TB300-06QC2
TB300-06QC2
    EATON(伊顿)
    9.53MM 2X12P
TB300-06QC2 数据手册
Connector products — 10 Section page Description Connector products to simplify wiring Compact rail and panel mount blocks NDN DIN-Rail and C-Rail feed through blocks 2-3 N512, NFT2, NFT3, NC3, NSE3, NSS3 C-Rail feed through blocks 4-5 15188, PLU3, PLU1, PSU1 depluggable DIN-Rail and C-Rail blocks 6-7 KT3, KT4 multi-pole panel mount blocks 7 BNQ21, BQQ41 quick-connect panel mount blocks 8 Power feed through terminal blocks C7021 1- to 6-pole block 9 Double row terminal blocks TB100 2- to 36-pole blocks 10-11 TB200 and TB200HB 2- to 30-pole blocks 12-13 TB300 and TB345 2- to 24-pole blocks 14-15 Accessories for double row terninal blocks Marking options and covers 16 Top and bottom marking strips for terminal blocks 17 Double row terminal blocks continued TB400 2- to 12-pole blocks 18 KU 2- to 12-pole blocks 19 Mounting accessories End brackets DIN-Rail and C-Rail mounting rails and brackets BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 20 10-1 Connector products Contents 10 — Connector products NDN DIN-Rail feed through blocks The NDN feed through blocks feature a compact line of terminal blocks suitable for both 35mm DIN-Rail or C-Rail applications. Products easily snap onto the mounting rail for a quick, simple, low-cost solution. Available accessories include jumpers and marking tape. UL E62622 NDN3 NDNV4 CSA File 15364 CSA File 47235 (NDN1, NDN111) Approval Approval Approval Technical data Technical data Technical data Rated voltage 600V Rated voltage 600V Rated voltage Rated Current 30A Rated Current 30A Rated Current Center spacing, in (mm) 0.25 / 6.35 Center spacing, in (mm) Conductor cross-section, flexible (AWG/mm2) 22~10 / 0.3~5.3 Conductor cross-section, flexible (AWG/mm2) 65A 0.3 / 7.62 Center spacing, in (mm) 0.375 / 9.52 22~10 / 0.3~5.3 Conductor cross-section, flexible (AWG/mm2) 18~6 / 0.8~13.3 4 Number of Poles 3 Number of Poles 3 Circuits per foot 48 Circuits per foot 38 Circuits per foot 30 Torque(N•m) 2 Torque(N•m) 2 Torque(N•m) 4 Torque(lb-in) 18 Torque(lb-in) 18 Torque(lb-in) 35 #6-32 WxHxD(mm) Screw #6-32 25.4 x 34 x 42.4 Colors WxHxD(mm) Cat. no. White (standard) NDNV4-WH Black NDNV4-BK Accessories Jumper 600V Number of Poles Screw Block NDN63 Cat. no. 4 circuits Marking tape White (standard) NDN3-WH Blue NDN3-BL Accessories Cat. no. 2 circuits C-Rail Modular option — NDN63-WH Black NDN63-BK Accessories Cat. no. 2 circuits JN1 MT12-1-2 DRL35MML DRL35MMHI NFTA NRA C-Rail — — DRL35MML DRL35MMHI NFTA NRA 35mm DIN-Rail C-Rail — — Dimensions — in (mm) — Dimensions — in (mm) Marking tape 1.67 1.47 1.23 (42.41) (37.33) (31.24) 1.50 (38.10) 1.47 (37.33) 1.67 (42.41) 1.67 (42.41) 1.34 (34.04) 10-2 Cat. no. White (standard) JNDN3 35mm DIN-Rail Dimensions — in (mm) 1.0 (25.4) 29.7 x 36.8 x 42.4 Colors MT12-1-2 DRL35MML DRL35MMHI NFTA NRA 35mm DIN-Rail WxHxD(mm) Cat. no. MTC6 Mounting #10-32 23.9 x 33.3 x 42.4 Colors JN4 Screw BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.94 (23.87) 1.31 (33.27) 1.17 (29.71) Eaton.com/bussmannseries 1.45 (36.83) Connector products Connector products — 10 NDN1 NDN111 Approval Approval Technical data Technical data Rated voltage 600V Rated voltage 600V Rated Current 90A Rated Current 90A 0.635 / 16.31 Center spacing in (mm) 0.635 / 16.31 18~2 / 0.8~33.6 Conductor cross-section, flexible (AWG/mm2) 18~2 / 0.8~33.6 Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) Number of Poles 1 Number of Poles 3 Circuits per foot 18 Circuits per foot 18 Torque(N•m) 3.6 Torque(N•m) 3.6 Torque(lb-in) 32 Torque(lb-in) 32 Screw Screw 1/4-28 WxHxD(mm) 15 x 30.3 x 43.5 Colors Accessories 35mm DIN-Rail C-Rail Colors Cat. no. NDN1-WH White (standard) — 1/4-28 WxHxD(mm) Cat. no. 47.5 x 36.6 x 43.5 Cat. no. White (standard) NDN111-WH Black NDN111-BK Accessories 2 circuits — Cat. no. JN1 MT12-1-2 MT12-1-2 DRL35MML DRL35MMHI NFTA NRA DRL35MML DRL35MMHI NFTA NRA 35mm DIN-Rail C-Rail NDN111A-WH, NDN111A-BK Dimensions — in (mm) Dimensions — in (mm) Mtg. holes 0.18 (4.57) dia. 0.28 (7.11) c'bores 1.46 (37.13) 1.71 (43.48) 1.32 (33.68) 1.71 (43.48) Dovetail option 0.62 (15.75) 1.87 (47.50) Dovetail Option 0.59 (14.99) 1.43 (36.31) 1.44 (36.57) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-3 