X2GCELNANF-25.000000 数据手册
X2 Type
3.2 x 2.5 mm Glass Seal SMD Crystal
Actual Size
FEATURE
- Typical 3.2 x 2.5 x 0.75 mm full ceramic SMD package.
- 8 mm width Tape & Reel package for automatic assembly.
T YPICAL APPLICATION
- PDA, DSC
- DECT/ WDCT
- 4G/LTE, WLAN
RoHS Compliant
X2
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ TOP VIEW ]
2.50±0.20
NC
0.75±0.15
[ BOTTOM VIEW ]
2.10±0.10
#1
#3
#1
#2
2.20
NC
#2 and #4 are empty terminals
1.10
[ SIDE VIEW ]
#4
1.60
3.20±0.20
#4
#3
1.20
0.80±0.10
1.50±0.10
#2
0.90±0.10
ELECTRICAL SPECIFICATION
Parameter
Storage Temp. Range
Standard Frequency
Level of Drive
Shunt Capacitance (Co)
Insulation Resistance
Aging
Min.
Typical
Max.
-55
13, 16, 20, 25, 30
10
± 3.0
125
500 MΩ@ DC100V
Unit
MHz
µw
pF
200
3.0
ppm / year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E. S. R.)
Frequency Range
12 MHz Fo
13 MHz
13 MHz < Fo < 19.5 MHz
19.5 MHz Fo < 27 MHz
27 MHz Fo
48 MHz
MODE
E.S.R
A1
A1
A1
A1
< 170 Ω
< 100 Ω
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±5
±10
±15
< 70 Ω
< 60 Ω
FREQ. STABILITY vs. WIDE TEMP. RANGE
Temp. ( o C)
-10 ~ +60
-20 ~ +70
-40 ~ +85
○: Available △:Conditional X: Not available
ppm
±15
±20
±30
±50
-40 ~ +105
-40 ~ +125
Note: not all combination of options are available. Other specifications may be available upon request.
18
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(7)12/2019
X2GCELNANF-25.000000 价格&库存
很抱歉,暂时无法提供与“X2GCELNANF-25.000000”相匹配的价格&库存,您可以联系我们找货
