Technical Data 10488
Effective January 2023
Supersedes October 2019
Class J modular ferrule and knifeblade
fuse blocks
Knifeblade fuse blocks from 100 to 600 amps
feature phase barriers between poles for additional
safety with up to four mounting holes per pole
increase installation flexibility. All knifeblade blocks
meet UL creep and clearance requirements for
Industrial Power Circuits (UL 508 and UL 845).
Additionally, the 200 to 600 amp blocks meet the
higher UL creep and clearance requirements for
Power Distribution Standards (UL 98, UL 67, UL
489, UL 891 and UL 869A)
All blocks have optional IP20 finger-safe high
clarity, see-through covers for inspecting wire
terminations or thermography measurements
without removal. All covers enhance safety by
featuring probe holes for easier, safer testing
and a lockout/tagout capability. These covers
also have optional open fuse indication to speed
troubleshooting.
Easy circuit identification is available for 30 and
60 amp blocks and covers with universal marker
labels.
Catalog symbol:
JM60_
Description:
Bussmann® series Class J modular fuse blocks
increase versatility, reduce labor and enhance
safety for any panel or electrical system design.
Available for the full Class J fuse amp range.
These fuse blocks feature a standard fuse
clip reinforcing spring for enhanced electrical
contact between the blcok and fuse. All blocks
are available as single-pole versions that snap
together for the required number of poles, or as
factory configured 2-, and 3-pole versions to meet
stocking requirements.
The modular design permits reducing inventory,
assembly time and labor with tool-less assembly
of multiple poles at point of use.
Ferrule fuse blocks up to 60 amps save panel
space with the smallest width dimension on the
market and feature DIN-Rail and panel mount
versatility so that one product can be used for
multiple applications with lower inventory cost.
Specifications:
Ratings
Volts 600 V
Amps up to 600 A
Withstand 200 kA RMS Sym
Agency information
Blocks:
• UL® Listed E14853 — IZLT and IZLT7
CSA® Certified 47235-6225-01
CE
RoHS Compliant
REACH declaration available upon request
Covers:
• UL Listed E58836 - JDVS
CSA Certified 47235-6225-01 (30 and 60A)
RoHS Compliant
Class J modular ferrule and knifeblade fuse blocks
Poles
1-, 2-, 3-pole units factory assembled
Single-pole units snap together to create desired number of poles
Flammability ratings
Blocks: UL 94V0, self-extinguishing
Covers: UL 94HB, self-extinguishing
Optional see-through covers provide IP20 finger-safe
protection and feature a lockout/tagout provision
to improve electrical safety. These covers are
also available with open fuse indicating
version for faster troubleshooting.
Order separately, one cover per
block pole.
Operating and storage temperature range
Blocks -40°C to +120°C
Covers;
• Non-Indicating -40°C to +120°C
Indicating -20°C to +90°C*
* Indication requires minimum 90V and closed circuit to illuminate.
Materials
Base: Thermoplastic
Terminals:
• Tin-plated copper brass (30 and 60A)
Tin-plated aluminum (box lug)
Covers: Thermoplastic
Conductors
See catalog numbers for details and torque specifications.
Standard dual lugs on
600A blocks and optional
dual lugs on 400A blocks
for easier wiring using two,
smaller conductors.
Modular Class J ferrule and knifeblade fuse blocks
30 and 60 amp ferrule fuse blocks have DIN-rail and panel mounting capability,
the modular designs allows blocks toand snap together for the desired number
of poles. They accept optional snap-on covers for IP20 finger-safe protection and
feature a lockout/tagout to improve electrical safety.
On blocks rated from 100 to 600A, the optional covers can be completely removed
for servicing or simply hinged open.
100 to 600 amp knifeblade fuse blocks are panel mount with multiple holes for
installation flexibility and the modular design allows blocks to snap together for the
desired number of poles. They accept optional snap-on covers for IP20 finger-safe
protection and feature a lockout/tagout provision to improve electrical safety.
2
Eaton.com/bussmannseries
Table 1: 30 and 60 amp block catalog numbers
Fuse
amp range
Terminal type
Poles Box lug/slot screw
1
JM60030-1CR
Box lug/hex screw
JM60030-1CHR
#10-32 Phil-slot screw Pressure plate
JM60030-1SR
JM60030-1PR
up to 30
2
JM60030-2CR
JM60030-2CHR
JM60030-2SR
JM60030-2PR
3
JM60030-3CR
JM60030-3CHR
JM60030-3SR
JM60030-3PR
1
JM60060-1CR
JM60060-1CHR
2
3
JM60060-2CR
JM60060-3CR
JM60060-2CHR
JM60060-3CHR
35 to 60
Optional covers*
Indicating**
Non-indicating
CVRI-J-60030
CVR-J-60030
CVRI-J-60060
CVR-J-60060
* Covers sold separately, one cover per pole.
