.1µF 0.80±0.15 #1 [SIDE VIEW] 5.08 #4 1.20 #3 5.00±0.20 #4 Function 1.50 Vcon:VC-TCXO GND/NC:TCXO GND OUTPUT VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION Parameter 2.5V Min. VDD-5% 5 Supply Voltage Variation (VDD) Frequency Range Standard Frequency 3.3V Max. Min. VDD+5% VDD-5% 52 5 10, 12.8, 16.384, 19.2, 20, 25, 26 -20 ~ 70 -40 ~ 85 Operating Temp. Range Frequency Stability (Overall, 20 Years)* Frequency Stability Vs Temp. Range (Ref. to (FMAX+Fmin)/2) _ _ ±0.14 (-20~+70°C) ±0.28 (-40~+85°C) Holdover Stability + _ ±0.32 _ _ 8 Supply Current (CMOS output) Supply Current (Clipped Sine Wave) Output Level (CMOS) Output High (Logic “1”) Output Low (Logic “0”) Duty Output Level (Clipped Sine Wave) Load (CMOS) Load (Clipped Sine Wave) Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 10 MHz Start time Storage Temp. Range 5 90%VDD _ ppm _ ±0.14 (-20~+70°C) ±0.28 (-40~+85°C) ppm _ _ _ ±0.32 ppm _ 45 0.8 _ 15pF 10 KΩ // 10pF 0.5 ±5.0 100 100 Hz 1 kHz 10 kHz _ -55 MHz ±4.6 8 5 _ 90%VDD 10%VDD 55 45 0.8 V °C _ ±4.6 _ Unit Max. VDD+5% 52 10%VDD 55 _ mA V % Vp-p 15pF 10 KΩ // 10pF 0.5 ±5.0 100 2.5 _ _ -130 -145 -154 5 125 2.5 _ _ V ppm kΩ dBc/Hz _ -55 5 mSec 125 °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Including calibration @ 25°C, supply voltage VDD±5% , load ±10%, reflow soldering, 20 years aging and frequency stability over temperature. + Including 24hours aging , supply voltage VDD±5% and frequency stability over temperature. Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(12) 07/2022 101
TTEATLJANF-40.000000 价格&库存
很抱歉,暂时无法提供与“TTEATLJANF-40.000000”相匹配的价格&库存,您可以联系我们找货
