FWH5-020A6F
FWH5-020A6F
    EATON(伊顿)
    FUSEBUSS500V20A6X32
FWH5-020A6F 数据手册
Technical Data 720038 Effective December, 2015 Supersedes August, 2003 BUSSMANN SERIES FWH 6x32mm high speed ferrule fuses Agency information • CE • RoHS compliant • UL® Recognized JFHR2, E91958, 0.25-7A • UL Recognized JDYX2, E19180, 10-30A • CSA® Component Acceptance file Class 1422-30, 1422-90 (53787) 0.25-7A Opening times: Catalog symbols: • FWH-(amp)A6F • FWH-(amp)A6FR (RoHS compliant) • FWH5-(amp)A6F • FWH5-(amp)A6FR (RoHS compliant) Amp range 150% 200% 300% 0.25-7A > 30 min. > 30 min. ≤ 10 sec. 10-30A > 30 min. > 30 min. ≤ 10 sec. Dimensions: 31.8 (1.25) 6.4 (0.25) Description: Eaton’s Bussmann® series of FWH 6x32mm ferrule high speed fuses are for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Specification: Ratings • • Volts Features: • Low watts loss in a compact size • Excellent cycling capability and DC performance • Low arc voltage and low energy let-through (I2t) • 500Vac (0.25-1A and 3.15-30A) • 1000Vac (2A) Typical applications: • 600Vdc (1-5A) • DC common bus • DC drives • Power converters/rectifiers • Reduced voltage starters Amps • • 3.2 (0.125) 0.25-30A Interrupting rating • 50kA AC (0.25-1A and 3.15-20A) • 30kA AC (2A) • 20kA AC (25-30A) • 50kA DC (1-5A) FWH 6x32mm high speed ferrule fuses Technical Data 720038 Effective December 2015 Catalog numbers: Amps 0.25 0.5 1 2 3.15 4 5 6.3 7 10 12.5 15 16 20 25 30 Rated voltage Vac 500 500 500 1000 500 500 500 500 500 500 500 500 500 500 500 500 I2t (A2s) Vdc — — 600 600 600 600 600 — — — — — — — — — Pre-arcing 0.01 0.05 0.4 1.3 3.1 — 15 36 50 9.9 20 44 48 75 126 145 Clearing @ 500Vac 0.05 0.25 2 3.5 7.7 — 40 90 125 139 60 146 177 259 345 430 Watts loss (W) 2.7 1.2 1.7 3.2 2.9 — 2.1 2.3 2.5 2.86 3.53 3.08 4.48 4.26 — — Catalog numbers Standard FWH-250A6F FWH-500A6F FWH-001A6F FWH-002A6F FWH-3.15A6F FWH-004A6F FWH-005A6F FWH-6.30A6F FWH-007A6F FWH5-010A6F FWH5-12-5A6F FWH5-015A6F FWH5-016A6F FWH5-020A6F FWH-025A6F FWH-030A6F RoHS compliant FWH-250A6F FWH-500A6F FWH-001A6F FWH-002A6F FWH-3.15A6F FWH-004A6F FWH-005A6F FWH-6.30A6F FWH-007A6F FWH5-010A6FR FWH5-12-5A6FR FWH5-015A6FR FWH5-016A6FR FWH5-020A6FR FWH-025A6FR FWH-030A6FR 0.25-7A 300% minimum opening current at rated voltage. 10-30A 200% minimum opening current at rated voltage. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 720038 — BU-SB15288 December 2015 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
FWH5-020A6F
1. 物料型号:文档列出了不同额定电流的熔断器型号,例如FWH-250A6F、FWH-500A6F等,以及符合RoHS标准的型号,如FWH5-010A6FR。
2. 器件简介:FWH系列熔断器用于保护直流总线、直流驱动器、功率转换器/整流器和降低额定电压的启动器。
3. 引脚分配:文档没有明确提供引脚分配图,但通常这类熔断器会有清晰的引脚定义。
4. 参数特性:包括额定电压(如500Vac、1000Vac、600Vdc)、中断额定值(如50kA AC、30kA AC、20kA AC、50kA DC)、以及在150%、200%和300%额定电流下的开断时间。
5. 功能详解:熔断器具有低瓦特损耗、紧凑尺寸、优异的循环能力和直流性能、低电弧电压和低能量通过(I2t)。
6. 应用信息:适用于直流总线、直流驱动器、功率转换器/整流器和降低电压启动器。
7. 封装信息:提供了熔断器的尺寸信息,例如长度31.8mm、宽度6.4mm等。
FWH5-020A6F 价格&库存
很抱歉,暂时无法提供与“FWH5-020A6F”相匹配的价格&库存,您可以联系我们找货
