PAS69278-91NF
PAS69278-91NF
    LAIRD(莱尔德)
    PANELSLP91CMNF
PAS69278-91NF 数据手册
PAS69278 698-960 MHz/1710-2700 MHz Pole Mount Directional Panel Antenna MULTI-BAND DIRECTIONAL PANEL ANTENNA The PAS69278 antenna is a wide band dual port directional panel antenna with slant 45 polarization that covers the domestic LTE700/Cellular/PCS/AWS/MDS and global GSM900/ GSM1800/UMTS/LTE2600 bands. The antenna is ideal for both indoor and outdoor applications. It includes a UV stable radome enclosure that provides years of use without degradation to either mechanical properties or aesthetics. FEATURES & BENEFITS • Applicable for both 3G and 4G solutions • Domestic LTE 700 band and Global LTE 2600 band • WiMax 2300/2500 bands • Domestic Cellular and Global GSM • Weatherproof UV stable radome SPECIFICATIONS • Wall mounting hardware included (optional mast mount kit available) • Conformance to RoHS APPLICATIONS • Wireless Terminal, Point-of-Sale, Machine to Machine, • Automatic Meter Reading and Home Security TYPICAL ELECTRICAL SPECIFICATIONS Frequency 698 – 960 MHz / 1710 – 2700 MHz VSWR 2.0:1 Max. Gain 698 – 960 MHz: 7.5 – 9.0 dBi, 1700 – 2700 MHz: 5.7 – 9.5 dBi Average Efficiency 698 – 960 MHz: 80% - 87%, 1700 – 2700 MHz: 60% - 85% 3 dB Beamwidth (Vertical plane) 698 – 960 MHz: 55° – 70°, 1700 – 2700 MHz: 50° – 80° 3 dB Beamwidth (Horizontal plane) 698 – 960 MHz: 55° – 70°, 1700 – 2700 MHz: 50° – 80° F/B Ratio , Co-pol 698 – 960 MHz: > 23 dB, 1700 – 2700 MHz: > 17 dB Cross polarization, Axial 698 – 960 MHz: > 25 dB, 1700 – 2700 MHz: > 17 dB, typical 23 dB Isolation > 25 dB Polarization Slant ± 45o Nominal Impedance 50 Ohms Power 2 x 10 Watts RF Connector Dual Type N female IP Class IP55 Environmental Conditions ETSI EN 300 019-2-4, class 4.1E. Mount Style Wall/Mast w/mounting hardware (Wall mount) Radome and Base Plastic UL94 V0 rated (UV resisted) Radome & Base color: White, Color code (SABIC) WH9B034 Material Substance Compliance ROHS Compliant Temperature -40°C to +70°C Dimensions 295 x 295 x 82 mm Weight 1.46 kg CABLES AND CONNECTORS Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.(0).1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com PART NUMBER CABLE LENGTH CONNECTOR PAS69278-91NF Dual 91 cm (36”) Dual Type N- Female PAS69278-FNF N/A (Direct connect) Dual Type N- Female PAS69278 698-960 MHz/1710-2700 MHz Pole Mount Directional Panel Antenna TYPICAL RADIATION PATTERNS 698 MHz 900 MHz 960 MHz Low Band 698-960 MHz 1710 MHz 2200 MHz 2700 MHz High Band 1710-2700 MHz ANT-DS-PAS69278 090414 Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
PAS69278-91NF 价格&库存
很抱歉,暂时无法提供与“PAS69278-91NF”相匹配的价格&库存,您可以联系我们找货
