X2DCCCNANF-25.000000
    TAITIEN(泰艺)
    SMD3225_4P
    陶瓷谐振器 25MHz ±20ppm ±20ppm SMD3225_4P
X2DCCCNANF-25.000000 数据手册
X2 Type 3.2 x 2.5 mm Glass Seal SMD Crystal Actual Size FEATURE - Typical 3.2 x 2.5 x 0.75 mm full ceramic SMD package. - 8 mm width Tape & Reel package for automatic assembly. T YPICAL APPLICATION - PDA, DSC - DECT/ WDCT - 4G/LTE, WLAN RoHS Compliant X2 DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ TOP VIEW ] 2.50±0.20 NC 0.75±0.15 [ BOTTOM VIEW ] 2.10±0.10 #1 #3 #1 #2 2.20 NC #2 and #4 are empty terminals 1.10 [ SIDE VIEW ] #4 1.60 3.20±0.20 #4 #3 1.20 0.80±0.10 1.50±0.10 #2 0.90±0.10 ELECTRICAL SPECIFICATION Parameter Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (Co) Insulation Resistance Aging Min. Typical Max. -55 13, 16, 20, 25, 30 10 ± 3.0 125 500 MΩ@ DC100V Unit MHz µw pF 200 3.0 - ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. EQUIVALENT SERIES RESISTANCE (E. S. R.) Frequency Range 12 MHz Fo 13 MHz 13 MHz < Fo < 19.5 MHz 19.5 MHz Fo < 27 MHz 27 MHz Fo 48 MHz MODE E.S.R A1 A1 A1 A1 < 170 Ω < 100 Ω FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±5 ±10 ±15 < 70 Ω < 60 Ω FREQ. STABILITY vs. WIDE TEMP. RANGE Temp. ( o C) -10 ~ +60 -20 ~ +70 -40 ~ +85 * ○: Available △:Conditional X: Not available ppm ±15 ±20 ±30 ±50 -40 ~ +105 -40 ~ +125 * ○: Available △:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. 18 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(7)12/2019
X2DCCCNANF-25.000000 价格&库存
很抱歉,暂时无法提供与“X2DCCCNANF-25.000000”相匹配的价格&库存,您可以联系我们找货