10 — Connector products C-Rail feed through terminal blocks 12-pole C-Rail terminal blocks provide a low-profile, compact footprint solution for various wire connection applications. Products feature an easy, snap-on installation method and an array of accessories including jumpers and marking strips. UL E62622 (excluding N512) CSA File 15364 CSA File 47235 (NFT3) N512 Approval Approval Approval Technical data Technical data Rated voltage 300V 600V Rated current 20A 5A Center spacing in (mm) 0.197 / 5.0 Conductor cross-section, flexible (AWG/mm2) NFT3 NFT2 Technical data Rated voltage Rated Current Center spacing in (mm) 22~12 / 0.3~3.3 600V Rated voltage 600V 40A Rated Current 40A Center spacing in (mm) 0.28 / 7.13 Conductor cross-section, flexible (AWG/mm2) 22~8 / 0.3~8.4 0.39 / 9.91 Conductor cross-section, flexible (AWG/mm2) 22~8 / 0.3~8.4 Number of Poles 12 Number of Poles 2 Number of Poles 3 Circuits per foot 60 Circuits per foot 38 Circuits per foot 28 Torque(N•m) 1.4 Torque(N•m) 2 Torque(N•m) 2 Torque(lb-in) 12 Torque(lb-in) 18 Torque(lb-in) 18 Screw #4-48 WxHxD(mm) Colors Jumper Cat. no. Colors #8-32 WxHxD(mm) 16.5 x 34.7 x 42.8 Colors Cat. no. NFT2-WH White (standard) NFT3-BK — — — Black Cat. no. Accessories Cat. no. Accessories Marking tape 2 circuits NFTA NRA C-Rail Dimensions — in (mm) Cat. no. JN3 MT12-1-2 MT12-1-2 NFTA NRA C-Rail 2 circuits JN2 AT512 Cat. no. NFT3-WH — JN512 30.0 x 32.9 x 31.4 White (standard) Accessories 12 circuits Mounting Screw #8-32 WxHxD(mm) N512-BK Black (standard) Block Screw 61.0 x 27.7 x 22.4 C-Rail NFTA NRA Dimensions — in (mm) Dimensions — in (mm) 2.40 (60.96) 0.60 (15.44) 0.07 (1.78) 1.68 (42.82) 1.09 (27.68) 10-4 1.29 (32.94) 0.93 (23.80) 0.88 (22.35) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 1.18 (29.97) 0.36 (9.14) 1.23 (31.34) 1.23 (31.37) 0.65 (16.51) Eaton.com/bussmannseries 1.29 (32.94) Connector products — 10 Connector products 3-pole NC3 NSE3 Approval Approval Technical data Technical data Rated voltage Rated Current Center spacing in (mm) 600V Rated voltage 175A Rated Current 1.06 / 26.92 Conductor cross-section, flexible (AWG/mm2) Approval Technical data Center spacing in (mm) 14~2/0 /2.1~67.4 Cu/AL NSS3 Conductor cross-section, flexible (AWG/mm2) 600V Rated voltage 600V 115A Rated Current 30A 1.06 / 26.92 Center spacing in (mm) 0.385 / 9.77 Ring terminals only Conductor cross-section, flexible (AWG/mm2) Ring terminals only 3 Number of Poles 3 Number of Poles 3 Circuits per foot 11 Circuits per foot 11 Circuits per foot 28 Torque(N•m) 5.1 Torque(N•m) 3.6 Torque(N•m) 1.4 45 Torque(lb-in) 32 Torque(lb-in) 12 Number of Poles Torque(lb-in) Screw Screw 5/16 - 24 WxHxD(mm) Colors White (standard) 1/4 - 28 WxHxD(mm) 79.4 x 44.5 x 44.5 Colors Cat. no. White (standard) NC3-WH Screw 79.2 x 38.9 x 445 #6-32 WxHxD(mm) Cat. no. Colors NSE3-WH White (standard) 31.5 x 33.7 x 31.8 Cat. no. NSS3-WH — — — — — Accessories Cat. no. Accessories Cat. no. Accessories Cat. no. — — 2 circuits — MT12-1-2 Panel mount C-Rail JNSE3 2 circuits MT12-1-2 — NFTA NRA Panel mount C-Rail — NFTA Series NRA Series Panel mount C-Rail Dimensions — in (mm) Dimensions — in (mm) JNSS3 MT12-1-2 — NFTA NRA Dimensions — in (mm) 1.25 (31.75) 3.12 (79.38) 1.75 (44.45) 0.250 x 0.190 mtg. slots 1.24 (31.50) 1.75 (44.45) 1.75 (44.45) 1.25 (31.75) 1.25 (31.75) 1.32 (33.73) 1.53 (38.86) 0.250 x 0.190" mtg. slots 3.12 (79.24) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-5 10 — Connector products DIN-Rail depluggable blocks Depluggable terminal blocks are available for both 35mm DIN-Rail and C-Rail applications. These blocks provide a simple depluggable* option for panel wiring applications with the convenience of quick, easy, snap-on installation. Product accessories such as jumpers and marking tape are available for most products. UL E62622 PLU3 15188 CSA File 15364 CSA File 47235 (15188 Series) * Not for use as a load break disconnect. Approval Approval Technical data Technical data Rated voltage 600V Rated voltage 30A Rated Current Rated Current Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) Technical data Rated voltage 40A Rated Current 0.39 / 9.91 Conductor cross-section, flexible (AWG/mm2) 16~12 / 1.3~3.3 