** Open fuse indication requires 90 volts minimum and closed circuit to operate.
Table 2: 30 and 60 amp block terminals and conductors
Terminal type
AWG type/range
Box lug
75°C
Cu 2-14,
AL 2-8
#10-32 Phil-slot
screw
75/90°C
Cu 10-18
AWG
2-3
4-6
8
10-14
Torque N•m (lb-in)
5.6 (50)
5.1 (45)
4.5 (40)
4.0 (35)
10-18
2.3 (20)
Recommended Bussmann series fuses:
Description
Ultimate protection Low-Peak LPJ timedelay fuses
Advanced protection Limitron JKS fastacting fuses
High speed DFJ drive fuse
DIN-Rail end stops
Marker labels
Finger grips on cover
for easy removal
Standard phase barriers
for additional safety
Data sheet no.
up to 60
1006
up to 60
1026
up to 60
1048
Recommended accessories for 30 and 60 amp blocks:
Description
Pressure plate
Amps
Catalog no.
BRKT-ND
BRKT-NDSCREW2
TM26CB
Marker label provision for easy
circuit dientification
Optional see-through, snap-on
cover for easy visual inspection
Optional open fuse indication
speeds troubleshooting
Vent slots improve cooling*
Toolless interlocking modular design
for easy point-of-use assembly
Lockout/tagout feature
improves safety
DIN-rail or panel mounting
on each pole provides
Probe holes for easy testing
without removing cover
*No fuse derating necessary.
3
Dimensions; 30A Class J block - in (mm)
55
2.2
28
1.1
JM60030-1CR
R3
.1
87 12
3.4 .5
PROVISION FOR
MARKING LABEL
46
1.8
17
.7
JM60030-2CR
28
1.1
29
1.1
56
2.2
58
2.3
83
3.3
PROVISION FOR
MARKING LABEL
CVR-J-60030
(COVER NON-INDICATING)
110
4.3
JM60030-3CR
84
3.3
LOCKOUT TAGOUT RINGS
JM60030-1CR
(SHOWN WITH COVER)
4
CVRI-J-60030
(COVER WITH INDICATION)
Dimensions; 60A Class J block - in (mm)
39
1.5
7
.3
76
3.0
R3
.1
94
3.7
JM60060-1CR
5
.2
18
.7
38
1.5
38
1.5
PROVISION FOR
MARKING LABEL
53
2.1
JM60060-2CR
18
.7
114
4.5
75
3.0
65
2.6
PROVISION FOR
MARKING LABEL
PROVISION FOR
MARKING LABEL
CVR-J-60060
119
4.7
JM60060-3CR
113
4.5
CVRI-J-60060
JM60060-1CR
(SHOWN WITH COVER)
5
Installing /removing covers
For larger conductors, trim center tab
at notch as show in detail A.
Install cover:
Position cover
over block and
push straight
down until it
snaps/clicks
into place.
Trim tab
here
A
Open cover:
Using both
outside handles,
pull straight up.
Detail A
Installing blocks on DIN-Rail
Place one edge of DIN-Rail in fuse block base, then rotate block down until it clicks into place.
6
Table 6: Class J 100 to 600 amp knifeblade blocks and covers
Fuse
amp
range
70-100
110-200
225-400
450-600
Covers*
Poles
Catalog nos.
1
JM60100-1CR
Conductors***
Non-indicating
CVR-J-60100-M
Indicating**
CVR-J-60100-M
Solid and stranded
Fine stranded
Torque
N•m (lb-in)
Cu 1-3 AWG
6.2 (55)
1/0-3 AWG; (2) Cu 4-6 AWG
Cu 4-6 AWG
5.6 (50)
2 4-6 AWG; (2) Cu 8 AWG
Cu 8 AWG
5.1 (45)
8 AWG; (2) Cu 10-14 AWG
4.5 (40)
2
JM60100-2CR
3
JM60100-3CR
Cu 10-14 AWG; Al 10-12 AWG
4.0 (35)
1
JM60200-1CR
250kcmil-1 AWG
Cu 3/0-1 AWG
42 (375)
2
JM60200-2CR
3
JM60200-3CR
2-6 AWG; (2) Cu 2-6 AWG
Cu 2-6 AWG
31 (275)
1
JM60400-1CR
600kcmil
2
JM60400-2CR
500kcmil-4 AWG
3
JM60400-3CR
1
JM60400-1MW22
2
JM60400-2MW22
3
JM60400-3MW22
1
JM60600-1CR
2
JM60600-2CR
3
JM60600-3CR
CVR-J-60200-M
CVR-J-60200-M
CVR-J-60400-M
CVR-J-60600
51 (450)
N/A
(2) Cu 3/0 - 4 AWG
57 (500)
(2) Al 3/0 - 4 AWG
CVR-J-60400-M
CVRI-J-60600
* Covers sold separately.
