ATR-10
ATR-10
    EATON(伊顿)
    ATR-10
ATR-10 数据手册
Automotive and hardware/home center product catalog BUSSMANN Circuit protection technology SERIES for automotive, home, marine and RVs. New Bussmann series product packaging coming 2017 Greater product display per linear foot with new, compact card sizes. Tri-lingual packaging meets today’s marketing needs. Enhanced shopability with large product and amp rating text. Quick identification with product family color coding. Bussmann yellow stays prominent. Bold new look. Package options In addition to boxed product, Bussmann™ series products are also available in packaging that is designed for various retail environments and needs. These package options do not apply to every product. Check the Bussmann series price sheet for availability. Below are explanations of the various packaging you’ll see listed in the product tables of this catalog. For more information, visit Eaton.com/BussmannConsumer. Traditional packs - automotive sAdditional packaging automotive Value packs Examples: VP/ATC-30ID, VP/ATM-25-RP, VP/FMX-A5-RP Ideal for small shops, mobile technicians, and avid car enthusiasts, these re-sealable clamshells and blister packs house 10 easyID™ fuses or 25 standard blade fuses. Tins Examples: ATC-20, SFE-14 Blade fuses and glass tube fuses may be ordered in tins. A tin holds FIVE fuses with the exception of MAXI™ fuses which are packed ONE fuse per tin. Polybags and boxes Examples: CB123-20HB, FMX-20, HHM Larger fuses like female MAXI, cartridge fuses and circuit breakers are packed ONE fuse per bag. High amp circuit breakers and fuse holders are packed in boxes. Retail packs - automotive Retail packs may be placed on a pegboard and come in blister packs and clamshells. They are generally ordered by adding the prefix “BP/” and suffix “-RP” or “-RPP” to the catalog number. Single amp packs Examples: BP/ATM-30-RP, BP/ATC-20ID These packs contain ONE to FIVE fuses of the same amp rating. Smaller parts are placed in blister packs while larger parts are placed in clamshells. Multiple amp assortment packs Examples: AGC-EK, ATC-ID-SK, BP/ATM-A5-RP, NO. 44 These packs house multiple fuses of varying amp ratings. Some packs come with a fuse puller. See pages 24 and 25 for more details. Bulk packs Examples: BK/AGC-30, BK/ATM-10LP, BK/MAX-20ID Available on select products, bulk pack fuses are available in plastic bags or boxes. Ask your Bussmann series sales rep or distributor for product availability. Reload packs Examples: ATM-2RLD, ATC-40RLD Available on select products, re-loads are bulk fuses packed in a clear polybag with product label and bar code. They are designed for re-loading product into installer assortments and tilt-bins like the NO.225. Installer assortments Examples: NO. 290, FUSE-CADDY2, CDY10TRY-ATC Contain a variety of circuit protection products for service technicians and repair shops. Retail packs - electrical Single amp assortment packs Examples: BP/GMA-2A, BP/FRN-R-30ID, BP/FRS-R-60 These packs contain ONE to FIVE fuses of the same amp rating. Glass fuses are placed in 1.77”W x 3.71”H cards. Assortment packs Examples: BP/ABC-A, NON-EK, TL-EK These packs contain multiple fuses of varying amp ratings. Some packs come with a fuse puller. See page 48 for more details. Table of contents (new products in red) Automotive products and accessories ATR, ATL, ATM, ATM-LP, ATC™ and MAXI™ blade fuses 6 ATR 2-leg micro blade fuses ATL 3-leg micro blade fuses ATM and low-profile ATM (ATM-(amp)LP) fuses ATC fuses MAXI fuses 7 7 7 7 7 8 easyID™ ATM, ATC, MAX and FMX illuminating fuses High amp fuses, cartridge fuses Multi-pole fuses Female MAXI™ Cartridge fuses Current limiters/blocks Battery terminal fuses Battery fuses/mounting bar High amp fuses/blocks MPF, MPF2 FMX, low-profile FMX (FMX-(amp)LP) FMM micro fuses FL Family: FLB, FLD, FLF, FLG, FLM, FLN, FLS ANN, ANL, SFR BTF CBBF, CBBF-MBC mounting bar AMG/HMEG, AMI/HMID 9 9 9 10 11 11 11 11 12 HH2 HHL, HHM, HHU, ATM-FHID HHC, HHD, HHF, HHG, HHR, HHS, ATC-FHID HHX, MAX-FHID BP/ATM-TAP-RP, BP/ATC-TAP-RP, BP/HHTR-RP, BP/ HHH-RP, BP/HHA-RP HFA, HFB, HHB, HHK, HLR, HHN, HMJ, HMK, HRH, HRI, HRJ, HRK HKP HKP-HH, HTB-(amp) 12 12 12 12 13 13 Fuse holders and taps ATR ATM fuse ATC fuse MAXI fuse ATR, ATM and ATC fuse taps and add-a-circuit Glass tube Glass tube panel-mount Fuse panels, blocks, fusible link wire and limiters ATR, ATM and ATC blocks ATM panels ATC panels FMX blocks Glass tube blocks Fusible link wire Current limiters/blocks 13 13 13 14 BP/FB(poles)-ATR, BP/FB(poles)-ATM, BP/FB(poles)-ATC RTMF 15600 Fuse only: CBPFM Fuse and relay: CBPRM S-8202-(amp), S8301-(amp) BP/FL-14, BP/FL-16, BP/FLW-14 ANN, ANL, SFR 14 14 14 14 14 CB22901-1.5, CB22902-68, CB22903-6 CB211, CB212, CB222OS, CB233, CB223OS, MMB ACB, CB221, CB222, CB223, CB227, CBB, CCB, FCB, UCB CB1911, CB1921 CBF Stud-terminal: CB123(amp), CBC(amp), CBP(amp) CB174 CB-CVR, BK/CB-CVR, BP/CB(amp)HB-CVR CBT-(amp), CBU CB181F, CB184F, CB185(amp), CB185P, CB285F 16 16 17 15 15 15 Automotive circuit breakers ATM mini devices ATM footprint ATC footprint MAXI footprint Glass tube footprint Heavy-duty Panel-mount Splash proof covers Quick-connect High amp 17 17 18-19 19 19, 32 19 20 Junction blocks and terminal strips Junction blocks Terminal blocks and strips JB3816-2, JB3816-3 TB200-(amp)B, TB300-(amp)B, C5237-(amp))BC 21 21 Not all products are listed in this catalog. If additional amperages are needed, contact your Bussmann series product representative. Some catalog numbers shown in this catalog are non-stock items and require longer lead times. Always check the latest price sheet for product status and availability. Bussmann series solutions comply with major industrial standards and agency requirements such as: BS, IEC, DIN, UL, NEMA, SAE, CSA, CE, C-UL, etc. and are manufactured at facilities that are ISO 9000 certified. This catalog is intended to present product data and provide technical information that will help the end user with design application. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this catalog. Once a product has been selected, it should be tested by the user in all possible applications. Further, Eaton takes no responsibility for errors or omissions contained in this catalog, or for misapplication of any Bussmann series product. Extensive product information is available in the Bussmann series product data sheets available online at Eaton.com/BussmannConsumer. © 2016 Eaton Printed in USA 4 For product information and data sheets, visit Eaton.com/BussmannConsumer Table of contents (new products in red) Toggle, rocker and battery disconnect switches Switches 22 Toggle, illuminated toggle, "Duckbill" toggle, metal housing toggle and rocker BMS-1, BMS-2, 15968-1 Battery switches Automotive flashers, lighting control modules and LED flashers Retail packaging, assortments and displays Automotive retail Automotive installer Automotive Plan-O-Gram Glass tube fuses Blade fuses Multi-fuse family Cartridge and blade fuse bulk assortments Fuse caddy installer assortments Five- and ten-cavity tray installer assortments Installer tilt-bin assortments 4FTAUTO-KIT, 4FTAUTO-TAGS Marine and RV products Circuit breakers Assortments Class T fuses Battery separators Battery isolators Battery isolator install kits 25 25 25 26-27 27 28 29 29 30 31 31 31 32 32 33 33 33 34 35 AGA, AGW, AGX, ABC, AGC, GBB, GBC, SFE AGU, AGU-(amp)GP MDA, MDL, MDQ GDA, GDB, GMA GDC, GMC, GMD, GMF 35 36-37 37 37 38 38 NON, NOS FRN-R-(amp), FRN-R-(amp)ID, FRS-R, FRS-R-(amp)ID CDN, PON BAF, KTK, KTK-R FNM, FNQ, FNQ-R SC s39 40-41 41 42 43 43 Cartridge fuses Class K5 and H Class RK5 Canadian CSA Type D and P Fast-acting midget, Class CC Time-delay midget, Class CC Class G specialty fuses 23 24 CB185, CB187-(amp), CB251, CB255 NO.108BK, BP/AGC-AH10-RP, BP/MDL-1, MA-5, BP/ AGC-SFE-A5-RP JJN 110 - 400 A RB-BS-1314, RB-BS-1315 RB-BI-70A, RB-BI-95A, RB-BI-120A, RB-BI-130A, RB-BI-240A B-BIK-1882, RB-GM-Kit Hardware and home products Glass and ceramic tube fuses Fuse overview and sizes Fast-acting 1⁄4” Fast-acting midget Time-delay 1⁄4” Fast-acting 5x20 mm Time-delay 5x20 mm 22 39 Plug fuses, adapters and circuit breakers 44 UL® Edison base Type T, TL Type BP/MB circuit breakers Type S, SL Type SA rejection base adapters Type TC, P Type CP/MB circuit breakers 44 44 45 45 45 45 Box cover units Surge protective device Accessories SOU, SRU, SSN, SSU, SSY, SSY-RL, STY RB-SPP-240PN Type 1 SPD 46 Fuse pullers Fuse testers/pullers FP-A3, FP-2, FP-3, FP-4, FP-6 FT-2, FT-3 47 47 47 NON and FRN-R fuse reducers NO.263, NO.263-R, NO.216-R, NO.2621-R 47 UL rejection base CSA® Edison base fuses Hardware packaging and assortments Hardware packaging Hardware Plan-O-Gram 46 48 Fuse assortments and emergency kits Holiday light fuse assortments 3FTHDWR-KIT, 3FTHDWR-TAGS Automotive and hardware circuit protection specifications Catalog number index Automotive fuse selection made easy chart For product information and data sheets, visit Eaton.com/BussmannConsumer 48 48 49 50-53 54 Inside back cover 5 Automotive products and accessories 6 For product information and data sheets, visit Eaton.com/BussmannConsumer ATR, ATL, ATM, ATM-LP, ATC, MAXI and blade fuses The industry standard - used in most domestic and imported cars today. All Bussmann series blade fuses meet or exceed OEM and SAE standards. ATR blade fuses 2-Leg micro fuses These space-saving fuses are used on newer vehicles. Color code Tan Brown Red Blue Yellow Clear Green Amps 5 7-1/2 10 15 20 25 30 Trad’l pack* ATR-5 ATR-7-1/2 ATR-10 ATR-15 ATR-20 ATR-25 ATR-30 Retail pack** BP/ATR-5-RP BP/ATR-7-1/2-RP BP/ATR-10-RP BP/ATR-15-RP BP/ATR-20-RP BP/ATR-25-RP BP/ATR-30-RP Bulk pack*** BP/ATR-5-RP BP/ATR-7-1/2-RP BP/ATR-10-RP BP/ATR-15-RP BP/ATR-20-RP BP/ATR-25-RP BP/ATR-30-RP * 5 Fuses per pack, 20 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. *** 50 Fuses per pack. See page 8 for easyID illuminating versions Black 1 ATM-1 — Gray 2 ATM-2 ATM-2RLD Violet 3 ATM-3 ATM-3RLD Pink 4 ATM-4 — Tan 5 ATM-5 ATM-5RLD Brown 7-1/2 ATM-7-1/2 ATM-7-1/2-RLD Red 10 ATM-10 ATM-10RLD Blue 15 ATM-15 ATM-15RLD Yellow 20 ATM-20 ATM-20RLD Clear 25 ATM-25 ATM-25RLD Green 30 ATM-30 ATM-30RLD * 5 Fuses per pack, 20 packs per shelf carton. ** 10 Fuses per pack. *** 5 Fuses per pack, 5 packs per shelf carton. † 25 Fuses per pack, 5 packs per shelf carton. ‡ 500 Fuses per pack. 3-Leg micro fuses These space-saving fuses are used on newer vehicles. The ATL fuses combine protection for two circuits in one package. Color code Tan Brown Red Blue Amps 5 7-1/2 10 15 Trad’l pack* ATL-5 ATL-7-1/2 ATL-10 ATL-15 * 5 Fuses per pack, 5 packs per shelf carton. ** 50 Fuses per pack. ATC blade fuses See page 8 for easyID illuminating versions Color code — BP/ATM-2-RP BP/ATM-3-RP BP/ATM-4-RP BP/ATM-5-RP BP/ATM-7-1/2-RP BP/ATM-10-RP BP/ATM-15-RP BP/ATM-20-RP BP/ATM-25-RP BP/ATM-30-RP Bulk pack** BK/ATL-5 BK/ATL-7-1/2 BK/ATL-10 BK/ATL-15 ATC blade fuses use the industry standard color-coding to indicate amp rating. Bussmann series ATC fuses are UL Recognized and feature an enclosed element for electrical isolation, corrosion resistance and longer service life. BK/ATC-5 through 30 A also available with open body. Refer to data sheet No. 2009 for available options. ATM blade fuses ATM fuses feature an enclosed element for electrical isolation, corrosion resistance and longer service life. Color Trad’l Retail code Amps pack* Reload** pack*** ATL blade fuses Value pack† Bulk pack‡ — VP/ATM-2-RP VP/ATM-3-RP VP/ATM-4-RP VP/ATM-5-RP VP/ATM-71/2-RP VP/ATM-10-RP VP/ATM-15-RP VP/ATM-20-RP VP/ATM-25-RP VP/ATM-30-RP BK/ATM-1 BK/ATM-2 BK/ATM-3 BK/ATM-4 BK/ATM-5 BK/ATM-7-1/2 BK/ATM-10 BK/ATM-15 BK/ATM-20 BK/ATM-25 BK/ATM-30 Trad’l Amps pack* Reload** Black 1 ATC-1 — Gray 2 ATC-2 — Violet 3 ATC-3 ATC-3RLD Pink 4 ATC-4 ATC-4RLD Tan 5 ATC-5 ATC-5RLD Brown 7-1/2 ATC-7-1/2 ATC-7-1/2RLD Red 10 ATC-10 ATC-10RLD Blue 15 ATC-15 ATC-15RLD Yellow 20 ATC-20 ATC-20RLD Clear 25 ATC-25 ATC-25RLD Green 30 ATC-30 ATC-30RLD Bl-Gn 35 ATC-35 — Orange 40 ATC-40 — * 5 Fuses per pack, 20 packs per shelf carton. ** 25 Fuses per pack. *** 5 Fuses per pack, 5 packs per shelf carton. † 25 Fuses per pack, 5 packs per shelf carton. ‡ 2000 Fuses per pack. Retail pack*** BP/ATC-1-RP BP/ATC-2-RP BP/ATC-3-RP BP/ATC-4-RP BP/ATC-5-RP BP/ATC-7-1/2-RP BP/ATC-10-RP BP/ATC-15-RP BP/ATC-20-RP BP/ATC-25-RP BP/ATC-30-RP — BP/ATC-40-RP Value pack† — — VP/ATC-3-RP VP/ATC-4-RP VP/ATC-5-RP VP/ATC-7-1/2-RP VP/ATC-10-RP VP/ATC-15-RP VP/ATC-20-RP VP/ATC-25-RP VP/ATC-30-RP — VP/ATC-40-RP Bulk pack‡ BK/ATC-1 BK/ATC-2 BK/ATC-3 BK/ATC-4 BK/ATC-5 BK/ATC-7-1/2 BK/ATC-10 BK/ATC-15 BK/ATC-20 BK/ATC-25 BK/ATC-30 BK/ATC-35 BK/ATC-40 MAXI™ (MAX) blade fuses See page 8 for easyID illuminating versions Low-profile ATM blade fuses Low-profile ATM fuses have the same ratings and universal color-coding as ATM and ATC fuses. Color Trad’l Retail code Amps pack* pack** Gray 2 ATM-2LP — Violet 3 ATM-3LP — Pink 4 ATM-4LP — Tan 5 ATM-5LP BP/ATM-5LP-RP Brown 7-1/2 ATM-7-1/2LP BP/ATM-7-1/2LP-RP Red 10 ATM-10LP BP/ATM-10LP-RP Blue 15 ATM-15LP BP/ATM-15LP-RP ATM-20LP BP/ATM-20LP-RP Yellow 20 Clear 25 ATM-25LP BP/ATM-25LP-RP Green 30 ATM-30LP BP/ATM-30LP-RP * 5 Fuses per pack, 20 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. *** 25 Fuses per pack, 5 packs per shelf carton. † 500 Fuses per pack. Value pack*** — — — — — VP/ATM-10LP-RP VP/ATM-15LP-RP VP/ATM-20LP-RP — — Bulk pack† — — — BK/ATM-5LP BK/ATM-7-1/2LP BK/ATM-10LP BK/ATM-15LP BK/ATM-20LP BK/ATM-25LP BK/ATM-30LP MAXI fuses protect circuits in the wiring harness - usually found under the hood, in a fuse panel or supplementary panel near the battery. Ideal for aftermarket accessories (such as high-end stereos) that require protection up to 80 amps. Color Trad’l. Retail code Amps pack* pack** Yellow 20 MAX-20 BP/MAX-20-RP Gray 25 MAX-25 — Green 30 MAX-30 BP/MAX-30-RP Brown 35 MAX-35 — Orange 40 MAX-40 BP/MAX-40-RP Red 50 MAX-50 BP/MAX-50-RP Blue 60 MAX-60 BP/MAX-60-RP Tan 70 MAX-70 BP/MAX-70-RP Clear 80 MAX-80 BP/MAX-80-RP Bulk pack*** BK/MAX-20 BK/MAX-25 BK/MAX-30 — BK/MAX-40 BK/MAX-50 BK/MAX-60 BK/MAX-70 BK/MAX-80 * 1 Fuse per pack, 20 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. *** 250 Fuses per pack. For product information and data sheets, visit Eaton.com/BussmannConsumer 7 easyID™ automotive illuminating fuses and fuse holders Finding the open fuse is easy with the Bussmann series easyID blade fuses and holders These drop-in replacements are available for applications that can benefit from open fuse indication. The easyID illuminating blade fuses and holders use LED technology that makes blown fuses easy to spot in fuse panels tucked up under dark dashboards. easyID ATM fuses With a large installed base, the ATC easyID illuminating fuse has great selling potential in popular amp ratings with trilingual packaging that’s designed for easy selling. See page 12 for easyID fuse holders. Color code See page 12 for easyID fuse holders. Amps Retail pack* Value pack** Violet 3 BP/ATM-3ID — Tan 5 BP/ATM-5ID — Brown 7-1/2 BP/ATM-7-1/2ID — Red 10 BP/ATM-10ID VP/ATM-10ID Blue 15 BP/ATM-15ID VP/ATM-15ID Yellow 20 BP/ATM-20ID VP/ATM-20ID Clear 25 BP/ATM-25ID VP/ATM-25ID Green 30 BP/ATM-30ID VP/ATM-30ID * 2 Fuses per pack, 5 packs per shelf carton. ** 10 Fuses per pack, 5 packs per shelf carton. *** 50 Fuses per pack. Bulk pack*** BK/ATM-3ID BK/ATM-5ID BK/ATM-7-1/2ID BK/ATM-10ID BK/ATM-15ID BK/ATM-20ID BK/ATM-25ID BK/ATM-30ID Contains one each of 10, 15, 20, 25 and 30 amp fuses. Retail pack* Contains one each of 10, 15, 20, 25 and 30 amp fuses plus a fuse puller. Violet 3 BP/ATC-3ID — Tan 5 BP/ATC-5ID — Brown 7-1/2 BP/ATC-7-1/2ID — Red 10 BP/ATC-10ID VP/ATC-10ID Blue 15 BP/ATC-15ID VP/ATC-15ID Yellow 20 BP/ATC-20ID VP/ATC-20ID Clear 25 BP/ATC-25ID VP/ATC-25ID Green 30 BP/ATC-30ID VP/ATC-30ID Blue-Green 35 BP/ATC-35ID — Orange 40 BP/ATC-40ID — * 2 Fuses per pack, 5 packs per shelf carton. ** 10 Fuses per pack, 5 packs per shelf carton. *** 50 Fuses per pack. Bulk pack*** BK/ATC-3ID BK/ATC-5ID BK/ATC-7-1/2ID BK/ATC-10ID BK/ATC-15ID BK/ATC-20ID BK/ATC-25ID BK/ATC-30ID — BK/ATC-40ID Contains one each of 10, 15, 20, 25 and 30 amp fuses. Contains one each of 10, 15, 20, 25 and 30 amp fuses plus a fuse puller. ATC-ID-SK fuse service kit ATM-ID-SK fuse service kit Contains six each of 5, 10, 15, 20, 25 and 30 amp fuses, making this service kit ideal for fleet maintenance departments. easyID FMX female MAXI fuses Following on the popularity and wider application of FMX fuses for late-model vehicles, the easyID FMX fuse, with LED blown fuse indication, is available in popular amp ratings with trilingual packaging that’s designed for easy selling. Retail pack* BP/FMX-20ID BP/FMX-30ID BP/FMX-40ID BP/FMX-50ID BP/FMX-60ID Contains seven each of 5, 10, 15, 20, 25 and 30 amp fuses, making this kit ideal for fleet maintenance departments. easyID MAXI™ (MAXI) fuses With ratings up to 100 amps, the Bussmann series easyID MAXI illuminating fuse line is a sure seller with trilingual retail packaging that’s designed for easy selling. See page 12 for easyID fuse holders. * 1 Fuse per pack, 5 packs per shelf carton. Color code Yellow Green Orange Red Blue Tan Clear Violet Amps 20 30 40 50 60 70 80 100 Retail pack* BP/MAX-20ID BP/MAX-30ID BP/MAX-40ID BP/MAX-50ID BP/MAX-60ID BP/MAX-70ID BP/MAX-80ID BP/MAX-100ID * 1 Fuse per pack, 5 packs per shelf carton. ** 250 Fuses per pack. 8 Value pack** ATC-FP-AID fuse emergency kit ATM-FP-AID fuse emergency kit Amps 20 30 40 50 60 Amps BP/ATC-AID fuse assortment BP/ATM-AID fuse assortment Color Blue Pink Green Red Yellow Trilingual packaging in English, Spanish and French. easyID ATC fuses Following on the popularity and wide application of ATM fuses, the easyID illuminating ATM fuse is available in popular amp ratings with trilingual packaging that’s designed for easy selling. Color code In-line easyID fuse holders allow adding fused circuits with blown fuse indication using regular ATM, ATC and MAXI fuses. For product information and data sheets, visit Eaton.com/BussmannConsumer Bulk pack** — BK/MAX-30ID BK/MAX-40ID BK/MAX-50ID BK/MAX-60ID — BK/MAX-80ID — High amp fuses Multi-pole fuses Female MAXI fuses Bussmann series multi-pole fuses (MPFs) provide sales-making opportunities formerly only dealerships and online parts websites enjoyed. Developed to meet the demand for smaller components, the FMX and low-profile FMX female MAXI fuses offer high amp protection in compact packages. Both FMX and low-profile FMX fuses are available in amp ratings from 20 to 60 A. Multi-pole fuses are OEM fuses that combine multiple circuits in to a single design to reduce the weight, space and cost of traditional fusing solutions. These fuses have been used since 2002 in popular models of Nissan®, Infiniti®, Toyota®, and Lexus models. These fuses are easy to replace by service technicians and DIYers alike using the same female maxi-type fuse puller. See page 8 for easyID FMX female Maxi fuses FMX Female MAXI fuses 1.06” MPF 32 Vdc multi-pole fuses Color code Amps Trad’l pack* Bulk pack** OEM no. Pink 40, 30, 30 MPF-433X BK/MPF-433X 24370-C9902 Green 40, 40, 40 MPF-444X BK/MPF-444X 24370-C9900 Red 50, 30, 30 MPF-533X BK/MPF-533X 24370-C9906 Blue 50, 30, 40 MPF-534X BK/MPF-633X 24370-C9907 Yellow 60, 30, 30 MPF-633X BK/MPF-534X 24370-C9904 Vehicle make Nissan, Infiniti Nissan, Infiniti Nissan, Infiniti Nissan, Infiniti Nissan * 1 Fuse per pack, 10 packs per shelf carton. ** 50 Fuses per pack. 58 Vdc multi-pole fuses Amps 30, 20, 40 Trad’l Bulk pack* pack** MPF2-324X BK/MPF2-324X Pink 40, 30, 30 MPF2-433X BK/MPF2-433X Green 40, 40, 40 MPF2-444X BK/MPF2-444X OEM no. 24370-C991C 24370-C991A 90982-08308 24370-C991B 90982-08299 24370-C992A Red 50, 30, 30 MPF2-533X BK/MPF2-533X 90982-08300 24370-C992B Blue 50, 30, 40 MPF2-534X BK/MPF2-534X 90982-08301 24370-C992C Black 50, 30, 50 MPF2-535X BK/MPF2-535X 90982-08302 Maroon 50, 50, 50 MPF2-555X BK/MPF2-555X * 1 Fuse per pack, 10 packs per shelf carton. ** 50 Fuses per pack. Trad’l pack* FMX-20 FMX-25 FMX-30 FMX-40 FMX-50 FMX-60 Amps 20 25 30 40 50 60 Retail pack** BP/FMX-20-RP BP/FMX-25-RP BP/FMX-30-RP BP/FMX-40-RP BP/FMX-50-RP BP/FMX-60-RP * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. FMX-LP Low-profile female MAXI fuses MPF2 Color code Yellow Color code Blue White Pink Green Red Yellow 90982-08303 Vehicle make Nissan Nissan Toyota, Lexus Nissan, Infiniti Toyota, Lexus Nissan, Infiniti Toyota, Lexus Nissan, Infiniti Toyota, Lexus Nissan, Infiniti Toyota, Lexus Lexus Color code Blue White Pink Green Red Yellow Amps 20 25 30 40 50 60 0.625” Trad’l pack* FMX-20LP FMX-25LP FMX-30LP FMX-40LP FMX-50LP FMX-60LP Retail pack** BP/FMX-20LP-RP BP/FMX-25LP-RP BP/FMX-30LP-RP BP/FMX-40LP-RP BP/FMX-50LP-RP BP/FMX-60LP-RP * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. 