Technical Data 10241
Effective December 2015
Supersedes August 2014
BUSSMANN
SERIES
Class CC and supplemental
Modular ferrule fuse blocks
Features and benefits:
Product description:
BCM (Class CC) and BMM (supplemental
13/32 x 1-1/2” / 10x38) modular style fuse blocks
with optional covers.
These new Bussmann® series fuse blocks
contain multiple features to add versatility,
reduce labor and enhance safety of any panel
design.
Available in 1-, 2- and 3-pole configurations
to meet stocking requirements.
Blocks are fully modular with a snap-together
design that provides tool-less assembly of
multiple pole blocks at point-of-use to reduce
inventory and save assembly time and labor.
DIN-Rail and panel mount versatility
allows one product to be used for multiple
applications, lowering inventory cost.
Compact footprint consumes minimal panel
space.
Optional see-through cover enhances safety
with IP20 finger-safe protection, lockout/
tagout capability and open circuit indication.
Easy circuit identification with available
universal marker labels for fuse block covers.
Tin-plated bimetallic copper fuse clips
deliver superior fatigue resistance compared
to traditional spring brass.
Terminal options to meet application needs
including 1/4” spade quick connect terminals
for faster panel assembly.
Patented rejection feature on Class CC fuse
blocks reduces temperature rise by up to
30%.
BCM and BMM modular
Class CC and supplemental ferrule fuse blocks
Specifications
Materials:
Ratings:
Volts – 600V
Amps – up to 30A
Withstand – 200kA RMS Sym.
Base – Thermoplastic
Terminals – Tin-plated bimetallic copper
Covers – Thermoplastic
Screws and pressure plates – Zinc-plated steel
Agency information:
Class CC BCM
Cover Part Numbers:
UL Listed E14853 - IZLT
CSA® Certified 47235-6225-01
CE
RoHS Compliant
Conflict mineral free
REACH declaration available upon request
Marker labels:
Class CC
Ultimate protection time-delay Low-Peak™ LP-CC,
data sheet No. 1023
• Advanced protection time-delay Limitron™ FNQ-R,
data sheet No. 1014
• Advanced protection fast-acting Limitron KTK-R,
data sheet No. 1015
13/32” x 1-1/2” (midget)
UL Recognized E14853 - IZLT2
CSA Certified 47235-6225-01
CE
RoHS compliant
Covers are included in the overall UL Listing/Recognition and
CSA Certification
IP20 finger-safe
RoHS compliant
Fast-acting 250Vac BAF, data sheet No. 2011
Fast-acting 600Vac KTK, data sheet No. 1011
• Fast-acting 600Vac/dc KLM, data sheet No. 2020
• Time-delay 250Vac FNM, data sheet No. 2028
• Time-delay 500Vac FNQ, data sheet No. 1012
10x38mm (IEC)
Covers:
Poles:
1-, 2-, 3-pole units factory assembled
Single-pole units snap together to create desired number of
poles
Use Bussmann series part number TM26CB
Recommended Bussmann series fuses:
13/32” x 1-1/2” (Midget) BMM
For blocks with quick connect terminals – CVR(I)-CCM-QC
All other terminal options – CVR(I)-CCM
Flammability ratings:
Class aM and gG/gL IEC industrial fuses, data sheet No.
720115
Recommended Bussmann series DIN-Rail end stops:
Part No. BRKT-ND
Part No. BRKT-NDSCREW2
Blocks – UL 94V0, self-extinguishing
Covers – UL 94HB, self-extinguishing
Operating and storage temperature range:
Blocks – -40°C to +120°C
Non indicating covers – -40°C to +120°C
Indicating covers – -20°C to +90°C*
* Indication requires minimum 90Vac/dc and closed circuit to
illuminate.
Table 1. Catalog numbers
Terminal type
#10-32
Phil-slot screw
BCM603-1S
Screw with
quick connect*
BCM603-1SQ
Pressure plate with
Pressure plate quick connect*
Box lug
BCM603-1P
BCM603-1PQ
BCM603-1C
Poles
1
Fuse class
CC
BCM603-2S
BCM603-3S
BCM603-2SQ
BCM603-3SQ
BMM603-1SQ
BMM603-2SQ
BMM603-3SQ
BCM603-2P
BCM603-3P
BCCMM603-3SQ —
CC
CC
10x38 (13/32”x1-1/2”)
3-Pole control circuit transformer block
2-pole CC with 1-pole 10x38 (13/32”x1½”)
BCM603-2PQ
BCM603-3PQ
BMM603-1PQ
BMM603-2PQ
BMM603-3PQ
BCM603-2C
BCM603-3C
BMM603-1C
BMM603-2C
BMM603-3C
2
3
1
2
3
BCCMM603-3PQ
3
* ¼“ Quick Connect terminal maximum ampacity dependent on female spade connector and wire ratings.
2
Eaton.com/bussmannseries
BCM and BMM modular
Dimensions - mm (in)
33
1.3
95
3.7
40
1.6
21
.8
77 10
3.0 .4
4
.2
16
.6
41
1.6
60
2.4
39
1.6
59
2.3
33
1.3
With cover.
see table
See
Table33for
foravailable
availablecovers.
covers.
Table 2. Terminal specifications
Terminal type
Box lug (C)
Torque
75/90°C AWG
type/range
AWG
lb-in (N•m)
Cu 2-3
50 (5.6)
Cu 4-6
45 (5.1)
Cu 2-14
Cu 8-14
35 (4.0)
Al 2-8
Al 2-6
50 (5.6)
Al 8
40 (4.5)
Screw (S)
Screw/quick connect* (SQ)
Cu 10-18
Pressure plate (P)
Pressure plate/
quick connect* (PQ)
10-18
BMM603-3C with
CVRI-CCM covers and
TM26CB marker labels
20 (2.3)
and wire ratings.
Table 3. Recommended covers*
Terminal type
Box lug (C)
Screw (S)
Screw/quick connect (SQ)
Pressure plate (P)
Pressure plate/quick connect
(PQ)
Cover part numbers
Indicating
Non indicating
CVRI-CCM
CVR-CCM
CVRI-CCM
CVR-CCM
CVRI-CCM-QC
CVR-CCM-QC
CVRI-CCM
CVR-CCM
CVRI-CCM-QC
CVR-CCM-QC
* For use with 4AWG max conductors.
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by
definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user
with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of
any products. Eaton also reserves the right to change or update, wit hout notice, any technical information contained in this bulletin. Once a product has been
selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 10241 – BUS-SB14605
December 2015
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton, Bussmann, Limitron and Low-Peak
are valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BMM603-1SQ”相匹配的价格&库存,您可以联系我们找货
