9C-12.000MEEJ-T
9C-12.000MEEJ-T
    TXC(台晶)
    HC49S
    陶瓷谐振器 12MHz ±10ppm ±10ppm HC49S
9C-12.000MEEJ-T 数据手册
Quartz Crystals SMD HC-49S 9C SERIES Features > Surface mount type crystal units. Quartz Crystals > A great number of standard frequencies. > High frequency pullability and low equivalent series resistance. > Highly mass production capability. > The best choice of PC, STB, LCDM, and Cable Modem. > RoHS Compliant / Pb Free. Electrical Specifications Item / Type 9C 3.2 ~ 90 MHz Frequency Range Frequency Tolerance (at 25 ºC) Frequency Stability Over Operating Temperature Range Operating Temperature Range ± 10 ppm, or specify ± 10 ppm (-20 ~ +70 ºC), or specify - 40 ~ + 85 ºC 7 pF Max. Shunt Capacitance (C0) 1 ~ 500 μW (100 μW typical) Drive Level 18 pF, or specify Load Capacitance ± 3 ppm / year Max. Aging (at 25 ºC) Storage Temperature Range - 55 ~ + 125 ºC Equivalent Series Resistance(ESR) Fundamental 3rd Overtone 3.2 ~ 3.686 MHz 200 Ω Max. 27 ~ 30 MHz 100 Ω Max. 3.686 ~ 5 MHz 150 Ω Max. 30 ~ 50 MHz 80 Ω Max. 5 ~ 10 MHz 80 Ω Max 50 ~ 90 MHz 60 Ω Max. 10 ~ 14 MHz 40 Ω Max. 14 ~ 30 MHz 30 Ω Max. Dimensions Units:mm Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com 04
9C-12.000MEEJ-T 价格&库存
很抱歉,暂时无法提供与“9C-12.000MEEJ-T”相匹配的价格&库存,您可以联系我们找货
