RM25200-1CR
RM25200-1CR
    EATON(伊顿)
    RM25200-1CR
RM25200-1CR 数据手册
Technical Data 10489 Effective February 2023 Supersedes December 2018 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Knifeblade fuse blocks from 100 to 600 amps feature phase barriers between poles for additional safety with up to four mounting holes per pole increase installation flexibility. All knifeblade blocks meet UL creep and clearance requirements for Industrial Power Circuits (UL 508 and UL 845). Additionally, the 200 to 600 amp blocks meet the higher UL creep and clearance requirements for Power Distribution Standards (UL 98, UL 67, UL 489, UL 891 and UL 869A) All blocks have optional IP20 finger-safe high clarity, see-through covers for inspecting wire terminations or thermography measurements without removal. All covers enhance safety by featuring probe holes for easier, safer testing and a lockout/tagout capability. These covers also have optional open fuse indication to speed troubleshooting. Catalog symbol: • RM25_ (250 V) • RM60_ (600 V) Easy circuit identification is available for 30 and 60 amp blocks and covers with universal marker labels. Specifications: Ratings • Description: Bussmann™ series Class R modular fuse blocks increase versatility, reduce labor and enhance safety for any panel or electrical system design. Available for the full Class R fuse amp range. These fuse blocks feature a standard fuse clip reinforcing spring for enhanced electrical contact between the block and fuse. All blocks are available as single-pole versions that snap together for the required number of poles, or as factory configured 2-, and 3-pole versions to meet stocking requirements. The modular design permits reducing inventory, assembly time and labor with tool-less assembly of multiple poles at point of use. Ferrule fuse blocks up to 60 amps save panel space with the smallest width dimension on the market and feature DIN-Rail and panel mount versatility so that one product can be used for multiple applications with lower inventory cost. Volts • 250 V • 600 V • Amps up to 600 • Withstand 200 kA RMS Sym. Agency information • • Blocks: • UL® Listed E14853 — IZLT and IZLT7 • CSA® Certified 47235-6225-01 • CE • RoHS Compliant • REACH declaration available upon request Covers: • UL Listed E58836 - JDVS • CSA Certified 47235-6225-01 (30 and 60 A) • RoHS Compliant • REACH declaration available upon request Technical Data 10489 Effective February 2023 Poles • 1-, 2-, 3-pole units factory assembled • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Optional see-through covers provide IP20 fingersafe protection and feature a lockout/tagout provision to improve electrical safety. These covers are also available with open fuse indicating version for faster troubleshooting. Order separately, one cover per block pole. Operating and storage temperature range • Blocks -40°C to +120°C • Covers • Non-Indicating -40°C to +120°C • Indicating -20°C to +90°C* * Indication requires minimum 90 V and closed circuit to illuminate. Materials • Base: Thermoplastic • Terminals • Tin-plated copper brass (30 and 60 A) • • Tin-plated aluminum (box lug) Covers: Thermoplastic Conductors • Dual lugs on 600 A blocks for easier wiring using two, smaller conductors. See catalog numbers for details and torque specifications Class R ferrule fuse blocks Class R knifeblade fuse blocks 30 and 60 amp ferrule fuse blocks have DIN-rail and panel mounting capability, the modular designs allows blocks to snap together for the desired number of poles. They accept optional snap-on covers for IP20 finger-safe protection and feature a lockout/tagout to improve electrical safety. 