XXGPPLNANF-20.000000 数据手册
XX Type
3.2 x 2.5 mm SMD Crystal
Actual Size
FEATURE
- Conforms to AEC-Q200
- Typical 3.2 x 2.5 x 0.75 mm ultra thin ceramic package.
- 8mm width Tape & Reel package for automatic assembly.
- Tight tolerance 10 ppm available.
TYPICAL APPLICATION
- Automotive
- Bluetooth, Mobile Phone, GPS
- Wireless LAN, 4G/LTE
- Hard Disk
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ B O T T O M V IE W ]
#3
#1
#2
2.20
GND
#2 and #4 are connected to the cover
(please connect to ground)
#3
1.20 1.0
0.75±0.10
1.50±0.10
2.10±0.10
#1
#2
#4
0.85±0.10
1.60
0.75 Max.
[ S ID E V IE W ]
#4
1.10
2.50±0.1
GND
0.5
[ T O P V IE W ]
3.20±0.1
ELECTRICAL SPECIFICATION
Parameter
Min.
Storage Temp. Range
Standard Frequency
Level of Drive
Shunt Capacitance (Co)
Insulation Resistance
Aging
Typical
-55
500 MΩ @ DC100V
Max.
16, 24, 26, 27, 32, 40
10
±1.0 to ±3.0
Unit
125
MHz
µw
pF
200
3.0
ppm / year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E. S. R.)
Frequency Range
8 MHz ≤ Fo < 10 MHz
10 MHz Fo
13 MHz
13 MHz < Fo 19.5 MHz
19.5 MHz < Fo
27 MHz
27 MHz < Fo
60 MHz
FREQ. STABILITY vs. TEMP. RANGE
Temp. ( o C)
ppm
±5
±10
±15
MODE
E.S.R
A1
A1
A1
A1
A1
XXGPPLNANF-20.000000 价格&库存
很抱歉,暂时无法提供与“XXGPPLNANF-20.000000”相匹配的价格&库存,您可以联系我们找货
