12351
12351
    GREENLEECOMMUNICATIONS(格林利)
12351 数据手册
PUNCH UNT-2-1/4" (POP) Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 12351 UPC No: 783310123514 Description • • • • • • "The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52"" (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster " Specifications • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 10 GA (3.500 MM) Includes : Punch, Die And Draw Stud Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers Replacement Part : 12355 UPC 12355 Punch, 12353 UPC 12353 Die And 04042 UPC 04042 Draw Stud Size : 2-1/4 IN (57.200 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 2.900 LB (1336.000 GM)
12351 价格&库存
很抱歉,暂时无法提供与“12351”相匹配的价格&库存,您可以联系我们找货