100 to 600 amp knifeblade fuse blocks are panel mount with multiple holes for installation flexibility and the modular design allows blocks to snap together for the desired number of poles. They accept optional snap-on covers for IP20 finger-safe protection and feature a lockout/tagout provision to improve electrical safety. 2 Eaton.com/bussmannseries Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Table 1: Class R 250 V 30 and 60 amp block catalog numbers Terminal type Fuse amp range Up to 30 35 to 60 Optional covers* Box lug/ slot screw Box lug/ hex screw #10-32 Phil-slot screw Screw with quick-connect Pressure plate 1 RM25030-1CR RM25030-1CHR RM25030-1SR RM25030-1QR RM25030-1PR 2 RM25030-2CR RM25030-2CHR RM25030-2SR RM25030-2QR RM25030-2PR 3 RM25030-3CR RM25030-3CHR RM25030-3SR RM25030-3QR RM25030-3PR 1 RM25060-1CR RM25060-1CHR 2 RM25060-2CR RM25060-2CHR — — — 3 RM25060-3CR RM25060-3CHR Poles Indicating** Non-indicating CVRI-RH-25030 CVR-RH-25030 CVRI-RH-25060 CVR-RH-25060 * Covers sold separately, order one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. Table 2: Class R 250 V 30 and 60 amp block terminals and conductors AWG type/ range Terminal type 75°C Cu 2-14, AL 2-8 Box lug #10-32 Phil-slot screw Screw with quick-connect* Pressure plate 75/90°C Cu 10-18 AWG 2-3 Torque N•m (lb-in) 5.6 (50) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) 10-18 2.3 (20) * 3/16” Quick-connect terminal maximum ampacity dependent on female spade connector and wire ratings. Finger grips on cover for easy removal Recommended Bussmann series fuses: Description Volts Amps Data sheet no. Ultimate protection time-delay Low-Peak™ LPN 250 V Up to 60 1003 Advanced protection fast-acting Limitron™ KTN-R 250 V All 1043 Advanced protection energy efficient time-delay Fusetron™ FRN-R 250 V Up to 60 1019 Recommended accessories for 30 and 60 amp blocks: Description DIN-Rail end stops Catalog no. BRKT-ND BRKT-NDSCREW2 Optional see through, snapon cover for easy visual inspection Optional open fuse indication speeds troubleshooting Standard phase barriers for additional safety Tool-less interlocking modular design for easy point-of-use assembly Vent slots improve cooling* Lockout/tagout feature improves safety Probe holes for easy testing without removing cover DIN-rail or panel mounting on each pole provides installation flexibility *No fuse derating necessary. Eaton.com/bussmannseries 3 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Dimensions; 30 A, 250 V Class R block - in (mm) 50 2.0 26 1.0 80 3.2 RM25030-1CR RM25030-2CR 25 1.0 49 1.9 PROVISION FOR MARKER LABEL 15 .6 25 1.0 PROVISION FOR MARKER LABEL CVR-RH-25030 (NON-INDICATING) CVRI-RH-25030 (WITH INDICATION) 75 2.9 99 3.9 RM25030-3CR 74 2.9 LOCKOUTTAGOUT RING 45 1.8 4 Eaton.com/bussmannseries 51 2.0 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Dimensions; 60 A, 250 V Class R block - in (mm) RM25060-1CR 7 .3 4 .2 3 .1 108 4.2 35 1.4 32 1.2 6 .2 34 1.3 69 2.7 68 2.7 RM25060-2CR 