VWEUPLLANF-153.600000
    TAITIEN(泰艺)
    SMD-6
    有源晶振 3.3V 153.6MHz SMD-6
VWEUPLLANF-153.600000 数据手册
VW Type 5.0 x 3.2mm SMD LVPECL/LVDS Voltage Controlled Crystal Oscillator Actual Size FEATURE - Typical 5.0 x 3.2 x 1.25 mm 6 pads ceramic SMD package. - Tight symmetry (45 to 55%) available. - Tri-state enable/disable TYPICAL APPLICATION - Set-top Box, HDTV - WiMAX/WLAN - xDSL/ VoIP, Cable modem RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ BOTTOM VIEW ] [ TOP VIEW ] 2.54 ± 0.15 5.00 ± 0.15 #4 #4 #5 #6 #2 #3 #3 #2 #1 0.1µF 1.20 #1 0.90 ± 0.15 2.10 ± 0.15 2.54 0.64 ± 0.15 0.55 1.25 ± 0.10 [ SIDE VIEW ] Pin# 1 2 3 4 5 6 2.20 #5 3.20 ± 0.15 #6 Function Vcon Tri-State GND Output Comp. Output VDD 0.85 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION LVPECL 3.3 V Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Absolute Pulling Range (APR) Control Voltage Range Supply Current 30 MHz Fo 250 MHz Output Level Output High (Logic “1”) Output Low (Logic “0”) Transition Time: Rise/Fall Time+ Max. Min. Max. VDD - 5% VDD+5% VDD - 5% VDD+5% 250 30 122.88, 153.6, 155.52, 156.25 _ ±50 0.3 3.0 100 ±50 0.3 2.275 _ _ _ 2.31 _ _ _ _ 1.68 0.9 1.0 3 _ _ _ 2.31 _ _ _ V 1.0 3 nSec mSec _ 20 10000 _ _ _ _ 1.0 0.7 0.5 0.3 _ _ _ _ 1.0 0.7 0.5 0.3 -105 -105 -128 -128 -145 -145 ±3 _ 125 -55 ppm V mA 1.6 _ 20 10000 _ MHz 3.0 75 0.99 10 _ _ -55 V 250 0.99 10 _ _ Phase Noise@122.88MHz 100 Hz 1 KHz 10 KHz Aging (@ 25°C 1st year) Storage Temp. Range unit Min. 30 Start Time Tri-State (input to Pin 2) Enable (High voltage or floating) Disable (Low voltage or GND) Linearity Modulation Bandwidth (BW) Input Impedance RMS Phase Jitter Fo < 100 MHz 100 MHz Fo < 125 MHz 125 MHz Fo < 150 MHz 150 MHz Fo 250 MHz LVDS 3.3 V V % kHz KΩ pSec dBc/Hz ±3 ppm 125 °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. + Transition times are measured between 20% and 80% of VDD. FREQ. STABILIT Y vs. TEMP. RANGE Temp. (°C) ppm -10 ~ +60 -20 ~ +70 -40 ~ +85 ±25 ±50 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. 80 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(9) 04/2022
物料型号为 VW Type,是一款5.0 x 3.2mm的SMD LVPECL/LVDS电压控制晶振。
器件简介: - 封装类型:6个焊盘的陶瓷SMD封装。
- 对称性:45%可用。
- 支持三态使能/禁用。
典型应用: - 机顶盒、高清电视(HDTV) - WiMAX/WLAN - xDSL/VoIP、有线电视调制解调器
引脚分配: - 1:Vcon - 2:三态 - 3:地(GND) - 4:输出 - 5:比较输出 - 6:电源电压(VDD)
参数特性: - 供电电压变化范围:VDD-5%至VDD+5% - 频率范围:30MHz至250MHz - 标准频率:122.88MHz、153.6MHz、155.52MHz、156.25MHz - 绝对拉偏范围(APR):+50ppm - 控制电压范围:0.3V至3.0V - 供电电流:30MHz时100mA,250MHz时75mA - 输出电平:高电平2.275V,低电平1.68V - 上升/下降时间:1ns - 启动时间:1ms至3ms - 三态使能:高电压或浮动2.31V,禁用低电压或地0.99V - 线性:10 - 调制带宽(BW):20kHz - 输入阻抗:10kΩ - 相位抖动:Fo<100MHz时1.0ps,100MHz≤Fo<125MHz时0.7ps,125MHz≤Fo<150MHz时0.5ps,150MHz≤Fo≤250MHz时0.3ps - 相位噪声:-105dBc/Hz至-145dBc/Hz - 老化(25°C第一年):+3ppm - 存储温度范围:-55°C至+125°C
功能详解: - 为了确保最佳振荡器性能,应在VDD和GND焊盘之间尽可能靠近器件放置一个0.1μF的旁路电容器。
应用信息: - 适用于需要精确频率控制的应用,如通信设备和高速数据传输设备。
封装信息: - 尺寸:5.0mm x 3.2mm x 1.25mm - 焊盘布局:详细尺寸和位置已提供。
请注意,以上信息是根据提供的PDF文档内容进行的中文分析。
VWEUPLLANF-153.600000 价格&库存
很抱歉,暂时无法提供与“VWEUPLLANF-153.600000”相匹配的价格&库存,您可以联系我们找货
