Technical Data 10801
BUSSMANN
SERIES
Effective August 2018
Supersedes April 2015
Red Spot fuse holders for BS88 HRC industrial fuses
Termination/Connection Styles:
Front connected (20-400 A)
Back stud connected (20-400 A)
Front/back stud connected (20-400 A)
Back stud connected, flush mounted (20 A)
Front connected
Back stud connected
Catalog symbol
RS(amps)(connection style/color)
Description
Bussmann™ series Red Spot fuse holders are
a range of CSA Certified IP20 finger-safe fuse
holders for BS88 HRC industrial fuses in rating up
to 400A.
Ratings
Volts
• 600 Vac/dc (CSA)
690 Vac (IEC)
Amps 20, 32, 63, 100, 200 and 400 A
SCCR 80 kA
Back stud connected flush mounted (20 A only)
Flammability rating
RS20H to RS63H, V-1
RS100H to RS400H, V-0
Protection level IP20
Available colors
Maximum Operating Temperature: 40°C
Wire type 70°C PVC/Cu
Wire range 8 AWG to 500 kcmil(10 to 240 mm2)
Agency information
CSA 22.2 No. 39, Class 6225 01, File 47235
IEC 60269-1 and IEC 60269-2
Black, white, green and grey (available colors
vary by amp rating)
Features
Industry standard fuse holder for protecting
utility and industrial installations
Large, proven contact system and anti-vibration
feature helps ensure perfect carrier contact
alignment and superior electrical contact
Conductor insulating sleeves help prevent
inadvertent contact at the entry point while fully
shrouded terminals deliver IP20 protection
Molded parts made from flame-retardant, nonhygroscopic, high dielectric strength phenolic
material
A broad range of accessories and Bussmann
series fuses available for all Red Spot fuse
holders
Technical Data 10083
20 amp holders
Volts
Catalog no.
IEC
Vac
Min. torque lb-in (N•m)
CSA
Vac/dc
Conductor
AWG (mm2)
Termination/connection styles
Conductors
Fuse mount
screws
Bussmann
series fuse
family and
amp range
Color
RS20H
Black
RS20HWH
White
8-10 (10-2)
RS20HGN
Front connected
18 (2.03)
Green
RS20HGY
Grey
RS20P/G
Black
RS20P/GWH
White
RS20P/GGN
690
600
Back stud connected
11 (1.24)
Green
RS20P/GGY
_CIF21 (1-20A)
Grey
RS20PH/G
8-10 (10-2)†
18 (2.03)†
Black
RS20F
Black
RS20FWH
White
RS20FGN
Green
RS20FGY
Grey
† Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer.
Dimensions — mm
TWO HOLES
14.3
TO CLEAR BUSHING
CL
59±1.0
79±1.0
79±1.0
CL
CL
6.6
15
29.4
6.6
58.8
29.4
CL
55±1.0
10.3
27±1.0
M6 STUD
16
15
55±1.0
13.5
ONE HOLE TO TAKE
M5 CHEESEHEAD
FIXING SCREW
CL
27±1.0
ONE HOLE TO TAKE
M5 CHEESEHEAD
FIXING SCREW
TERMINALS ACCOMMODATE
CABLES UP TO 10 Sq.mm
Front connected
28.6
Back stud connected
38.1
58.7±1.0
54
58.7
10.3
28.6
55±1.0
10.3
1 HOLE
14.3
TO CLEAR BUSHING
27±1.0
58.8
5.57
10.3
6.6
M6 STUDS
CL
80.6
84.4
M6 STUD
79.4±1.0
13.5
29.4
13.5
R4.8
CL
ONE HOLE TO TAKE
M5 CHEESEHEAD
FIXING SCREW
ONE MOULDING CLIP
(LIST No. P67/10)
IS SUPPLIED WITH
EACH FLUSH MOULDING
CARRIER AND BASE
TYPE RS20F.
5.8
16
28.2
30.2
HOLE REQUIRED IN PANEL
FOR FLUSH MOULDING RS20F.
DIAMETER OF CABLE HOLE
IN BASE CONTACT.
2
Eaton.com/bussmannseries
Accessories
Catalog no.
Padlockable inserts
RS20LOCK
Red warning carriers
RS20RED
28.6
32 amp holders
Volts
IEC
Vac
Catalog no.
