9B12000689
9B12000689
    TXC(台晶)
    HC49S
    陶瓷谐振器 12MHz ±20ppm ±20ppm HC49S
9B12000689 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : HC-49/S NOMINAL FREQ. : 12.000000MHz TXC P/N : 9B12000689 REVISION : A3 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : HC-49/S NOMINAL FREQ. : 12.000000MHz TXC P/N : 9B12000689 REVISION : A3 PE/RD QA MFG 2015/4/16 2015/4/16 2015/4/16 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page A1 N/A A2 4 A3 4,7,9,10 TXC P/N: 9B12000689 Revise contents REVISION:A3 PAGE: 2 Date Ref.No. Reviser Initial Release 2007/3/9 N/A Shu-Chen Ko TC Range change from -10~60 to 20~75 2012/8/16 ECN-08P112702 ECR-12A081401 Simon Wang Form Change(Page 4,Page 9, Add Page 7,Page 10). 2013/12/17 ECR-12A112101 Shu-Chen Ko ` FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 9B12000689 REVISION:A3 PAGE: 3 CONTENT SPECIFICATIONS • ELECTRICAL SPECIFICATIONS PAGE 4 DIMENSIONS • SUGGESTED REFLOW PROFILE • MANUAL SOLDER CONDITION 5 5 5 • 6 • MARKING • STRUCTURE ILLUSTRATION 7 • PACKING 8 • RELIABILITY SPECIFICATIONS 9 , 10 ATTACHMENT(S) (optional) TESTING DATA FMT-DOC024 • ELECTRICAL CHARACTERISTICS TEST A YES NO • TEMPERATURE CHARACTERISTICS TEST B YES NO Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 9B12000689 REVISION: A3 PAGE: 4 ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight : 0.52 g +/- 0.05g please refer to marking code page Parameters 1 2 3 4 SYM FL Electrical MIN. TYP. MAX. 12.000000 MHz Fundamental 20.0 -20 +20 Nominal Frequency Oscillation Mode Load Capacitance Frequency Tolerance CL FT 5 Frequency Tolerance ST -20 +20 6 7 8 9 10 11 12 13 14 OT -20 -5 +75 +5 500 40 7 Operating Temperature Aging Drive level Effective Resistance Rr Shunt Capacitance Motional Capactiance Insulation Resisstance Storage Tempeature Range SPDB(+/-5000ppm) DL Rr C0 C1 100 500 -40 +85 -3.0 Notes UNITS MHz pF ppm ppm at 25 oC +/- 3 oC Over Operating Temp.Range o C ppm uW ohm pF fF Mohm 1st year at DC 100V o C dB ■ FACTORY LOCATION : CHINA FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 9B12000689 REVISION: A3 PAGE: 5 UNIT:mm DIMENSIONS TXC 10.7 max. 3.8 max. 3.68 max. 3.4+/-0.2 0.43+/-0.125 Solder Coating 11.5 Max. (Sn-Ag-Cu Pb Free Coating) 5.0 Max. 4.88+/-0.25 ■ SUGGESTED REFLOW PROFILE o Solder melting point :220+/-10 C, 60 sec. Min. Peak Temperature: 260 +/- 5 oC, 10 sec. Max. (℃) 10 sec 260 220 180 ■ SUGGESTED MANUAL SOLDER CONDITION 150 Temperature: 350 +/- 10 oC Time: 3 sec. Re-solder times: twice FMT-DOC024 Time (sec) 120 sec 60 sec Issue Date: 12.15'08 VER.E TXC P/N: 9B12000689 TXC CORPORATION REVISION: A3 PAGE: 6 MARKING Marking For Pb Free Parts: TXC TXC Logo G Pb Free Product Lot Code (2 digits) Frequency Code Production Line Code Date Code Date Code: MONTH YEAR 2013 2017 2014 2018 2015 2019 2016 2020 For example : 2021 2025 2029 A B C D E F G 2022 2026 2030 N P Q R S T U 2023 2027 2031 a b c d e f g 2024 2028 2032 n p q r s t u *This date code will be cycled every four years. H J K V W X h j k v w x L Y l y M Z m z Marking TXC G 12.0MA01 FMT-DOC024 JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC Pb Free Product Introduction: 49S 12.000 MHz Made in 2013/JAN. 01Lot Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 9B12000689 REVISION: A3 PAGE: 7 STRUCTURE ILLUSTRATION : NO COMPONENTS 1 CRYSTAL BLANK HOLDER 2.1 SUPPORTER 2.2 CRYSTAL GLASS 2 2.3 BASE 2.4 3 4 5 FMT-DOC024 LEAD MATERIALS QUARTZ (SiO2) SPCC NICKEL SILVER GLASS KOVAR COVER NICKEL SILVER CONDUCTIVE ADHESIVE Ag + RESIN ELECTRODE Noble Metal FINISH/SPECIFICATIONS / Ni PLATED / / / (Coating : Sn/Ag/Cu) / / / Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 9B12000689 REVISION: A3 PAGE: 9 Packing For Pb Free Parts : 5bagx200pcs =1000pcs/box 1.INNER BOX:(Unit:mm) 200pcs/bag PUT PUT IN 2.LOGO STICKER(CARTON and INNER BOX):(Unit:mm) 150+/-10 190+/-10 42+/-10 PUT IN # (1) Put in stuff between space. [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5oC ~40oC temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC P/N: 9B12000689 TXC CORPORATION REVISION: A3 PAGE: 9 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance Test Item No. Test Methods Test Criteria 1.1 Drop test 50 cm Height, Fall freely onto firm wood for 3 times. BC 1.2 Mechanical Shock 1000 G , 0.5 m Sec. , 3 times for all 3 directions. BC 1.3 Vibration Frequency range 10 ~ 2000 Hz Acceleration 5G Sweep time 20 minute Pendicular axes each test time 4 hours BC (Total test time 12 hours) 1.4 Terminal Strength 1.5 Solderability 17.7N force for 60sec +/-1sec. F o Pb free :Temperature 235+/-5 C,Immersion time:5+/-1sec Pb :Temperature 215+/-5oC,Immersion time:5+/-1sec E 2.Environmental Endurance Test Item No. 2.1 Resistance To Soldering Heat SPEC Test Methods Test temperature 260 +/- 5 oC Test time 10 +/- 1 sec. Emersion Rate 25 +/- 6 mm/s Immersed of specimen 1.5mm ACD 2.2 High Temp. Storage + 85oC +/- 3 oC for 500 +/- 12 Hrs ACD 2.3 Low Temp. Storage - 40 oC +/- 3 oC for 500 +/-12 Hrs ACD o o -40 C~85 C,for 300 cycles. 1 cycle 85+/-3 oC 2.4 Temperature cycle ACD 25 oC -40+/-3 oC 30 min. 30 min. 5 min. 2.5 High Temp&Humidity 85oC +/- 3oC , RH 85% , 500 Hrs ACD ■HANDING CAUTIONS Prohibit the use of ultrasonic welding in Assemblying FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 9B12000689 REVISION: A3 PAGE: 10 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within +/-20ppm or in customer's specification. B Frequency change: Within +/-10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within +/-15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. F No damage on specimen Measurement condition Measurements are carried out with Network-analyzer( S&A 250B or equivalent). FMT-DOC024 Issue Date: 12.15'08 VER.E
9B12000689 价格&库存
很抱歉,暂时无法提供与“9B12000689”相匹配的价格&库存,您可以联系我们找货