103 4.1 47 1.8 58 2.3 34 1.3 19 .7 PROVISION FOR MARKER LABEL 135 5.3 RM25060-3CR 103 4.1 102 4.0 LOCKOUT TAGOUT RING CVR-RH-25060 (NON INDICATING) CVRI-RH-25060 (WITH INDICATION) Eaton.com/bussmannseries 5 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Installing/removing covers For larger conductors, trim center tab at notch as show in detail A. Install cover: Position cover over block and push straight down until it snaps/clicks into place. Trim tab here A Open cover: Using both outside handles, pull straight up. Detail A Installing blocks on DIN-Rail Place one edge of DIN-Rail in fuse block base, then rotate block down until it clicks into place. 6 Eaton.com/bussmannseries Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Table 3: Class R 250 V 100 to 600 amp knifeblade blocks and covers Covers* Fuse amp range Catalog nos. 1 70-100 110-200 225-400 450-600 2 Indicating** Conductors*** Non-indicating RM25100-1CR RM25100-2CR CVRI-RH-25100 CVR-RH-25100 Fine stranded — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG — 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 250 kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) 3 RM25100-3CR 1 RM25200-1CR 2 RM25200-2CR 3 RM25200-3CR 1 RM25400-1CR 600 kcmil 2 RM25400-2CR 500 kcmil-4 AWG 3 RM25400-3CR 1 RM25600-1CR 2 RM25600-2CR 3 RM25600-3CR CVRI-RH-25200 CVRI-RH-25400 CVR-RH-25200 CVR-RH-25400 57 (500) 51 (450) N/A (2) Cu 3/0 - 4 AWG 57 (500) (2) Al 3/0 - 4 AWG CVRI-RH-25600 CVR-RH-25600 Torque N•m (lb-in) Solid and stranded 34 (300) 2 (2) 500 kcmil-4 AWG N/A 51 (450) * Covers sold separately, order one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. *** Ratings for copper and aluminum conductors except where otherwise noted. Recommended Bussmann series fuses: Description Volts Amps Data sheet no. Ultimate protection time-delay Low-Peak™ LPN 250 V 70 to 600 1004 Advanced protection fast-acting Limitron™ KTN-R 250 V All 1043 Advanced protection energy efficient time-delay Fusetron™ FRN-R 250 V 70 to 600 1020 Probe holes for easy testing without removing cover Finger grips on cover for easy removal Standard phase barriers for additional safety Multiple mounting holes for each pole provide flexible, secure mounting Tool-less interlocking modular design for easy point-of-use assembly *No fuse derating necessary. Optional see through, snap-on cover for easy visual inspection Optional open fuse indication speeds troubleshooting Vent slots improve cooling* Lockout/tagout feature improves safety Finger-safe wire entry with cutout tabs for larger wires on all versions Dual lugs on 600 A blocks for easier wiring using two, smaller conductors. Eaton.com/bussmannseries 7 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Dimensions; 100 A, 250 V Class R block - in (mm) 1 .0 171 6.7 61 2.4 61 2.4 55 2.2 14 .6 102 4.0 51 2.0 22 .9 51 2.0 103 4.1 ALLEN KEY #: 3/16"(5.5MM) 1 .0 7 .3 13 .5 103 4.1 ALLEN KEY #: 3/16"(5.5MM) 8 14 .6 22 .9 38 1.5 38 1.5 7 .3 13 8 .5 51 2.0 35 1.4 35 1.4 RM25100-1CR RM25100-2CR 171 6.7 61 2.4 14 .6 22 .9 72 2.8 55 2.2 51 2.0 171 6.7 153 6.0 184 7.2 51 2.0 38 1.5 51 2.0 35 1.4 RM25100-3CR 8 7 .3 13 8 .5 103 4.1 ALLEN KEY #: 3/16"(5.5MM) Eaton.com/bussmannseries 51 2.0 67 2.6 69 2.7 182 7.2 WITH OPTIONAL COVER 70 2.8 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Dimensions; 200 A, 