NA-10M-2051
NA-10M-2051
    TAITIEN(泰艺)
    DIP-5
    有源晶振 10MHz 3.3V DIP-5
NA-10M-2051 数据手册
Our Performance Your Reputation Oven Controlled Crystal Oscillator NA-10 MHz-2000 series 2000 Series in 25.4x25.4mm DIP package NA-10M-2000 series oscillators is designed for applications where space is at a premium and good frequency stability is required. The oscillators can be used in many communications applications. A choice of quartz resonators offers a variety of performance versus cost options to fit most applications. RoHS Compliant Standard ELECTRICAL SPECIFICATIONS 1. OUTPUT (PIN = “R.F. OUTPUT”) Parameter 1.1. Min. Frequency Typ. Max. 10.000000 Unit Test Condition MHz @ +25 ±1C 1.2. Initial Accuracy -0.1 +0.1 ppm after turn on power 15 ±1 minutes  90 days following date code VCO Input at Center Voltage ±0.001V 1.3. Waveform Rectangular Level CMOS “1” level 1.4. +2.4 V “0” level 1.5. Load 1.6. Duty cycle 1.7. Rise/fall time 1.8. Spurious 2. +0.4 15 45 pF 55 % @ +1.65V 6 ns 10% to 90% -60 dBc Max. Unit FREQUENCY STABILITY Parameter 2.1. 50 V Min. Ambient Aging 2.2. Typ. ±3, ±5, ±10 ppb -30 ~ +70 -40 ~ +85 C Test Condition referenced to 25C Refer to Table 1 : Ordering Information -0.5 +0.5 ppb per day, at time of shipment after 30 days Daily -0.5 +0.5 ppb Yearly -50 +50 ppb 10 Years -0.3 +0.3 ppm -0.5 +0.5 ppb 2.3. Voltage ±5% change 2.4. Short term 0.05 ppb/s 2.5. Load -0.5 +0.5 ppb ±5% change 2.6. Warm-up -10 +10 ppb in 10 minutes @ +25 ±1C root Allan variance http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice referenced to 1 hour Page 1of 3 Rev(2) 03/2023 Our Performance Your Reputation Parameter 2.7. 3. Min. Phase Noise 3.1. Min. Tuning Range 3.2. Slope 3.4. Center Voltage Test Condition -95 -90 dBc/Hz @ 1Hz -125 -120 dBc/Hz @ 10Hz -140 -135 dBc/Hz @ 100Hz -148 -145 dBc/Hz @ 1KHz -156 -155 dBc/Hz @ 10KHz -158 -155 dBc/Hz @ 100KHz Typ. Max. Unit -0.5 ppm VCO @ Min. Voltage ppm VCO @ Max. Voltage 0 +3.3 V 0 +2.8 V Test Condition Referenced to frequency at nominal Center Voltage Optional, Refer to Table 1 : Ordering Information Positive 3.5. Linearity -10 3.6. Input Impedance 100 +1.65 V +1.4 V +10 Optional, Refer to Table 1 : Ordering Information Note 1 % kΩ INPUT POWER (PIN = “+VDC”) Parameter 4.1. Voltage 4.2. Current 4.3. Steady State Min. Typ. Max. Unit Test Condition +3.135 +3.3 +3.465 V 1000 mA @ turn on 1.3 W @ +25C REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") (Optional Function. Refer to Table 1 : Ordering Information.) 5.1. 5.2. 6. Unit +0.5 Control Voltage 3.3. 5. Max. ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter 4. Typ. Parameter Min. Typ. Max. Voltage +2.7 +2.8 +2.9 Load 9 Units V Test Condition Over temperature range in 2.1. kΩ ENVIRONMENTAL Parameter 6.1. Operating Temperature 6.2. Storage Temperature Reference Std. -40C to +85C Test Condition Note 2 -55C to +105C 6.3. Humidity MIL-STD-202, Method 103 Test Condition A 6.4. Vibration (non-operating) MIL-STD-202, Method 201 0.06” Total p-p, 10 to 55 Hz 6.5. Shock (non-operating) MIL-STD-202, Method 213, Test Condition J 30g, 11ms, half-sine Note 1. Note 2. 95% RH @ +40C,non-condensing,240 hours When not connected, VCO INPUT is internally held at this voltage. Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Page 2of 3 Rev(2) 03/2023 Our Performance Your Reputation Table 1 : ORDERING INFORMATION TAITIEN Model No. ppb ±3 ±5 ±10 NA-10M-2000 NA-10M-2003 NA-10M-2050 NA-10M-2053 NA-10M-2001 NA-10M-2004 NA-10M-2051 NA-10M-2054 NA-10M-2002 NA-10M-2005 NA-10M-2052 NA-10M-2055 Control Voltage Reference Voltage +1.65V N/A +1.4V +2.8V Temp. (℃) -30~+70 -40~+85 -30~+70 -40~+85 OUTLINE DRAWING http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Page 3of 3 Rev(2) 03/2023
NA-10M-2051 价格&库存
很抱歉,暂时无法提供与“NA-10M-2051”相匹配的价格&库存,您可以联系我们找货