0.59” FMM Micro fuses The new FMM micro slow-blow fuse meets the latest demand for smaller, high current circuit protection products being found on new model vehicles. Color code Grey Blue White Pink Green Amps 15 20 25 30 40 Trad’l pack* FMM-15 FMM-20 FMM-25 FMM-30 FMM-40 Retail pack** BP/FMM-15-RP BP/FMM-20-RP BP/FMM-25-RP BP/FMM-30-RP BP/FMM-40-RP Bulk pack*** BK/FMM-15 BK/FMM-20 BK/FMM-25 BK/FMM-30 BK/FMM-40 * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. *** 50 Fuses per pack. For product information and data sheets, visit Eaton.com/BussmannConsumer 9 Cartridge fuses FL family of cartridge fuses Used primarily in Japanese-designed vehicles for wiring harness protection. FLB FLG Bolt-mount fuses Female fuses Fits 13/16” bolt terminal fuse block. Color code Pink Green Red Yellow Brown Black Blue Gray Maroon Amps 30 40 50 60 70 80 100 120 140 1.939” C-C Trad’l pack* FLB-30 FLB-40 FLB-50 FLB-60 FLB-70 FLB-80 FLB-100 FLB-120 FLB-140 Retail pack** BP/FLB-30-RP BP/FLB-40-RP BP/FLB-50-RP BP/FLB-60-RP BP/FLB-70-RP BP/FLB-80-RP BP/FLB-100-RP BP/FLB-120-RP BP/FLB-140-RP * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. FLD Bolt-mount fuses Fits 9/16” bolt terminal fuse block. Color code Pink Green Red Yellow Brown Black Blue Gray Maroon Amps 30 40 50 60 70 80 100 120 140 1.413” C-C Trad’l pack* FLD-30 FLD-40 FLD-50 FLD-60 FLD-70 FLD-80 FLD-100 FLD-120 FLD-140 Retail pack** BP/FLD-30-RP BP/FLD-40-RP BP/FLD-50-RP BP/FLD-60-RP BP/FLD-70-RP BP/FLD-80-RP BP/FLD-100-RP BP/FLD-120-RP BP/FLD-140-RP * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. Color code Red Yellow Black Amps 50 60 80 Trad’l pack* FLG-50 FLG-60 FLG-80 Retail pack** BP/FLG-50-RP BP/FLG-60-RP BP/FLG-80-RP * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. FLM Male fuses Color code Pink Green Yellow Black Blue Gray Violet Amps 30 40 60 80 100 120 140 Trad’l pack* FLM-30 FLM-40 FLM-60 FLM-80 FLM-100 FLM-120 FLM-140 Retail pack** BP/FLM-30-RP BP/FLM-40-RP BP/FLM-60-RP BP/FLM-80-RP BP/FLM-100-RP BP/FLM-120-RP — * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. FLN Female fuses with tab Color code Brown Green Amps 25 30 Trad’l pack* FLN-25 FLN-30 Retail pack** BP/FLN-25-RP BP/FLN-30-RP * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. FLF Female fuses FLS Color code Lt-Blue Pink Green Red Yellow Amps 20 30 40 50 60 Trad’l pack* FLF-20 FLF-30 FLF-40 FLF-50 FLF-60 * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. 10 Retail pack** BP/FLF-20-RP BP/FLF-30-RP BP/FLF-40-RP BP/FLF-50-RP BP/FLF-60-RP Miniature female fuses Color code Pink Green Amps 30 40 Trad’l pack* FLS-30 FLS-40 * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. For product information and data sheets, visit Eaton.com/BussmannConsumer Retail pack** BP/FLS-30-RP BP/FLS-40-RP Battery terminal and high amp fuses Battery terminal fuses AMG Bussmann series battery terminal fuses (BTFs) provide sales-making opportunities formerly only dealerships and online parts websites enjoyed. Stud-mount fuses These fuses have been used since 2001 in popular models of Chrysler®, Ford®, Lexus, Lincoln, Mercury, Mitsubishi, Nissan®, Scion, Subaru, Suzuki, and Toyota® models. Bussmann series BTFs are OEM fuses that contain one or more circuits in a single design to reduce the weight, space and cost of traditional fusing solutions to protect the cables coming off the battery and other electrical components. AMG fuses are for high current applications on select late model vehicles and available in ratings from 80 to 500 A. Use with the HMEG fuse block see below. These fuses are easy to replace by service technicians and DIYers alike using common hand tools. Trad’l pack* 80 BTF-1P-80 100 BTF-1P-100 120 BTF-1P-120 140 BTF-1P-140 180, 120 BTF-2P-180120 200, 100 BTF-2P-200100 250, 125 120, 60, 80 120, 80, 80 BTF-2P-250125 BTF-3P-1206080** BTF-3P-1208080** Retail pack** — — — — BP/AMG-175-RP — — — — — — — HMEG Battery terminal fuses Amps Trad’l pack* AMG-80 AMG-100 AMG-125 AMG-150 AMG-175 AMG-200 AMG-225 AMG-250 AMG-300 AMG-400 AMG-450 AMG-500 * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. See page 22 for battery switches, and pages 32 and 33 for isolators and separators BTF Amps 80 100 125 150 175 200 225 250 300 400 450 500 Fuse block OEM part no. 82211AG150 3673-950J00 MN164187 3673-952J00 MN164188 3673-966J00 82620-33040 24380-JA70A 68164797-AA BR3Z-14526-AA AE5Z-14526-BA AL3Z-14526-AA 82620-52080A 82620-52060A Vehicle make Subaru Suzuki Mitsubishi Suzuki Mitsubishi Suzuki Lexus, Scion, Toyota Nissan Chrysler Ford Ford, Lincoln, Mercury Ford Scion, Toyota Scion, Toyota * 1 Fuse per pack, 5 packs per shelf carton. ** 1 Fuse per pack, 24 packs per master carton. For use with up to 500 amp AMG fuses, the HMEG bolt-in fuse holder features an impact resistant base and elastomer cover for full access and ease of wiring using 8 AWG to 1/0 wire. Order catalog number HMEG* or bulk catalog number FMG-211.** *1 fuse block per pack, 24 packs per master carton. ** 100 fuse blocks per pack. AMI Stud-mount fuses Used in some late model vehicle systems for high power distribution. Use with HMID fuse holder see below. CBBF battery fuses These fuses are suitable for main and auxiliary circuit protection (alternator outputs, starter motor inputs and accessories) in demanding environments or tight space constraints. Marine-rated under SAE J1171 for ignition protection. Use with CBBF-MBC mounting bar. CBBF-MBC mounting bar Amps Trad'l pack* 30 CBBF-30 40 CBBF-40 50 CBBF-50 60 CBBF-60 70 CBBF-75 80 CBBF-80 90 CBBF-90 100 CBBF-100 125 CBBF-125 150 CBBF-150 175 CBBF-175 200 CBBF-200 250 CBBF-250 300 CBBF-300 * 1 Fuse per pack, 10 packs per shelf carton. Amps 30 40 50 60 70 80 100 125 150 200 Trad’l pack* AMI-30 AMI-40 AMI-50 AMI-60 AMI-70 AMI-80 AMI-100 AMI-125 AMI-150B ­AMI-200 * 1 Fuse per pack, 10 packs per shelf carton. HMID Fuse block Use with up to 80 amp AMI fuses. Multiple blocks can be dovetailed together to form an assembly. Removable, splash resistant cover for full access and ease of wiring using 8 AWG to 1/0 wire. Order catalog number HMID.* * 1 Fuse block per pack, 10 packs per shelf carton. Mounting bar with 1⁄4-20 stud, nut and cover for the CBBF battery fuse. Order catalog number CBBF-MBC*. * 1 Bar per pack, 10 packs per shelf carton. For product information and data sheets, visit Eaton.com/BussmannConsumer 11 Fuse holders We offer a complete line of Bussmann series fuse holders to install blade or glass tube fuses. Choose water resistant and/or splash-proof versions for extra protection in special applications. Five available connector types meet the needs of technicians and do-it-yourselfers: •• Wire loop: To install, simply cut the wire, strip ends and attach each end to the circuit. Requires using additional connectors. See catalog numbers HHK, HMJ, HMK, HRI, HRJ and HRK. •• Open wire: To install, simply strip lead ends and attach each end to the circuit. Requires using additional connectors. See catalog numbers ATC-FHID, ATM-FHID, MAX-FHID, HHC, HHD, HHF, HHG, HHL, HHM, HHN, HHR, HHU and HHX. •• Crimp-on: Strip the wire, insert into fuse holder and crimp tightly, and you're done. No additional hardware needed. See catalog numbers HFA, HFB and HHB. •• Self-stripping: To install, simply locate fuse holder at a convenient spot along the wire. Snap fuse holder closed around wire to automatically pierce insulation. See catalog number HHS. •• Solder: To install, simply solder the wire onto the holder’s terminals. See catalog number HKP. •• Quick-connect: Attach fully insulated female terminal onto the 1/4” quick-connect terminals. See catalog numbers HKP-HH, HTB-26I, HTB-38I, HTB-68I and HTB-88I. In-line ATC fuse holders Trad’l pack* Retail pack** Max volts/amps Leadwire HHC BP/HHC-RP 32 V/20 A 2x4”/#16 HHD BP/HHD-RP 32 V/30 A 2x4”/#12 — BP/HHD-30-RP 32 V/30 A 2x4”/#12 HHF BP/HHF-RP 32 V/20 A 2x4”/#16 HHG BP/HHG-RP 32 V/30 A 2x4”/#12 HHR BP/HHR 32 V/30 A 2x5”/#12 — BP/HHS-RP 32 V/20 A #18 to 14 32 V/20 A 2x6”/#16 ATC-FHID BP/ATC-FHID Description Yellow fuse holder Black fuse holder Holder with ATC-30 A fuse Holder with protective cover Heavy-duty holder with cover Heavy-duty water-resistant holder Self-stripping fuse holder Holder with protective cover and open fuse illuminating LED * 1 Fuse holder per pack, 10 packs per shelf carton. ** 1 Fuse holder per pack, 5 packs per shelf carton. HHC HHD HHF HHG Select fuse holders by matching it to the wire size being fused. An undersized fuse holder will increase electrical resistance and reduce performance in the circuit. NOTE: Never install a fuse with a larger amp rating than specified for the application, holder or wire size. In-line ATR and ATM fuse holders Trad’l pack* ATR Retail pack** Max volts/amps Leadwire Description HH2 — 32 V/15 A 2x4”/#16 Holder with cover HHL BP/HHL-RP 32 V/20 A 2x4”/#16 HHM BP/HHM-RP 32 V/30 A 2x4”/#12 HHU BP/HHU 32 V/30 A 2x4”/#12 Holder with cover Holder with cover Waterresistant holder Holder with protective cover and open fuse illuminating LED HHR HHS ATC-FHID ATM ATM-FHID BP/ATM-FHID 32 V/20 A 2x4”/#16 * 1 Fuse holder per pack, 10 packs per shelf carton. ** 1 Fuse holder per pack, 5 packs per shelf carton. HHU Fuses sold separately. In-line MAXI fuse holders Catalog no.* Retail Max volts pack** /amps Lead-wire HHX — 32 V/60 A 2x5”/#6 32 V/60 A 2x5”/#6 MAX-FHID Description Fuse holder with cover Fuse holder with protective cap and open fuse illuminating LED ** 1 Fuse holder per pack, 10 packs per shelf carton. ** 1 Fuse holder per pack, 5 packs per shelf carton. HHL HHM HH2 ATM-FHID HHX Fuses sold separately. Fuses sold separately. 12 For product information and data sheets, visit Eaton.com/BussmannConsumer MAX-FHID Fuse taps and holders ATR, low-profile ATM, ATM and ATC add-a-circuits and fuse taps Retail pack* BP/ATM-TAP-RP BP/ATC-TAP-RP BP/HHTR-RP BP/HHLP-RP BP/HHH-RP BP/HHA-RP Description Taps into existing ATM fuse for additional non-fused circuit, includes crimp-on connector - fuses not included Taps into existing ATC fuse by fitting over the leg for additional non-fused circuit, includes crimp-on connector - fuses not included Adds a 10 A max ATR 2-leg micro fuse circuit by inserting into an existing ATR fuse block with 5 inch #16 leadwire and crimp connector - fuses not included Adds a 10 A max low-profile ATM fuse circuit by inserting into an existing ATM fuse block with 5 inch #16 leadwire and crimp connector - fuses not included Adds a 10 A max ATM fuse circuit by inserting into an existing ATM fuse block with 5 inch #16 leadwire and crimp connector - fuses not included Adds a 10 A max ATC fuse circuit by inserting into an existing ATC fuse block with 5 inch #16 leadwire and crimp connector - fuses not included * 1 Part per pack, 5 packs per shelf carton.a BP/ATC-TAP-RP BP/ATM-TAP-RP For ATM fuse For ATC fuse BP/HHTR-RP BP/HHLP-RP BP/HHH-RP BP/HHA-RP For ATR 2-leg micro fuse For low-profile ATM fuse For ATM fuse For ATC fuse Fuses sold separately. Glass tube in-line holders for 1/4" diameter fuses Trad’l pack* HFA HFB-R HHB HHK HHN† HLR Retail pack** — BP/HFB-RP BP/HHB-RP BP/HHK-RP BP/HHN-RP — Fuse/size 1/4” x 1-1/4” 1/4” x 1-1/4” 1/4” x 7/8” to 1-1/4” 1/4” x 5/8” to 1-1/4” and SFE-20 1/4” x 1-1/4” For GMF fuse, see page 38 Max volts/amps 250 V/20 A 32 V/30 A 32 V/30 A 32 V/20 A 32 V/30 A 300 V/15 A HMJ BP/HMJ-RP For SFE-20 (included) 32 V/20 A HMK HRH BP/HMK-RP — 1/4” x 1-1/4” and SFE-20 For SFE-9 (included) 32 V/30 A 32 V/9 A HRI — For SFE-14 (included) 32 V/14 A HRJ — For SFE-20 (included) 32 V/20 A Leads/terminals Crimp #12 to 16 wire Crimp #12 to 18 wire Crimp #12 to 16 wire #14 leadwire/yellow #12 leadwire/yellow 6" of #18 leadwire/red 8" of #14 leadwire/ black #12 leadwire/black 19" of #14 leadwire 19" of #14 leadwire/ black 19" of #14 leadwire/ black HRK BP/HRK-RP 1/4” dia. x 7/8” to 1-1/4” 32 V/20 A #14 leadwire/black Description/feature Water-resistant - black body Water-resistant - yellow body Universal - yellow body Universal nylon, twist lock, no fuse - black body Nylon heavy-duty with AGC-30 fuse - white body Holder with installed lineside terminal wire for GMF fuses With fuse and wire loop leads - black body No fuse, wire loop leads - black body With fuse and wire loop leads - black body With fuse and wire loop leads - gray body With fuse and wire loop leads - black body Universal with wire loop leads and springs for different fuse lengths - black body * 1 Fuse holder per pack, 10 packs per shelf carton. ** 1 Fuse holder per pack, 5 packs per shelf carton. † Traditional pack not sold with AGC-30 fuse. HFA HFB HHB HHK HHN HMK HRJ HLR HMJ Max. panel thickness Knob type Terminals Max volts/amps 0.3” Knob Solder terminals 250 V/30 A 0.3" Knob 1/4” quick-connect terminals 250 V/15 A 0.3" Knob 250 V/20 A 0.3" Screwdriver/ Slotted 0.3" Knob 0.125" Knob In-line 1/4” quick-connect terminals Right angle 1/4” quick-connect terminals Right angle 1/4” quick-connect terminals Right angle 1/4” quick-connect terminals HRI HRK Panel-mount holders for 1/4" x 1-1/4" fuses Trad’l pack* Retail pack** HKP — HKP-HH BP/HKP-HH-RP HTB-26I — HTB-38I — HTB-68I — HTB-88I — Description/mounting High-profile cover knob, rear hexnut High-profile cover knob, rear hexnut Low-profile cover knob, rear hexnut Low-profile cover knob, rear hexnut Low-profile cover knob, front hexnut Low-profile cover knob, through-hole snap * 1 Fuse holder per pack, 10 packs per shelf carton. ** 1 Fuse holder per pack, 5 packs per shelf carton. HKP HKP-HH HTB-26I HTB-38I For product information and data sheets, visit Eaton.com/BussmannConsumer HTB-68I 250 V/20 A 250 V/20 A 250 V/20 A HTB-88I 13 Fuse panels and blocks 15600 fuse panels Splash-proof ATR, ATM and ATC fuse blocks The Bussmann series FB fuse blocks are available in 4-, 6-, 8and 10-pole versions for ATR micro, ATM and ATC fuses. The clear plastic cover allows viewing for installed fuse amp ratings and blown fuses when used with easyID™ ATM and ATC fuses. The cover's O-ring provides a splash-proof IPX4 rating and ensures a positive fit to reduce infiltration of dirt and other contaminants. The plastic back plate provides additional isolation from ground sources when mounted on any chassis surface. All blocks are rated 32 V and 20 amps per pole, with maximum total amps per block not to exceed the value shown in the catalog number table. Mounting requires two customer-supplied #10 screws. Electrical connection is easily made with readily available, customer supplied 1/4" quick-connect terminals and 12 to 16 AWG* wire. *Wire size dependent on length of run. Fuse type ATR micro ATM mini ATC Poles 4 6 8 10 4 6 8 10 4 6 8 10 Retail pack* BP/FB4-ATR BP/FB6-ATR BP/FB8-ATR BP/FB10-ATR BP/FB4-ATM BP/FB6-ATM BP/FB8-ATM BP/FB10-ATM BP/FB4-ATC BP/FB6-ATC BP/FB8-ATC BP/FB10-ATC Max. total amps per block 30 45 60 90 30 45 60 90 30 45 60 90 A single, common power input makes it simple to wire multiple fused circuits - each rated to 20 amps (95 amps max per panel), up to 32 volts. Molded of high grade thermoplastic, for superior performance, the 15600 fuse panel features 1⁄4” quick-connect terminals for easy installation. Short base shown. Recessed fuse contacts Fuses and circuit breakers provide finger-safe sold separately. protection. Available in short base (without ground pad terminal strip) and long base (includes ground pad terminal strip that provides 1⁄4” quick connect terminals for separate ground lead connection). Note: The 15600 ATC fuse panels are not intended for installation under the hood or in an environment that would expose them to water or extreme temperatures. Fuse positions 4 6 8 10 12 14 16 18 20 Short base catalog no.* 15600-04-20 15600-06-20 15600-08-20 15600-10-20 15600-12-20 15600-14-20 15600-16-20 15600-18-20 15600-20-20 Short base retail pack** — BP/15600-06-20 — — — — — — — Long base catalog no. 15600-04-21 15600-06-21 15600-08-21 15600-10-21 15600-12-21 15600-14-21 15600-16-21 15600-18-21 15600-20-21 * 1 Per pack. ** 1 Per pack, 5 boxes per shelf carton. Power distribution relay module and fuse block * 1 Per pack, 5 packs per shelf carton. The sealed power FMX fuse module (CBPFM) and power relay module (CBPRM) are compact power distribution modules for high current applications having extreme moisture and high vibration. RTMF ATM fuse panel The CBPFM power fuse module has two FMX fuse positions for separate circuits. The Rear Terminal 20 Position (RTMF) fuse panel for ATM fuses provides efficient power distribution in a rugged compact package.The RTMF offers a weather-tight enclosure (IP66/67) for ATM fuses and circuit breakers when cover, cable seals, and cavity plugs are installed.