250 V Class R block - in (mm) ALLEN KEY #: 3/8"(10.0MM) 70 2.7 68 2.7 16 .6 9 .3 ALLEN KEY #: 3/8"(10.0MM) 68 2.7 70 2.7 16 .6 19 .8 19 12 .8 35 1.4 116 4.6 9 .3 35 1.4 136 5.3 8 .3 68 2.7 33 1.3 116 4.6 12 45 1.8 35 1.4 45 1.8 47 1.8 47 1.8 RM25200-1CR ALLEN KEY #: 3/8"(10.0MM) 68 2.7 RM25200-2CR 70 2.7 68 2.7 16 .6 8 .3 96 3.8 9 .3 203 8.0 19 .8 8 .3 207 8.1 35 1.4 221 8.7 33 1.3 12 35 1.4 33 1.3 75 3.0 94 3.7 91 3.6 35 1.4 116 4.6 220 8.7 WITH OPTIONAL COVER 45 1.8 47 1.8 68 2.7 68 2.7 RM25200-3CR Eaton.com/bussmannseries 9 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Dimensions; 400 A, 250 V Class R block - in (mm) 21 .8 80 3.2 80 3.1 ALLEN KEY #:1/2" 9 .3 80 3.1 ALLEN KEY #:1/2" 21 .8 80 3.2 50 2.0 8 .3 42 1.7 185 7.3 50 2.0 92 3.6 50 2.0 19 .8 9 .3 19 .8 16 129 5.1 16 129 5.1 71 2.8 71 2.8 92 3.6 44 1.7 44 1.7 RM25400-2CR RM25400-1CR 80 3.1 21 .8 80 3.2 50 2.0 277 10.9 121 4.8 42 1.7 50 2.0 105 4.1 241 9.5 42 1.7 254 10.0 ALLEN KEY #:1/2" 50 2.0 9 .3 19 .8 71 2.8 92 3.6 44 1.7 RM25400-3CR 10 258 10.1 129 5.1 16 Eaton.com/bussmannseries 116 4.6 113 4.5 WITH OPTIONAL COVER 92 3.6 8 .3 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Dimensions; 600 A, 250 V Class R block - in (mm) 107 4.2 8 .3 107 4.2 91 3.6 125 4.9 9 .3 19 16 .8 155 6.1 50 2.0 250 9.9 19 .8 75 2.9 75 2.9 9 .3 25 1.0 25 1.0 91 3.6 16 75 2.9 29 1.1 97 3.8 78 3.1 43 1.7 ALLEN KEY #: 3/8” (10.0mm) 155 6.1 ALLEN KEY #:3/8"(10.0MM) 29 1.1 43 1.7 29 1.1 78 3.1 RM25600-2CR RM25600-1CR 107 4.2 25 1.0 91 3.6 75 2.9 50 2.0 91 3.6 16 155 6.1 29 1.1 78 3.1 ALLEN KEY #:3/8"(10.0MM) 29 1.1 97 3.8 303 11.9 141 5.6 138 5.4 75 2.9 9 .3 135 5.3 151 6.0 289 11.4 75 2.9 375 14.8 19 .8 50 2.0 307 12.1 WITH OPTIONAL COVER 29 1.1 97 3.8 43 1.7 RM25600-3CR Eaton.com/bussmannseries 11 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Table 4: Class R 600 V 30 and 60 amp block catalog numbers Terminal type Fuse amp range Box lug/ hex screw #10-32 Phil-slot screw Pressure plate 1 RM60030-1CR RM60030-1CHR RM60030-1SR RM60030-1PR 2 RM60030-2CR RM60030-2CHR RM60030-2SR RM60030-2PR 3 RM60030-3CR RM60030-3CHR RM60030-3SR RM60030-3PR 1 RM60060-1CR RM60060-1CHR 2 RM60060-2CR RM60060-2CHR — — 3 RM60060-3CR RM60060-3CHR Poles Up to 30 35 to 60 Optional covers* Box lug/ slot screw Indicating** Non-indicating CVRI-RH-60030 CVR-RH-60030 CVRI-RH-60060 CVR-RH-60060 * Covers sold separately, order one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. Table 5: Class R 600 V 30 and 60 amp block terminals and conductors Terminal type AWG type/range 75°C Cu 2-14, AL 2-8 Box lug #10-32 Phil-slot screw Pressure plate 75/90°C Cu 10-18 AWG Torque N•m (lb-in) 2-3 5.6 (50) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) 10-18 2.3 (20) Recommended Bussm ann series fuses: Description Volts Amps Data sheet no. Ultimate protection time-delay Low-Peak LPS 600 V Up to 60 1001 Advanced protection fast-acting Limitron KTS-R 600 V All 1044 Advanced protection energy efficient time-delay Fusetron FRS-R 600 V Up to 60 1017 Recommended accessories for 30 and 60 amp blocks: Description Catalog no. DIN-Rail end stops Finger grips on cover for easy removal Standard phase barriers for additional safety Tool-less interlocking modular design for easy point-of-use assembly BRKT-ND BRKT-NDSCREW2 Optional see through, snap-on cover for easy visual inspection Optional open fuse indication speeds troubleshooting Vent slots improve cooling* Lockout/tagout feature improves safety Probe holes for easy testing without removing cover *No fuse derating necessary. 