XVHCCLNANF-16.000000 数据手册
XV Type
5.0 x 3.2 mm SMD Crystal
Actual Size
FEATURE
- Typical 5.0 x 3.2 x 0.8 mm ceramic SMD package.
- 12 mm width Tape & Reel package for automatic assembly.
- Tight tolerance 10 ppm available.
TYPICAL APPLICATION
- Bluetooth, GPS
- Display, TV(FPD/FTF LCD)
- Computer Peripherals
RoHS Compliant
XV
DIMENSION (mm)
[ TOP VIEW ]
#3
#2
[ BOTTOM VIEW ]
3.80±0.10
#1
#3
#1
#2
3.80
GND
#2 and #4 are connected to the cover
(please connect to ground)
2.20
#1
[ SIDE VIEW ]
GND #4
1.20
#4
0.80±0.20
3.20±0.20
5.00±0.20
#2
1.50
#4
#3
1.20±0.10
0.80±0.10
2.20±0.10
SOLDER PAD L AYOUT (mm)
ELECTRICAL SPECIFICATION
Parameter
Min.
Storage Temp. Range
Standard Frequency
Level of Drive
Shunt Capacitance (Co)
Insulation Resistance
Aging
Typical
Max.
-55
12, 16, 20, 25, 27, 28, 40
10
500 MΩ@ DC100V
±3.0
Unit
125
MHz
µw
pF
300
5.0
ppm / year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E. S. R.)
Frequency Range
8 MHz
11 MHz
12 MHz
13 MHz
16 MHz
24 MHz
48 MHz
Fo < 11 MHz
Fo
Fo
Fo
Fo
Fo
E.S.R
A1
XVHCCLNANF-16.000000 价格&库存
很抱歉,暂时无法提供与“XVHCCLNANF-16.000000”相匹配的价格&库存,您可以联系我们找货