CSA
Vac/dc
Conductor
AWG (mm2)
styles
Fuse mount
screws
Conductors
Bussmann series
fuse family and
amp range
Color
RS32H
Black
RS32HWH
6-10 (16-5)
Front connected
18 (2.03)
White
RS32HGN
Green
RS32P
690
600
18 (2.03)
RS32PWH
Back stud connected
_CIH07 (25-30 A)
_H07C (25-30 A)
CGL-_ (1-30 A)
Black
White
RS32PGN
Green
RS32PH
6-10 (16-5)†
18 (2.03)†
Black
Dimensions — mm
31.8
70
6.4
CL
TWO HOLES
19.1
TO CLEAR BUSHINGS
31.8
70
81
15
6.4
28.6
17.5
36.5
103.2
CL
CL
36.5
3.2
5.56
73
3.2
3.2
103.2
3.2
M6 STUD
15
CL
15
5.6
6.4
22.2
2 HOLES TO TAKE
M5 CHEESEHEAD
FIXING SCREWS
6.4
TWO HOLES TO TAKE
M5 CHEESEHEAD
FIXING SCREWS
CABLES UP TO 16 Sq.mm
Front connected
Back stud connected
19.1
ONE HOLE
TO CLEAR BUSHING
31.8
81
6.4
CL
70
28.6
M6
STUD
CL
3.2
103.2
3.2
36.5
17.5
15
CL
5.56
6.2
6.4
TWO HOLES TO TAKE
M5 CHEESEHEAD
FIXING SCREWS
22.2
IN BASE CONTACT
Accessories
Catalog no.
Use with GS fuse
Padlockable inserts
RS32LOCK
RS32RED
Adaptors for GS fuses*
GRS32-A
GSA 5 to 20 A
* One kit required per fuse.
3
63 amp holders
Volts
IEC
Vac
Catalog no.
CSA
Vac/dc
RS63H
Conductor
AWG (mm2)
1-6 (50-13)
RS63HWH
RS63P
690
RS63PWH
600
RS63PH
Fuse mount
screws
Conductors
Front connected
Black
White
Bussmann series
fuse family and
amp range
Color
31 (3.50)
Back stud connected
1-6 (50-13)†
RS63PHWH
styles
_CIK07 (35-60 A)
_K07C (40-60 A)
CGL-_ (35-60 A)
Black
18 (2.03)
White
Black
31 (3.50)†
White
Dimensions — mm
75.4
2 HOLES TO TAKE M5
CHEESEHEAD FIXING SCREWS
34.9
23.8
TWO HOLES
19.1
TO CLEAR BUSHINGS
15
CL
75.4
84
6.4
35
15.85
28.6
CL
17.5
3.2
M8 STUD
109.5
36.5
52.4
3.2
51.6
6.4
CL
3.2
5.6
5.6
41.3
6.4
77.8
3.2
109.5
CL
15.85
15
9.50
6.4
TWO HOLES TO TAKE
M5 CHEESEHEAD
FIXING SCREWS
CABLES UP TO 50 Sq. mm
Front connected
Back stud connected
84
ONE HOLE
19.1 TO
CLEAR BUSHING.
75.4
28.6
17.5
3.2
36.5
52.4
6.4
M8 STUD
109.5
3.2
16
35
6.4
15
5.6
TWO HOLES TO TAKE
M5 CHEESEHEAD
FIXING SCREWS.
9.5
23.8
IN BASE CONTACT TERMINALS
ACCOMMODATE CABLE
UP TO 50sq mm
Accessories
Catalog no.
Use with GS fuse
Padlockable Inserts
RS63LOCK
Red Warning Carriers
RS63RED
Adaptors for GS Fuses*
GRS63-A
GSA 25 to 50A
4
100 amp holders
Volts
IEC
Vac
Catalog no.
CSA
Vac/dc
RS100H
RS100HWH
RS100P
690
600
Conductor
AWG (mm2)
styles
3/0-4 (70-21)
Front connected
RS100PWH
RS100PH
Conductors
White
22 (2.50)
Color
Bussmann series
fuse family and
amp range
Black
35 (3.95)
Back stud connected
3/0-4 (70-21)†
Fuse mount
screws
Black
White
35 (3.95)†
_CIL14 (80-100 A)
_L14C (80-100 A)
CGL-_ (70-100 A)
Black
Dimensions — mm
TWO HOLES
23.8
TO CLEAR BUSHINGS
100±1.0
50.8
15
CL
100
87.3
31.8
9.5
22.2
CL
M10 STUD
9.5
50.8 ±1.0
11.1
139.7
CL
11.1
11.1
11.1
139.7 ±1.0
46.8
7.15
CL
7.15
12.7
9.5
15.0
9.5
27.8
2 HOLES TO TAKE M6
TWO HOLES TO TAKE M6
CHEESEHEAD FIXING
SCREWS
CABLES UP TO 70 sq. mm
Front connected
Back stud connected
23.8
ONE HOLE
TO CLEAR BUSHING
87.3
9.5
50.8
100
31.8
M10
STUD
46.8
11.1
CL
11.1
139.7
22.2
CL
CL
7.15
15
12.7
9.5
TWO HOLES TO TAKE
M6 CHEESEHEAD
FIXING SCREWS
27.8
CABLES UP TO 70 Sq .mm
Accessories
Catalog no.