* * Electrical terminals, cable seals and cavity plugs are either Delphi Packard Metri-Pack® 280 Series terminals (sealed/tangless) or AMP® terminals. They accept #12-22 AWG wire sizes. Delphi Packard 280 Series cavity plugs are installed where wires are not used. Seals and cavity plugs not sold by Eaton. Shown with deep cover. Fuses and circuit breakers sold separately. Catalog no.* RTMF RTMF-SC RTMF-DC Description 20 position fuse block 20 position fuse block with shallow cover 20 position fuse block with deep cover The 24 volt CBPRM power relay module contains a 35 amp relay and two FMX fuse positions (one protects the relay and the other a single-circuit in-line fuse). Both the CBPRM and CBPFM feature rugged M8 power input studs, and an IP66 removable, weather-tight cover to protect the fuse positions. Electrical terminations not supplied by Eaton, FMX fuses sold separately. Catalog no.* CBPFM CBPRM Description Power fuse module Power relay module * 1 Per box. * 1 Per box, 10 boxes per shelf carton. 14 CBPFM Power fuse module For product information and data sheets, visit Eaton.com/BussmannConsumer CBPRM Power relay module Fusible link wire and limiters Bussmann series S-8202 300 volt, 20 amp glass tube fuse blocks ANN and ANL current limiters S-8202 blocks with 1/4” quick-connect 40° bend terminals are available in 1 up to 12 poles. Break-away design permits snapping off or combining poles to get the exact number required for the application. UL Recognized, 20 amps maximum. Used to protect charging systems in battery-operated vehicles like forklifts and golf carts, the ANN and ANL limiters offer high amp ratings in a compact 7/8" x 3-3/16" size. Fuse block poles 1 2 3 4 5 10 12 Trad’l pack* S-8202-1 S-8202-2 S-8202-3 S-8202-4 S-8202-5 S-8202-10 S-8202-12 Retail pack** — BP/S-8202-2-RP — BP/S-8202-4-RP — — — Durable glass-laminated melamine body and riveted construction provides a rugged package and clear window provides visual indication. Both the ANN and ANL limiters use the SFR fuse block. ANN Very fast-acting limiters * 1 Per pack, 10 packs per shelf carton. ** 1 Per pack, 5 packs per shelf carton. Bussmann series S-8301 300 volt, 30 amp glass tube fuse blocks S-8301 blocks with screw connect terminals are available in 1 Trad'l/pack catalog no. ANN-10 ANN-125 ANN-325 ANN-35 ANN-150 ANN-350 ANN-40 ANN-175 ANN-400 ANN-50 ANN-200 ANN-500 ANN-60 ANN-225 ANN-600 ANN-80 ANN-250 ANN-700 ANN-90 ANN-275 ANN-800 ANN-100 ANN-300 — * 1 Limiter per pack, 5 packs per shelf carton. *up 1 Per box.poles. Break-away design permits snapping off or to 12 combining poles to get the exact number required for the application. UL Recognized, 30 amps maximum. Fuse block poles 1 2 3 4 5 6 8 12 Trad’l pack* S-8301-1 S-8301-2 S-8301-3 S-8301-4 S-8301-5 S-8301-6 S-8301-8 S-8301-12 ANL Non time-delay limiters * 1 Per pack, 10 packs per shelf carton. Trad'l/pack catalog no. ANL-35 ANL-150 ANL-350 ANL-40 ANL-175 ANL-400 ANL-50 ANL-200 ANL-500 ANL-60 ANL-225 ANL-600 ANL-80 ANL-250 ANL-675 ANL-100 ANL-275 ANL-750 ANL-125 ANL-300 — ANL-130 ANL-325 — * 1 Limiter per pack, 5 packs per shelf carton. Fusible link wire The BP/FL-14 and BP/FL-16 fusible link wire kits include 14 Vdc wire with printed wire gauge label. BP/FLW-14 is a six-foot coil of bulk fusible link wire. SFR Block for ANL and ANN limiters Retail pack* BP/FL-14 BP/FL-16 BP/FLW-14 Open stud fuse block handles up to 800 amps. Available only without cover. Description 9 inches of 14 gauge fusible link wire with 3/8” and 5/16” terminals and crimp connector 9 inches of 16 gauge fusible link wire with 1/4” and 5/16” terminals and crimp connector 6 foot coil of 14 gauge fusible link wire Order catalog number SFR.* * 1 Block per pack, 100 packs per master carton. * 1 Fusible link per pack, 5 packs per shelf carton. For product information and data sheets, visit Eaton.com/BussmannConsumer 15 Automotive circuit breakers We offer a large selection of Bussmann series automotive circuit breakers including both OEM-style and fuse-replacement devices. High amp circuit breakers High amp circuit breakers are available for automotive and marine applications in Type I and Type III reset modes. Typically used in auxiliary and accessory circuits for trucks, busses, RVs and boats, they are available in weatherproof/waterproof panel and flush mount versions. They can also be used in battery charging systems that use battery isolators to manage and protect batteries in multi-battery installations. ATM footprint circuit breakers Type I, Type II and Type III circuit breakers match the ATM fuse footprint. Ultra-thin, to fit in tight spaces, they're the smallest automotive circuit breakers on the market and comply with SAE standard J553. CB211 Type I ATM circuit breaker Type I - automatic reset Type I circuit breakers automatically reset after opening. If the fault or overcurrent condition still exists, the breaker will continue to cycle between ON and OFF positions until the overcurrent problem is corrected. These devices are sometimes called "cycling breakers." Type I/Automatic Reset circuit breakers do not address, or correct, overcurrent or fault conditions. They only react by cycling OFF and ON. Any overcurrent or fault condition that causes a Type I circuit breaker to operate should be corrected as soon as possible. Continued vehicle operation with an overcurrent or fault condition (causing the Type I circuit breaker to cycle) is NOT recommended. CB212 Amps 7-1/2 10 15 20 25 30 Trad’l pack* CB211-7-1/2 CB211-10 CB211-15 CB211-20 CB211-25 CB211-30 * 1 Circuit breaker per pack, 10 packs per shelf carton. ** 1 Circuit breaker per pack, 5 packs per shelf carton. Amps 10 15 20 25 30 Type II ATM circuit breaker Type II - modified reset Type II circuit breakers will remain “tripped” by an internal resistor (in the OFF position) as long as the circuit is powered. Type II breakers can be reset by turning the circuit OFF, or by turning the ignition switch to the OFF position. These devices are sometimes called "non-cycling breakers." Type III - manual reset CB233 Type III ATM circuit breaker Color code Tan Brown Red Blue Yellow White Green Trad’l pack* CB233-05 CB233-71/2 CB233-10 CB233-15 CB233-20 CB233-25 CB233-30 Amps 5 7-1/2 10 15 20 25 30 * 1 Circuit breaker per pack, 10 packs per shelf carton. Mini devices Transorb, resistor and diode electrical protection devices easily install in common ATM fuse holders and blocks. These circuit protection devices provide voltage and current limiting functionality and are designed for the on- and off-highway requirements of trucks, RVs, construction, agriculture, ATV and material handling equipment. CB222OS Trad’l pack* CB222OS-05 CB222OS-10 CB222OS-15 CB222OS-20 CB222OS-25 CB222OS-30 Amps 05 10 15 20 25 30 Type II ATM circuit breaker with offset terminals • Transorb - Protects against voltage spikes. * 1 Circuit breaker per pack, 10 packs per shelf carton. Clamp rating: 27 Vdc Power rating: 1500 W • Resistor - Drops circuit voltage. CB223OS Power rating: 5 W Resistance: 68 Ω • Diode - Prevents reverse current flow. Amps 05 7-1/2 10 15 20 25 30 Type III ATM circuit breaker with offset terminals Amp rating: 6 A Description Transorb voltage spike protector Resistor voltage drop device Diode reverse current protector Diode reverse current protector with wing key * 1 Circuit breaker per pack, 10 packs per shelf carton. 16 Trad’l pack* CB212-10 CB212-15 CB212-20 CB212-25 CB212-30 * 1 Circuit breaker per pack, 10 packs per shelf carton. Type III circuit breakers will remain tripped (in the OFF position) until an indicator button or lever is manually reset. Some Type III breakers are available with a switch feature that allows the use of an external button to de-energize the circuit. Trad’l pack* CB22901-1.5 CB22902-68 CB22903-6 CB22903-6V Retail pack** — BP/CB211-10-RP BP/CB211-15-RP BP/CB211-20-RP BP/CB211-25-RP BP/CB211-30-RP Trad’l pack* CB223OS-05 CB223OS-7-1/2 CB223OS-10 CB223OS-15 CB223OS-20 CB223OS-25 CB223OS-30 * 1 Circuit breaker per pack, 10 packs per shelf carton. MMB Type I, wide ATM footprint circuit breaker for GM vehicles For product information and data sheets, visit Eaton.com/BussmannConsumer Amps 15 20 Trad’l pack* MMB-15 MMB-20 OEM part no. 12135171 12135072 * 1 Circuit breaker per pack, 10 packs per shelf carton. Automotive circuit breakers ATC footprint circuit breakers CB227 Type I, Type II and Type III circuit breakers match the ATC fuse footprint. They are the thinnest available in the aftermarket and comply with SAE standard J553. Type III ATC low-profile circuit breakers Color code Tan Moss Green Brown Red Blue Yellow White Green CB227 complies with SAE J553 and SAE J1171 for ignition protection. We also offer the Bussmann series ACB-20, CCB-25, and FCB-20 breakers as replacements for specific OEM applications. ACB-20 Type I ATC circuit breaker for GM vehicles Amps 20 Trad’l pack* ACB-20 OEM no. 12040816 * 1 Circuit breaker per pack, 10 packs per shelf carton. Amps 5 6 7-1/2 10 15 20 25 30 Trad’l pack* CB227-05 CB227-06 CB227-7-1/2 CB227-10 CB227-15 CB227-20 CB227-25 CB227-30 * 1 Circuit breaker per pack, 10 packs per shelf carton. CBB-30 Type II ATC circuit breaker Amps 30 Trad’l pack* CBB-30 Retail pack** BP/CBB-30-RP * 1 Circuit breaker per pack, 10 packs per shelf carton. CB221 Type I ATC circuit breakers Amps 7-1/2 10 15 20 25 30 Trad’l pack* CB221-7-1/2 CB221-10 CB221-15 CB221-20 CB221-25 CB221-30 CCB-25 Amps CCB-25 Type I ATC circuit breaker for Chrysler vehicles Trad’l pack* CCB-25 OEM no. 4527053 * 1 Circuit breaker per pack, 10 packs per shelf carton. * 1 Circuit breaker per pack, 10 packs per shelf carton. CB222 Type II ATC circuit breakers Amps 10 15 20 25 30 Trad’l pack* CB222-10 CB222-15 CB222-20 CB222-25 CB222-30 FCB-20 Trad’l Retail Amps pack* pack OEM no. Type II ATC 20 FCB-20 BP/FCB-20 D9AB-14526-BA circuit breaker for Ford vehicles * 1 Fuse per pack, 10 packs per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. * 1 Circuit breaker per pack, 10 packs per shelf carton. CB223 Type III ATC circuit breakers Amps 7-1/2 10 15 20 25 30 Trad’l pack* CB223-7-1/2 CB223-10 CB223-15 CB223-20 CB223-25 CB223-30 UCB Type I ATC circuit breakers UCB breakers feature "snap-off" universal blades to fit tight fuse block spacing or recessed fuse terminals. * 1 Circuit breaker per pack, 10 packs per shelf carton. Color code Plain Brown Red Blue Yellow Plain Green Amps 6 8 10 15 20 25 30 Trad’l pack* UCB-6 UCB-8 UCB-10 UCB-15 UCB-20 UCB-25 UCB-30 Retail pack** — — BP/UCB-10-RP BP/UCB-15-RP BP/UCB-20-RP BP/UCB-25-RP BP/UCB-30-RP Bulk pack*** — — BK/UCB-10 BK/UCB-15 BK/UCB-20 — BK/UCB-30 * 1 Circuit breaker per pack, 10 packs per shelf carton. ** 1 Circuit breaker per pack, 5 packs per shelf carton. *** 100 Circuit breakers per pack. For product information and data sheets, visit Eaton.com/BussmannConsumer 17 Automotive circuit breakers MAXI footprint circuit breakers Heavy-duty circuit breakers Bussmann series MAXI circuit breakers are the first breakers on the market to match the MAXI fuse footprint and body dimensions. Ideal for many heavy-duty and truck applications, Bussmann series stud-terminal and quick-connect circuit breakers are available with and without a mounting bracket and comply with SAE standard J553. CB1911 Type I MAXI circuit breakers Amps 10 15 20 25 30 35 40 50 Traditional pack* CB1911-10 CB1911-15 CB1911-20 CB1911-25 CB1911-30 CB1911-35 CB1911-40 CB1911-50 CB123-B Type III 10-32 stud-terminal circuit breakers with crosswise bracket Amps 10 15 20 25 30 Traditional pack* CB1921-10 CB1921-15 CB1921-20 CB1921-25 CB1921-30 Traditional pack* CB123-10B CB123-15B CB123-20B CB123-30B CB123-40B CB123-50B * 1 Circuit breaker per pack, 10 packs per shelf carton. * 1 Circuit breaker per pack, 10 packs per shelf carton. CB1921 Type II MAXI circuit breakers Amps 10 15 20 30 40 50 CB123-HB Type III 10-32 stud-terminal circuit breakers with lengthwise bracket * 1 Circuit breaker per pack, 10 packs per shelf carton. Amps 10 15 20 30 40 50 Traditional pack* CB123-10HB CB123-15HB CB123-20HB CB123-30HB CB123-40HB CB123-50HB * 1 Circuit breaker per pack, 10 packs per shelf carton. Glass tube footprint breakers CBF Type II circuit breakers for glass tube fuse blocks CBF circuit breakers can be used to replace glass fuses in blocks for 1/4” x 1-1/4” fuses. Trad’l Retail Amps pack* pack** 10 CBF-10 — 15 CBF-15 — 20 CBF-20 BP/CBF-20-RP 25 CBF-25 — 30 CBF-30 BP/CBF-30-RP 35 CBF-35 — 40 CBF-40 — * 1 Circuit breaker per pack, 10 packs per CBC Type I 10-32 stud-terminal circuit breakers shelf carton. ** 1 Circuit breaker per pack, 5 packs per shelf carton. Amps 8 10 15 20 25 30 35 40 50 Traditional pack* CBC-8 CBC-10 CBC-15 CBC-20 CBC-25 CBC-30 CBC-35 CBC-40 CBC-50 * 1 Circuit breaker per pack, 10 packs per shelf carton. CBC-B Type I 10-32 stud-terminal circuit breakers with crosswise bracket Amps 8 10 15 20 25 30 35 40 50 Trad’l pack* CBC-8B CBC-10B CBC-15B CBC-20B CBC-25B CBC-30B CBC-35B CBC-40B CBC-50B Retail pack** — — — BP/CBC-20B-RP — BP/CBC-30B-RP — BP/CBC-40B-RP BP/CBC-50B-RP * 1 Circuit breaker per pack,10 packs per shelf carton. ** 1 Circuit breaker per pack, 5 packs per shelf carton. 18 For product information and data sheets, visit Eaton.com/BussmannConsumer Automotive circuit breakers and splash prrof covers CBC-BWP Type I 10-32 stud-terminal weatherproof circuit breakers with crosswise bracket Traditional pack* CBC-20BWP CBC-30BWP Amps 20 30 * 1 Circuit breaker per pack, 10 packs per shelf carton. Quick-connect circuit breakers For use in trucks, RVs, boats, buses, etc. featuring 1/4" quick-connect terminals for easy installation. CB174 Type III panel-mount circuit breakers with 1/4" quick-connect terminals CBC-HB Amps 10 15 20 25 30 40 50 Type I 10-32 stud-terminal circuit breakers with lengthwise bracket Traditional pack* CBC-10HB CBC-15HB CBC-20HB CBC-25HB CBC-30HB CBC-40HB CBC-50HB Retail pack** — — BP/CBC-20HB-RP — BP/CBC-30HB-RP BP/CBC-40HB-RP BP/CBC-50HB-RP * 1 Circuit breaker per pack, 10 packs per shelf carton. ** 1 Circuit breaker per pack, 5 packs per shelf carton. Amps 10 15 20 30 Traditional pack* CB174-10 CB174-15 CB174-20 CB174-30 * 1 Circuit breaker per pack, 10 packs per shelf carton. CBT-M Type II circuit breakers for Mack® trucks with 1/4" blades on 1" centers Amps 15 20 25 30 Traditional pack* CBT-15M CBT-20M CBT-25M CBT-30M * 1 Circuit breaker per pack, 10 packs per shelf carton. CBP-BA Type I 10-32 stud-terminal circuit breakers with crosswise bracket Amps 20 25 30 40 50 Traditional pack* CBP-20BA CBP-25BA CBP-30BA CBP-40BA CBP-50BA Retail pack** — — BP/CBP-30BA-RP — BP/CBP-50BA-RP * 1 Circuit breaker per pack, 10 packs per shelf carton. ** 1 Circuit breaker per pack, 5 packs per shelf carton. CBT-N Type II circuit breakers for Navistar trucks with 1/4" blades on 1.08" centers ® Amps 20 25 30 Traditional pack* CBT-20N CBT-25N CBT-30N * 1 Circuit breaker per pack, 10 packs per shelf carton. Splash proof covers Catalog no. Description Cover for stud terminal CB-CVR circuit breaker Cover for stud terminal BK/CB-CVR circuit breaker-BULK with coverBP/CB20HB-CVR* CB123-20HB retail pack with coverBP/CB40HB-CVR* CB123-40HB retail pack Pack qty. 1 — Shelf qty. Master qty. 10 300 100 2000 1 5 120 1 5 120 CBU Type I circuit breaker with 1/4" quick-connect terminals on 0.99" centers with crosswise bracket Amps 30 Traditional pack* CBU-30B * 1 Circuit breaker per pack, 10 packs per shelf carton. * Packed with CB123-20HB and CB123-40HB. For product information and data sheets, visit Eaton.com/BussmannConsumer 19 Automotive circuit breakers High amp circuit breakers High amp circuit breakers are typically used in auxiliary and accessory circuits for trucks, buses, RVs and marine applications. CB181F Amps Type I waterproof, flush-mount circuit breakers with SEMS nuts installed, 30 Vdc Catalog no.* 60 CB181F-60 70 CB181F-70 80 CB181F-80 90 CB181F-90 100 CB181F-100 110 CB181F-110 120 CB181F-120 135 CB181F-135 150 CB181F-150 * 1 Circuit breaker per box, 20 boxes per master carton. CB184F Amps 25 30 35 40 50 60 70 80 90 100 110 120 135 150 Type III waterproof, flush-mount, manual reset circuit breakers with SEMS nuts installed, 48 Vdc Catalog no.* CB184F-25 CB184F-30 CB184F-35 CB184F-40 CB184F-50 CB184F-60 CB184F-70 CB184F-80 CB184F-90 CB184F-100 CB184F-110 CB184F-120 CB184F-135 CB184F-150 All high amp circuit breakers comply with the SAE J1171 standard for ignition protection and have applications in battery charging systems that use battery isolators to manage and protect batteries in multi-battery installations. Offered in flush-mount or panel-mount. CB185P Type III switchable, panel-mount, manual reset circuit breakers with SEMS nuts installed, 48 Vdc Amps Type III switchable, waterproof, 25 flush-mount manual reset circuit 30 breakers with 1⁄4-28 threaded 35 stud terminals with SEMS nuts 40 installed, and black reset lever, 50 48 Vdc 60 70 80 90 100 110 120 135 150 Catalog no.* CB185-25 CB185-30 CB185-35 CB185-40 CB185-50 CB185-60 CB185-70 CB185-80 CB185-90 CB185-100 CB185-110 CB185-120 CB185-135 CB185-150 Retail pack** — — — — BP/CB185-50 — BP/CB185-70 BP/CB185-80 — BP/CB185-100 — BP/CB185-120 BP/CB185-135 BP/CB185-150 CB285F Type III switchable, waterproof, flush-mount manual reset circuit breakers with M6 threaded stud terminals with stainless steel nuts and washers installed, and yellow reset lever, 42 Vdc Amps 30 40 50 60 70 80 90 100 120 150 Catalog no.* CB285F-30 CB285F-40 CB285F-50 CB285F-60 CB285F-70 CB285F-80 CB285F-90 CB285F-100 CB285F-120 CB285F-150 * 1 Circuit breaker per box, 20 boxes per master carton. Stock OEM fuses for Nissan, Infiniti, Toyota and Lexus vehicles New Bussmann™ series multi-pole fuses (MPF) * 1 Circuit breaker per box, 20 boxes per master carton. ** 1 Circuit breaker per pack, 4 packs per shelf carton. See page 31 for marine-rated circuit breakers. See page 9. 20 Catalog no.