600V 600V 70A Center spacing in (mm) 22~8 / 0.3~8.4 0.3 / 7.62 Conductor cross-section, flexible (AWG/mm2) 18~4 / 0.8~21.2 Number of Poles 3 or 4 Number of Poles 3 Number of Poles Circuits per foot 32 Circuits per foot 28 Circuits per foot 19 Torque(N•m) 1.4 Torque(N•m) 2 Torque(N•m) 3.6 Torque(lb-in) 12 Torque(lb-in) 18 Torque(lb-in) 32 Screw Screw #6-32 3-Pole 4-Pole #8-32 WxHxD(mm) 30.2 x 49.3 x 47.8 39.2 x 49.3 x 47.8 Colors Block Approval Center spacing in (mm) 0.375 / 9.52 PLU1 3-Pole Colors Cat. no. 1-3 Screw 1/4 - 28 WxHxD(mm) 31.8 x 47.0 x 45.6 1-Pole 2-Pole 3-Pole Colors Cat. no. WxHxD(mm) 18.5 x 47.0 x 45.6 34.0 x 47.0 x 45.6 49.5 x 47.0 x 45.6 Cat. no. PLU1-WH White (standard) 15188-3 White (standard) PLU3-WH White (1-Pole) White (standard) 15188-4 Black PLU3-BK White (2-Pole) PLU11-WH White (3-Pole) PLU111-WH Accessories Cat. no. Accessories Jumper 2 circuits 15188J-2-J, J15188 2 circuits Marking tape — — Mounting 35mm DIN-Rail DRL35MMLO DRL35MMHI Configurable Reverse Wiring Locking Reverse; Locking 15188-_R 15188-_S 15188-_RS Cat. no. Accessories JN3 2 circuits MT12-1-2 C-Rail (AL) MT12-1-2 NFTA NRA — Cat. no. JN1 C-Rail (AL) — NFTA NRA — — Options offered for both pole lengths Dimensions — in (mm) Dimensions — in (mm) Dimensions — in (mm) 3 Pole = 1.19 (30.22) 4 Pole = 1.56 (39.62) 1.87 (47.49) 1.25 (31.75) 1.94 (49.27) 0.59 (14.98) 1.85 (46.99) 1.48 (37.59) 1.79 (45.64) IN-LINE WIRING DIRECTION 1.25 (31.75) 3 Pole = 1.19 (30.22) 4 Pole = 1.56 (39.62) 0.375 (9.52) 1.25 (31.75) 1.85 (46.99) 0.22 (5.58) 1.25 (31.75) 1.94 (49.27) REVERSE WIRING DIRECTION 10-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 Panel mount multi-pole blocks Connector products Multi-pole panel mount terminal blocks provide a compact, high density circuit connection solution without the necessity of a mounting rail. These products are designed to be nested together to form one string of circuit connections. UL E62622 CSA 15364 PSU1 Approval Approval Technical data Technical data Rated voltage Rated Current Center spacing in (mm) Approval Technical data 600V Rated voltage 600V Rated voltage 600V 45A Rated Current 40A Rated Current 30A Center spacing in (mm) 0.625 / 15.88 Conductor cross-section, flexible (AWG/mm2) KT4 KT3 Conductor cross-section, flexible (AWG/mm2) Ring terminals only 0.39 / 9.91 Center spacing in (mm) 0.25 / 6.35 Conductor cross-section, flexible (AWG/mm2) 22~8 / 0.3~8.4 22~10 / 0.3~5.3 Number of Poles 1-3 Number of Poles 3 Number of Poles 4 Circuits per foot 19 Circuits per foot 28 Circuits per foot 48 Torque(N•m) 2.7 Torque(N•m) 2 Torque(N•m) 2 Torque(lb-in) 24 Torque(lb-in) 18 Torque(lb-in) 18 Screw Screw #10-32 3-Pole Colors #8-32 WxHxD(mm) WxHxD(mm) 50.3 x 49.1 x 62.1 Cat. no. Colors White (standard) Block PSU111-WH Jumper Cat. no. Cat. no. — — Panel mount • Mounting foot Mounting JN3 1.87 (47.63) — Cat. no. KT4-WH-A* White KT4-WH-B* 4 circuits Cat. no. JN4 MTC6 — KAD 1.25 (31.75) 43.8 x 34.0 x 32.2 White Accessories Panel mount Dimensions — in (mm) NFTA NRA — Colors MT12-1-2 MT12-1-2 C-Rail (AL) Cat. no. 2 circuits Marking tape Accessories #6-32 WxHxD(mm) KT3-WH Accessories White (3-Pole) Screw 59.5 x 31.8 x 31.0 Dimensions — in (mm) 0.98 (24.99) 0.25 (6.35) 1.22 (31.04) — 0.62 (15.88) 0.37 (9.40) 1.26 (32.23) #8 screw clearance Dimensions — in (mm) KAD end mtg. adapter 1.93 (49.12) 1.48 (37.64) 0.625 (15.88) 2.34 (59.51) 1.34 (34.04) 1.25 (31.75) * The KT4 products are designed to be nested together to form one string of circuit connectors. When used in series, order catalog numbers KT4WH-A and KT4-WH-B. 2.44 (62.10) 0.43 (11.10) 1.25 (31.75) 1.30 (33.00) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-7 10 — Connector products Panel mount quick-connect blocks A time saving alternative for electrical connections, the Bussmann series quickconnect terminal blocks offer a convenient solution. With male spade terminals, wire connections are made quickly and simply with these terminal blocks. UL E62622 CSA 15364 BNQ21 BQQ41 Approval Approval Technical data Technical data Rated voltage 600V Rated voltage 600V Rated Current 40A Rated Current 30A Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.437 / 11.1 Center spacing in (mm) 0.437 / 11.1 22~8 / 0.3~8.4 