For Bussmann series fuses
Padlockable inserts
RS100LOCK
RS100RED
P5372-10
_CIH07 (25-30A)
_CIK07 (35-60A)
Fuse adaptor kits*
5
200 amp holders
Volts
Catalog
no.
IEC
Vac
CSA
Vac/dc
RS200H
250 kcmil-2/0 (120-67)
RS200HWH
RS200P
Conductor AWG
(mm2)
690
600
RS200PWH
RS200PH
styles
Conductors
Front connected
222 (25.08)
Back stud connected
250 kcmil-2/0 (120-67)†
Color
Bussmann series
fuse family and
amp range
Black
White
22 (2.50)
Fuse mount
screws
Black
_M09C (125-200 A)
CGL-_ (110-200 A)
White
222 (25.08)†
Black
Dimensions — mm
TWO HOLES TO TAKE
M6 CHEESEHEAD
FIXING SCREW
19.1
CL
136.5
95.3
CL
171.5
28.6
CL
28.6
215.9
215.9
9.53
CL
28.6
28.6
85.7
25.4
CL
69.9
22.2
31.8
22.2
136.5
M12
STUD
2 HOLES TO TAKE M6
CHEESE HEAD FIXING
SCREWS
19.1
69.9
9.53
22.2
19.1
19.1
27mm
TWO HOLES
TO CLEAR BUSHINGS
CABLES UP TO 120 Sq. mm
Front connected
Back stud connected
HOLE
27mm
TO CLEAR BUSHING
136.5
19.1
69.9
95.3
28.6
CL
28.6
215.9
9.53
22.2
16.3
19.1
TWO HOLES TO TAKE
M6 CHEESEHEAD
FIXING SCREWS
6
31.8
M12
STUD
85.7
25.4
22.2
CL
31.8
22.2
16.3
400 amp holders
Volts
IEC
Vac
Catalog no.
CSA
Vac/dc
RS400
RS400P
690
Conductor AWG (mm2)
styles
Conductors
500-250 kcmil (240-127)
Front connected
222 (25.08)
600
RS400PH
Back stud connected
500-250 kcmil (240-127)†
Fuse mount
screws
Color
Bussmann series
fuse family and
amp range
53 (6.00)
Black
_P11C (250-400A)
CGL-_ (225-400A)
222 (25.08)†
Dimensions — mm
192
151
98.4
192
TWO Ø35 HOLES TO
CLEAR BUSHINGS
CL
98.4
114.3
151
38.1
31.8
31.8
139.7
CL
254
CL
M16
STUD
31.8
A
A
70
254.0
70
31.8
57.2
CL
31.8
57.2
21
CHEESEHEAD FIXING
SCREWS
CHEESEHEAD FIXING
SCREWS
36.5
CABLES UPTO 240sq.mm
27
27
DETAIL A
27
27
DETAIL A
Front connected
Back stud connected
192
Ø35 HOLES TO
CLEAR BUSHING
CL
114.3
151
38.1
254
CL
M16
STUD
70
31.8
31.8
57.2
98.4
A
31.8
21
CHEESEHEAD FIXING
SCREWS
27
36.5
27
DETAIL A
Accessories
Adaptors for Bussmann series fuses*
Catalog
no.
For Bussmann
series fuse
TCA2
_M09C (125-200A)
7
Technical Data 100038801
Red Spot holder accessories
Padlockable inserts
Fuse adaptor kits
Padlockable Insert fits into fuse holder and accepts small padlock.
Fuse adaptors mount on the fuse carrier to accept a smaller
dimensioned fuse.
Fuse holder
Catalog no.
RS20
RS20LOCK
RS32
RS32LOCK
RS63
RS63LOCK
RS100
RS100LOCK
Fuse holder
Catalog no.*
Use with Bussmann series fuse
RS100
P5372-10
_CIH07 (25-30A)
_CIK07 (35-60A)
RS400
TCA2
_MC09C (125-200A)
Red warning carriers replaces the regular fuse carrier and cannot
hold a fuse.
Adaptors for GS fuses mount on the fuse carrier to accept a smaller
dimensioned fuse. Includes label to indicate use of GS fuse.
Fuse Holder
Catalog no.
Fuse holder
Catalog no.**
Use with GS fuse
RS20
RS20RED
RS32
GRS32-A
GSA 5 to 20A
RS32RED
RS63
GRS63-A
GSA 25 to 50A
RS32
RS63
RS63RED
RS100
RS100RED
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document
are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help
the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue
or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this
bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2018 Eaton
All Rights Reserved
Printed in USA
Publication No. 10083 - BU-MC13988
August 2018
Eaton, Bussmann, Quik-Spec and CUBEFuse
are valuable trademarks of Eaton in the U.S.
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
NEC is a registered trademark of the National
Fire Protection Association, Inc.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“RS32H”相匹配的价格&库存,您可以联系我们找货