* CB185P-25 CB185P-30 CB185P-35 CB185P-40 CB185P-50 CB185P-60 CB185P-70 CB185P-80 CB185P-90 CB185P-100 CB185P-110 CB185P-120 CB185P-135 CB185P-150 * 1 Circuit breaker per box, 20 boxes per master carton. * 1 Circuit breaker per box, 20 boxes per master carton. CB185 Amps 25 30 35 40 50 60 70 80 90 100 110 120 135 150 For product information and data sheets, visit Eaton.com/BussmannConsumer Junction blocks, terminal blocks and terminal strips Junction blocks Stud junction terminal strips BP/C5237 Stud junction blocks are designed for trucks, RVs and wiring accessories. Available in 3, 6 and 8 terminal configurations, they are rated for applications to 30 A, 300 V (UL)/ 600 V (CSA). JB3816-2 Non-feed through stud-type junction block 3/8-16 thread/stud size, 250 amps max. NOTE: Voltage rating dependent upon installation. Poles Trad’l pack* Retail pack** 1 JB3816-2 BP/JB3816-2 1 JB3816-3 — BP/JB3816-2 Description/color Stud junction block black Stud junction block - red Stud thread 3/8-16 Poles 3 6 8 Retail pack* BP/C5237-3BC BP/C5237-6BC BP/C5237-8BC Stud 10-32 10-32 10-32 Volts/amps 300 V/30 A 300 V/30 A 300 V/30 A * 1 Terminal strip per pack, 5 packs per shelf carton. 3/8-16 * 1 Junction block per pack, 50 per master pack. ** 1 Junction block per pack, 5 packs per shelf carton. C5237-3BC Bussmann series double row barrier terminal blocks TB200 and TB300 double row barrier terminal blocks are nickel-plated brass with black thermoplastic construction. Poles 4 6 8 10 15 4 6 8 10 12 20 Trad'l pack* TB200-04B TB200-06B TB200-08B TB200-10B TB200-15B TB300-04B TB300-06B TB300-08B TB300-10B TB300-12B TB300-20B Terminal screw 6-32 6-32 6-32 6-32 6-32 8-32 8-32 8-32 8-32 8-32 8-32 Retail pack** BP/TB200-04-RP — — — — — — — — — — C5237-6BC Volts/amps 300 V/20 A 300 V/20 A 300 V/20 A 300 V/20 A 300 V/20 A 600 V/30 A 600 V/30 A 600 V/30 A 600 V/30 A 600 V/30 A 600 V/30 A * 1 Junction block per pack, 50 per master pack. ** 1 Junction block per pack, 5 packs per shelf carton. TB200-_B C5237-8BC Coming 2017 More OEM products for the automotive aftermarket Bussmann series multi slow-blow (MSB) fuses TB300-_B Meeting complex automotive circuit needs in Honda and Ford vehicles. OEM parts now available to aftermarket Bussmann™ series battery terminal fuses (BTF) See page 11. For product information and data sheets, visit Eaton.com/BussmannConsumer 21 Switches Toggle and rocker switches Metal housing toggle switches with screw terminals We offer a line of Bussmann series single pole toggle switches, rocker switches and duck-bill toggle switches, in a variety of styles, colors and finishes for replacement applications or custom installations. Retail pack* BP/SDN BP/STF BP/STT Function ON/OFF ON/OFF/ON ON/OFF Retail pack* BP/STE BP/STJ BP/STK Function ON/OFF ON/OFF ON/OFF/ON Rating 12 V/15 A 12 V/25 A 12 V/15 A Feature — — — *1 Switch per pack, 5 packs per shelf carton. Toggle switches with quick connect terminals Color Black Black Chrome Color Chrome Chrome Chrome Rating 12 V/20 A 12 V/20 A 12 V/20 A Feature — — Red LED *1 Switch per pack, 5 packs per shelf carton. BP/STE BP/STJ BP/STK Rocker switches with quick connect terminals BP/SDN BP/STT BP/STF Illuminated toggle switches with quick connect terminals Color Amber Blue Green Red Color Amber Blue Green Black Red Retail pack* BP/SRA BP/SRB BP/SRG BP/SRN BP/SRR Function ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF Rating 12 V/16 A 12 V/16 A 12 V/16 A 12 V/16 A 12 V/16 A Feature Illuminated Illuminated Illuminated — Illuminated *1 Switch per pack, 5 packs per shelf carton. Retail pack* BP/STA BP/STB BP/STG BP/STR Function ON/OFF ON/OFF ON/OFF ON/OFF Rating 12 V/20 A 12 V/20 A 12 V/20 A 12 V/20 A Feature — — — — *1 Switch per pack, 5 packs per shelf carton. BP/SRA BP/SRB BP/SRG BP/SRN BP/SRR Battery disconnect switches BMS-1 Top post anti-theft battery switch. Complete with HHM fuse holder, ATM-20 fuse, ring terminals and stainless steel bolt and wing nut. BP/STA BP/STG BP/STB BP/STR Duckbill toggle switches with quick connect terminals Color Amber Chrome Retail pack* BP/SDA BP/STC Function ON/OFF ON/OFF *1 Switch per pack, 5 packs per shelf carton. Rating 12 V/20 A 12 V/20 A Feature Illuminated — BMS-2 Side post anti-theft battery switch for GM vehicles. Complete with HHM fuse holder, ATM-20 fuse and ring terminals. 15968-1 Heavy-duty switch is designed to open the circuit between the battery and load of a battery powered system typically in large truck applications. Rated at 50 Vac/dc maximum, 400 A continuous, it can withstand cranking or surge currents up to 2000 A for 5 seconds maximum. Catalog no. BP/BMS-1* BP/SDA BP/STC BP/BMS-2* 15968-1** Description Top post anti-theft master switch with HHM fuse holder, ATM-20 fuse, ring terminals and stainless steel bolt and wing nut Side post anti-theft master switch with HHM fuse holder, ATM-20 fuse and ring terminals Heavy-duty disconnect; 50 Vac/dc, 400 A maximum * 1 Battery switch per pack, 5 packs per shelf carton. ** Non-stock part 22 For product information and data sheets, visit Eaton.com/BussmannConsumer Automotive flashers and lighting control modules We offer a complete line of Bussmann series flashers that meet SAE standards for a variety of vehicles. To select the proper replacement flasher, match these three specifications: •• Specific versus variable load. Specific load flashers flash only a certain number of lamps. Variable load flashers handle a range of amps, such as when pulling a trailer. •• Lamp capacity. Designates the total number of lamps in the circuit for the left or right directional signal. •• Number of terminals. Select the number of blades to match the socket in the panel. Thermal flashers NO.535 NO.550 NO.552 NO.575 NO.577 Extra Loud Heavy-duty electronic flashers Thermal and electronic 12 and 24 Vdc flashers Trad’l pack* Retail pack** Flasher type No. of terminals Volts NO.535 — Thermal 3 NO.550 BP/550-RP Thermal 3 NO.552 BP/552-RP Thermal 2 NO.575 BP/575-RP Thermal 2 NO.577 BP/577-RP Therm./ex. loud 2 NO.243 — H-D electronic 2 NO.244 — H-D electronic 3 NO.246 — H-D electronic 3 NO.726 BP/726-RP H-D electronic 4 NO.727 BP/727-RP H-D electronic 5 NO.756 BP/756-RP H-D electronic 3 NO.757 BP/757-RP H-D electronic 3 NO.758 BP/758-RP H-D electronic 3 NO.759 BP/759-RP H-D electronic 3 NO.760 BP/760-RP H-D electronic 3 NO.761 BP/761-RP H-D electronic 3 NO.762 BP/762-RP H-D electronic 4 NO.763 — H-D electronic 2 NO.764 — H-D electronic 2 NO.850 — H-D electronic 3 NO.852 — H-D electronic 2 NO.232 BP/232-RP S-D electronic 2 NO.233 BP/233-RP S-D electronic 3 NO.234 BP/234-RP S-D electronic 3 * 1 Flasher per pack, 10 packs per shelf carton. ** 1 Flasher per pack, 5 packs per shelf carton. 6 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 Amps 5.2 12.8 12.8 12.8 14 25 25 25 12.6 12.6 12.6 12.6 12.6 12.6 12.6 12.6 12.6 12 12 25 35 20 20 20 Number of bulbs 2-6 2-6 2-6 1-8 2-6 12 12 Alternating 2-4 2-4 2-6 2-6 2-6 3-6 2-6 2-6 3-6 16 20 10HZ/5TS 16HZ/8TS 1-10 1-10 1-10 LED flashers NO.243 NO.244 NO.246 NO.726 NO.727 NO.756, 757, 758, 759, 760 Trad’l pack* NO-727-LED NO-758-LED NO-759-LED NO-760-LED NO-762-LED No. of terminals 5 3 3 3 3 Volts 12.8 12.8 12.8 12.8 12.8 Amps 12.6 12.6 12.6 12.6 12.6 Number of LED lamps 2-6 2-6 3-6 2-4 2-6 * 1 Flasher per pack, 10 packs per shelf carton. NO.761 NO.762 NO.763 and 764 NO.850 Super heavy-duty electronic flashers NO.232 NO.233 NO.234 NO.852 Lighting control modules (LCM) Trad’l pack* No. of terminals Volts Amps NO-455 10 12.8 2.1 NO-468 9 12.8 2.1 NO-470 5 12.8 2.1 NO-487 8 12.8 2.1 Rated load range 1 to 6 SAE #1156 lamps 1 to 6 SAE #1156 lamps Fixed 2 for lamps 4 for hazards 1 to 6 SAE #1156 lamps Rated voltage 11 to 15 Vdc 11 to 15 Vdc 11 to 15 Vdc 11 to 15 Vdc * 1 LCM per pack, 10 packs per shelf carton. LED flashers Lighting control modules (LCM) NO-727-LED NO-750-LED NO-760-LED NO-762-LED NO-758-LED NO-455 NO-468 NO-470 NO-487 For product information and data sheets, visit Eaton.com/BussmannConsumer 23 Retail packaging and assortments Automotive assortments, emergency and diagnostic kits Automotive glass tube assortments Covering in-demand applications, fuse offerings include traditional glass tube and German automotive fuses, a wide selection of micro fuses, ATM, low-profile ATM, ATC and MAX in indicating and non-indicating versions, and higher amp cartridge fuses. Fuse assortments provide customers a handy selection of fuses and fuse ratings for general replacement applications. Emergency kits provide a range of fuses and fuse ratings, plus a fuse puller to make quick, emergency replacements easier. Diagnostic kits provide the advantage of a fuse tester/puller along with an assortment of fuses and fuse ratings. The tester permits users to quickly determine whether a fuse is good or not. Bonus packs increase the "basket ring" on your fuse assortment sales with large-count fuse packages that are great for small shops, do-it-yourself mechanics - or for stocking commercial / service vehicles. Example: BP/AGW-A8-RP Automotive glass tube kit Glass tube fuse assortments and kits AGA BP/AGA-AH8-RP AGA high amp fuse assortment:-10 (2), 15 (2), 20 (2) and 30 (2) A BP/AGA-AL8-RP AGA low amp fuse assortment:-1, 2, 3 (2), 5 (2) and 7-1⁄2 (2) A AGC BP/AGC-A5-RP AGC fuse assortment: 10, 15, 20, 25 and 30 A BP/AGC-AH10-RP AGC high amp fuse assortment: 7-1⁄2, 10 (2), 15 (2), 20 (2), 25 and 30 (2) A BP/AGC-AL10-RP AGC low amp fuse assortment: 1 (2), 2 (2), 3 (2), 4, 5 (2) and 6 A AGC-EK AGC kit: (60 pieces/10 each) 5, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller MA-5 AGC low amp marine assortment 1/2, 1, 1-1/2, 2, 3 A AGW BP/AGW-A8-RP AGW fuse assortment: 5, 7-1⁄2, 15 (2), 20 (2) and 30 (2) A AGX BP/AGX-A8-RP AGX fuse assortment: 5, 8, 20 (2), 25 (2) and 30 (2) A SFE BP/SFE-AH6-RP SFE high amp fuse assortment: 14 (2), 20 (2) and 30 (2) A BP/SFE-AL6-RP SFE low amp fuse assortment: 4, 6, 7-1⁄2 (2) and SFE-9 (2) A Glass tube fuse assortments BP/AGC-SFE-A5-RP AGC/SFE fuse assortment: AGC- 10, 15, 30 and SFE-14, 20 A German automotive fuses BP/GBC-A8-RP GBC German fuse assortment: 5, 8 (2), 15, 16 (2) and 25 (2) A 24 Example: AGC-EK For product information and data sheets, visit Eaton.com/BussmannConsumer Retail packaging and assortments Multi-fuse bonus kits Blade fuses ATR BP/ATR-A7-RPP ATL BP/ATL-A4-RPP ATM ATM-FP-AID BP/ATM-A5-RP BP/ATM-A8-RP BP/ATM-AH8-RPP BP/ATM-AL8-RP DIA-2 NO.43 ATM-ID-SK BP/ATM-AID ATR 2-leg micro fuse emergency kit: 5, 7-1⁄2, 10, 15, 20, 25 and 30 A and fuse puller ATL 3-leg micro fuse emergency kit: 5, 7-1⁄2, 10, 15 A and fuse puller easyID indicating ATM emergency kit: 10, 15, 20, 25 and 30 A and FP-A3 fuse puller ATM 5-count fuse assortment: 10, 15, 20, 25 and 30 A ATM 8-count fuse assortment: 2, 5, 7-1⁄2, 10, 15, 20, 25 and 30 A ATM high amp fuse emergency kit: 10 (2), 15 (2), 20 (2), 25 and 30 A and FP-A3 fuse puller ATM low amp assortment: 2, 3 (2), 4, 5 (2) and 7-1⁄2 (2) A ATM diagnostic kit: 2, 5, 7-1⁄2, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller ATM kit: 7 each of 5, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller. Fuses are loose-packed for easy access in reclosable heavy-duty clamshell package. easyID ATM fuse service kit: 6 each 5, 10, 15, 20, 25 and 30 A easyID ATM fuse assortment: 10, 15, 20, 25 and 30 A Multi-fuse assortments Example: BP/ATC-A5-RP Low-profile ATM ATM-LP-EK BP/ATM-A6LP-RP DIA-3 ATC ATC-FP-AID BP/ATC-A5-RP BP/ATC-AH8-RPP BP/ATC-AL8-RP DIA-1 NO.44 NO.80 ATC-ID-SK BP/ATC-AID Example: ATM-FMX-EK Low-profile ATM fuse emergency kit: (7 each) 5, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller Low-profile ATM fuse assortment: 7-1⁄2, 10, 15, 20, 25 and 30 A Low-profile ATM diagnostic kit: 2, 5, 7-1/2, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller easyID indicating ATC emergency kit: 10, 15,20, 25 and 30 A and FP-A3 fuse puller ATC fuse assortment: 10, 15, 20, 25 and 30 A ATC fuse emergency kit: 10, 15 (2), 20 (2), 25, 30 and 40 A and FP-A3 fuse puller ATC low amp fuse assortment: 1, 2, 3, 4, 5 (2) and 7-1⁄2 (2) A ATC diagnostic kit: 5, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller. ATC kit: 7 each of 5, 10, 15, 20, 25 and 30 A and FT-3 fuse tester/puller. Fuses are loose-packed for easy access in reclosable heavy-duty clamshell package. ATC bulk assortment: (80 pieces/10 each) 3, 5, 7-1⁄2, 10, 15, 20, 25 and 30 A. Fuses are loose-packed for easy access. Reclosable, heavy-duty clamshell package stores easily in tool boxes. easyID ATC fuse service kit: 7 each 5, 10, 15, 20, 25 and 30 A easyID ATC fuse assortment: 10, 15, 20, 25 and 30 A Multi-fuse family emergency/bonus kits ATM-FMX-EK ATM and FMX emergency kit: 5 each of ATM-10, 15, 20, 25 and 30 A, 1 each of FMX-20, 30, 40, and 50 A, and FT-3 fuse tester/puller. NO.24 Emergency fuse safety kit: one each of ATM-10, 15, 20, 25, 30, ATM-10LP, 15LP, 20LP, 25LP, 30LP, ATC-3, 5, 7-1⁄2, 10, 15, 20, 25, 30, 40, MAX-30, 40, FMX-30, 40 and FT-3 fuse tester/puller. NO.53 ATC and MAXI fuse kit: (45 pieces) ATC-10, 15, 20, and 30A; MAX-30, 40 and 50A and FT-3 fuse tester/ puller. NO.64 ATM and MAXI fuse kit: (64 pieces) ATM-2, 3, 4, 5, 7-1⁄2, 10, 15, 20 and 30 A; MAX 30, 40 and 50 A and FT-3 fuse tester/puller VP-FMX-A5-RP FMX female MAXI fuse value pack assortment: (5 pieces) 20, 30, 40, 50 and 60 A Multi-fuse emergency kits (includes a fuse puller) Example: BP/ATC-AH8-RPP Diagnostic kits Example: DIA-1 easyID assortments Examples: ATM-FP-AID and ATC-ID-SK For product information and data sheets, visit Eaton.com/BussmannConsumer 25 Traditional automotive installer assortments NO.136 NO.45 ATR, ATL and FMM micro fuse assortment Cartridge fuse bulk assortment Selection of 135 ATR 2-leg and ATL 3-leg micro blade fuses, and FMM micro cartridge fuses plus a fuse puller. Fuses are loosely packed in 12-cavity, shatter-resistant plastic box. Contains ten each of ATR-5, 7-1⁄2, 10, 15, 20, 25 and 30, ten each of ATL-5, 7-1⁄2, 10, and 15, and five each of FMM-15, 20, 25, 30 and 40. The top 16 assorted cartridge fuses for wiring harness protection. Comes with selection guide on inside lid. Contains one each of FLD-80, FLF-20, 30, 40, 50, FLM-80, 100, 120, FLS-30, 40, FMX-20, 30, 40, 50, 60 and FMX-30LP NO.60LP NO.105 Low-profile ATM fuses Late model automotive fuse assortment Assortment contains 60 fuses: ten each of ATM-7-1/2LP, 10LP, 15LP, 20LP, 25LP and 30LP. Selection of low-profile and regular fuses loosely packed in 18-cavity, shatter-resistant plastic box. Contains: 10 each ATM-7-1⁄2LP, 10LP, 25LP and 30LP; 15 each ATM-15LP and 20LP; 3 each FMX-20, 30 and 40; 2 each FMX-50 and 60; 3 each FMX-20LP, 30LP and 40LP; 2 each FMX-50LP and 60LP; 2 each MAX-30 and 40; 1 each MAX-20, 50, 60 and 80. NO.95BK NO.160BK ATC and ATM bulk assortment ATC bulk assortment Selection of 95 ATC and ATM blade fuses. Fuses are loosely packed in 12-cavity, shatter-resistant plastic box. Contains five each of ATC-5, 15, 25, ATM-5, 10, 15, 25, 30, ten of ATM-20, fifteen of ATC-10, 20, 30. Selection of 160 ATC blade fuses loosely packed in 12-cavity, shatter-resistant plastic box. Contains ten fuses each of 3, 4, 7-1/2, 40, fifteen of 5, 10, 15, 25, thirty of 20, 30. 26 For product information and data sheets, visit Eaton.com/BussmannConsumer Traditional automotive installer assortments and fuse caddies Fuse caddies NO.290 PRO PAK professional technician’s assortment Contains the circuit protection products every service technician needs. The compact case organizes 290 of the most common circuit protection products to restore power fast. Comes with a free, high-power white LED spotlight made of high-grade polished aluminum with metal clip and magnetic base. Features a locking ON/OFF switch with an LED mounted on an insulated flexible shaft. Batteries included: 3 AG13 button cell. PRO PAK contents •• Fuse assortments: AGA-AL (1, 2, 3, 5 and 7-1/2 A), AGA-AH (10, 15, 20 and 30 A), AGW-A (5, 7-1/2, 15, 20 and 30 A) and AGX-A (5, 8, 20, 25 and 30 A). •• AGC glass fuses. One tin each containing five fuses: AGC-1, 2, 3, 4, 5, 7-1/2, 10, 15, 20, 25 and 30 A. •• SFE size-rejecting 1/4” glass fuses. One tin each containing five fuses: SFE-4, 7-1/2, 9, 14, 20 and 30 A. •• GBC German vehicle fuses. One tin each containing five fuses: GBC-8, 16 and 25 A. •• ATM blade fuses. One tin of each rating containing five fuses: ATM-5, 7-1/2, 10, 15, 20, 25 and 30 A. •• Low-profile ATM blade fuses. One tin each containing five fuses: ATM-7-1/2LP, 10LP, 15LP, 20LP, 25LP and 30LP. •• ATC blade fuses. One tin each containing five fuses: ATC-3, 4, 5, 7-1/2, 10, 15, 20, 25, 30, 35 and 40 A. •• MAXI blade fuses. MAX-20, (2)30, (2)40, 50, 60, 70 and 80 A. •• FLB bolt-mount cartridge fuses. One each: FLB-40, 50, 60, 70 and 80 A. •• FLD bolt-mount cartridge fuses. One FLD-80 A. •• FLF female termination cartridge fuses. One each: FLF-20, 30, 40, 50 and 60 A. •• FLM male termination cartridge fuses. One each: FLM-60, 80 and 100 A. •• FLS female miniature termination cartridge fuses. One each: FLS-30 and 40 A. •• FMX female MAXI fuses. One each: FMX-20, 30, 40, 50 and 60 A. •• FMX_LP low-profile female MAXI fuses. One each: FMX-20LP, 25LP, 30LP, 40LP, 50LP and 60LP. •• HHD 30 A in-line ATC fuse holder •• HHM 30 A in-line ATM fuse holder •• HHN in-line glass tube fuse holder with AGC-30 A fuse •• HMK heavy-duty in-line glass tube fuse holder •• CBB-30 Type II 30 A ATC blade-type circuit breaker •• CBC-30HB Type I stud-mount 30 A circuit breaker with lengthwise bracket •• UCB-20 universal 20 A ATC blade-type circuit breaker •• UCB-30 universal 30 A ATC blade-type circuit breaker •• FT-3 fuse puller/tester, FP-A3 3-way fuse puller Bussmann series fuse caddies offer a full array of fuses for automotive repair facilities to meet your fuse replacement needs. Each caddy is specially stocked to cover the majority of cars, vans, light trucks, SUVs and RVs on the road today. Select from the five-tray caddy or the more comprehensive ten-tray caddy to offer your customers a convenient and secure means to store and transport their replacement fuse inventory. FUSE-CADDY1 With convenient folding handle and security latch, this five-tray capacity caddy contains 275 fuses in popular ratings. Four, ten-cavity trays contain ATM, low-profile ATM, ATC and MAX fuses. One, five-cavity tray contains FMX fuses. Contains fuse tray catalog numbers CDY10TRY-ATM CDY10TRY-MAX CDY10TRY-ATM-LP CDY5TRY-FMX CDY10TRY-ATC See fuse tray contents on page 28 for type, quantities and ratings for each tray catalog number. Caddy measures 7.4”W x 4.5”D x 7.8”H (handle not extended) FUSE-CADDY2 Caddy measures 14.8”W x 4.5”D x 7.8”H (handle not extended) With convenient folding handle and security latches, this ten-tray capacity caddy contains 372 fuses in popular ratings. Seven, ten-cavity trays contain ATM, Low-profile