Conductor cross-section, flexible (AWG/mm2) 0.25" Quick-connect terminals only Number of Poles 1 Number of Poles 1 Circuits per foot 24 Circuits per foot 24 Torque(N•m) 2 Torque(N•m) NA Torque(lb-in) 18 Torque(lb-in) NA Screw NA Screw #8-32 WxHxD(mm) Colors Block White (standard) 33.3 x 35.8 x 37.3 WxHxD(mm) Cat. no. BNQ21-WH Cat. no. Accessories — — — Mounting — BQE Cat. no. — Panel mount • Mounting foot Dimensions — in (mm) #BQE (end mtg. adaptor) Cat. no. BQQ41-WH White (standard) Accessories Panel mount • Mounting foot 33.3 x 35.8 x 37.3 Colors #8 mtg. screw — BQE Dimensions — in (mm) #BQE (end mtg. adaptor) #8 mtg. screw 0.56 (14.28) 0.56 (14.28) 1.47 (37.33) B A 10-8 1.47 (37.33) 1.41 (35.81) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 B A 1.41 (35.81) Eaton.com/bussmannseries Connector products — 10 C7021 power feed through terminal blocks Dimensions — mm (in) D C With mounting ends 9.6 28.0 (0.38) (1.10) 15.8 (0.62) 5.4 (0.21) 15.8 (0.62) 7.9 (0.31) 55.7 (2.19 12.5 (0.49) Ø 9.0 TYP (0.35) 1/4-20 UNC-2A Thread TYP A Ratings Ø12.2 TYP (0.48) B 17.5 TYP (0.69) • Volts 300 V • Amps 115/175 A* per pole * 175 achieved using both studs in parallel, 115 A using a single stud per line. Without mounting ends 15.0 TYP (0.59) 24.0 (0.94) 12.7 (0.50) Agency information 33.0 (1.30) • cURus, Guides XCFR2, XCFR8, File E62622 • CE A Panel cutouts Poles: 1- to 6 • Wire range: AWG #3/0-8 • Center spacing: 0.69" (18mm) • Bolt hole spacing: 0.625" or 5/8" (16mm) • Stud: Standard 1/4-20 stud (tin-plated brass) or optional M6 stud. • Mounting: #6 thread cutting screws (not included) or optional mounting ends. • Torque: 36 lb-in. • Operating temperature: 130°C (266°F) max. Typical applications • Applications requiring up to 175 A utilizing a 2-hole compression lug on 5/8" centers • Input/output block for telecommunications power panels • To eliminate busbars 14.5 TYP (0.57) E 14.2 ( ø.56) 1.6 (R.06) 30.0 (1.18) Specifications • Blind Hole for #6 Thread Cutting Screw 14.5 TYP (0.57) Catalog no. A B C D E C7021-01-X with mounting ends C7021-02-X 17.5 (0.69) — 54.4 (2.14) 67.3 (2.65) 31.8 (1.25) C7021-03-X 34.9 (1.37) — 70.9 (2.83) 84.8 (3.34) 49.2 (1.94) C7021-04-X 52.3 (2.06) — 89.3 (3.52) 102.2 (4.02) 66.7 (2.63) C7021-05-X 69.8 (2.75) — 106.8 (4.20) 119.7 (4.71) 84.2 (3.31) C7021-06-X 87.2 (3.44) — 124.2 (4.89) 134.1 (5.40) 101.7 (4.00) C7021-01N-X without mounting ends C7021-02N-X 17.5 (0.69) 36.1 (1.42) — — 31.8 (1.25) C7021-03N-X 34.9 (0.69) 53.5 (2.11) — — 49.2 (1.94) C7021-04N-X 52.3 (2.06) 71.0 (2.80) — — 66.7 (2.63) C7021-05N-X 69.8 (2.75) 88.4 (3.48) — — 84.2 (3.31) C7021-06N-X 87.2 (3.44) 105.9 (4.17) — — 101.7 (4.00) Catalog number build-a-code Symbol Poles Mount ends Studs C7021 Hardware — 01 = 1-pole (2 studs) Blank = Mount ends Blank = Standard Blank = No hardware 02 = 2-pole (4 studs) N = No mount ends M6 = M6 studs 0 = Bulk pack, one set 03 = 3-pole (6 studs) 1 = Bulk pack, two sets 04 = 4-pole (8 studs) 2 = Assembled, bottom 05 = 5-pole (10 studs) 3 = Assembled, top 06 = 6-pole (12 studs) 4 = Assembled, both sets BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-9 Connector products Power feed through terminal block with two rows 1/4-20 studs capable of accommodating the industry standard two-hole compression lugs on both studs in parallel. 10 — Connector products TB100 double row terminal blocks Dimensions — in A Ratings* 0.14 (3.5) • 300 V • 30 A • Breakdown voltage: 3600 V TB100-08 cULus file E62622; IEC Compliance; CE 0.375 (9.5) 0.17 dia. (4.3) TB100-04SP Agency information 0.88 (22.3) 0.31 (7.9) * Maximum rating shown; some options may be rated lower. • 0.14 (3.5) B 0.30 (7.6) 0.41 (10.4) 0.25 (6.3) Specifications Poles: 2 to 36 Poles A B A B A B • Center spacing: 0.375" or 3/8" (10mm) 02 1.40 1.12 14 5.90 5.62 26 10.40 10.12 • Screw size: #6-32 phil-slot screws 03 1.78 1.50 15 6.28 6.00 27 10.78 10.50 Wire range and torque rating: 04 2.16 1.88 16 6.66 6.38 28 11.16 10.88 14 - 22 AWG Cu @ 9 in-lbs 05 2.53 2.25 17 7.03 6.75 29 11.53 11.25 12 AWG Cu @ 15 in-lbs 06 2.90 2.62 18 7.40 7.12 30 11.90 11.62 07 3.28 3.00 19 7.78 7.50 31 12.28 12.00 08 3.66 3.38 20 8.16 7.88 32 12.66 12.38 09 4.03 3.75 21 8.53 8.25 33 13.03 12.75 10 4.40 4.12 22 8.90 8.62 34 