SL-30PK4
SL-30PK4
    EATON(伊顿)
    SL-30PK4
SL-30PK4 数据手册
Bussmann® Plug Fuses Type SL Time-Delay 125 Volts, 15–30 Amps • Size Rejecting Plug Fuse. • No-interchangeablility prevents installing a higher amp fuse than the circuit was designed for. • Has ability to withstand typical motor starting surges. • Use in residential or light-duty motor circuits. • These fuses thread into SA adaptors. 15 20 35 30 Time-Current Characteristics–Total Clear CATALOG SYMBOL: SL TIME-DELAY 15 TO 30A 125VAC OR LESS U.L. LISTED (GUIDE #JEFV, FILE # E12112) 100 10 SL-30 Package Quantity and Weight Ampere Quantity Ratings Box Card Weight Per Box Per 5 Cards 4 3 0.200 0.995 TIME IN SECONDS Electrical Ratings (Catalog Symbol and Amperes) 125 Volts SL-15 SL-20 SL-25 15, 20, 25, & 30A AMPERE RATING 1 2,000 1,000 100 10 .01 4 .1 CURRENT IN AMPERES The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-28-98 SB98107 Rev. A Form No. Type SL Page 1 of 1 BIF Doc #1033
SL-30PK4 价格&库存
很抱歉,暂时无法提供与“SL-30PK4”相匹配的价格&库存,您可以联系我们找货