ATM, ATC, MAX, FMM/ low-profile FMX, FLF/FLS, ATR/ATL micro fuses. Three, five-cavity trays contain FMX, FLB/FLD/FLM and AMG/AMI fuses. Together, all ten trays meet virutally any automotive blade and high amp fuse replacement need. Contains fuse tray catalog numbers CDY10TRY-ATM CDY10TRY-FLNK1 CDY10TRY-ATM-LP CDY10TRY-FLNK2 CDY10TRY-ATC CDY10TRY-MICRO CDY10TRY-MAX CDY5TRY-FMX CDY5TRY-BMOUNT CDY5TRY-SMOUNT See fuse tray contents on page 28 for type, quantities and ratings for each tray catalog number. For product information and data sheets, visit Eaton.com/BussmannConsumer 27 Automotive fuse tray assortments Fuse tray assortments Bussmann series fuse trays make it convenient to sell popular fuse assortments that repair facilities need to keep on hand for today’s cars, vans, light trucks and SUVs. Clear, compact trays that measure 3.5”D x 7”W x 1”H are easy to store and allow quick, visual identification of fuses without the hassel of opening the tray. Three, five-cavity tray assortments and eight, ten-cavity tray assortments cover the most popular fuse applications including the new, ATR and ATL 2- and 3-blade micro fuses and FMM micro cartridge fuses. Offer your customers the convenience of these five-tray and ten-tray fuse caddies. Trays are easily restocked from traditional or value fuse packs. Ten- and five-tray fuse caddies conveniently store multiple fuse trays to efficiently organize an entire replacement fuse inventory. Order individually or offer customers the convenience of the FUSECADDY-1 (five-tray) or FUSECADDY-2 (ten-tray) fuse caddies. Fuse tray contents and quanities CDY10TRY-ATM 10 Cavity tray 80 ATM blade fuses Fuse (Qty) ATM-2 (5) ATM-10 (15) ATM-3 (5) ATM-15 (15) ATM-4 (5) ATM-20 (15) ATM-5 (5) ATM-25 (5) ATM-7-1⁄2 (5) ATM-30 (5) CDY10TRY-ATM-LP 10 Cavity tray 65 Low-profile ATM blade fuses Fuse (Qty) ATM-2LP (5) ATM-10LP (10) ATM-3LP (5) ATM-15LP (10) ATM-4LP (5) ATM-20LP (10) ATM-5LP (5) ATM-25LP (5) ATM-7-1⁄2LP (5) ATM-30LP (5) CDY10TRY-ATC* 10 Cavity tray 100 ATC blade fuses Fuse (Qty) ATC-3 (5) ATC-20 (15) ATC-4 (5) ATC-25 (10) ATC-5 (5) ATC-30 (15) ATC-7-1⁄2 (5) ATC-35 (10) ATC-10 (10) ATC-40 (10) ATC-15 (10) * Replaces NO.100BK CDY10TRY-EZID 10 Cavity tray 59 ATC/ATM/MAX blade fuses Fuse (Qty) ATM-3ID (4) ATC-3ID (4) MAX-30ID (2) ATM-5ID (2) ATC-5ID (2) MAX-40ID (2) ATM-10ID (4) ATC-10ID (4) MAX-50ID (1) ATM-15ID (4) ATC-15ID (4) MAX-60ID (1) ATM-20ID (4) ATC-20ID (4) MAX-80ID (1) ATM-25ID (4) ATC-25ID (4) ATM-30ID (4) ATC-30ID (4) CDY10TRY-MAX 10 Cavity tray 16 MAXI blade fuses Fuse (Qty) MAX-20 (1) MAX-60 (3) MAX-30 (1) MAX-70 (2) MAX-40 (3) MAX-80 (2) MAX-50 (3) MAX-100ID (1)** ** easyID indicating fuse. CDY10TRY-MICRO 10 Cavity tray 55 ATR/ATL micro blade fuses Fuse (Qty) ATR-5 (5) ATR-30 (5) ATR-7-1⁄2 (5) ATL-5 (5) ATR-10 (5) ATL-7-1⁄2 (5) ATR-15 (5) ATL-10 (5) ATR-20 (5) ATL-15 (5) ATR-25 (5) CDY10TRY-FLNK1 10 Cavity tray 13 FMM/low-profile FMX fuses Fuse (Qty) FMM-15 (1) FMX-25LP (1) FMM-20 (1) FMX-30LP (1) FMM-25 (1) FMX-40LP (1) FMM-30 (1) FMX-50LP (2) FMM-40 (1) FMX-60LP (2) FMX-20LP (1) CDY10TRY-FLNK2 10 Cavity tray 7 FLF/FLS cartridge fuses Fuse (Qty) FLF-20 (1) FLF-60 (1) FLF-30 (1) FLS-30 (1) FLF-40 (1) FLS-40 (1) FLF-50 (1) CDY5TRY-FMX 5 Cavity tray 14 FMX high amp fuses Fuse (Qty) FMX-20 (2) FMX-50 (3) FMX-30 (3) FMX-60 (3) FMX-40 (3) CDY5TRY-BMOUNT 5 Cavity tray 10 FLB/FLD/FLM cartridge fuses Fuse (Qty) FLB-80 (1) FLM-30 (1) FLB-140 (1) FLM-60 (1) FLD-40 (1) FLM-80 (1) FLD-80 (1) FLM-100 (1) FLD-120 (1) FLM-120 (1) CDY5TRY-SMOUNT 5 Cavity tray 12 AMG/AMI high amp fuses Fuse (Qty) AMG-80 (1) AMG-225 (1) AMG-100 (1) AMG-250 (1) AMG-125 (1) AMG-300 (1) AMG-150 (1) AMI-40 (1) AMG-175 (1) AMI-50 (1) AMG-200 (1) AMI-80 (1) 28 For product information and data sheets, visit Eaton.com/BussmannConsumer Traditional automotive installer tin-bin assortments and Plan-O-Gram Retail automotive Plan-O-Gram Tilt-bin assortments Color-coded packaging for fast, easy product selection. Fits standard four-foot wide gondola. Turn any pegboard or shelf into a profit-building professional fuse center with interlocking tilt-bin sets from Eaton. Bin rows are stocked with assortments of the fastest-selling fuses, holders and accessories. Transparent, tilt-out bins make selection a snap, and let you check inventory at a glance. Visual categorization •• Color-coded Bussmann series retail packaging. Reload part numbers are available for AFC-225, NO.225 and NO.227. The reloads are packed in a polybag labeled with the catalog number and UPC code. •• Fast and easy product identification. Bins can be stacked in any combination so you can modify your display to fit your customer's needs. •• Provides increased shopability and faster merchandising. Merchandising ease •• Retail set is simple and straightforward. •• Color-coding encourages return of product to correct peg. •• AFC-90 Two tilt-bin sets containing five each of MAX-20, 30, 40, 50 and 60 A and FMX-20, 30 and 40 A fuses, FLB-70, FLF-20, 30, 40 and 60 A and FLM-60, 80 and 100 A and FLS-30 and 40 A cartridge fuses. Reduces need for assistance by store personnel. Consumer friendly •• Fuse center is easily located. •• Point-of-sale identifies fuse types. •• Package color codes identify product category. 4FTAUTO-KIT. Peg hooks and gondola not included. AFC-225 Contains: 25 Each of glass tube fuses. AGC-5, 10, 15, 20, 25 and 30 A and SFE-14, 20 and 30 A. 4FTAUTO-TAGS UPC reorder tags. Catalog no. 4FTAUTO-KIT 4FTAUTO-TAGS Description 151 SKU auto prepack. Includes one of each catalog number, a complete set of UPC reorder tags and a header card as pictured. Replacement set of UPC reorder tags for the 4FTAUTO-KIT. Order tags through your Eaton Bussmann series rep. For details on automotive Plan-O-Gram SKUs, visit Eaton.com/BussmannConsumerPOG NO.225 Contains: 25 Each of ATC blade fuses. ATC-3, 4, 5, 7-1/2, 10, 15, 20, 25 and 30 A. NO.227 Contains: Ten each of ATM blade fuses. ATM-2, 3, 5, 7-1/2, 10, 15, 20, 25 and 30 A. Available reload packs Reloads contain 10 and 25 fuses of the specified ampacity in a poly bag. See table below for available fuses and amp ratings. Catalog no. ATC-(amp)RLD All five units stacked together provide a complete fuse selection for the automotive repair technician or store display. Bins interlock and can be wall-mounted. ATM-(amp)RLD For product information and data sheets, visit Eaton.com/BussmannConsumer Description 25 fuses in a poly bag, available amps: 3, 4, 5, 7-1/2, 10, 15, 20, 25, 30 A 10 fuses in a poly bag, available amps: 2, 3, 5, 7-1/2, 10, 15, 20, 25, 30 A 29 Marine and RV products 30 For product information and data sheets, visit Eaton.com/BussmannConsumer Marine products and assortments Marine-rated circuit breakers CB187P Specifically designed to meet the needs of marine applications, the CB187F and CB187P offer 5 kA @ 12 Vdc interrupting ratings and ignition protection per ABYC E-11. Usable as an ON/OFF switch, they have corrosion resistant plating on 15/16-18 copper terminals. CB251 and CB255 offer an interrupting rating of 2.5 kA per ABYC E-11 and feature a "Push-to-Trip option and reset mechanism that provides visual indication of a tripped condition. CB185 Type III switchable, waterproof, flush-mount manual reset circuit breakers with 1⁄4-28 threaded stud terminals with SEMS nuts installed, and black reset lever, 48 Vdc Amps Boxed Retail pack 25 30 35 40 50 CB185-25 CB185-30 CB185-35 CB185-40 CB185-50 — — — — BP/CB185-50 60 70 80 90 100 110 120 135 150 CB185-60 CB185-70 CB185-80 CB185-90 CB185-100 CB185-110 CB185-120 CB185-135 CB185-150 — BP/CB185-70 BP/CB185-80 — BP/CB185-100 — BP/CB185-120 BP/CB185-135 BP/CB185-150 Type III marine-rated panel-mount, manual reset circuit breakers with switch function and nuts/lock washers installed, 48 Vdc Catalog no. (amps) boxed only CB187P-25 CB187P-30 CB187P-35 CB187P-40 CB187P-50 CB187P-60 CB187P-70 CB187P-80 CB187P-90 CB187P-100 CB187P-110 CB187P-120 CB187P-135 CB187P-150 CB251 Type I ignition protected, weatherproof panel-mount, manual reset circuit breakers with SEMS nuts installed, 32 Vdc Catalog no. (amps) boxed only CB251-10 CB251-15 CB251-20 CB251-25 CB251-30 CB251-35 CB251-40 CB251-50 CB187F CB255 Type III marine-rated flush-mount, manual reset circuit breakers with switch function and nuts/lock washers installed, 48 Vdc Type III ignition protected, weatherproof panel-mount, manual reset circuit breakers with "Push-to-Trip" option and SEMS nuts installed, 32 Vdc Catalog no. (amps) boxed only CB187F-25 CB187F-30 CB187F-35 CB187F-40 CB187F-50 CB187F-60 CB187F-70 CB187F-80 CB187F-100 CB187F-110 CB187F-120 CB187F-135 CB187F-150 CB187F-200 Catalog no. (amps) boxed only CB255-10 CB255-15 CB255-20 CB255-25 CB255-30 CB255-35 CB255-40 CB255-50 Marine assortments BP/AGC-AH10-RP NO.108BK AGC fuse assortment for marine accessories and bilge pumps. Includes AGC-7-1/2, 10 (2), 15 (2), 20 (2), 25 and 30 (2) A. Marine circuit protection emergency kit in a sturdy, compact reclosable box for replacement of fuses and circuit breakers. A must for commercial or recreational marine applications. Fuses: Five each of ABC-10, AGC-1-1/2, GMA-2 A, MDA-8, ten of AGC-3, 7-1/2, 15, 25, fifteen of AGC-20, 30. Circuit breakers: Three CBF-30. Water resistant holders available on pages 12 and 13. See additional circuit breakers on pages 16 to 20. BP/MDL-1 Marine motor protection fuses. Retail pack with two fuses per card. See page 37 for retail pack availability in ratings from 1/2 to 15 amps. MA-5 Marine accessory assortment, Contains (1) each: AGC-1/2, 1, 1-1/2, 2 and 3 A. BP/AGC-SFE-A5-RP AGC and SFE fuse assortment for marine applications. Contains (1) each: - AGC-10, 15 and 30 A - SFE-14 and 20 A For product information and data sheets, visit Eaton.com/BussmannConsumer 31 Class T fuses, splash proof covers and battery separators JJN - Class T very fast-acting, current-limiting 300 Vac, 160 Vdc fuses Amps 110 125 150 175 200 225 250 300 350 400 Catalog no.* JJN-110 JJN-125 JJN-150 JJN-175 JJN-200 JJN-225 JJN-250 JJN-300 JJN-350 JJN-400 * 1 Fuse per pack, 5 packs per master carton. Splash proof covers Catalog no. Description Cover for stud terminal CB-CVR circuit breaker Cover for stud terminal BK/CB-CVR circuit breaker-BULK with coverBP/CB20HB-CVR* CB123-20HB retail pack with coverBP/CB40HB-CVR* CB123-40HB retail pack Pack qty. Shelf qty. Master qty. 1 10 300 — 100 2000 1 5 120 1 5 120 * Packed with CB123-20HB and CB123-40HB. Battery separators manage batteries for reliable starts •• For vehicles and boats with main and auxiliary battery systems and alternator outputs up to 100 amps — or on systems incompatible with battery isolators. •• Battery separators from Sure Power actively manage multi-battery electrical systems to ensure greater reliability for main battery engine starting. •• Battery separators provide a solenoid priority system for multi-battery systems. •• When main battery is low, the separator will utilize auxiliary battery power to assist in vehicle starting. •• Separators disconnect main and auxiliary batteries from one another to protect them from excessive drain. Time-delay function prevents battery separator from reacting to temporary voltage fluctuations. Catalog no. Description •• RB-BS-1314 Uni-directional 100 A battery separator — model no. 1314A* RB-BS-1315 Bi-directional 100 A battery separator — model no. 1315A* * Use the catalog numbers to order these products. Multi-battery systems Many vehicles and boats have accessories and other electrical loads, such as lights, entertainment systems and communications equipment that draw power when the engine is off. When applied to a single battery electrical system, main batteries can become drained and present an engine “no-start” condition. Adding an auxiliary battery to operate these additional loads helps avoid this, but it needs more than simply being wired into the electrical system — the auxiliary battery needs to be separated. Priority charging The battery separator waits until the main battery’s active charging source reaches approximately 13.2 volts before it begins charging the auxiliary battery. The uni-directional battery separator RB-BS-1314 will only charge the auxiliary battery when the main battery reaches 13.2 volts. The bi-directional battery separator RB-BS-1315 will engage both main and auxiliary batteries and disconnect at approximately 12.8 volts. Charging system protection Once the engine starts, the battery separator monitors the main battery and charging system voltage. When the charging system reaches 13.2 volts, the battery separator will engage, signaling a charged main battery. The auxiliary battery is then connected to the vehicle charging system. When the charging system reaches 12.8 volts, the battery separator will disconnect the auxiliary battery to protect the vehicle’s charging system. This process of managing the battery charging is repeated until the engine is turned off. Simple installation Uni-directional and bi-directional versions available. The battery separators work with any 12 volt DC, negative ground charging system up to 100 amps. They easily connect to the main battery, auxiliary battery and ground. No system modifications are necessary. Optional engine start assist When the engine starter is engaged, the battery separator will compare the voltage in both main and auxiliary batteries. If the main battery is lower than the auxiliary battery, the battery separator will engage the auxiliary battery to aid in engine start. The start signal must reach 3 volts in order for the auxiliary to main battery connection procedure to begin. Attractive retail packaging easily displays on peg boards or stacks on shelves. 32 For product information and data sheets, visit Eaton.com/BussmannConsumer Battery isolators and installation kits Battery isolators ensure reliable engine starts •• Battery isolators prevent auxiliary batteries from draining main battery power in vehicle electrical systems. •• Suited for light truck, RV, select commercial and marine applications. •• Solid-state technology isolates each battery circuit to extend battery life by allowing each to charge and discharge according to need. •• Easily connects alternator to one main and one auxiliary battery. •• Designed by Sure Power, the leader in battery isolators, for superior performance that exceeds original equipment manufacturer specifications. •• Includes wiring and hardware for basic installation; an optional installation kit available for advanced installation. Catalog no. RB-BI-70A RB-BI-95A RB-BI-120A RB-BI-130A RB-BI-240A Description 70 amp battery isolator w/wiring kit — model no. 702* 95 amp battery isolator w/wiring kit — model no. 9523A* 120 amp battery isolator w/wiring kit — model no. 12023A* 130 amp battery isolator w/wiring kit — model no. 13023A* 240 amp battery isolator w/wiring kit — model no. 24023A* 70 A and 95 A size 120 A and 130 A size 240 A size Battery isolator models are available in 70 A, 95 A, 120 A, 130 A and 240 A versions for alternators with outputs from 70 to 240 amps. * Use the catalog numbers to order these products. Multi-battery systems Many vehicles and boats have accessories and other electrical loads, such as lights, entertainment systems and communications equipment that draw power when the engine is off. When applied to a single battery electrical system, main batteries can become drained and present an engine “no-start” condition. Adding an auxiliary battery to operate these additional loads helps avoid this, but it needs more than simply being wired into the electrical system — the auxiliary battery needs to be isolated. Why batteries need isolating Multiple batteries connected in an electrical system can become problematic when a partially discharged,or dead, battery is connected to a fully charged battery. The current in the fully charged battery will flow to the less charged battery until both are equally discharged, or even worse, completely discharged and may prevent the engine from starting. Battery isolators manage battery power Attractive 70 to 130 amp retail packaging easily mounts on peg boards or stacks on shelves. 240 amp isolator package for shelf display only. A battery isolator can eliminate the problem of battery drain by acting as a check valve between the batteries to prevent current flowing from a fully charged battery to a partially charged battery. A battery isolator enables each battery to act as an independent power source so that the main battery can conserve power even if the auxiliary battery is fully discharged. When charging, the isolator gives priority to the main battery so that there is always a full charge to start the engine. Battery isolator installation kit and Delco® alternator connector kit Enhance your battery isolator sales by offering the instalation kit RB-BIK-1882 that contains the wire, connectors and hardware needed for an easier installation. When customers are installing their isolator on a Delco/Delphi CS Series alternator system, also sell them the connector kit that’s required for OEM connector modification. Catalog no. RB-BIK-1882 RB-GM-KIT Description Battery isolator installation kit — model no. 1882* GM Delco CS Series connector kit — model no. 144-CD* * Use the catalog numbers to order these products. Installation kit and GM connector kit increases sales opportunities while easing installation for customers. For product information and data sheets, visit Eaton.com/BussmannConsumer 33 Hardware and home products 34 For product information and data sheets, visit Eaton.com/BussmannConsumer Glass and ceramic tube fuses Automotive Glass and ceramic tube fuse sizes Used in older-model cars, glass tube fuses today are found primarily in automotive accessory applications. The expansive Bussmann series line of glass fuses includes many types and sizes in addition to those listed in this catalog. Call Eaton for more product details if you have requirements which are not covered here. Both glass and ceramic tube fuses vary by diameter and length. The chart below provides a visual reference for the various sizes of the Bussmann series fuse families. Images are shown to scale. Fuse selection criteria •• For electronic/electrical applications, fuses must be rated at 125 V or better. •• Voltage must match or exceed the fuse being replaced (125 V for household current; 12 V for auto; 24 V for heavy duty). •• Fuses must match required fuse characteristic – either fast-acting or time-delay. •• Amp rating must match that of the original fuse. Appliances and consumer electronics Glass and ceramic tube fuses are often used to protect appliances and consumer electronics. As electronic equipment becomes smaller, the circuits and components become more delicate and easily damaged. Fuses are the preferred method of protection due to their accuracy, small size and reliability. Fuses are available in a wide variety of amp ratings to provide precise protection. Generally, two sizes of user-replaceable fuses are found: the 1/4” x 1-1/4” and 5x20 mm. Each is available in a variety of volt and amp ratings. Fuse types There are two basic types of fuses available for appliances and consumer electronics: fast-acting or time-delay. Any replacement fuse must match the one it’s replacing. In general, fast-acting fuses are a single strand of wire or strip of metal. Time-delay fuses usually have a coiled wire, a thick element wrapped in wire, or a spring. Most electronic fuses will have the voltage and amp rating stamped on the end cap. The type of fuse can generally be visually identified. Also, owner’s manuals will have the correct replacement fuse generically identified. For example: “Use a 2 amp, time-delay, 250 volt fuse.” A note on voltage rating All fuses have a voltage rating. To maintain safety, this voltage rating should not be exceeded in application, although it is acceptable to use a higher voltage rated fuse in a lower voltage application. For example: A fuse rated for 125 volts is appropriate in household (110 V) or automotive (12 V), while a fuse rated for 32 volts is appropriate for automotive (12 V), but not for household (125 V). Always replace a fuse with one of the same or higher voltage rating. See page 50 for specifications. Glass and ceramic tube fuse sizes (actual size) 5 x 20 mm 1⁄4” x 5⁄8” AGA GDA SFE-4 GDB GDC GMA GMC GMD 1⁄4” x 3⁄4” SFE-6 1⁄4” x 7⁄8” AWG SFE-7-1/2 SFE-9 1⁄4” x 31⁄32” GBC 1⁄4” x 1” AGX 1⁄4” x 1-1⁄16” 1⁄4” x 1-1⁄4” SFE-14 ABC AGC GBB SFE-20 MDA MDL MDQ 1⁄4” x 1-7⁄16” SFE-30 13⁄32” x 1-1⁄2” AGU AGU_GP GMF* * Mounts in HLR in-line holder, see page 13. For product information and data sheets, visit Eaton.com/BussmannConsumer 35 Glass and ceramic tube fuses Fast-acting 1/4” diameter automotive fuses AGA 1/4” x 5/8” fast-acting glass tube fuses See page 24 for available assortments. Amps 1/4 1 1-1/2 2 2-1/2 3 5 6 7-1/2 10 15 20 30 Catalog no.