13.40 13.12 11 4.78 4.50 23 9.28 9.00 35 13.78 13.50 5.16 4.88 24 9.66 9.38 36 14.16 13.88 5.53 5.25 25 10.03 9.75 • • • • • Distance between barriers: 0.30" (8mm) • Mounting: #6 screws • Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials • Molded black thermoplastic base, UL rated 94V0 12 • Tin-plated brass terminals 13 • Zinc-plated steel screws Poles Poles 1" = 25.4mm. Catalog number build-a-code Symbol TB100 Poles Screw options Marking/cover Hardware options 02 to 36 Blank = steel phil-slot, zinc-plated L1 to L6 QC1 to QC20 = Quick-connects 00 = screws shipped bulk Marking options, see page 10-16 Custom options† B = brass phil-slot, nickel-plated Special markings , see page 10-16 J101 = flat slip-on jumper (2 position only) — SP = steel SEMS phil-slot, zinc-plated † OJ2 = over barrier jumpers OJ4 = over barrier jumpers † Contact factory for configuration. Accessories • Marker strips, see page 10-17 • Covers, see page 10-16 10-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 B SP Brass phil-slot, nickel-plated F502-J (bulk) Steel SEMS phil-slot, zinc-plated B001-7021-J (bulk) Connector products Screw options Hardware options Quick-connects — assembled: 0.187" x 0.020" terminals, 13 amps maximum. For other orientations, contact factory. QC1 QC2 QC3 QC4 QC5 QC6 QC7 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC19 QC20 Quick-connects — bulk: minimum order 100 pieces per catalog number. QC101-J QC102-J QC103-J QC104-J QC105-J Flat — none QC 45° — none QC 90° — none Flat — Flat Flat — QC 45° QC106-J QC107-J QC108-J QC109-J Flat — QC 90° QC 45° — QC 45° QC 45° — QC 90° QC 90° — QC90° Jumpers — bulk: minimum order 100 pieces per catalog number. Contact factory for jumper assembly. J101 Flat slip-on (bulk: J101-J) OJ2 OJ4 Slip-on over barrier (bulk: OJ2-J) Closed over barrier (bulk: OJ4-J) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-11 10 — Connector products TB200 and TB200HB double row terminal blocks Dimensions — in A Ratings* • 0.16 (4.0) Volts TB200-10SP • 300 V (TB200) • 600 V (TB200HB) • Amps 30 A • Breakdown voltage 4800 V * Maximum rating shown; some options may be rated lower. TB200 0.353 (8.9) 0.56 (14.2) 0.31 (7.8) TB200HB-06 A 0.16 (4.0) 0.16 (4.0) B 0.90 1.37 (22.8) (34.8) 0.44 (11.2) Specifications TB200HB • Poles: 2 to 30 • Center spacing: 0.437" or 7/16" (11mm) • Screw size: #6-32 phil-slot screws • Wire range and torque rating: • 14 - 22 AWG Cu @ 9 in-lbs • 12 AWG (Str) Cu @ 12 in-lbs • 12 AWG (Sol) Cu @ 18 in-lbs Poles Distance between barriers: 0.353" (9mm) • Mounting: #6 screws • Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials • Molded black thermoplastic base UL rated 94V0 • Terminal plating: Tin-plated brass terminals • Zinc-plated steel screws 0.353 (8.9) 0.17 x 0.22 slots (4.3 x 5.6) 0.75 (19.0) A B A B A B 02 1.63 1.31 Poles 12 6.00 5.68 Poles 22 10.37 10.06 03 2.07 1.75 13 6.44 6.12 23 10.81 10.50 04 2.51 2.18 14 6.87 6.56 24 11.25 10.93 05 2.94 2.62 15 7.31 7.00 25 11.68 11.37 06 3.38 3.06 16 7.75 7.43 26 12.12 11.81 07 3.82 3.50 17 8.19 7.87 27 12.56 12.25 08 4.25 3.93 18 8.62 8.31 28 13.00 12.68 09 4.69 4.37 19 9.06 8.75 29 13.44 13.12 10 5.13 4.81 20 9.50 9.18 30 13.87 13.56 11 5.57 5.25 21 9.94 9.62 1" = 25.4mm. Catalog number build-a-code Barrier style 0.437 (11.1) 0.17 dia. (4.3) 0.33 (8.4) • TB 0.437 (11.1) 0.17 dia. (4.3) cULus File E62622; IEC Compliance; CE Symbol 1.12 (28.4) 0.44 (11.2) Agency information • 0.16 (4.0) B Poles Screw options Marking/cover Hardware options 02 to 30 Blank = Steel phil-slot, zinc-plated L1 to L6 = Marking options, see page 10-16 QC1 to QC20 = Quick-connects 00 = Screws shipped bulk Special markings†, see page 10-16 Custom options† — 200 = Standard 200HB = High barrier B = Brass phil-slot, nickel-plated J201 = Flat slip-on jumper, 2 position only BS = Brass SEMS phil-slot, nickelplated OJ3 = Over barrier jumpers P = Steel SEMS (P-style) OJ5 = Over barrier jumpers SP = Steel SEMS phil-slot, zinc-plated OJ7 = Over barrier jumpers SS = Stainless steel SEMS, phil-slot ST = Stainless steel, phil-slot † Contact factory for configuration. Accessories • Marker strips, see page 10-17 • Covers, see page 10-16 10-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 B BS SP P ST SS