12 Eaton.com/bussmannseries DIN-rail or panel mounting on each pole provides installation flexibility Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Dimensions; 30 A, 600 V Class R block - in (mm) 30 1.16 59 7 2.32 .28 13 .50 RM60030-1CR 4 .16 PROVISION FOR MARKING LABEL 159 6.25 RM60030-2CR 2 .08 31 1.21 2 .08 60 2.37 29 1.16 CL 46 1.80 58 2.28 PROVISION FOR MARKING LABEL 88 3.48 RM60030-3CR 80 3.13 90 3.53 183 7.21 CVR-RH-60030 (NON-INDICATING) CVRI-RH-60030 (WITH INDICATION) LOCKOUT TAGOUT RING Eaton.com/bussmannseries 13 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Dimensions; 60 A, 600 V Class R block - in (mm) 7 .3 8 .3 RM60060-1CR 3 .1 5 .2 39 1.6 172 RM60060-2CR 6.8 77 3.0 38 1.5 54 2.1 77 3.0 66 2.6 17 .7 38 1.5 PROVISION FOR MARKER LABEL 82 3.2 RM60060-3CR 116 4.6 CVR-RH-60060 (NON-INDICATING) CVRI-RH-60060 (INDICATING) 202 8.0 115 4.5 LOCKOUT TAGOUT RING 14 Eaton.com/bussmannseries Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Installing/removing covers For larger conductors, trim center tab at notch as show in detail A. Install cover: Position cover over block and push straight down until it snaps/clicks into place. Trim tab here A Open cover: Using both outside handles, pull straight up. Detail A Installing blocks on DIN-Rail Place one edge of DIN-Rail in fuse block base, then rotate block down until it clicks into place. Eaton.com/bussmannseries 15 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Table 6: Class R 600 V 100 to 600 amp knifeblade blocks and covers Fuse amp range Covers* Poles 1 70-100 110-200 225-400 450-600 Catalog nos. Conductors*** Indicating** Non-indicating RM60100-1CR CVRI-RH-60100 CVR-RH-60100 Torque N•m (lb-in) Solid and stranded Fine stranded — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 4.5 (40) 2 RM60100-2CR 8 AWG; (2) Cu 10-14 AWG — 3 RM60100-3CR Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 1 RM60200-1CR 250 kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2 RM60200-2CR 3 RM60200-3CR 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) 1 RM60400-1CR 600 kcmil 2 RM60400-2CR 500 kcmil-4 AWG 3 RM60400-3CR 1 RM60600-1CR 2 RM60600-2CR 3 RM60600-3CR CVRI-RH-60200 CVRI-RH-60400 CVR-RH-60200 CVR-RH-60400 57 (500) 51 (450) N/A (2) Cu 3/0 - 4 AWG 57 (500) (2) Al 3/0 - 4 AWG CVRI-RH-60600 CVR-RH-60600 34 (300) 2 (2) 500 kcmil-4 AWG N/A 51 (450) * Covers sold separately. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. *** Ratings for copper and aluminum conductors except where otherwise noted. Recommended Bussmann series fuses: Description Volts Amps Ultimate protection time-delay Low-Peak LPS 600 V 70 to 600 1004 Advanced protection fast-acting Limitron KTS-R 600 V All 1044 Advanced protection energy efficient time-delay Fusetron FRS-R 600 V 70 to 600 1018 Probe holes for easy testing without removing cover Finger grips on cover for easy removal Optional see through, snap-on cover for easy visual inspection Data sheet no. Optional open fuse indication speeds troubleshooting Vent slots improve Standard phase barriers for additional safety Lockout/tagout feature improves safety Multiple mounting holes for each pole provide flexible, secure mounting Finger-safe wire entry with cutout tabs for larger wires on all versions Tool-less interlocking modular design for easy point-of-use assembly *No fuse derating necessary. 