470-045
470-045
    BIVAR
    Molded
    HDWR INS TAB .495 X .245 NYL WHT
470-045 数据手册
REV. B C D E F D APPROVED M. C. M. C. J. C. J. C. J. C. Ø.060 [Ø1.5mm] TYP. IH IW TYP. DATE 02/23/04 04/06/05 02/27/15 05/06/15 05/22/16 F W Ø DESCRIPTION Engineering Update w/o Changes Typo Correction Removed P/Ns Removed P/Ns Removed Material Code H L IL C/C PART NO. 470-015 470-025 470-035 470-045 471-015 471-025 471-035 471-045 L IL W IW C/C D .495 (12.6mm) .455 (11.6mm) .245 (6.2mm) .205 (5.2mm) .192 (4.9mm) .028 (.71mm) .495 (12.6mm) .455 (11.6mm) .245 (6.2mm) .205 (5.2mm) .192 (4.9mm) .050 (1.3mm) IH F H .015 (.38mm) .025 (.64mm) .035 (.89mm) .045 (.71mm) .015 (.38mm) .025 (.64mm) .035 (.89mm) .045 (.71mm) .000 (0.0mm) .010 (.25mm) .020 (.51mm) .030 (.76mm) .000 (0.0mm) .010 (.25mm) .020 (.51mm) .030 (.76mm) .050 (1.3mm) .060 (1.5mm) .070 (1.8mm) .080 (2.0mm) .050 (1.3mm) .060 (1.5mm) .070 (1.8mm) .080 (2.0mm) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ± .1 ± .01 ± .005 DESIGNED: M. Chen CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: CRYSTAL MOUNT SERIES DATE: 03/10/03 DATE: 03/10/03 PART NO: REVISION: 47X-XXX CAGE CODE : 32559 F SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
470-045 价格&库存
很抱歉,暂时无法提供与“470-045”相匹配的价格&库存,您可以联系我们找货
    • 16+1.5124216+0.19604
    库存:16
    470-045
    • 1+78.111991+10.12480
    • 10+31.2971010+4.05670
    • 100+28.15868100+3.64990
    • 500+25.02025500+3.24310
      • 1+6.051441+0.78438