* AGA-1/4 AGA-1 AGA-1-1/2 AGA-2 AGA-2-1/2 AGA-3 AGA-5 AGA-6 AGA-7-1/2 AGA-10 AGA-15 AGA-20 AGA-30 Retail pack** — — — — — — — — — — — BP/AGA-20-RP — ABC 1/4” x 1-1/4” fast-acting ceramic tube fuses See page 48 for available assortment. Amps 1/4 1/2 1 2 2-1/2 3 4 5 6 7 8 10 12 15 20 25 30 * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. AGW 1/4” x 7/8” fast-acting automotive glass tube fuses See page 24 for available assortment. Amps 1 1-1/2 2-1/2 3 4 5 6 7-1/2 10 15 20 30 Catalog no.* AGW-1 AGW-1-1/2 AGW-2-1/2 AGW-3 AGW-4 AGW-5 AGW-6 AGW-7-1/2 AGW-10 AGW-15 AGW-20 AGW-30 Retail pack** — — — — — — — — — BP/AGW-15-RP — — * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. AGX 1/4” x 1” fast-acting automotive glass tube fuses See page 24 and 48 for available assortments. Amps 1 2 2-1/2 3 5 Catalog no.* AGX-1 AGX-2 AGX-2-1/2 AGX-3 AGX-5 7 8 10 15 20 25 30 AGX-7 AGX-8 AGX-10 AGX-15 AGX-20 AGX-25 AGX-30 * 5 Fuses per pack, 10 packs per shelf carton. GBB 1/4” x 1-1/4” very fast-acting ceramic tube fuses Amps 1-1/4 10 15 30 Catalog no.* GBB-1-1/4-R GBB-10-R GBB-15-R GBB-30-R * 5 Fuses per pack, 10 packs per shelf carton. Catalog no.* ABC-1/4 ABC-1/2 ABC-1 ABC-2 ABC-2-1/2 ABC-3 ABC-4 ABC-5 ABC-6 ABC-7 ABC-8 ABC-10 ABC-12 ABC-15 ABC-20 ABC-25 ABC-30 Retail pack** — — — — — — — — — — — BP/ABC-10 — BP/ABC-15 BP/ABC-20 — — * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. AGC 1/4” x 1-1/4” fast-acting automotive glass tube fuses See pages 24, 29 and 48 for available assortments. Amps 1/8 3/10 1/4 3/8 1/2 3/4 1 1-1/4 1-1/2 2 2-1/2 3 32/10 3-1/2 4 5 6 6-1/4 7 7-1/2 8 10 12 15 20 25 30 35 40 50 Catalog no.* AGC-1/8 AGC-3/10 AGC-1/4 AGC-3/8 AGC-1/2 AGC-3/4 AGC-1 AGC-1-1/4 AGC-1-1/2 AGC-2 AGC-2-1/2 AGC-3 AGC-3-2/10 AGC-3-1/2 AGC-4 AGC-5 AGC-6 AGC-6-1/4 AGC-7 AGC-7-1/2 AGC-8 AGC-10 AGC-12 AGC-15 AGC-20 AGC-25 AGC-30 AGC-35 AGC-40 AGC-50 Retail pack** — — — — BP/AGC-1/2-RP — BP/AGC-1-RP — BP/AGC-1-1/2-RP BP/AGC-2-RP BP/AGC-2-1/2-RP BP/AGC-3-RP — — BP/AGC-4-RP BP/AGC-5-RP BP/AGC-6-RP — — BP/AGC-7-1/2-RP — BP/AGC-10-RP — BP/AGC-15-RP BP/AGC-20-RP BP/AGC-25-RP BP/AGC-30-RP BP/AGC-35-RP — — * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. 36 For product information and data sheets, visit Eaton.com/BussmannConsumer Glass and ceramic tube fuses Fast-acting fuses Time-delay 1/4” diameter fuses GBC MDA 1/4” x 31/32” fast-acting German automotive fuses 1/4” x 1-1/4” time-delay ceramic tube fuses See page 24 for available assortment. Color code Yellow White Red Blue Amps 5 8 16 25 Catalog no.* GBC-5 GBC-8 GBC-16 GBC-25 Retail pack** — BP/GBC-8-RP BP/GBC-16-RP BP/GBC-25-RP * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. SFE Amps 1 1-1/2 2 2-1/2 3 4 5 6 7 8 10 12 15 20 25 30 Catalog no.* MDA-1 MDA-1-1/2 MDA-2 MDA-2-1/2 MDA-3 MDA-4 MDA-5 MDA-6 MDA-7 MDA-8 MDA-10 MDA-12 MDA-15 MDA-20 MDA-25 MDA-30 * 5 Fuses per pack, 10 packs per shelf carton. 1/4” size-rejecting fast-acting automotive glass tube fuses See pages 24 and 29 for available assortments. Amps 4 6 7-1/2 9 14 20 30 Fuse length 5/8” 3/4” 7/8” 7/8” 11/16” 11/4” 17/16” Catalog no.* SFE-4 SFE-6 SFE-7-1/2 SFE-9 SFE-14 SFE-20 SFE-30 Retail pack** BP/SFE-4-RP BP/SFE-6-RP — BP/SFE-9-RP BP/SFE-14-RP BP/SFE-20-RP BP/SFE-30-RP MDL 1/4” x 1-1/4” time-delay glass tube fuses See page 48 for available assortment. * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. AGU 13/32” x 1-1/2” fast-acting automotive glass tube fuses Available with gold-plated end caps for high-end stereo and AV markets. Catalog Retail Amps no.* pack** Nickel-plated 10 AGU-10 — 15 AGU-15 — 20 AGU-20 — 25 AGU-25 — 30 AGU-30 — 40 AGU-40 BP/AGU-40-RP 50 AGU-50 BP/AGU-50-RP 60 AGU-60 BP/AGU-60-RP Gold-plated 10 AGU-10GP — 15 AGU-15GP — 20 AGU-20GP — 25 AGU-25GP — 30 AGU-30GP — 35 AGU-35GP — 40 AGU-40GP BP/AGU-40GP-RP 50 AGU-50GP BP/AGU-50GP-RP 60 AGU-60GP BP/AGU-60GP-RP Amps 1/16 1/8 1/4 3/8 1/2 3/4 1 1-1/4 1-1/2 2 2-1/2 3 3-2/10 3-1/2 4 5 6 6-1/4 7 7-1/2 8 10 12 15 20 25 30 40 Catalog no.* MDL-1/16 MDL-1/8 MDL-1/4 MDL-3/8 MDL-1/2 MDL-3/4 MDL-1 MDL-1-1/4 MDL-1-1/2 MDL-2 MDL-2-1/2 MDL-3 MDL-32/10 MDL-3-1/2 MDL-4 MDL-5 MDL-6 MDL-6-1/4 MDL-7 MDL-7-1/2 MDL-8 MDL-10 MDL-12 MDL-15 MDL-20 MDL-25 MDL-30 MDL-40 Retail pack** — — BP/MDL-1/4 — BP/MDL-1/2 — BP/MDL-1 — BP/MDL-1-1/2 BP/MDL-2 BP/MDL-2-1/2 BP/MDL-3 — — BP/MDL-4 BP/MDL-5 BP/MDL-6 — BP/MDL-7 — BP/MDL-8 BP/MDL-10 — BP/MDL-15 BP/MDL-20 BP/MDL-25 BP/MDL-30 — * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. MDQ 1/4” x 1-1/4” dual-element, time-delay glass tube fuses * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. For product information and data sheets, visit Eaton.com/BussmannConsumer Amps 2 4 5 6 Catalog no.* MDQ-2 MDQ-4 MDQ-5 MDQ-6 * 5 Fuses per pack, 10 packs per shelf carton. 37 Glass and ceramic tube fuses Time-delay 5x20 mm fuses Fast-acting 5x20 mm fuses GDA IEC 5x20 mm high-breaking capacity fast-acting ceramic tube fuses Amps 500 mA 630 mA 1 1.25 1.6 2 2.5 3.15 4 5 6.3 Catalog no.* GDA-500MA GDA-630MA GDA-1A GDA-1.25A GDA-1.6A GDA-2A GDA-2.5A GDA-3.15A GDA-4A GDA-5A GDA-6.3A GDC IEC 5x20 mm time-delay glass tube fuses * 5 Fuses per pack, 10 packs per shelf carton. Amps 160 mA 2 4 6.3 8 10 GDB IEC 5x20 mm fast-acting glass tube fuses Catalog no.* GDB-160MA GDB-2A GDB-4A GDB-6.3A GDB-8A GDB-10A * 5 Fuses per pack, 10 packs per shelf carton. GMC UL 5x20 mm medium time-delay glass tube fuses UL 5x20 mm fast-acting glass tube fuses See page 48 for available assortments. Catalog no.* GMA-63MA GMA-100MA GMA-125MA GMA-200MA GMA-250MA GMA-300MA GMA-315MA GMA-500MA GMA-600MA GMA-750MA GMA-800MA GMA-1A GMA-1.25A GMA-1.5A GMA-1.6A GMA-2A GMA-2.5A GMA-3A GMA-3.15A GMA-3.5A GMA-4A GMA-5A GMA-6A GMA-7A GMA-8A GMA-10A Retail pack** — — — BP/GMA-200MA BP/GMA-250MA — — BP/GMA-500MA — BP/GMA-750MA — BP/GMA-1A — — — BP/GMA-2A — BP/GMA-3A — — — BP/GMA-5A BP/GMA-6A BP/GMA-7A — BP/GMA-10A Amps 500 mA 630 mA 1 1.5 1.6 2 3 3.5 4 5 6 7 Retail pack** — — — — — — — BP/GDC-5A — Catalog no.* GMC-500MA GMC-630MA GMC-1A GMC-1.5A GMC-1.6A GMC-2A GMC-3A GMC-3.5A GMC-4A GMC-5A GMC-6A GMC-7A Retail pack** BP/GMC-500MA — — — — — — — — BP/GMC-5 — BP/GMC-7 * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. GMD UL 5x20 mm medium time-delay glass tube fuses Amps 500 mA 1 2 3 Catalog no.* GMD-500 MA GMD-1A GMD-2A GMD-3A * 5 Fuses per pack, 10 packs per shelf carton. GMF Non-rejection time-delay in-line fuse with cap * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. Use with HLR in-line fuse holder page 13. 38 Catalog no.* GDC-500MA GDC-1A GDC-1.6A GDC-2A GDC-2.5A GDC-3.15A GDC-4A GDC-5A GDC-6.3A * 5 Fuses per pack, 10 packs per shelf carton. ** 5 Fuses per pack, 5 packs per shelf carton. GMA Amps 63 mA 100 mA 125 mA 200 mA 250 mA 300 mA 315 mA 500 mA 600 mA 750 mA 800 mA 1 1.25 1.5 1.6 2 2.5 3 3.15 3.5 4 5 6 7 8 10 Amps 500 mA 1 1.6 2 2.5 3.15 4 5 6.3 For product information and data sheets, visit Eaton.com/BussmannConsumer Amps 2-1/2 2-8/10 3 3-2/10 4 Catalog no.* GMF-2-1/2 GMF-2-8/10 GMF-3 GMF-3-2/10 GMF-4 * 5 Fuses per pack, 10 packs per shelf carton. Cartridge fuses Cartridge fuses are used to protect motors and branch circuits where higher amps or volt ratings are required. They are available in a wide variety of sizes, amp and volt ratings up to 600 Vac and 600 amps. Cartridge fuses are used extensively in commercial, industrial and agricultural applications as well as residential fuse panels, air conditioning, pumps, appliances and other equipment. Cartridge fuses are available in two types. General purpose fuses have no time-delay and protect fuse panels, appliances and branch circuits. Heavy-duty fuses have a time-delay feature, allowing momentary motor startups. Both are available in 250 Vac and 600 Vac versions with catalog symbol and amp rating stamped on the knife blade or end cap. General purpose one-time NON and NOS Used in lighting circuits, main panel protection and other circuits that don't contain large electric motors or inductive loads. Up to 60 amp fuses UL Listed Class K5 (IR: 50 kA). 70 to 600 A fuses UL Class H (IR: 10 kA). Cartridge fuse dimensions - in (mm) Ferrule styles* Amp range 250 Vac A 1/10-30 2 (50.8) 35-60 3 (76.2) Blade styles* Amp 250 Vac range A 70-100 5.88 (149.2) 110-200 7.13 (181.0) 225-400 8.63 (219.1) 450-600 10.38 (263.5) 600 Vac B 0.56 (14.3) 0.81 (20.6) A 5.0 (127.0) 5.5 (139.7) B 0.81 (20.6) 1.06 (27.0) B 1.06 (26.9) 1.56 (39.6) 2.06 (52.3) 2.59 (65.8) 600 Vac A 7.88 (200.0) 9.63 (244.5) 11.63 (295.3) 13.38 (339.7) B 1.34 (34.0) 1.84 (46.7) 2.59 (65.8) 3.13 (79.5) NON Amps 250 Vac general purpose non 2 current-limiting Class K5 3 and H fuses 5 See page 48 for available 6 assortments and emergency 10 kits. 15 20 25 30 35 40 45 50 60 70 80 35-60 A 90 100 125 150 200 250 70 A and over 300 400 Catalog no.* NON-2 NON-3 NON-5 NON-6 NON-10 NON-15 NON-20 NON-25 NON-30 NON-35 NON-40 NON-45 NON-50 NON-60 NON-70 NON-80 NON-90 NON-100 NON-125 NON-150 NON-200 NON-250 NON-300 NON-400 Retail pack** — — — — — BP/NON-15 BP/NON-20 BP/NON-25 BP/NON-30 BP/NON-35 BP/NON-40 BP/NON-45 BP/NON-50 BP/NON-60 — — — BP/NON-100 — — — — — — * Refer to packaging spec file for individual fuse packaging options. ** 70 and 100 amp fuses 1 fuse per pack, 15 to 60 amps, 2 fuses per pack, 5 packs per shelf carton. * NON and NOS one-time fuses do not have a rejection feature. NOS 600 Vac general purpose non current-limiting Class K5 and H fuse Class R fuses with rejection feature (FRN-R and FRS-R). Amps 6 10 15 20 25 30 35 40 50 60 100 200 Catalog no. NOS-6 NOS-10 NOS-15 NOS-20 NOS-25 NOS-30 NOS-35 NOS-40 NOS-50 NOS-60 NOS-100 NOS-200 * Refer to packaging spec file for individual fuse packaging options. Up to 60 A 70 A and over Class H fuses without rejection feature (NON/NOS and CDN/PON). For product information and data sheets, visit Eaton.com/BussmannConsumer 39 Cartridge fuses Fusetron™ energy efficient FRN-R fuses FRN-R fuses with easyID blown fuse indication Bussmann series Fusetron cartridge fuses are 23% more energy efficient* and offer the best time-delay performance. Their dual-element feature allows closer sizing to load for superior protection of motors and transformers. These Class RK5 fuses with a 200 kA interrupting rating can be used in a broad range of applications. Featuring the same energy efficiency and electrical performance characteristics as their green label non-indicating versions, easyID FRN-R fuses offer consumers the additional advantage of blown fuse status that makes finding the open fuse easier and faster. When sized correctly, they help protect motors from burnout caused by overloads or single-phasing. The time-delay feature allows the initial startup current surge for typical motors to pass, but opens prior to motor burnout when longer, dangerous overloads are present. In addition, the dual-element design opens in as little as 0.004 second if the fuse experiences short-circuit conditions. All fuses are UL Listed Class R (IR: 200 kA). Groove in end cap or notch in knife blade permit the fuse to be used in only Class H, Class K or Class R fuse blocks. FRN-R 250 Vac indicating dual-element, time-delay Class RK5 fuses 250 Vac non-indicating dual-element, time-delay Class RK5 fuses See page 48 for available assortments. Up to 60 A 70 A and over Amps 1 2 3 4 5 6 6-1/4 7 8 10 12 15 17-1/2 20 25 30 35 40 45 50 60 70 75 80 90 100 150 200 Catalog no.* FRN-R-1 FRN-R-2 FRN-R-3 FRN-R-4 FRN-R-5 FRN-R-6 FRN-R-6-1/4 FRN-R-7 FRN-R-8 FRN-R-10 FRN-R-12 FRN-R-15 FRN-R-17-1/2 FRN-R-20 FRN-R-25 FRN-R-30 FRN-R-35 FRN-R-40 FRN-R-45 FRN-R-50 FRN-R-60 FRN-R-70 FRN-R-75 FRN-R-80 FRN-R-90 FRN-R-100 FRN-R-150 FRN-R-200 Retail pack** — — — — — — — — — BP/FRN-R-10 — BP/FRN-R-15 — BP/FRN-R-20 BP/FRN-R-25 BP/FRN-R-30 BP/FRN-R-35 BP/FRN-R-40 BP/FRN-R-45 BP/FRN-R-50 BP/FRN-R-60 — — — — BP/FRN-R-100 — — easyID retail pack** BP/FRN-R-15ID BP/FRN-R-20ID BP/FRN-R-30ID BP/FRN-R-40ID BP/FRN-R-50ID BP/FRN-R-60ID blown fuse indication Good * Refer to packaging spec file for individual fuse packaging options. ** 10 to 60 amp fuses, 2 per pack; 100 amp fuse, 1 fuse per pack, 5 packs per shelf carton. 40 Catalog no.* FRN-R-15ID FRN-R-20ID FRN-R-30ID FRN-R-40ID FRN-R-50ID FRN-R-60ID * Refer to packaging spec file for individual fuse packaging options. ** 2 Fuses per pack, 5 packs per shelf carton. * Test results are based on weighted sales volume of Fusetron and Ferraz Shawmut (Mersen) fuses by selected amp and volt rating combination. Next leading brand refers to Ferraz Shawmut based on third-party fuse market share data for a twenty-seven month period (July 2008 through September 2010). FRN-R Amps 15 20 30 40 50 60 For product information and data sheets, visit Eaton.com/BussmannConsumer Indicator shows when fuse is blown Cartridge fuses Fusetron energy efficient FRS-R fuses These cartridge fuses are 23% more energy efficient* and offer the best time-delay performance. Their dual-element feature allows closer sizing to load for superior protection of motors and transformers. These Class RK5 fuses with a 200 kA interrupting rating can be used in a broad range of applications. When sized correctly, they help protect motors from burnout caused by overloads or single-phasing. The time-delay feature allows the initial startup current surge for typical motors to pass, but opens prior to motor burnout when longer, dangerous overloads are present. In addition, the dual-element design opens in as little as 0.004 second if the fuse experiences short-circuit conditions. All fuses are UL Listed Class R (IR: 200 kA). CDN Type D and PON Type P CSA Certified standard code fuses Economical fuses for a variety of applications where available short-circuit current is relatively low. CDN 250 Vac CSA Type D time-delay fuses * Test results are based on weighted sales volume of Fusetron and Ferraz Shawmut (Mersen) fuses by selected amp and volt rating combination. Next leading brand refers to Ferraz Shawmut based on third-party fuse market share data for a twenty-seven month period (July 2008 through September 2010). FRS-R 600 Vac indicating and non-indicating dual-element, time-delay Class RK5 fuses Catalog With easyID Retail Up to 60 A 65 A and over Amps 2 3 3-1/2 4 5 6 6-1/4 7 8 10 12 15 17-1/2 20 25 30 35 40 45 50 60 70 80 90 100 125 150 175 200 no.* FRS-R-2 FRS-R-3 FRS-R-3-1/2 FRS-R-4 FRS-R-5 FRS-R-6 FRS-R-6-1/4 FRS-R-7 FRS-R-8 FRS-R-10 FRS-R-12 FRS-R-15 FRS-R-17-1/2 FRS-R-20 FRS-R-25 FRS-R-30 FRS-R-35 FRS-R-40 FRS-R-45 FRS-R-50 FRS-R-60 FRS-R-70 FRS-R-80 FRS-R-90 FRS-R-100 FRS-R-125 FRS-R-150 FRS-R-175 FRS-R-200 indication — — — — — FRS-R-6ID FRS-R-6-1/4ID FRS-R-7ID FRS-R-8ID FRS-R-10ID FRS-R-12ID FRS-R-15ID FRS-R-17-1/2ID FRS-R-20ID FRS-R-25ID FRS-R-30ID FRS-R-35ID FRS-R-40ID FRS-R-45ID FRS-R-50ID FRS-R-60ID — — — — — — — — pack** — — — — — — — — — — — BP/FRS-R-15 — BP/FRS-R-20 — BP/FRS-R-30 — — — — BP/FRS-R-60 — — — — — — — — Amps 10 12 15 20 25 30 35 40 45 50 60 100 110 175 200 Catalog no.* CDN10 CDN12 CDN15 CDN20 CDN25 CDN30 CDN35 CDN40 CDN45 CDN50 CDN60 CDN100 CDN110 CDN175 CDN200 Retail pack** — — BP/CDN10 BP/CDN20 BP/CDN25 BP/CDN30 BP/CDN35 BP/CDN40 BP/CDN45 BP/CDN50 BP/CDN60 — — — — * Refer to packaging spec file for individual fuse packaging options. ** 1 Fuse per pack, 5 packs per shelf carton. PON 250 Vac CSA Type P one-time fuses Amps 15 20 25 30 35 40 45 50 60 Catalog no.* PON15 PON20 PON25 PON30 PON35 PON40 PON45 PON50 PON60 Retail pack** BP/PON15 BP/PON20 BP/PON25 BP/PON30 BP/PON35 BP/PON40 BP/PON45 BP/PON50 BP/PON60 * Refer to packaging spec file for individual fuse packaging options. ** 1 Fuse per pack, 5 packs per shelf carton. * Refer to packaging spec file for individual fuse packaging options. ** 1 Fuse per pack, 5 packs per shelf carton. For product information and data sheets, visit Eaton.com/BussmannConsumer 41 Fast-acting cartridge fuses Midget fuses Midget fuses are 13/32” x 1-1/2” cartridge fuses in a wide variety of volt and amp ratings to provide supplemental protection to industrial, commercial, agricultural, heating, ventilating and air conditioning equipment. Small size midget fuses often protect control circuit wiring, motor control transformers or small motors. The National Electrical Code® (NEC®) now requires more protection of these components creating an increased replacement demand for these fuses. BAF 250 Vac fast-acting 13/32" x 1-1/2" midget fuses Amps 1 3 5 6 10 15 20 25 30 Catalog no.