NA-10M-2403
NA-10M-2403
    TAITIEN(泰艺)
    DIP-5
    有源晶振 10MHz 5V DIP-5
NA-10M-2403 数据手册
Our Performance Your Reputation Oven Controlled Crystal Oscillator NA-10 MHz-2400 series 2400 Series-square wave in 25.4x25.4mm DIP package NA-10M-2400 series oscillators is designed for applications where space is at a premium and good frequency stability is required. The oscillators can be used in many communications applications. A choice of quartz resonators offers a variety of performance versus cost options to fit most applications. RoHS Compliant Standard ELECTRICAL SPECIFICATIONS 1. OUTPUT (PIN = “R.F. OUTPUT”) Parameter 1.1. Min. Frequency Typ. Max. 10.000000 Unit Test Condition MHz @ +25 ±1C 1.2. Initial Accuracy -0.1 +0.1 ppm after turn on power 15 ±1 minutes  90 days following date code VCO Input at Center Voltage ±0.001V 1.3. Waveform Rectangular Level CMOS “1” level 1.4. +2.6 +3.3 “0” level 1.5. Load 1.6. Duty cycle 1.7. Rise/fall time 1.8. Spurious 2. 15 45 50 V pF 55 % @ +1.65V 6 ns 10% to 90% -60 dBc Max. Unit FREQUENCY STABILITY Parameter 2.1. V +0.4 Min. Ambient Aging 2.2. Typ. ±3, ±5, ±10 ppb -30 ~ +70 -40 ~ +85 C Test Condition referenced to 25C Refer to Table 1 : Ordering Information -0.5 +0.5 ppb per day, at time of shipment after 30 days Daily -0.5 +0.5 ppb Yearly -50 +50 ppb 10 Years -0.3 +0.3 ppm -0.5 +0.5 ppb 2.3. Voltage ±5% change 2.4. Short term 0.05 ppb/s 2.5. Load -0.5 +0.5 ppb ±5% change 2.6. Warm-up -10 +10 ppb in 10 minutes @ +25 ±1C root Allan variance http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice referenced to 1 hour Page 1of 3 Rev(2) 03/2023 Our Performance Your Reputation Parameter 2.7. 3. Min. Phase Noise Max. Unit Test Condition -95 -90 dBc/Hz @ 1Hz -125 -120 dBc/Hz @ 10Hz -140 -135 dBc/Hz @ 100Hz -148 -145 dBc/Hz @ 1KHz -156 -155 dBc/Hz @ 10KHz -158 -155 dBc/Hz @ 100KHz ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter 3.1. Tuning Range 3.2. Control Voltage 3.3. Slope 3.4. Center Voltage Min. Typ. Max. Unit -0.5 ppm VCO @ Min. Voltage ppm VCO @ Max. Voltage +0.5 0 +5.0 V 0 +4.0 V Test Condition Linearity -10 3.6. Input Impedance 100 Optional, Refer to Table 1 : Ordering Information +2.5 V +2.0 V +10 Optional, Refer to Table 1 : Ordering Information % INPUT POWER (PIN = “+VDC”) Min. Typ. Max. Unit 4.1. Voltage +4.75 +5.0 +5.25 V 4.2. Current 800 mA @ turn on 4.3. Steady State 1.3 W @ +25C Test Condition REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") (Optional Function. Refer to Table 1 : Ordering Information.) 5.1. 5.2. 6. Note 1 kΩ Parameter 5. Referenced to frequency at nominal Center Voltage Positive 3.5. 4. Typ. Parameter Min. Typ. Max. Voltage +3.8 +4 +4.2 Load 9 Units V Test Condition Over temperature range in 2.1. kΩ ENVIRONMENTAL Parameter 6.1. Operating Temperature 6.2. Storage Temperature Reference Std. -40C to +85C Test Condition Note 2 -55C to +105C 6.3. Humidity MIL-STD-202, Method 103 Test Condition A 6.4. Vibration (non-operating) MIL-STD-202, Method 201 0.06” Total p-p, 10 to 55 Hz 6.5. Shock (non-operating) MIL-STD-202, Method 213, Test Condition J 30g, 11ms, half-sine Note 1. Note 2. 95% RH @ +40C,non-condensing,240 hours When not connected, VCO INPUT is internally held at this voltage. Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Page 2of 3 Rev(2) 03/2023 Our Performance Your Reputation Table 1 : ORDERING INFORMATION TAITIEN Model No. ppb ±3 ±5 ±10 NA-10M-2400 NA-10M-2403 NA-10M-2450 NA-10M-2453 NA-10M-2401 NA-10M-2404 NA-10M-2451 NA-10M-2454 NA-10M-2402 NA-10M-2405 NA-10M-2452 NA-10M-2455 Control Voltage Reference Voltage +2.5V N/A +2.0V +4.0V Temp. (℃) -30~+70 -40~+85 -30~+70 -40~+85 OUTLINE DRAWING http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Page 3of 3 Rev(2) 03/2023
NA-10M-2403
物料型号: - NA-10M-2400系列:包括NA-10M-2400至NA-10M-2405,以及NA-10M-2450至NA-10M-2455,这些型号对应不同的温度范围和功能选项。
器件简介: - NA-10M-2400系列晶体振荡器设计用于空间有限且需要良好频率稳定性的应用。这些振荡器可用于多种通信应用,并提供多种石英谐振器选择,以适应不同性能与成本需求。
引脚分配: - 1号引脚:R.F. OUTPUT(射频输出) - 2号引脚:0 VOLTS & CASE(地和金属外壳) - 3号引脚:VCO INPUT(电压控制振荡器输入) - 4号引脚:REFERENCE VOLTAGE(参考电压)或未连接,具体取决于型号 - 5号引脚:+VDC(电源正极)
参数特性: - 频率:10.000000 MHz - 初始精度:±0.1 ppm(25±1°C) - 波形:矩形波 - 输出电平:CMOS电平,"1"电平2.6V至3.3V,"0"电平0.4V - 负载:15 pF - 占空比:45%至55% - 上升/下降时间:6 ns(10%至90%) - 杂散抑制:-60 dBc
功能详解: - 频率稳定性:根据不同环境温度范围,频率稳定性在±3至±10 ppb之间。 - 老化:每日-0.5至+0.5 ppb,每年-50至+50 ppb。 - 电压变化影响:±5%变化影响-0.5至+0.5 ppb。 - 短期稳定性:0.05 ppb/s(Allan方差)。 - 负载变化影响:±5%变化影响-0.5至+0.5 ppb。 - 预热:在+25±1°C下10分钟内-10至+10 ppb。
应用信息: - 该系列振荡器适用于需要空间节省和良好频率稳定性的通信应用。
封装信息: - 该系列提供25.4x25.4mm的DIP封装。
NA-10M-2403 价格&库存
很抱歉,暂时无法提供与“NA-10M-2403”相匹配的价格&库存,您可以联系我们找货
NA-10M-2403
  • 5+762.602025+98.66293
