CI-192-050
CI-192-050
    BIVAR
    HDWR INS TAB 0.465 X 0.219 CLR
CI-192-050 数据手册
REV. A B C D DESCRIPTION Engineering Update w/o Changes Engineering Release for Quote EOL 12/2010, CI-148-XXX Removed Material Code DATE APPROVED 02/24/04 07/10/08 02/21/11 05/24/16 M. C. M. C. T. Y. J. C. C/C 0.005 [0.1mm] C W CI-1XX-XXX SR Ø L PART NO. CI-192-028 CI-192-028SR* CI-192-028-3 CI-192-028-3SR* CI-192-050 CI-192-050-3 TYP. C .096 (2.4) .096 (2.4) .096 (2.4) C/C .192 (4.9) .192 (4.9) .192 (4.9) .192 (4.9) .192 (4.9) .192 (4.9) D L .465 (11.8) .465 (11.8) .465 (11.8) .465 (11.8) .465 (11.8) .465 (11.8) D .028 (.71) * .028 (.71) * .050 (1.3) .050 (1.3) W .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) .219 (5.6) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 3. * SR STANDS FOR SELF RETAINING LANCED FEATURE. 2. MATERIAL: POLYESTER FILM, 94VTM-2, CLEAR. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: CRYSTAL INSULATOR DATE: 02/24/03 DATE: 02/24/03 PART NO: REVISION: CI-1XX-XXX CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
CI-192-050 价格&库存
很抱歉,暂时无法提供与“CI-192-050”相匹配的价格&库存,您可以联系我们找货
CI-192-050
    • 438+1.51262438+0.19641
    • 569+1.16313569+0.15103
    • 1000+0.894541000+0.11616
    库存:4500
    CI-192-050
      • 18+1.2564018+0.16314
      • 50+1.1687450+0.15176
      • 100+1.09008100+0.14154
      • 300+0.98332300+0.12768
      • 500+0.93949500+0.12199
      • 1000+0.885551000+0.11499
      库存:18
      CI-192-050
        • 1+1.520861+0.19748