* BAF-1 BAF-3 BAF-5 BAF-6 BAF-10 BAF-15 BAF-20 BAF-25 BAF-30 * Refer to packaging spec file for individual fuse packaging options. KTK 600 Vac fast-acting 13/32" x 1-1/2" midget fuses Amps 1 2 3 4 5 6 10 15 20 25 30 Catalog no.* KTK-1 KTK-2 KTK-3 KTK-4 KTK-5 KTK-6 KTK-10 KTK-15 KTK-20 KTK-25 KTK-30 Did you know? There’s more Talk to your Bussmann series sales representative about other available amp ratings. Retail pack** BP/KTK-1 BP/KTK-2 BP/KTK-3 — BP/KTK-5 — BP/KTK-10 BP/KTK-15 BP/KTK-20 — BP/KTK-30 * 10 Fuses per shelf carton. ** 1 Fuse per pack, 5 packs per shelf carton. Class CC fuses The rejection Midget fuses are Class CC and are suitable for both branch circuit and supplemental protection. KTK-R 600 Vac fast-acting 13/32" x 1-1/2" Class CC branch circuit fuses Amps 1/2 1 2 3 4 5 6 8 10 12 15 20 25 30 Catalog no.* KTK-R-1/2 KTK-R-1 KTK-R-2 KTK-R-3 KTK-R-4 KTK-R-5 KTK-R-6 KTK-R-8 KTK-R-10 KTK-R-12 KTK-R-15 KTK-R-20 KTK-R-25 KTK-R-30 * Refer to packaging spec file for individual fuse packaging options. 42 For product information and data sheets, visit Eaton.com/BussmannConsumer Time-delay and Class G cartridge fuses FNM 250 Vac time-delay 13/32" x 1-1/2" midget fuses Catalog no.* 1/2 FNM-1/2 6/10 FNM-6/10 1 FNM-1 2 FNM-2 2-1/2 FNM-2-1/2 3 FNM-3 3-2/10 FNM-32/10 3-1/2 FNM-3-1/2 4 FNM-4 5 FNM-5 6 FNM-6 6-1/4 FNM-6-1/4 7 FNM-7 8 FNM-8 9 FNM-9 10 FNM-10 12 FNM-12 15 FNM-15 20 FNM-20 25 FNM-25 30 FNM-30 Amps See page 48 for available assortments. Retail pack** — — — BP/FNM-2 — — — — — BP/FNM-5 — — — — — BP/FNM-10 BP/FNM-12 BP/FNM-15 BP/FNM-20 — BP/FNM-30 * 10 Fuses per shelf carton. ** 2 Fuses per pack, 5 packs per shelf carton. FNQ 500 Vac time-delay 13/32" x 1-1/2" midget fuses Amps 1/2 1 1-1/2 2 2-1/2 3 4 5 6 7 8 10 12 15 20 25 30 Catalog no.* FNQ-1/2 FNQ-1 FNQ-11/2 FNQ-2 FNQ-2-1/2 FNQ-3 FNQ-4 FNQ-5 FNQ-6 FNQ-7 FNQ-8 FNQ-10 FNQ-12 FNQ-15 FNQ-20 FNQ-25 FNQ-30 * 10 Fuses per shelf carton. FNQ-R Amps 1/2 1 2 3 4 5 6 6-1/4 7-1/2 8 10 12 15 20 30 600 Vac time-delay 13/32" x 1-1/2" Class CC branch circuit fuses Catalog no.* FNQ-R-1/2 FNQ-R-1 FNQ-R-2 FNQ-R-3 FNQ-R-4 FNQ-R-5 FNQ-R-6 FNQ-R-6-1/4 FNQ-R-7-1/2 FNQ-R-8 FNQ-R-10 FNQ-R-12 FNQ-R-15 FNQ-R-20 FNQ-R-30 * 10 Fuses per shelf carton. SC Specialty Class G rejection fuses •• 600 Vac fast-acting (1⁄2-6 A) •• 600 Vac time-delay (7-20 A) •• 480 Vac time-delay (25-60 A) Amps 2 3 5 6 8 10 15 20 25 30 40 60 Fuse Length 1.31” 1.31” 1.31” 1.31” 1.31” 1.31” 1.31” 1.41” 1.62” 1.62” 2.25” 2.25” Catalog no.* SC-2 SC-3 SC-5 SC-6 SC-8 SC-10 SC-15 SC-20 SC-25 SC-30 SC-40 SC-60 Retail pack** — — — — — — BP/SC-15 BP/SC-20 BP/SC-25 BP/SC-30 — — * 10 Fuses per shelf carton. ** 2 Fuses per pack, 5 packs per shelf carton. These highly compact branch circuit fuses are used in residential, mobile home and industrial applications. They have a minimum 300 volt rating and are available up to 60 A. All SC fuses are 13/32” in diameter with varying lengths to provide a rejection feature that prevents over fusing (installing a 30 amp fuse in a 20 A circuit). One half to 6 A SC fuses are fast-acting, while 7 to 60 A SC fuses are time-delay to permit temporary overloads to pass without nuisance openings. See page 48 for available assortment. For product information and data sheets, visit Eaton.com/BussmannConsumer 43 Plug fuses, adapters and circuit breakers Plug fuses Type T Plug fuses thread into receptacles. Two types of threaded fuses are available: Edison base (brass) and rejection base (porcelain). The two are not interchangeable. TL and SL medium-duty fuses are regular duty fuses. T and S are heavy duty fuses for more demanding applications with high inrush currents. They feature a dual-element design that provides superior short-circuit and overload protection. 125 Vac dual-element, time-delay, Edison base plug fuses Plug fuses are often used in residential applications to protect furnace blower motors, pumps, power tools, garage door openers, etc. Edison base plug fuses for motor protection are often used in conjunction with branch circuit protection and located in a box cover unit (see page 46). Plug fuses provide a compact and economical method to prevent electric motor damage, reduce downtime and lower maintenance costs by opening when an overload is present. When used for residential branch circuit protection, fuses are typically located in the main fuse panel. Heavy duty T fuses are used for air conditioners, furnace blower motors, swimming pool pumps, deep freezers or any circuit where motors frequently turn ON and OFF. The T plug fuse is an industrial strength and provides superior protection that will resist nuisance openings under repeated motor startups. Available in a wide amp range to permit exact sizing to motor load. Catalog Amps no.* 1-1/4 T-1-1/4 1-6/10 T-1-6/10 3-2/10 T-3-2/10 4 T-4 5 T-5 6-1/4 T-6-1/4 8 T-8 10 T-10 12 T-12 15 T-15 20 T-20 25 T-25 30 T-30 Retail pack** — — BP/T-3-2/10 — — BP/T-6-1/4 BP/T-8 BP/T-10 BP/T-12 BP/T-15 BP/T-20 BP/T-25 BP/T-30 * 4 fuses per box, 25 packs per shelf carton. ** Less than 15 amps, 1 fuse per pack, 15 to 30 amps, 2 fuses per pack, 5 packs per shelf carton. Edison base plug fuses The Edison base plug fuse uses the same thread as a light bulb base. All ampacities will fit the same fuse receptacle. To help prevent overfusing a circuit — installing a fuse with a greater amp rating than the circuit can handle — it is recommended to install the correctly sized SA rejection base fuse adapter and use a correctly rated S or SL fuse. Type BP/MB 125 Vac Edison base UL circuit breakers For replacing Edison base plug fuses in residential fuse panels. Not for use in box cover units. Amps 15 20 Retail pack* BP/MB-15 BP/MB-20 * 1 Circuit breaker per pack, 5 packs per shelf carton. Type TL 125 Vac time-delay Edison base plug fuses Catalog no.* TL-15 TL-20 TL-25 TL-30 Retail box* TL-15PK4 TL-20PK4 TL-25PK4 TL-30PK4 Retail pack** BP/TL-15 BP/TL-20 BP/TL-25 BP/TL-30 Medium duty TL fuses are used for residential motor * 4 Fuses per box. circuits in kitchens, ** 3 Fuses per pack, 5 packs per shelf carton. workshops, garages and utility rooms. See page 48 for available emergency kits. 44 Amps 15 20 25 30 For product information and data sheets, visit Eaton.com/BussmannConsumer Plug fuses, adapters and circuit breakers Rejection base plug fuses CSA Edison base plug fuses The rejection base threads prevent installing a larger amp fuse, e.g., a 30 amp fuse cannot be installed in a 20 amp receptacle. The base is the same as a light bulb base. All sizes fit the same fuse receptacle. Type S 125 Vac dual-element, time-delay, rejection base plug fuses UL and CSA heavy-duty S fuses are for use in air conditioners, furnace blower motors, swimming pool pumps, deep freezers or where motors frequently turn ON and OFF. The S rejection base plug fuse is an industrial strength product and provides superior protection that will resist nuisance openings under repeated motor startups. Available in a wide amp range to permit exact sizing to motor load. Amps 11/4 16/10 2-1/2 3-2/10 3-1/2 4 5 6-1/4 7 8 10 12 15 20 25 30 Catalog no.* S-11/4 S-16/10 S-2-1/2 S-3-2/10 S-3-1/2 S-4 S-5 S-6-1/4 S-7 S-8 S-10 S-12 S-15 S-20 S-25 S-30 Retail pack** BP/S-11/4 BP/S-16/10 — BP/S-32/10 — — — BP/S-6-1/4 — BP/S-8 BP/S-10 BP/S-12 BP/S-15 BP/S-20 BP/S-25 BP/S-30 * 4 Fuses per box. ** Less than 15 amps, 1 fuse per pack; 15 to 30 amps, 2 fuses per pack, 5 packs per shelf carton. Type TC 125 Vac CSA Type D dual-element time-delay Edison base plug fuses Heavy duty TC fuses are used for residential motor circuits in kitchens, workshops, garages and utility rooms. 125 Vac time-delay, rejection base plug fuses SL fuses for residential motor circuits in kitchens, workshops, garages and utility rooms. Amps 15 20 25 30 Catalog no.* SL-15 SL-20 SL-25 SL-30 Retail box* SL-15PK4 SL-20PK4 SL-25PK4 SL-30PK4 Retail pack** BP/SL-15 BP/SL-20 BP/SL-25 BP/SL-30 Retail box* TC-15PK4 TC-20PK4 TC-25PK4 TC-30PK4 Retail pack** BP/TC-15 BP/TC-20 BP/TC-25 BP/TC-30 * 4 Fuses per box. ** 2 Fuses per pack, 5 packs per shelf carton. See page 48 for available emergency kits. Type P Type SL Amps 15 20 25 30 125 Vac CSA Type P dual-element one-time Edison base plug fuses Medium-duty P fuses are used for non-inductive loads such as lighting and heating circuits. Amps 15 20 25 30 Retail box* P-15PK4 P-20PK4 P-25PK4 P-30PK4 Retail pack** BP/P-15 BP/P-20 BP/P-25 BP/P-30 * 4 Fuses per box. ** 2 Fuses per pack, 5 packs per shelf carton. * 4 Fuses per box. ** 3 Fuses per pack, 5 packs per shelf carton. See page 48 for available emergency kits. See page 48 for available emergency kits. Type CP/MB Type SA Fustat adapters for using S and SL rejection plug fuses in Edison base sockets Amp range 1 or less 1.25 or less 1.6 or less 3.5 to 6.25 7 to 15 20 20 to 30 Catalog no.* SA-1 SA-1-1/4 SA-1-6/10 SA-6-1/4 SA-15 SA-20 SA-30 Retail pack** — — — — BP/SA-15 BP/SA-20 BP/SA-30 125 Vac CSA Edison base circuit breakers For replacing Edison base plug fuses in residential fuse panels. Not for use in box cover units. Amps 15 20 Retail pack* CP/MB-15 CP/MB-20 * 1 Circuit breaker per pack, 5 packs per shelf carton. SA adapters convert Edison base receptacles to accept a * 4 SA Adapters per box. rejection base fuse. SA ** 3 SA Adapters per pack, 5 packs per shelf adapters limit the fuse amp carton. rating that can be installed to protect circuits from being overfused and are available in a variety of sizes to deliver the desired fuse rejection. See page 48 for available assortment. For product information and data sheets, visit Eaton.com/BussmannConsumer 45 Box cover units and Type 1 SPD Box cover units For supplemental circuit and small motor protection Box cover units are available in a variety of styles that fit standard electrical boxes, to provide an efficient and economical method to protect motors from overloads. Often, branch circuit protection cannot protect small motors, e.g., a 6-1/4 amp rated motor will likely burn up before a 30 amp breaker trips. A box cover unit permits using a fuse sized close to the motor’s load so that it opens when the motor draws too much current. Catalog no* Retail pack** Max Hp/volts/amps SOU BP/SOU 3/4 Hp/125 Vac/15 A Box type 2-1/4” handy SRU BP/SRU 1/2 Hp/125 Vac/15 A 2-1/4” handy SSN — 1/2 Hp/125 Vac/15 A SSU BP/SSU 1/2 Hp/125 Vac/15 A SSY BP/SSY† 1/2 Hp/125 Vac/15 A Single gang 2-1/4” handy 4” square SSY-RL — 1/2 Hp/125 Vac/15 A 4” square STY — 1/2 Hp/125 Vac/15 A 4” square Description Fuse holder only Fuse holder/ three-prong receptacle Weatherproof fuse holder/switch Fuse holder/switch Fuse holder/switch Fuse holder/switch, three-prong receptacle and switch light Twin fuse holders/double pole switch * 1 Box cover unit per pack, 10 packs per shelf carton. ** 1 Box cover unit per pack, 3 packs per shelf carton. † 1 Box cover unit per pack, 2 packs per shelf carton. SOU SRU SSU SSY SSY-RL STY * SSN * Double pole switch opens both sides of the circuit. Can be used for two separate motors with common switch or a single motor (3/4 Hp, 250 Vac max.) SurgePOD™ PRO Type 1 power surge protective device The value Type 1 SPD for sensitive residential applications •• Type 1 UL and cULus Listed 1449 4th Edition SPD is easily installed on the loadside or lineside of the service entrance overcurrent protective device. •• For 240 Vac, split-phase electrical systems. •• 200 kA SCCR. •• Compact UV resistant NEMA 4X enclosure for indoor or outdoor applications. •• easyID LED status indicators provide surge protection status at a glance. •• Voltage specific model protects electrical systems, equipment, appliances and consumer electronics better than “One-Size-Fits-All” economy SPDs. •• Two-year warranty (see warranty statement 3A1502 for details). •• Thermal disconnect MOV technology eliminates the need for additional fusing. See data sheet No. 10033 for technical specifications. Retail pack* RB-SPP-240PN System voltage 240 Vac Description Split-phase, 3 wire, 3 connection points * 1 SurgePOD PRO per pack, 4 packs per master carton. 46 For product information and data sheets, visit Eaton.com/BussmannConsumer Accessories Automotive blade and glass tube fuse pullers and testers NON and FRN-R 250 volt fuse reducers Remove automotive fuses quickly and easily with the FP-A3 fuse puller. The innovative tool design lets you remove or install both blade-type and glass fuses. Fuse reducers allow a smaller size fuse to be installed in a fuse block intended for a larger fuse. For example: a 30 amp fuse is two inches long and will not fit into a 60 amp fuse block (which is three inches between clips). A NO.263 reducer installed on the fuse permits it to be installed in a 60 amp fuse block. Reducers are particularly useful when equipment is being converted. Proper protection can be maintained without the expense of replacing the fuse block. Catalog numbers with the “-R” suffix (NO.263-R) fit rejection Class R fuse blocks. Consult your Bussmann™ series sales rep or distributor for 600 volt and Class J reducers. The FT-3 combination fuse tester/puller is designed for easy one-handed testing of glass and blade fuses. Light glows when fuse is good. Cartridge fuse pullers Bussmann series cartridge fuse pullers are heavy-duty tools for safely removing fuses from their blocks. Can be used with all cartridge fuses matching fuse diameter range. Catalog Retail no.* pack** Automotive fuse pullers FP-A3 BP/FP-A3-RP — BP/FT-2 FT-3 BP/FT-3-RP Cartridge fuse pullers FP-2 BP/FP-2 FP-3 BP/FP-3 FP-4 — FP-6 — Fuse block Fuse size Catalog no.* size (amps) (amps) NON 250 Vac Class H reducers NO.263 60 30 FRN-R 250 Vac Class R reducers NO.263-R 60 30 NO.216-R 100 60 NO.2621-R 200 100 Description Fuse puller only Fuse tester only Fuse puller and tester Puller Puller Puller Puller - *10 Fuse reducers per shelf carton. 1 to 60 A (13/32” to 1-3/16” Dia.) 70 to 200 A (1” to 1-1/4” Dia.) 225 to 600 A (1-3/4” to 2-1/2” Dia.) 0 to 60 A Class T fuses * FP-A3 and FT-3, 1 fuse puller per pack, 10 packs per shelf carton. ** 1 Fuse puller per pack, 5 packs per shelf carton. FP-A3 FP-2 FT-2 FP-3 NO.263 NON fuse reducer NO.263-R 60/30 A FRN-R fuse reducers NO.216-R 100/60 A FRN-R fuse reducers NO.2621-R 200/100 A FRN-R fuse reducers FT-3 FP-4 FP-6 For product information and data sheets, visit Eaton.com/BussmannConsumer 47 Hardware packaging and assortments Retail hardware fuse assortments Retail hardware holiday light fuses Popular fuse assortments and kits to meet the needs of residential circuit protection. BP/ABC-A Microwave oven fuse assortment, ABC-10, (2)15 and (2)20 A BP/FNM-AH High amp FNM cartridge fuse assortment: FNM-15 and 20 A BP/FNM-AL Low amp FNM cartridge fuse assortment: FNM-5 and 10 A BP/FRN-AH High amp FRN-R Class RK5 fuse assortment: FRN-R-35 and 50 A BP/FRN-AL Low amp FRN-R Class RK5 fuse assortment: FRN-R-15 and 25 A BP/GMA-AH High amp GMA electronic glass tube fuse assortment: two each GMA-3, 5 and 6 A BP/GMA-AL Low amp GMA electronic glass tube fuse assortment: two each GMA-500 MA, 1 and 2 A BP/MDL-AL Low amp MDL electronic glass tube fuse assortment: one each MDL-1⁄2, 1, 2, 3, 5 BP/NON-AL Low amp NON cartridge fuse assortment: NON-15 and 25 A BP/SA-A Fustat rejection base plug fuse adapter assortment: SA-15 and 20 A BP/SC-A SC Class G fuse assortment: SC-15 and 20 A HEF-1 Mobile phone, electronic equipment and stereos assortment: (2)AGC-1, (1)2 and (2)3 A. HEF-2 Computers and peripherals assortment: MDL-1/2, 1 and 2 A; GDC-1 and 2 A Useful year-round, these fuses come in handy for keeping the lights on and the festivities going strong. Retail hardware fuse emergency kits NON-EK SL-EK TL-EK TC-EK P-EK NON cartridge fuse kit: 20, (2)30, 40 and (2)60 A and FT-2 fuse tester SL rejection base plug Fuse kit: (3)15, (2)20 and 30 A and FT-3 fuse tester/puller TL Edison base plug fuse kit: 15, (2)20 and (3)30 A and FT-3 fuse tester/puller CSA Type D Edison base plug fuse kit: (3)15, (1)20, (2)30 A and FT-3 fuse tester/puller CSA Type P Edison base plug fuse kit: (3)15, (1)20, (2)30 A and FT-3 fuse tester/puller Year-round holiday and party light fuses BP/MAS-3A* MAS 3x10 mm fast-acting 3 amp fuses. Five fuses per pack. BP/GMA-5A* GMA 5x20 mm fast-acting 5 amp fuses. Two fuses per pack. BP/MAS-3A-CS One carton of 10 BP/MAS-3A with clip strip included. *Five packs per shelf pack. Christmas light counter displays with two clip strips* BP/GMA-5XM BP/MAS-3X5 GMA 5x20 mm fast-acting 5 amp fuses. Five fuses per pack. MAS 3x10 mm fast-acting 3 amp fuses. Five fuses per pack. BP/AGX-7X5 AGX 1/4” x 1-1/4” fast-acting 7 amp fuses. Five fuses per pack. BP/XMAS-6F AGC-7, AGX-7, (2)GMA-5 and MAS-3 A fuses. Assortment Total five fuses per pack. *20 Packs per display. 20-pack counter display with clip strips BP/GMA-5XM Look for new holiday graphics to order for the 2018 season. BP/MAS-3X5 48 BP/MAS-3A For product information and data sheets, visit Eaton.com/BussmannConsumer BP/GMA-5A Hardware Plan-O-Gram Retail hardware Plan-O-Gram Color-coded packaging for fast, easy product selection. Fits standard three-foot wide gondola. Visual categorization •• Color-coded Bussmann series retail packaging. •• Fast and easy product identification. •• Provides increased shopability and faster merchandising. Merchandising ease •• Retail set is simple and straightforward. •• Color-coding encourages return of product to correct gondola peg. •• Reduces need for assistance by store personnel. 