SH5-400
SH5-400
    EATON(伊顿)
    SH5-400
SH5-400 数据手册
2A ER4 industrial disconnect switches UL/cULus Listed NEMA 4X (enclosure) ER4 industrial disconnect switches provide a robust UL98 rated design to withstand long-term corrosive and harsh environments. The complete line includes both fused and non-fused rotary disconnect switches from 30A to 800A, providing flexibility and convenience for point-of-use configuration. Applications: • Built to serve as a main disconnect or provide branch circuit protection in a variety of applications in heavy industrial environments Features: • UL98 Listed for general purpose, main disconnect or branch circuit protection up to 600 VAC/DC • Multiple field installed accessories enhance the enclosed disconnect switches to fit the desired application • Lockout/tagout – up to three 1/4” padlocks can be installed on external handles for added safety 2A Certifications and compliances: • • • • • • • • UL98 Listed – File No. E182262, Guide WIAX, WIAX7 cULus Listed to CSA Standard 22.2, No. 14 cULus Listed to CSA Standard 22.2, No. 4 Conforms with IEC 60947-3 CE compliant RoHS compliant NEMA 4X (enclosure) Non-metallic enclosure flammability rating – polycarbonate: UL 94-5VA-0; fiberglass: UL 94-5V Electrical ratings: •  Voltage – 600 VAC; 250-600 VDC • Amperage – 16A-800A • Short circuit current ratings – UL98: 35kA-200kA; UL508: 10kA-65kA • Operating temperature – -20ºC to +70°C www.crouse-hinds.com US: 1-866-764-5454 CAN: 1-800-265-0502 Copyright© 2016 Eaton ER4 industrial disconnect switches 2A UL/cULus Listed NEMA 4X (enclosure) Ordering information: Part number example ER4X-60J3PB ER 4X – 60 Enclosure type 4X 4P 60 100 304 stainless steel, NEMA 4X Polycarbonate, NEMA 4X BLANK N 400 600 800 P Number of poles Fused Non-fused 3 3-pole B Handle color B Black Handle type Select fuse class only if fused style disconnect switch is selected. P Pistol Fuse class 30A 60A 100A 200A 400A 600A 800A J Class J LA Class L 2A 200 3 Style Amperage rating 30 J Fused disconnects: Non-fused disconnects: Enclosure type Enclosure type Amperage Fuse type 4X plastic 304 stainless steel Amperage 4X plastic 304 stainless steel 30 60 100 200 400 600 800 J J J J J J L ER4P-30J3PB ER4P-60J3PB ER4P-100J3PB ER4P-200J3PB ER4P-400J3PB ER4P-600J3PB ER4P-800L3PB ER4X-30J3PB ER4X-60J3PB ER4X-100J3PB ER4X-200J3PB ER4X-400J3PB ER4X-600J3PB ER4X-800L3PB 30 60 100 200 400 600 800 ER4P-30N3PB ER4P-60N3PB ER4P-100N3PB ER4P-200N3PB ER4P-400N3PB ER4P-600N3PB ER4P-800N3PB ER4X-30N3PB ER4X-60N3PB ER4X-100N3PB ER4X-200N3PB ER4X-400N3PB ER4X-600N3PB ER4X-800N3PB All catalog numbers provided with integral or installed lugs and black selector handle. All catalog numbers provided with integral or installed lugs and black selector handle. Accessories (ordered separately): Accessories (ordered separately): Cat. # Description Cat. # Description BAC05B Aux. contact, (1) NO type, 10A, 600 VAC BAC01D Aux. contact, 30A-100A, (1) NO type, (1) NC type, 10A, 240 VAC BAC06B Aux. contact, (1) NC type, 10A, 600 VAC BAC02D Aux. contact, 30A-100A, (2) NO type, 10A, 240 VAC TSH8-3TBC Terminal shroud, 200A switch rating, 3-pole TSH9-3TBC Terminal shroud, 400A switch rating, 3-pole TSH10-3TBC Terminal shroud, 600A-800A switch rating, 3-pole BAC03E BAC04E BAC11E Aux. contact, 220A-800A, (1) NO type, (1) NC type, 1A, 125 VAC BAC12E Aux. contact, 220A-800A, (1) NO type, (1) NC type, 1A, 125 VAC TSH3-3TB AClass L fuses for 800A disconnect switch only. BFor 30A-800A switches: maximum number of contacts per switch: (4) 30A to 200A; (8) 400A to 800A. CFor 200A-800A switches: includes terminal shroud for line side or load side. DTwo units per switch maximum. EFor one auxiliary contact, install either BAC03 or BAC11. For two auxiliary contacts, install BAC03 + BAC04, or BAC11 + BAC12. Aux. contact, 220A-800A, (1) NO type, (1) NC type, 10.1A, 125-250 VAC Aux. contact, 220A-800A, (1) NO type, (1) NC type, 10.1A, 125-250 VAC TSH4-3T TSH4-3B TSH5-3T TSH5-3B TSH6-3B TSH7-3TB Terminal shroud, 30A-100A switch rating, line side and load side, 3-pole Terminal shroud, 200A switch rating, line side, 3-pole Terminal shroud, 200A switch rating, load side, 3-pole Terminal shroud, 400A switch rating, line side, 3-pole Terminal shroud, 400A switch rating, load side, 3-pole Terminal shroud, 600A switch rating, line side or load side, 3-pole Terminal shroud, 800A switch rating, line side or load side, 3-pole www.crouse-hinds.com US: 1-866-764-5454 CAN: 1-800-265-0502 Copyright© 2016 Eaton ER4 industrial disconnect switches 2A UL/cULus Listed NEMA 4X (enclosure) Dimensions (in inches): Fused – stainless steel: Non-fused – stainless steel: 2A Mounting H x W (in.) Mounting H x W (in.) Amperage H x W x D (in.) A B Weight (lbs.) Amperage H x W x D (in.) A B Weight (lbs.) 30 60 100 200 400 600 800 10 x 10 x 6 12 x 10 x 6 14 x 12 x 6 24 x 20 x 8 48 x 36 x 12 48 x 36 x 12 48 x 36 x 12 10.7 x 8.3 12.7 x 8.3 14.7 x 10.3 24.7 x 18.3 48.7 x 34.3 48.7 x 34.3 48.7 x 34.3 8.3 x 10.7 8.3 x 10.7 12.3 x 12.7 22.3 x 20.7 46.3 x 36.7 46.3 x 36.7 46.3 x 36.7 15 19 21 55 188 216 216 30 60 100 200 400 600 800 10 x 8 x 6 10 x 8 x 6 12 x 10 x 6 20 x 16 x 8 36 x 30 x 8 48 x 36 x 12 48 x 36 x 12 10.7 x 6.3 10.7 x 6.3 12.7 x 8.3 20.7 x 14.3 36.7 x 28.3 48.7 x 34.3 48.7 x 34.3 8.3 x 8.7 8.3 x 8.7 8.3 x 10.7 18.3 x 16.7 34.3 x 30.7 46.3 x 36.7 46.3 x 36.7 11 12 12 39 122 209 211 Fused – polycarbonate or fiberglass: Non-fused – polycarbonate or fiberglass: Mounting H x W (in.) Mounting H x W (in.) Amperage H x W x D (in.) A B Weight (lbs.) Amperage H x W x D (in.) A B Weight (lbs.) 30 60 100 200 400 600 800 12 x 10 x 6 13 x 13 x 6 13 x 13 x 6 27 x 21 x 10 51 x 37 x 14 51 x 37 x 14 51 x 37 x 14 12.0 x 5.6 14.0 x 7.6 14.0 x 7.6 25.75 x 14.0 50.0 x 28.5 50.0 x 28.5 50.0 x 28.5 7.6 x 10.0 9.6 x 12.0 9.6 x 12.0 – – – – 8 11 12 39 186 214 214 30 60 100 200 400 600 800 9x9x6 9x9x6 13 x 13 x 6 20 x 17 x 12 37 x 32 x 14 51 x 37 x 14 51 x 37 x 14 10.0 x 3.6 10.0 x 3.6 14.0 x 7.6 21.5 x 10.1 38.0 x 28.9 50.0 x 28.5 50.0 x 28.5 5.6 x 8.0 5.6 x 8.0 9.6 x 12.0 – – – – 5 5 8 31 103 187 189 Enclosures ≤100A are polycarbonate; flammability rating: UL 94-5VA-VO. Enclosures ≤100A are polycarbonate; flammability rating: UL 94-5VA-VO. Enclosures ≥200A are fiberglass; flammability rating: UL 94-5V. Enclosures ≥200A are fiberglass; flammability rating: UL 94-5V. Switch ratings: Fused Non-fused Voltage No. of poles Switch amperage rating Disc. switch Fuse type VAC VDC Max. HP rating at 600 VAC 3 30 60 100 200 400 600 800 RDF30J-3 RDF60J-3 RDF100J-3 RDF200J-3 RDF400J-3 RDF600J-3 RDF800L-3 J J J J J J L 600 600 600 600 600 600 600 250 250 250 N/A 250 600 600 20 50 75 150 350 500 500 No. of poles SSCR at 600 VAC 3 200kA Switch amperage rating Disc. switch VAC Max. HP rating at 600 VAC SSCR at 600 VAC 30 60 RD30-3 RD60-3 600 600 25 50 100kA 100kA 100 RD100-3 600 50 200 400 600 800 RD200-3 RD400-3 RD600-3 RD800-3 600 600 600 600 200 350 350 500 25/100kAF 200kA 200kA 200kA 100kA F25kA at 600 VAC; 100kA at 480 VAC. www.crouse-hinds.com US: 1-866-764-5454 CAN: 1-800-265-0502 Copyright© 2016 Eaton
SH5-400 价格&库存
很抱歉,暂时无法提供与“SH5-400”相匹配的价格&库存,您可以联系我们找货
SH5-400
  • 1+718.228251+93.36735