16 Eaton.com/bussmannseries Dual lugs on 600 A blocks for easier wiring using two, smaller conductors Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Dimensions; 100 A, 600 V Class R block - in (mm) ALLEN KEY #:3/16"(5.5MM) ALLEN KEY #:3/16"(5.5MM) 14 .6 55 2.2 112 4.4 1 .0 51 2.0 22 .9 112 4.4 102 4.0 51 2.0 7 .3 13 8 .5 13 .5 38 1.5 8 51 2.0 35 1.4 35 1.4 RM60100-2CR RM60100-1CR 14 .6 22 .9 55 2.2 112 4.4 72 2.8 51 2.0 153 6.0 234 9.2 13 .5 51 2.0 68 2.7 67 2.6 7 .3 154 6.1 55 2.2 222 8.7 51 2.0 38 1.5 7 .3 154 6.1 38 1.5 ALLEN KEY #:3/16"(5.5MM) 14 .6 22 .9 55 2.2 8 70 2.8 233 9.2 WITH OPTIONAL COVER 51 2.0 35 1.4 RM60100-3CR Eaton.com/bussmannseries 17 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Dimensions; 200 A, 600 V Class R block - in (mm) ALLEN KEY #:3/8"(10.0MM) ALLEN KEY #:3/8"(10.0MM) 70 2.7 131 5.2 8 .3 179 7.1 32 1.2 9 .3 12 19 .8 35 1.4 179 7.1 12 46 1.8 67 2.6 45 1.8 45 1.8 RM60200-1CR 9 .3 12 131 5.2 RM60200-2CR 70 2.7 16 .6 96 3.8 75 3.0 35 1.4 32 1.2 200 7.9 271 10.7 35 1.4 285 11.2 32 1.2 179 7.1 ALLEN KEY #:3/8"(10.0MM) 67 2.6 67 2.6 45 1.8 RM60200-3CR 18 35 1.4 67 2.6 46 1.8 46 1.8 16 .6 35 1.4 9 .3 19 .8 70 2.7 16 .6 67 2.6 19 .8 131 5.2 Eaton.com/bussmannseries 35 1.4 92 3.6 89 3.5 284 11.2 WITH OPTIONAL COVER Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Technical Data 10489 Effective February 2023 Dimensions; 400 A, 600 V Class R block - in (mm) ALLEN KEY #:1/2" ALLEN KEY #:1/2" 80 3.2 156 6.2 8 .3 9 .3 21 .8 9 .3 50 2.0 185 7.3 92 3.6 19 .8 50 2.0 206 8.1 42 1.7 16 92 3.6 71 2.8 44 1.7 44 1.7 71 2.8 RM60400-2CR RM60400-1CR 156 6.2 80 3.2 21 .8 50 2.0 42 1.7 121 4.8 50 2.0 105 4.1 317 12.5 277 10.9 330 13.0 42 1.7 ALLEN KEY #:1/2" 50 2.0 116 4.6 113 4.5 334 13.2 206 8.1 9 .3 71 2.8 50 2.0 206 8.1 16 19 .8 19 .8 21 .8 80 3.2 156 6.2 WITH OPTIONAL COVER 16 92 3.6 92 3.6 44 1.7 RM60400-3CR Eaton.com/bussmannseries 19 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 Dimensions; 600 A, 600 V Class R block - in (mm) 184 7.2 25 1.0 91 3.6 75 2.9 25 1.0 91 3.6 184 7.2 8 .3 125 4.9 ALLEN KEY #: 3/8"(10.0MM) 250 9.9 ALLEN KEY #: 3/8"(10.0MM) 9 .3 19 .8 50 2.0 91 3.6 75 2.9 231 9.1 16 9 .3 19 .8 75 2.9 231 9.1 16 97 3.8 29 1.1 78 3.1 29 1.1 43 1.7 43 1.7 78 3.1 29 1.1 RM60600-2CR RM60600-1CR 184 7.2 91 3.6 25 1.0 75 2.9 50 2.0 151 6.0 135 5.3 366 14.4 91 3.6 ALLEN KEY #: 3/8"(10.0MM) 379 14.9 75 2.9 50 2.0 9 .3 19 .8 78 3.1 16 29 1.1 97 3.8 RM60600-3CR Eaton.com/bussmannseries 383 15.1 WITH OPTIONAL COVER 29 1.1 43 1.7 20 75 2.9 231 9.1 142 5.6 139 5.5 97 3.8 29 1.1 Technical Data 10489 Class R 250 V and 600 V modular ferrule and knifeblade fuse blocks Effective February 2023 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2023 Eaton All Rights Reserved Printed in USA Publication No. 10489 — BU-MC16XXX February 2023 Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Follow us on social media to get the latest product and support information.
RM25200-1CR 价格&库存
很抱歉,暂时无法提供与“RM25200-1CR”相匹配的价格&库存,您可以联系我们找货
RM25200-1CR
    • 1+748.31040
    • 200+289.59120
    • 500+279.40680
    • 1000+274.38480
