AGU-50
AGU-50
    EATON(伊顿)
AGU-50 数据手册
Bussmann® Fast-Acting Ferrule Fuses AGU ⁄‹Ω£™∑ ≈ 1⁄Ω™∑ Midget AMPERE RATING 5 100 2 1 Time-Current Characteristic Curves–Average Melt Dimensional Data 1.5" (±0.031) 10 TIME IN SECONDS 0.41" (±0.003) Catalog Symbol: AGU (5AG) Fast-Acting Ampere Rating: 1 to 60 Amperes No Agency Listings • Glass tube. • Nickel plated brass ferrules. Options: • Gold plated ferrules Order number AGU-(amp)-1J0281 1 .1 Electrical Ratings (Catalog Symbol and Amperes) 32 Volts AC AGU-25 AGU-60 AGU-3 AGU-8 AGU-30 — — AGU-10 AGU-35 — — AGU-15 AGU-40 — .01 200 AGU-50 AGU-5 100 AGU-20 AGU-2 10 AGU-4 1 AGU-1 .4 250 Volts AC CURRENT IN AMPERES CE logo denotes compliance with European Union Low Voltage Directive (50-1000 Vac, 75-1500 Vdc). Refer to BIF document #8002 or contact Bussmann Application Engineering at 314-527-1270 for more information. Carton Quantity and Weight Ampere Ratings Carton Qty. Lbs. Weight Kg. 1-60 100 1.3 0.590 Recommended Fuseblocks–30 amps maximum Poles 1 2 3 Terminal Type Screw With Quick Connect BM6031SQ BM6032SQ BM6033SQ Pressure Plate w/Quick Connect BM6031PQ BM6032PQ BM6033PQ Box Lug BM6031B BM6032B BM6033B The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-17-98 SB98107 Rev. A Form No. AGU Page 1 of 1 BIF Doc #2008
AGU-50 价格&库存
很抱歉,暂时无法提供与“AGU-50”相匹配的价格&库存,您可以联系我们找货
