X3LEEJNANF-32.000000 数据手册
X3 Type
1.65 x 1.25 mm SMD Crystal
Actual Size
FEATURE
- Typical 1.65 x 1.25 x 0.3 mm ultra thin ceramic package.
- 8 mm width Tape & Reel package for automatic assembly.
- Tight tolerance 10 ppm available.
TYPICAL APPLICATION
- Bluetooth, Mobile phone, Wireless LAN.
- Office Automation.
- Audio & Video.
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ TOP VIEW ]
1.65 ± 0.10
GND
1.25 ± 0.10
#4
1.1
#1
[ BOTTOM VIEW ]
#1
#2
0.8
GND
0.3 ± 0.10
#2 and #4 are connected to the cover.
(please connect to ground)
0.6
[ SIDE VIEW ]
#2
#4
#3
0.7
0.37 ± 0.10
0.67 ± 0.10
#3
0.47 ± 0.10
ELECTRICAL SPECIFICATION
Parameter
Storage Temp. Range
Min.
Typical
Max.
-40
125
26,40
Standard Frequency
Shunt Capacitance (C0)
Insulation Resistance
o
C
MHz
μW
pF
200
3.0
10
500MΩΩ @ DC100V
±1.0 to ±3.0
Level of Drive
Unit
Aging
ppm/year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E. S. R.)
MODE
E.S.R.
24 MHz≦ Fo≦ 40 MHz
A1
X3LEEJNANF-32.000000 价格&库存
很抱歉,暂时无法提供与“X3LEEJNANF-32.000000”相匹配的价格&库存,您可以联系我们找货