3FTHDWR-TAGS UPC reorder tags. Consumer friendly •• Fuse center is easily located. •• Point-of-sale identifies fuse types. •• Package color codes identify product category. Catalog no. 3FTHDWR-KIT 3FTHDWR-TAGS Description Three foot hardware/electrical SKU prepak. Prepak includes header and reorder tags for all SKUs. Replacement set of UPC reorder tags for the 3FTHDWR-KIT. Allows for creating a custom Plan-O-Gram. Order tags through your Eaton Bussmann series rep. 3FTHDWR-KIT. Peg hooks and gondola not included. For details on hardware Plan-O-Gram product SKUs, visit Eaton.com/BussmannConsumerPOG New hardware Plan-O-Gram coming in 2017 For product information and data sheets, visit Eaton.com/BussmannConsumer 49 Circuit protection specifications Fuse type Catalog symbol ATL Class Constuction/ size Volts Amps IR ­— 3-leg micro blade fuse 32 Vdc 5-15 1 kA Miniature blade fuse Fast-acting — — — X — — X — 32 Vdc 1-30 1 kA Fast-acting — 32 Vdc 2-30 1 kA Fast-acting — — — X — ATC/ATC-_ID* — 32 Vdc 1-40 1 kA Fast-acting — E56412 J1284 X — ATR — 32 Vdc 5-30 1 kA Fast-acting — — — X — MAX/MAX-_ID* — 32 Vdc 20-100 1 kA Fast-acting — — — X — 35 A 100 A 200 A 750 A 400 A 200 A Fast-acting E19180, 1/4-15 A E19180, — 18-30 A X 53787, 1/4-30 A ATM/ATM-_ID* — *easyID illuminating version ATM_LP ABC — 1/4" x 1-1/4" ceramic 250 Vdc 1/4-1 1-1/2-3 4-10 12-15 20 25-30 AGA — 1/4" x 5/8" 125 Vac 125 Vac 32 Vac 1-1-1/2 2-5 6-30 10 kA 200 kA 1 kA Fast-acting E19180, 0-3 1/2 A JDYX2, — 12-30 A — — 1/20-1 1-1/4-3 4-10 12-30 35 40-50 35 A 100 A 200 A 1 kA 70 A 80 A Fast-acting E19180, 0-10 A E19180, — 12-30 A X 053787, 1/20-30 A 1-3 A 4-60 A 10 kA 10 KA Fast-acting — — — — — AGC — 1/4" x 1-1/4" 250 Vac 250 Vac 250 Vac 32 Vac 32 Vac 32 Vac AGU AGU-(amp)GP Midget Glass tube ferrule 13/32" x 1-1/2" 250 Vac 32 Vac AGW — 1/4" x 7/8" 32 Vac 1-30 A 1 kA Fast-acting — — — — — — 1/4" x 1-1/4" 250 Vac 250 Vac 125 Vac 125 Vac 32 Vac 1/500-1/2 A 3/4-2 A 2-1/2-5 A 6-7 A 8-30 A 35 A 100A 100 A 1 kA 1 kA Fast-acting E19180, 0-10 A E19180, — 15-30 A X 53787, 15-30 A GBB — 1/4" x 1-1/4" ceramic 250 Vac 125 Vac 1-30 A 1-15 A 200 kA 10 kA Fast-acting — E56412, 1-30 A, — 125 Vdc/ 250 Vac X 53787, 1-30 A, 125 Vdc/ 250 Vac GBC — 1/4" x 31/32" 32 V 5-25 A — Fast-acting — — — — — GDA — 5 x 20 mm ceramic 250 Vac 50 mA-6.3 A 1.5 kA Fast-acting — E19180 — X 53787 GDB — 5 x 20 mm 250 Vac 32 mA-16 A 35 A Fast-acting — E19180 — — — GDC — 5 x 20 mm 250 Vac 32 mA-6.3 A 35 A Fast-acting — E19180 — — — 5 x 20 mm 250 Vac 250 Vac 125 Vac 125 Vac 125 Vac 32 mA-1 A 1.2-3 A 3.15-6 A 7-10 A 15 A 35 A 100 A 1 kA 200 A 150 A Fast-acting E19180, 0-6 A E19180, — 7-15 A X 53787, 0-6 A 5 x 20 mm 250 Vac 250 Vac 125 Vac 125 Vac 63 mA-1 A 1.25-3.15 A 3.5-6.3 A 7-10 A 35 A 100 A 10 kA 200 kA E19180, Time-delay 0-6.3 A E19180, — 7-8 A X 53787, 0-6.3 A 5 x 20 mm 250 Vac 250 Vac 125 mA-3 A 4A 100 A 200 A E19180, E19180, — Time-delay 125 mA-3 A 4 A X 53787, 0-4 A 1/4" x 1-1/4" ceramic 250 Vac 250 Vac 250 Vac 250 Vac 125 Vac 1/4-1 A 1 1/2-2 A 2 1/2-10 A 12-15 A 20-30 A 35 A 100 A 200 A 750 A 1.5 kA Time-delay E19180, 0-20 A X 1422-30, 25-30 A AGX GMA GMC GMD MDA 50 RoHS CSA AU 169 2-30 A non— indicating ATM Blade Glass tube Type Agency file information UL UL SAE Rec List — — For product information and data sheets, visit Eaton.com/BussmannConsumer E19180, — 25-30 A Circuit protection specifications Fuse type Glass tube High amp *easyID illuminating version Current limiters Catalog symbol Class Constuction/ size Volts Amps IR Type Agency file information UL UL SAE Rec List RoHS CSA MDL — 1/4" x 1-1/4" 250 Vac 250 Vac 250 Vac 32 Vac 1/16-1 A 1 1/4-3 A 4-8 A 9-40 A 35 A 100 A 200 A 1 kA Time-delay E19180, 1/16-8 A E19180, — 9-30 A X E19180, 1/16-8 A MDQ — 1/4" x 1-1/4" 250 Vac 250 Vac 250 Vac 32 Vac 1/16-1 A 1 1/4-3 A 4-7 A 8-30 A 35 A 100 A 200 A 1 kA Time-delay E19180, 1/16-7 A E19180, — 7.1-30 A — 47233, 1/16-7 A SFE — 1/4" x various length 32 V 4-30 A — Fast-acting AU169 — — X — AMG — Bolt-in fuse 32 Vdc 80-500 A 1 kA — — — — X — AMI — Bolt-in fuse 32 Vdc 30-200 A 2 kA — — — — X — CBBF — Bolt-in 58 Vdc 30-300 A 2 kA — — — — — — FMM — Micro FMX fuse 32 Vdc 15-40 A 1 kA Time-delay — — — X — FMX, FMX_ID* — Female Maxi 6 mm blade on 5.5 mm centers 32 Vdc 20-60 A 1 kA Time-delay — — — X — FMX_LP Low-profile FMXfuse Low-profile 6 mm blade on 58 Vdc 5.5 mm centers 20-60 A 1 kA @ Time-delay — 32 Vdc — — — — MPF MPF2 Multi-amp 32 Vdc 58 Vdc 30-60 A 20-50 A 1 kA 1 kA — — — — — — — — X X — — ANN — Bolt-in fuse 2.44 mm blade centers 125 Vac/ 10 to 800 A 80 Vdc 2.5 kA Vac Very 2.7 kA Vdc fast-acting — E56412 — X 53787 ANL — Bolt-in fuse 2.44 mm blade centers 32 Vac/ 80 Vdc 35 to 750 A 6 kA Vac Non 2.7 kA Vdc time-delay — E56412 — X 53787 32 Vdc 32 Vdc 32 Vdc 30-140 A 30-140 A 20-60 A 10 kA 10 kA 10 kA — — — — — — — — — — — — X X X — — — 32 Vdc 50-80 A 10 kA — — — — X — 32 Vdc 32 Vdc 30-120 A 25-30 A 10 kA 10 kA — — — — — — — — X X — — 32 Vdc 30-40 A 10 kA — — — — X — 32 Vdc 80-250 A 1 kA — — — — X — RoHS CSA FLB FLD FLF FLG Auto cartridge fuses FLM FLN FLS — — — — — — — Bolt mount Bolt mount Female terminals Female terminals Male terminals Female terminals with lock tab Female mini terminals Battery terminal BTF fuses — Multi-amp Circuit Catalog breakers symbol SAE type Constuction/ size Volts Amps IR Type Agency file information UL UL SAE Rec List 150 A 225 A 300 A 450 A Automatic — — J553 — — CB211 I ATM footprint 14 Vdc 7-1/2-30 A 15 A 20 A 25-30 A CB212 II ATM footprint 14 Vdc 7-1/2-30 A 15 A 20 A 25-30 A 150 A 225 A 300 A 450 A Modified — — J553 — — II ATM offset footprint 14 Vdc 5-10 A 15 A 20 A 25-30 A 150 A 225 A 300 A 450 A Modified — — J553 — J1171 — CB223OS III ATM offset footprint 28 Vdc 5-10 A 15 A 20 A 25-30 A 150 A 225 A 300 A 450 A Manual — — J553 — J1171 — CB233 III ATM footprint 28 Vdc 5-10 A 15 A 20 A 25-30 A 100 A 150 A 200 A 300 A Manual — — J553 — — MMB I ATM footprint 12 Vdc 15-20 A 300 A Automatic — — J553 — — CB22OS ATM footprint For product information and data sheets, visit Eaton.com/BussmannConsumer 51 Circuit protection specifications Agency file information Circuit Catalog breakers symbol SAE type Constuction/ size ACB CB221 CB222 CB223 CB227 I I II III III CBB-30 CCB-25 FCB-20 UCB II I II I CB1911 MAXI footprint CB1921 Glass tube ATC footprint Volts Amps IR Type UL List UL Rec ATC footprint ATC footprint ATC footprint ATC footprint ATC footprint/ color coded ATC footprint ATC footprint ATC footprint ATC footprint/ color coded ­ — 14 Vdc 12 Vdc 28 Vdc 28 Vdc — 7-1/2-30 A 10-30 A 7-1/2-30 A 5-30 A — 150 A 150 A 150 A 2 kA Automatic Automatic Modified Manual Manual — — — — — 24 Vdc — 14.5 Vdc 12 Vdc 30 A 25 A 20 A 6-30 A — — — — Modified Automatic Modified Automatic I II MAX footprint MAX footprint 14 Vdc 12 Vdc 10-50 A 10-30 A 150 A* 150 A CBF II 1/4" x 1-1/4" 12 Vdc 6-40 A CB123-(amp)B III 28 Vdc CB123-(amp)HB III CBC I Stud CBC-(amp)B terminal Panel mount I CBC-(amp)BWP I CBC-(amp)HB I CBP-(amp)BA I CB174 III CBT-(amp)M II CBT-(amp)N II CBU-6 I CBU-30B I Quick connect High amp CB181F I CB184F III CB185 III CB185P III CB187F III CB187P III CB251 I CB255 III CB285 III 10-32 studs 0.69" centers 10-32 studs 0.69" centers 10-32 studs 0.69" centers 10-32 studs 0.69" centers 10-32 studs 0.69" centers 10-32 studs 0.69" centers 10-32 studs 0.69" centers 1/4" quick-connect terminals 1/4" quick-connect terminals 1/4" quick-connect terminals 1/4" quick-connect terminals 1/4" quick-connect terminals Flush-mt. waterproof 1/4-28 stud Flush-mt. waterproof 1/4-28 stud Flush-mt. waterproof 1/4-28 stud Flush-mt. waterproof 1/4-28 stud Panel-mt. weatherproof 5/16-18 stud Panel-mt. weatherproof 5/16-18 stud Panel-mt. weatherproof 10-32 stud Panel-mt. weatherproof 10-32 stud Flush-mt. waterproof M6 stud SAE RoHS CSA — — — — — J553, JH71 — — — — — — — — — — — — — — — — — — J553 J553 J553 J553 — — — — — — — — Automatic Modified — — J553 J553 — — — — — Modified — — — — — 10-50 A 1.5 kA@12 Vdc Manual — — — — 28 Vdc 10-50 A 1.5 kA@12 Vdc Manual — — — — 14 Vdc 8-50 A 1.5 kA Automatic — — — — 14 Vdc 8-50 A 1.5 kA Automatic — — — — 12 Vdc 20-30 A 1.5 kA Automatic — — — — 14 Vdc 10-50 A 1.5 kA Automatic — — — — 14 Vdc 20-50 A 1.5 kA Automatic — — — — 250 Vac/ 10-30 A 32 Vdc 200 A Manual — — — — — — 10-30 A — Modified — — — — — — 10-30 A — Modified — — — — — — 6A — Automatic — — — — — — 30 A — Automatic — — — — — 30 Vdc 60-150 A 3 kA Automatic — — 48 Vdc 25-150 A 3 kA Manual — — 48 Vdc 25-150 A 3 kA Manual — — 48 Vdc 25-150 A 3 kA Manual — — 48 Vdc 25-200 A 5 kA@ 12 Vdc Manual — — J553, J1171 J553, J1171 J553, J1171 J553, J1171 J553, J1171 48 Vdc 25-150 A 5 kA@ 12 Vdc Manual — — 32 Vdc 10-50 A 2.5 kA Automatic — 32 Vdc 10-50 A 2.5 kA Manual 42 Vdc 30-150 A 2.5 kA Manual * Interrupting rating varies with circuit breaker amp rating. 52 J553, J1171 J553, J1171 J553, J1171 J553, J1171 J553, J1171 J553, J1171 J553, J1171 For product information and data sheets, visit Eaton.com/BussmannConsumer X — X — — — X — — — J553, J1171 X — — J553, J1171 — — — — J553, J1171 — — — — J553, J1171 — — Circuit protection specifications Fuse type Plug Cartridge *easyID illuminating version Catalog symbol RoHS CSA 10 kA Time-delay E12112 — — — — 3/16-30 A 10 kA Heavy-duty time-delay E56412, 0-6-1/4 A E12112 7-30 A — — — 53787 125 Vac 15-30 A — — — — — 53787 125 Vac 15-30 A — Dual-element time-delay General purpose — — — — 53787 125 Vac 15-30 A 10 kA Time-delay E12112 — — — — 125 Vac 1/4-30 A 10 kA Heavy-duty time-delay E56412, 0-6-1/4 A E12112 7-30 A — — — 53787 250 Vdc 250 Vdc 250 Vdc 250 Vdc 125 Vdc 2/10-1 A 1 1/2-2 1/2 A 3-9 A 10-15 A 20-30 A 35 kA 100 kA 200 kA 750 kA 10 kA Fast-acting Fast-acting Fast-acting Fast-acting Fast-acting E19180 — — X 53787 — — — — C22.2, No.59.1 E19180 — — X 53787 Class Volts Amps IR TL — Edison thread base 125 Vac 15-30 A T — Edison thread base 125 Vac TC P CSA Type D CSA Type P SL — Edison thread base Edison thread base Rejection thread base S — Rejection thread base BAF Midget 13/32" x 1-1/2" ferrule CDN CSA Type D Ferrule style Blade style 250 Vac 250 Vac 1-60 A 70-600 A 10 kA 10 kA Gen. Purpose Time-delay FNM Midget 13/32" x 1-1/2" ferrule 250 Vac 250 Vac 250 Vac 125 Vac 1/10-1 A 1 1/8-3 1/2 A 4-10 A 12-30 A 35 kA 100 A 200 A 10 kA Time-delay FNQ Midget 500 Vac 1/10-30 A 10 kA Time-delay E19180 — — X 53787 FNQ-R CC 600 Vac 1/4-30 A 200 kA Time-delay E4273 — — X 53787 FRN-R FRN-R_ ID** RK5 250 Vac 250 Vac 1/10-60 A 70-600 A 200 kA 200 kA Time-delay E4273 — — — 53787 600 Vac 600 Vac 1/16-60 A 65-600 A 200 kA 200 kA Time-delay E4273 — — — 53787 300 Vac 110-400 A 200 kA Very fast-acting E4273 — — X 53787 600 Vac 1/10-30 A 100 kA Fast-acting E19180 — — X 53787 600 Vac 1/10-30 A 200 kA Fast-acting E4273 — — X 53787 250 Vac 250 Vac 600 Vac 600 Vac 250 Vac 250 Vac 600 Vac 1/8-60 A 65-600 A 1-60 A 70-600 A 1-60 A 70-600 A 1-6 A 50 kA 10 kA 50 kA 10 kA 10 kA 10 kA 100 kA General Purpose General Purpose General Purpose Fast-acting E4273 — — — 53787 E4273 — — — 53787 — — — — C22.2, No.59.1 600 Vac 7-15 A 100 kA Time-delay 600 Vac 20 A 100 kA Time-delay E4273 — — x 53787 480 Vac 25-30 A 100 kA Time-delay 480 Vac 35-60 A 100 kA Time-delay 13/32" x 1-1/2" ferrule 13/32" x 1-1/2" ferrule Ferrule style Blade style FRS-R FRS-R_ ID** RK5 Ferrule style (1-60 A) Blade style (64-600 A) JJN T Blade style KTK Midget KTK-R CC K5 H K5 H CSA Type P NON NOS PON SC Circuit breakers Type Agency file information UL UL SAE Rec List Constuction/ size G 13/32" x 1-1/2" ferrule 13/32" x 1-1/2" ferrule Ferrule style Blade style Ferrule style Blade style Ferrule style Blade style 13/32" x 15/16" ferrule 13/32" x 15/16" ferrule 13/32" x 1-13/32" ferrule 13/32" x 1-5/8" ferrule 13/32" x 2-1/4" ferrule Catalog symbol Constuction/ size Volts Amps BP/MB CP/MB Edison base plug thread CSA version 125 Vac 125 Vac 15 and 20 A 15 and 20 A IR Reset type Agency file information UL UL RoHS Rec List CSA — — Manual Manual E14942 — — 013089 For product information and data sheets, visit Eaton.com/BussmannConsumer — — — — 53 Part number index Catalog no. Page 12023A 33 12040816 17 12135072 16 12135171 16 13023A 33 1314A 32 1315A 32 15600-_-20 14 15600-_-21 14 15968-1 22 24023A 33 3FTHDWR-KIT 49 3FTHDWR-TAGS 49 4527053 17 4FTAUTO-KIT 29 4FTAUTO-TAGS 29 702 33 9523A 33 ABC-_ 36 ACB-20 17 AFC-225 29 AFC-90 29 AGA-_ 36 AGC-_ 36 AGC-EK 24 AGU-_ 37 AGU-_GP 37 AGW-_ 36 AGX-_ 36 AMG-_ 11 AMI-_ 11 ANL-_ 15 ANN-_ 15 ATC-_ 7 ATC-_RLD 7, 29 ATC-FHID 12 ATC-FP-AID 8, 25 ATC-ID-SK 8, 25 ATL-_ 7 ATM-_ 7 ATM-_LP 7 ATM-_RLD 7, 29 ATM-FHID 12 ATM-FMX-EK 25 ATM-FP-AID 8, 25 ATM-ID-SK 8 ATM-LP-EK 25 ATR-_ 7 BAF-_ 42 BK/ATC-_ 7 BK/ATC-_ID 8 BK/ATL-_ 7 BK/ATM-_ 7 BK/ATM-_ID 8 BK/ATM-_LP 7 BK/CB-CVR 19, 32 BK/CCB-_ 17 BK/FMM-_ 9 BK/MAX-_ 7 BK/MAX-_ID 8 BK/MPF2-_X 9 BK/MPF-_X 9 BK/UCB-_ 17 BMS-_ 22 BP/15600-_-_ 14 BP/232-RP 23 BP/233-RP 23 BP/234-RP 23 BP/550-RP 23 BP/552-RP 23 BP/575-RP 23 BP/577-RP 23 BP/726-RP 23 BP/727-RP 23 BP/756-RP 23 BP/757-RP 23 BP/758-RP 23 BP/759-RP 23 BP/760-RP 23 BP/761-RP 23 BP/762-RP 23 BP/ABC-_ 36 BP/ABC-A 48 BP/AGA-_-RP 36 BP/AGA-AH8-RP 24 BP/AGA-AL8-RP 24 BP/AGC-_-RP 36 BP/AGC-A5-RP 24 BP/AGC-AH10-RP 24, 31 BP/AGC-AL10-RP 24 BP/AGC-SFE-A5-RP 24, 31 BP/AGU-_RP 37 BP/AGU-_GP-RP 37 BP/AGW-_-RP 36 BP/AGW-A8-RP 24 BP/AGX-7X5 48 54 Catalog no. Page BP/AGX-A8-RP 24 BP/AMG-_-RP 11 BP/ATC-_ID 8 BP/ATC-_-RP 7 BP/ATC-A5-RP 25 BP/ATC-AH8-RPP 25 BP/ATC-AID 8, 25 BP/ATC-AL8-RP 25 BP/ATC-FHID 12 BP/ATC-TAP-RP 13 BP/ATL-A4-RPP 25 BP/ATM-_ID 8 BP/ATM-_LP-RP 7 BP/ATM-_-RP 7 BP/ATM-A5-RP 25 BP/ATM-A6LP-RP 25 BP/ATM-A8-RP 25 BP/ATM-AH8-RPP 25 BP/ATM-AID 8, 25 BP/ATM-AL8-RP 25 BP/ATM-FHID 12 BP/ATM-TAP-RP 13 BP/ATR-_-RP 7 BP/ATR-A7-RPP 25 BP/BMS-_ 22 BP/C1938 21 BP/C5237-_BC 21 BP/CB185-_ 31 BP/CB_HB-CVR 19, 32 BP/CB211-_-RP 16 BP/CBB-30-RP 17 BP/CBC-_B-RP 18 BP/CBC-_HB-RP 19, 32 BP/CBF-_-RP 18 BP/CBP-_BA-RP 19 BP/CDN_ 41 BP/FB_ 14 BP/FCB-20 17 BP/FL-14 15 BP/FL-16 15 BP/FLB-_-RP 10 BP/FLD-_-RP 10 BP/FLF-_-RP 10 BP/FLG-_-RP 10 BP/FLM-_-RP 10 BP/FLN-_-RP 10 BP/FLS-_-RP 10 BP/FLW-14 15 BP/FMM-_-RP 9 BP/FMX-_ID 8 BP/FMX-_LP-RP 9 BP/FMX-_-RP 9 BP/FNM-_ 43 BP/FNM-AH 48 BP/FNM-AL 48 BP/FP-2 47 BP/FP-3 47 BP/FP-A3-RP 47 BP/FRN-AH 48 BP/FRN-AL 48 BP/FRN-R-_ 40 BP/FRN-R-_ID 40 BP/FRS-R-_ 41 BP/FT-2 47 BP/FT-3-RP 47 BP/GBC-_-RP 37 BP/GBC-A8-RP 24 BP/GDC-5A 38 BP/GMA-_A 38 BP/GMA-5A 48 BP/GMA-5XM 48 BP/GMA-AH 48 BP/GMA-AL 48 BP/GMC-_ 38 BP/HFB-RP 13 BP/HHA-RP 13 BP/HHB-RP 13 BP/HHC-RP 12 BP/HHD-30-RP 12 BP/HHD-RP 12 BP/HHF-RP 12 BP/HHG-RP 12 BP/HHH-RP 13 BP/HHK-RP 13 BP/HHLP-RP 13 BP/HHL-RP 12 BP/HHM-RP 12 BP/HHN-RP 13 BP/HHR 12 BP/HHTR-RP 13 BP/HHU 12 BP/HKP-HH-RP 13 BP/HMJ-RP 13 BP/HMK-RP 13 BP/HRK-RP 13 BP/JB3816-2 21 Catalog no. Page BP/KTK-_ 42 BP/MAS-3A 48 BP/MAS-3A-CS 48 BP/MAS-3X5 48 BP/MAX-_ID 8 BP/MAX-_-RP 7 BP/MB-_ 44 BP/MDL-_ 31, 37 BP/MDL-AL 48 BP/NON-_ 39 BP/NON-AL 48 BP/P-_ 45 BP/PON_ 41 BP/S-_ 45 BP/S-_-_RP 14 BP/SA-_ 45 BP/SA-A 48 BP/SC-_ 43 BP/SC-A 48 BP/SDA 22 BP/SDN 22 BP/SFE-_-RP 37 BP/SFE-AH6-RP 24 BP/SFE-AL6-RP 24 BP/SL-_ 45 BP/SOU 46 BP/SRA 22 BP/SRB 22 BP/SRG 22 BP/SRN 22 BP/SRR 22 BP/SRU 46 BP/SSU 46 BP/SSY 46 BP/STA 22 BP/STB 22 BP/STC 22 BP/STE 22 BP/STF 22 BP/STG 22 BP/STJ 22 BP/STK 22 BP/STN 22 BP/STR 22 BP/STT 22 BP/T-_ 44 BP/TB_-_-RP 21 BP/TC-_ 45 BP/TL-_ 44 BP/UCB-_-RP 17 BP/XMAS-6F 48 BTF-_P-_ 11 CB-CVR 19, 32 CB123-_B 18 CB123-_HB 18, 19 CB174-_ 19 CB181F-_ 20 CB184F-_ 20 CB185-_ 20, 31 CB185P-_ 20 CB187F-_ 31 CB187P-_ 31 CB1911-_ 18 CB1921-_ 18 CB211-_ 16 CB212-_ 16 CB221-_ 17 CB222-_ 17 CB222OS-_ 16 CB223-_ 17 CB223OS-_ 16 CB227-_ 17 CB22901-1.5 16 CB22902-68 16 CB22903-6 16 CB22903-6V 16 CB233-_ 16 CB251-_ 31 CB255-_ 31 CB285F-_ 20 CBB-30 17 CBBF-_ 11 CBBF-MCB 11 CBC-_ 18 CBC-_B 18 CBC-_BWP 19 CBC-_HB 19 CBF-_ 18 CBP-_BA 19 CBPFM 14 CBPRM 14 CBT-_M 19 CBT-_N 19 CBU-30B 19 CCB-25 17 CDN_ 41 Catalog no. Page CDY10TRY-___ 27, 28 CDY5TRY-___ 27, 28 CP/MB-_ 45 D9AB-14526-BA 17 DIA-1 25 DIA-2 25 DIA-3 25 FCB-20 17 FLB-_ 10 FLD-_ 10 FLF-_ 10 FLG-_ 10 FLM-_ 10 FLN-_ 10 FLS-_ 10 FMM-_ 9 FMX-_ 9 FMX-_LP 9 FNM-_ 43 FNQ-_ 43 FNQ-R-_ 43 FP-2 47 FP-3 47 FP-4 47 FP-6 47 FP-A3 47 FRN-R-_ 40 FRN-R-_ID 40 FRS-R-_ 41 FRS-R-_ID 41 FT-3 47 FUSE-CADDY1 27, 28 FUSE-CADDY2 27, 28 GBB-_-R 36 GBC-_ 37 GDA-_A 38 GDB-_A 38 GDC-_A 38 GMA-_A 38 GMC-_A 38 GMD-_A 38 HEF-1 48 HEF-2 48 HFA 13 HFB-R 13 HH2 12 HHB 13 HHC 12 HHD 12 HHF 12 HHG 12 HHK 13 HHL 12 HHM 12 HHN 13 HHR 12 HHU 12 HHX 12 HKP 13 HKP-HH 13 HLR 13 HMEG 11 HMID 11 HMJ 13 HMK 13 HRH 13 HRI 13 HRJ 13 HRK 13 HTB-26I 13 HTB-38I 13 HTB-68I 13 HTB-88I 13 JB3816-_ 21 JJN-_ 32 KTK-_ 42 KTK-R-_ 42 MA-5 24, 31 MAX-_ 7 MAX-FHID 12 MDA-_ 37 MDL-_ 37 MDQ-_ 37 MMB-_ 16 MPF2-_X 9 MPF-_X 9 NO.105 26 NO.108BK 31 NO.136 26 NO.160BK 26 NO.216-R 47 NO.225 29 NO.227 29 NO.232 23 NO.233 23 NO.234 23 For product information and data sheets, visit Eaton.com/BussmannConsumer Catalog no. Page NO.24 25 NO.243 23 NO.244 23 NO.246 23 NO.2621-R 47 NO.263 47 NO.263-R 47 NO.290 27 NO.43 25 NO.44 25 NO.45 26 NO-455 23 NO-468 23 NO-470 23 NO-487 23 NO.53 25 NO.535 23 NO.550 23 NO.552 23 NO.575 23 NO.577 23 NO.60LP 26 NO.64 25 NO.726 23 NO.727 23 NO-727-LED 23 NO-750-LED 23 NO.756 23 NO.757 23 NO.758 23 NO-758-LED 22 NO.759 23 NO.760 23 NO-760-LED 23 NO.761 23 NO.762 23 NO-762-LED 23 NO.763 23 NO.764 23 NO.80 25 NO.850 23 NO.852 23 NO.95BK 26 NON-_ 39 NON-EK 48 NOS-_ 39 P-_PK4 45 P-EK 48 PON_ 41 RB-BI-120A 33 RB-BI-130A 33 RB-BI-240A 33 RB-BI-70A 33 RB-BI-95A 33 RB-BIK-1882 33 RB-BS-1314 32 RB-BS-1315 32 RB-GM-KIT 33 RB-SPP-240PN 46 RTMF 14 RTMF-_ 14 S-_ 45 S-8202-_ 15 S-8301-_ 15 SA-_ 45 SC-_ 43 SFE-_ 37 SFR 15 SL-_ 45 SL-_PK4 45 SL-EK 48 SOU 46 SRU 46 SSN 46 SSU 46 SSY 46 SSY-RL 46 STY 46 T-_ 44 TB200-_B 21 TB300-_B 21 TC-_PK4 45 TC-EK 48 TL-_ 44 TL-_PK4 44 TL-EK 48 UCB-_ 17 VP/ATC-_ID 8 VP/ATC-_-RP 7 VP/ATM-_ID 8 VP/ATM-_LP-RP 7 VP/ATM-_-RP 7 VP-FMX-A5-RP 25 Customer satisfaction team: Emergency and after-hours orders: My.Eaton.com: Application engineering: Available to answer questions regarding Bussmann series products and services MondayFriday, 7:00 a.m. — 6:00 p.m. Central time. Next flight out or will call shipment for time-critical needs. Customers pay only standard product price, rush freight charges, and modest emergency service fee. Place these orders through the customer satisfaction team during regular business hours. Provides real time product availability, net pricing, order status and shipment tracking. Log onto my.eaton.com or call: Technical assistance is available to all customers. Application support is available MondayFriday, 7:00 a.m. — 5:00 p.m. Central time. •• Toll-free phone: 855-287-7626 (855-BUSSMANN) •• Toll-free fax: 800-544-2570 •• Email: busscustsat@eaton.com •• •• 1-800-468-1705 Option #3 for log-in assistance. •• Toll-free phone: 855-287-7626 (855-BUSSMANN) •• Email: Fusetech@eaton.com After hours: 314-995-1342 Eaton, Bussmann, ATC, easyID, Fusetron and MAXI are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 5084 February 2017 Chrysler is a registered trademark of FCA US LLC. Delco is a registered trademark of General Motors. CSA is a registered trademark of the Canadian Standards Group. Ford is a registered trademark of Ford Motor Company. Mack is a registered trademark of Mack Trucks, Inc. Navistar is a registered trademark of the International Truck and Engine Corporation. Nissan and Infiniti are registered trademarks of Nissan North America, Inc. Toyota is a registered trademark of Toyota Motor Corporation. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/BussmannConsumer Follow us on social media to get the latest product and support information.
ATR-10 价格&库存
很抱歉,暂时无法提供与“ATR-10”相匹配的价格&库存,您可以联系我们找货