Brass phil-slot nickel-plated B001-7016-J (bulk) Brass SEMS phil-slot nickel-plated B001-7019-J (bulk) Steel SEMS phil-slot zinc-plated B001-7007-J (bulk) Steel SEMS (P-style) B001-7000-J (bulk) Stainless steel philslot F507-J (bulk) Stainless steel SEMS phil-slot B001-7085-J (bulk) Hardware options Quick-connects — assembled: 0.25" x 0.031" terminals, 20 amps maximum. For other orientations, contact factory. QC1 QC2 QC3 QC4 QC5 QC6 QC7 QC8 QC9 QC11 QC10 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC19 QC20 Quick-connects — bulk: minimum order 100 pieces per catalog number. QC201-J QC202-J QC203-J QC204-J QC205-J Flat — blank QC 45° — blank QC 90° — blank Flat — Flat Flat — QC 45° QC206-J QC207-J QC208-J QC209-J Flat — QC 90° QC 45° — QC 45° QC 45° — QC 90° QC 90° — QC 90° Jumpers — bulk: minimum. order 100 pieces per catalog number. Contact factory for jumper assembly. J201 OJ3 OJ5 OJ7 Flat slip-on (not available on TB200HB) J201-J (bulk) Slip-on over barrier for TB200HB OJ3-J (bulk) Closed over barrier for TB200HB OJ5-J (bulk) Closed over barrier for TB200 OJ7-J (bulk) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-13 Connector products Screw options 10 — Connector products TB300 and TB345 double row terminal blocks Ratings* • • • Volts 600 V TB300-08 Amps • 30 A (TB300) • 45 A (TB345) • Distance between barriers: 0.41" (10mm) • Mounting • • TB300 — #8 screws • TB345 — #10 screws Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials Breakdown voltage 7500 V TB345-06SP * Maximum rating shown; some options may be rated lower. Agency information • Molded black thermoplastic base, UL rated 94V0 • Tin-plated brass terminals • Zinc-plated steel screws Dimensions — in cULus File E62622; IEC Compliance; CE 8-32 binding head screw - TB 300 10-32 binding head screw - TB 345 Specifications A 0.22 (5.6) • Poles: 2 to 24 • Center spacing: 0.562" or 9/16" (14mm) • Screw size • • TB300 — #8-32 phil-slot screws • TB345 — #10-32 phil-slot screws TB300 and TB345 • 0.90 1.33 (22.8) (33.8) 0.50 (12.7) 0.56 (14.2) TB300: 0.21 x 0.25 slots (5.3 x 6.3) 0.412 (10.4) 0.56 (14.2) 0.21dia. (5.3) Wire range and torque rating • B 0.81 (20.5) 0.33 (8.4) • 12 - 22 AWG Cu @ 15 in-lbs • 10 AWG Cu @ 21 in-lbs Poles TB345: • 10 - 22 AWG Cu 20 in-lbs • 8 AWG @ 26 in-lbs A B A B A B 02 2.13 1.69 10 Poles 6.62 6.19 18 Poles 11.12 10.68 03 2.69 2.25 11 7.18 6.75 19 11.68 11.25 04 3.25 2.81 12 7.75 7.31 20 12.24 11.81 05 3.81 3.37 13 8.31 7.87 21 12.80 12.37 06 4.37 3.94 14 8.87 8.44 22 13.37 12.93 07 4.94 4.50 15 9.43 9.00 23 13.93 13.50 08 5.50 5.06 16 9.99 9.56 24 14.49 14.06 09 6.06 5.62 17 10.56 10.12 1" = 25.4mm. Catalog number build-a-code Symbol Screw size TB Poles Screw options Marking/cover Hardware options 02 to 24 Blank = Steel phil-slot, zinc-plated L1 to L6 marking options, see page 10-16 QC1 to QC20 = Quick-connects (TB300 only) 00 = Screws shipped bulk Special markings†, see page 10-16 Custom options (TB300 only)† — 300 = 8-32 screw 345 = 10-32 screw B = Brass phil-slot, nickel-plated J301 = Flat slip-on jumper BS = Brass SEMS phil-slot, nickelplated (TB300 only) OJ6 = Over barrier jumper SP = Steel SEMS phil-slot, zinc-plated OJ11 = Over barrier jumper ST = Stainless steel, phil-slot † Contact factory for configuration. Accessories • Marker strips, see page 10-17 • Covers, see page 10-16 10-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 B BS Brass phil-slot nickel-plated - B001-7018-J (TB300 bulk) - B500-023-028-J (TB345 bulk) SP Brass SEMS phil-slot nickel-plated - B001-7015-J (TB300 bulk) ST Steel SEMS phil-slot zinc-plated - B001-7017-J (TB300 bulk) - B001-5774-J (TB346 bulk) Stainless steel phil-slot - B001-7063-J (TB300 bulk) - B001-7064-J (TB345 bulk) Hardware options Quick-connects — assembled: TB300 only; 0.25" x 0.031" terminals, 20 amps maximum. For other orientations, contact factory. QC1 QC2 QC3 QC4 QC5 QC6 QC7 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC19 QC20 Quick-connects — bulk: *TB300 only; minimum order 100 pieces per catalog number. QC201-J QC202-J QC203-J QC204-J QC205-J Flat — blank QC 45° — blank QC 90° — blank Flat — Flat Flat — QC 45° QC206-J QC207-J QC208-J QC209-J Flat — QC 90° QC 45° — QC 45° QC 45° — QC 90° QC 90° — QC 90° Jumpers — bulk: TB300 only; minimum order 100 pieces per catalog number. Contact factory for jumper assembly. J301 OJ6 OJ11 Flat slip-on J301-J (bulk) Closed over barrier OJ6-J (bulk) Slip-on over barrier OJ11-J (bulk) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-15 Connector products Screw options 10 — Connector products Marking options and covers for double row terminal blocks Special marking* Standard marking 3 L1 2 1 1 2 3 3 L2 1 1 2 3 1 2 3 L4 L3 L5 2 2 3 1 L6 Standard markings are applied directly to the side(s) of a block. The standard marking color is white. The standard numeral height is 0.125 inches (3mm). Special markings are available at an additional charge. Drawing(s) must be submitted to ensure accuracy of part required. Consult factory for price and delivery. * Not available on TB400 products Note: Blocks marked on both sides require a different code for each side. Example: Style L1 on one side of the block requires Style L2 on the other side to ensure common terminal marking. To order, add appropriate suffix (L1, L2, L3, L4, L5 and/or L6) to block catalog number in the proper sequence. Covers Catalog no. For block family (must be ordered separately) DD1-J TB100 DD2-J TB200 DD2HB-J TB200HB DD3-J TB300 Covers prevent personnel, screws and foreign items from contacting live terminals, and are available in white (opaque) or clear plastic. Two cover clips are supplied with each cover. The cover width is 1.31 inches (33mm). Example: 10 position cover, white, TB100 = catalog number X12010. Cover catalog number build-a-code† Symbol Cover strip† Poles 119 = TB100 - clear 02 to 36 (TB100) 120 = TB100 - white 02 to 30 (TB200/ TB200HB) 219 = TB200/TB200HB - clear 02 to 24 (TB300/ TB345) High barrier option only X HB = High barrier†† 220 = TB200/TB200HB - white 319 = TB300/TB345 - clear 320 = TB300/TB345 - white † Cover strip not available for TB400 products. †† Applicable to X219 and X220 only. Cover clips — bulk 10-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 Bottom marker strips (order separately from blocks) (order separately from blocks) Connector products Top marker strips des o si g Top mounting marker strips must be ordered separately and are only available in white (opaque) plastic. Two cover clips are supplied with each marker strip. Example: 12 position cover, TB200, 0.032" x 0.312" = catalog number X20312. Example: 12 position cover, TB200HB, 0.06" x 0.50" = catalog number X23312HB. Top marker strip catalog number build-a-code Series Top marker strip† Poles High barrier option only 103 = TB100 (0.032 thk x 0.312 w) 02 to 36 (TB100) HB = High barrier†† 133 = TB100 (0.060 thk x 0.500 w) 02 to 30 (TB200/TB200HB) 203 = TB200/TB200HB (0.032 thk x 0.312 w) 02 to 24 (TB300/TB345) X 233 = TB200/TB200HB (0.060 thk x 0.500 w) 303 = TB300/TB345 (0.032 thk x 0.380 w) in ark one w ng t arki M e sid M o g tw es sid rkin Ma Bottom mounting marker strips are made of 0.03" thick black PVC. Space is available along the edge to handle most marking needs. All marker strips must be ordered separately. To order, specify catalog number and required marking orientation. Example: 13 position strip, TB100 with no markings, space for marking one side = catalog number X10513. Consult factory for specials. Standard numeral height is 0.125". Standard markings are 0-99. Special markings are available on special order. Drawing(s) must be submitted to ensure accuracy of part required. Dimensions — in For TB block Dim. TB100 TB200 TB200HB TB300 TB345 TB400 A 1.13 1.37 1.62 1.58 1.58 N/A B 1.38 1.62 1.81 1.81 1.81 N/A Bottom marker strip catalog number build-a-code 333 = TB300/TB345 (0.060 thk x 0.500 w) † Marking strips not available for TB400 products †† Applicable to X203 and X233 only. Symbol X Bottom Marker Strip† Poles 101 = TB100 marking both sides 105 = TB100 marking one side 201 = TB200 marking both sides 205 = TB200 marking one side 291 = TB200HB marking both sides 295 = TB200HB marking one side 301 = TB300 and TB345 marking both sides 305 = TB300 and TB345 marking one side 02 to 36 (TB100) 02 to 30 (TB200/TB200HB) 02 to 24 (TB300/TB345) Marking orientation BF = Bottom forward BR = Bottom reverse TF = Top forward TR = Top reverse † Not available for TB400 products. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-17 10 — Connector products TB400 double row terminal blocks Dimensions — in A Ratings B • Volts 600 V • Amps 75 A • Breakdown voltage 7500 V 0.22 (5.6) 0.15 dia. (3.8) TB400-05 0.625 (15.9) 1.12 (28.4) Agency information 0.22 dia. (5.6) cULus file E62622; IEC Compliance; CE • 0.687 (17.4) Specifications Poles: 2 to 12 • Center spacing: 0.687" or 11/16" (17mm) • Screw size: #10-32 phil-slot screws • Wire range and torque rating: 10 - 14 AWG Cu @ 20 in-lbs • Distance between barriers: 0.56" (14mm) • Mounting: #10 screws Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials Molded black thermoplastic base, UL rated 94V0 • 0.562 (14.3) 1.81 (46.0) • • 0.687 (17.4) 0.76 (19.3) 0.46 (11.7) 1.34 (34.0) Poles A B A B A B 02 2.51 2.06 06 5.26 4.81 10 8.01 7.56 03 3.20 2.75 07 5.95 5.50 11 8.70 8.25 04 3.89 3.44 08 6.64 6.19 12 9.39 8.94 05 4.58 4.13 09 7.33 6.88 • Tin-plated brass terminals 1" = 25.4mm. • Zinc-plated steel screws Screw options Poles Poles Catalog number build-a-code Symbol TB400 Poles Screw options — 02 to 12 Brass nickel-plated phil-slot B500-023-028-J (bulk) Blank = Zinc-plated steel phil-slot 00 = Screws shipped bulk B = Nickel-plated brass phil-slot Stainless steel phil-slot B001-7064-J (bulk) Hardware options ST = Stainless steel, phil-slot Accessories • OJ14 - Jumper over barrier, consult factory for pole configuration OJ14: Closed over barrier OJ14-J (bulk) 10-18 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 KU double row terminal blocks • Volts 600 V • Amps 60 A* KU KU_ * 60 A rating achieved with 6 AWG Cu wire crimped to ring terminal. Poles 02 04 06 08 10 12 KU_SC Agency information • A 2.50 3.75 5.00 6.25 7.50 8.75 B 1.62 2.87 4.12 5.37 6.62 7.87 B KUX 0.62 only (15.9) A 2.00 3.25 4.50 5.75 #10 screw 7.00 clearance 0.43 (11.1) 8.25 1.50 (38.1) 2.00 (50.8) 0.50 (12.7) 1" = 25.4mm. 1.25 (31.8) UL File E62622, CSA File 47235 A Specifications Accessories (order separately) • Poles: 2 to 12 • Wire range: 6-22 AWG Cu • Center spacing: 0.625" (16mm) • Screw size: #10-32 • Torque rating: 20 lb-in • Distance between barriers: 0.437" (11mm) • Mounting: Panel mount • Operating temperature: 105°C (221°F) max. MTMU(poles) Molded marking tape, matte finish NUM(poles) Molded marking tape JU12 Jumper, 12 circuits Materials • Molded black Noryl base, UL rated 94V1 • Terminal plating: Nickel-plated brass terminals • Zinc-plated steel screws NUE End piece for NUC NUC(poles) Cover Catalog number build-a-code - KU versions Symbol / for Poles Screw options Covers Marking strip 00 = Screws shipped bulk WC = Top cover and2 end plates MT = Matte finish — KU / Standard block KUX / Short block KURL / Standard w/removable link 2 4 6 8 10 12 KUXRL / Short block w/removable link BP = Brass phil-slot, nickel-plated NU = Numbered 1 to 12, horizontal P = Steel screw w/pressure plate zinc-plated NUV = Numbered 1 to 12, vertical W = Brass washer head, nickel-plated PT = Marker strip for cover† Catalog number build-a-code - KU__SC versions Symbol / for Poles Screw options Covers Marking strip 00 = Screws shipped bulk WC = Top cover and 2 end plates PT = Marker strip for cover† — KUSC / Standard w/shorting strap and 4 shorting screws KUXSC / Short block w/shorting strap and 4 shorting screws 2 4 6 8 10 12 BP = Brass phil-slot, nickel-plated P = Steel screw w/pressure plate, zinc-plated W = Brass washer head, nickel-plated † Requires WC cover option BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-19 Connector products Ratings Dimensions — in 10 — Connector products End brackets BRKT-ND BRKT-NDSCRW BRKT-NDSCRW2 BRKT-NDSCRW3 Use with DRL35MMHI Use with DRL35MMHI Use with DRL35MMHI Use with DRL35MMHI DRL35MMLO DRL35MMLO DRL35MMLO DRL35MMLO Dimensions — mm Dimensions — mm Dimensions — mm Dimensions — mm DRL35MMLO* DRL35MMHI* NFTA** NRA** Low profile High profile C-Rail C-Rail 35mm DIN-Rail 35mm DIN-Rail BRKT-ANGL BRKT-FLT Angle bracket Flat bracket Mounting rails and brackets * Available in 1 meter lengths only. ** Cut-to-length. Consult your Bussmann series product representative for details. 10-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries
TB300-06QC2 价格&库存
很抱歉,暂时无法提供与“TB300-06QC2”相匹配的价格&库存,您可以联系我们找货
TB300-06QC2
