XJCBBIAANF-10.368000
    TAITIEN(泰艺)
    HC49S
    无源晶振 10.368MHz ±10ppm 10pF 40Ω -10℃~+60℃
XJCBBIAANF-10.368000 数据手册
XJ Type 12.5 x 4.5 mm Crystal FEATURE - Typical 12.5 x 4.5 x 4.0 mm metal can SMD package. - 24mm width Tape & Reel package for automatic assembly. TYPICAL APPLICATION - Automotive - Bluetooth, Wireless - Computers, Modems, Communications - Set-top Box, DECT/WDCT RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ BOTTOM VIEW ] [ TOP VIEW ] INSULATION BASE 12.50±0.50 9.00 4.50±0.20 0.6±0.20 11.40±0.20 2.00 CRYSTAL LEAD 4.28±0.20 [ SIDE VIEW ] 5.50 0.55±0.02 4.00±0.20 0.30±0.10 METAL CAN ELECTRICAL SPECIFICATION Parameter Typical Min. Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (Co) Insulation Resistance Aging (@25°C 1st year) -55 4.096, 10.368, 16, 25, 32, 48 10 500 MΩ@ DC100V ±5.0 Max. 125 500 7.0 - Unit MHz µw pF ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. EQUIVALENT SERIES RESISTANCE (E.S.R) Frequency Range 3.58 MHz Fo 4 MHz < Fo < 5 MHz 5 MHz Fo < 7 MHz 7 MHz Fo < 9 MHz 9 MHz Fo < 13 MHz 13 MHz Fo < 16 MHz 16 MHz Fo < 20 MHz 20 MHz Fo < 30 MHz 30 MHz Fo < 36 MHz 30 MHz Fo < 36 MHz 36 MHz Fo 80 MHz MODE E.S.R A1 A1 A1 A1 A1 A1 A1 A1 A1 A3 A3
XJCBBIAANF-10.368000 价格&库存
很抱歉,暂时无法提供与“XJCBBIAANF-10.368000”相匹配的价格&库存,您可以联系我们找货
  • 1000+7.546741000+0.97943