*** Ratings for copper and aluminum conductors except where otherwise noted.
57 (500)
34 (300)
250kcmil-1 AWG
Cu 3/0-1 AWG
42.37 (375)
Cu 2-6 AWG
31.07 (275)
2 (2) 500kcmil-4 AWG
N/A
51 (450)
Description
Amps
Data sheet no.
70 to 600 1007
70 to 600 1026
70 to 600 1048
improves safety
for easy removal
Finger-safe wire entry
with cutout tabs for larger
wires on all versions
Multiple mounting holes for
each pole provide flexible,
secure mounting
two, smaller conductors.
7
Dimensions; 100A Class J block - in (mm)
22 TYP
.9
JM60100-1CR
53
2.1
51
2.0
104
4.1
102
4.0
1 TYP
.04
29 TYP
1.1
8 TYP
.3
71
2.8 29 TYP
1.1
138 TYP
5.4
JM60100-2CR
13 TYP
.5
ALLEN KEY
9/32" TYP
77
3.0
55 TYP
2.2
35 TYP
1.4
51 TYP
2.0
37 TYP
1.5
155
6.1
153
6.0
CVR-J-60100-M
JM60100-3CR
152
6.0
CVRI-J-60100-M
REMOVE FOR
WIRE LARGER
THAN 6 AWG
JM60100-1CR
(SHOWN WITH COVER)
8
Dimensions; 200A Class J block - in (mm)
69 TYP
2.7
67 TYP
2.6
8 TYP
.3
JM60200-1CR
136
5.4
134
5.3
35 TYP
1.4
32 TYP
1.2
172 TYP
6.8
81 TYP
32 TYP
3.2
1.3
9 TYP
.3
19 TYP
.8
JM60200-2CR
ALLEN KEY
3/8" TYP.
97 TYP
3.8
75 TYP
3.0
45 TYP
1.8
67 TYP
2.6
46 TYP
1.8
203
8.0
200
7.9
186
7.3
CVR-J-60200-M
JM60200-3CR
CVRI-J-60200-M
REMOVE FOR
WIRE LARGER
THAN 2 AWG
JM60200-1CR
(SHOWN WITH COVER)
9
Dimensions; 400A Class J block - in (mm)
91 TYP
3.6
88 TYP
3.5
50 TYP
2.0
179
7.1
8 TYP
.3
41 TYP
1.6
JM60400-1CR
176
6.9
38 TYP
1.5
9 TYP
.3
201 TYP
7.9
JM60400-2CR
19 TYP
.8
90 TYP
3.5
ALLEN KEY
1/2" TYP
27 TYP
1.1
125 TYP
4.9
67 TYP
2.6
44 TYP
1.7
104 TYP
4.1
268
10.5
JM60400-1MW22
JM60400-3CR
88 TYP
3.5
88 TYP
3.5
67 TYP
2.6
JM60400-2MW22
265
10.4
216
8.5
CVR-J-60400-M
CVRI-J-60400-M
REMOVE ONLY
FOR DUAL LUG
JM60400-1CR
(SHOWN WITH COVER)
10
REMOVE FOR
WIRE LARGER
THAN 250KCMIL
Dimensions; 600A Class J block - in (mm)
123 TYP
4.8
120 TYP
4.7
ALLEN KEY
3/8" TYP
71 TYP
2.8
244
9.6
241
9.5
8 TYP
.3
51 TYP
2.0
52 TYP
2.1
JM60600-1CR
9 TYP
.3
234 TYP
100 TYP
9.2
3.9
JM60600-2CR
19 TYP
.8
151 TYP
5.9
134 TYP
5.3
43 TYP
1.7
73 TYP
2.9
121 TYP
4.8
29 TYP
1.1
363
14.3
365
14.4
253
10.0
JM60600-3CR
CVR-JM60600
CVRI-JM60600
REMOVE FOR
WIRE LARGER
THAN 250KCMIL
JM60600-1CR
(SHOWN WITH COVER)
11
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2023 Eaton
All Rights Reserved
Printed in USA
Publication No. 10488
January 2023
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“JM60060-2CR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 6+1624.923576+210.30155
- 国内价格
- 1+382.19040
- 200+147.90600
- 500+142.71120
- 1000+140.14080
