REV.
B
C
D
E
F
D
APPROVED
M. C.
M. C.
J. C.
J. C.
J. C.
Ø.060 [Ø1.5mm]
TYP.
IH
IW
TYP.
DATE
02/23/04
04/06/05
02/27/15
05/06/15
05/22/16
F
W
Ø
DESCRIPTION
Engineering Update w/o Changes
Typo Correction
Removed P/Ns
Removed P/Ns
Removed Material Code
H
L
IL
C/C
PART NO.
470-015
470-025
470-035
470-045
471-015
471-025
471-035
471-045
L
IL
W
IW
C/C
D
.495 (12.6mm) .455 (11.6mm) .245 (6.2mm)
.205 (5.2mm)
.192 (4.9mm)
.028 (.71mm)
.205 (5.2mm)
.192 (4.9mm)
.050 (1.3mm)
IH
F
H
.015 (.38mm)
.025 (.64mm)
.035 (.89mm)
.045 (.71mm)
.015 (.38mm)
.025 (.64mm)
.035 (.89mm)
.045 (.71mm)
.000 (0.0mm)
.010 (.25mm)
.020 (.51mm)
.030 (.76mm)
.000 (0.0mm)
.010 (.25mm)
.020 (.51mm)
.030 (.76mm)
.050 (1.3mm)
.060 (1.5mm)
.070 (1.8mm)
.080 (2.0mm)
.050 (1.3mm)
.060 (1.5mm)
.070 (1.8mm)
.080 (2.0mm)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-2, WHITE.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
± .1
± .01
± .005
DESIGNED:
M. Chen
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
CRYSTAL MOUNT SERIES
DATE:
03/10/03
DATE:
03/10/03
PART NO:
REVISION:
47X-XXX
CAGE CODE : 32559
F
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“470-015”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+2.40234500+0.31081
