S34018PT
3400-3600 MHz 18dBi
Wide Band Panel Antenna
Innovative Technology
for a Connected World
3400-3600 MHZ 18 dBi PANEL ANTENNA
Laird Technologies’ S34018PT antenna is a high gain vertical linear panel antenna exhibiting 18 dBi
of gain. Wall mount hardware is included with the each antenna and the standard configuration includes
a 39”integrated coax pigtail and an N female connector. Common applications include point-to-point links
and customer premises antennas in point-to-multipoint applications.
The antenna’s rugged UV stabile outdoor low profile enclosure makes it a perfect choice for Broadband
Wireless access subscribers. Although the antenna is aesthetically neutral an will blend into any environment,
it can also be painted using non-carbon based paint.
FEATURES
• Low profile housing
• IP66 Rating
• Heavy Duty Tilt Mount
• Performance optimized using Laird Technologies’
proprietary RF optimization tools
• Various connector and coax lengths options available
SPECIFICATIONS
PARAMETER
Part Number
Frequency
18 dBi
2.0:1
100
RF Connector
N-male
Power Rating
1 W (average) /10 W (peak)
Weight
Wind Surface Area
Wind Survival
Operational Temperature
Mount Style
Water / Dust Seal Rating
RoHS
Europe: +1.32.80.7866.12
IAS-EUSales@lairdtech.com
Asia: +1.65.6.243.8022
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
20º
Linear, Vertical/Horizontal
Cable Length in. (cm)
Dimensions (mm)
TM
19º
VSWR
Radome
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
3400 - 3600 MHz
50 Ohm
Polarization
global solutions: local support
S34018PT
Nominal Impedance
3 dBi Beamwidth-Horizontal
• WiMax networks
• WISP networks
• WLAN networks
• Designed specifically to support
802.11,b/g networks
• Campus
• Public safety wireless systems
SPECIFICATIONS
Gain
3 dBi Beamwidth-Vertical
MARKETS
Plastic Polycarbonate
10.2”x 10.2”x 1.3”
(259.1 x 259.1 x 33.5)
907.2 g
@ 0°, 0.067 m² / @ 90°, 0.009 m²
200 km/h
-40°C to +75°C
Tilt for Mast
IP-66
Compliant
S34018PT
3400-3600 MHz 18dBi
Antenna Patterns
E-Plane 3.5 GHz
H-Plane 3.5 GHz
SYSTEM ORDERING INFORMATION
S34018PT39NM 3400-3600 MHz 18 dBi wide band panel antenna
S34018PT12NM 3400-3600 MHz 18 dBi wide band panel antenna with N Male connector
S34018PT12NF 3400-3600 MHz 18 dBi wide band panel antenna with SMA Male connector
ANT-DS-S34018PT 1110
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird
Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability
of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold
pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2010 Laird Technologies, Inc. All Rights Reserved. Laird,
Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the
property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“S34018PT12NM”相匹配的价格&库存,您可以联系我们找货
