RS63PWH
RS63PWH
    EATON(伊顿)
    RS63PWH
RS63PWH 数据手册
Technical Data 10801 BUSSMANN SERIES Effective August 2018 Supersedes April 2015 Red Spot fuse holders for BS88 HRC industrial fuses Termination/Connection Styles: • Front connected (20-400 A) • Back stud connected (20-400 A) • Front/back stud connected (20-400 A) • Back stud connected, flush mounted (20 A) Front connected Back stud connected Catalog symbol • RS(amps)(connection style/color) Description Bussmann™ series Red Spot fuse holders are a range of CSA Certified IP20 finger-safe fuse holders for BS88 HRC industrial fuses in rating up to 400A. Ratings • Volts • 600 Vac/dc (CSA) • 690 Vac (IEC) • Amps 20, 32, 63, 100, 200 and 400 A • SCCR 80 kA Front/back stud connected Back stud connected flush mounted (20 A only) Flammability rating • RS20H to RS63H, V-1 • RS100H to RS400H, V-0 Protection level IP20 Available colors • Maximum Operating Temperature: 40°C Wire type 70°C PVC/Cu Wire range 8 AWG to 500 kcmil(10 to 240 mm2) Agency information • CSA 22.2 No. 39, Class 6225 01, File 47235 • IEC 60269-1 and IEC 60269-2 Black, white, green and grey (available colors vary by amp rating) Features • Industry standard fuse holder for protecting utility and industrial installations • Large, proven contact system and anti-vibration feature helps ensure perfect carrier contact alignment and superior electrical contact • Conductor insulating sleeves help prevent inadvertent contact at the entry point while fully shrouded terminals deliver IP20 protection • Molded parts made from flame-retardant, nonhygroscopic, high dielectric strength phenolic material • A broad range of accessories and Bussmann series fuses available for all Red Spot fuse holders Technical Data 10083 Red Spot fuse holders for BS88 HRC industrial fuses Effective August 2018 20 amp holders Volts Catalog no. IEC Vac Min. torque lb-in (N•m) CSA Vac/dc Conductor AWG (mm2) Termination/connection styles Conductors Fuse mount screws Bussmann series fuse family and amp range Color RS20H Black RS20HWH White 8-10 (10-2) RS20HGN Front connected 18 (2.03) Green RS20HGY Grey RS20P/G Black RS20P/GWH White RS20P/GGN 690 † 600 Back stud connected † 11 (1.24) Green RS20P/GGY _CIF21 (1-20A) Grey RS20PH/G 8-10 (10-2)† Front/back stud connected 18 (2.03)† Black RS20F Black RS20FWH White † RS20FGN Back stud connected, flush mounted † Green RS20FGY Grey † Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer. Dimensions — mm TWO HOLES 14.3 TO CLEAR BUSHING CL 59±1.0 79±1.0 79±1.0 CL CL 6.6 15 29.4 6.6 58.8 29.4 CL 55±1.0 10.3 27±1.0 M6 STUD 16 15 55±1.0 13.5 ONE HOLE TO TAKE M5 CHEESEHEAD FIXING SCREW CL 27±1.0 ONE HOLE TO TAKE M5 CHEESEHEAD FIXING SCREW TERMINALS ACCOMMODATE CABLES UP TO 10 Sq.mm Front connected 28.6 Back stud connected 38.1 58.7±1.0 54 58.7 10.3 28.6 55±1.0 10.3 1 HOLE 14.3 TO CLEAR BUSHING 27±1.0 58.8 5.57 10.3 6.6 M6 STUDS CL 80.6 84.4 M6 STUD 79.4±1.0 13.5 29.4 13.5 R4.8 CL ONE HOLE TO TAKE M5 CHEESEHEAD FIXING SCREW ONE MOULDING CLIP (LIST No. P67/10) IS SUPPLIED WITH EACH FLUSH MOULDING CARRIER AND BASE TYPE RS20F. 5.8 16 28.2 30.2 HOLE REQUIRED IN PANEL FOR FLUSH MOULDING RS20F. Back stud connected, flush mounted DIAMETER OF CABLE HOLE IN BASE CONTACT. Front/back stud connected 2 Eaton.com/bussmannseries Accessories Catalog no. Padlockable inserts RS20LOCK Red warning carriers RS20RED 28.6 Red Spot fuse holders for BS88 HRC industrial fuses Technical Data 10083 Effective August 2018 32 amp holders Volts Min. torque lb-in (N•m) IEC Vac Catalog no. CSA Vac/dc Conductor AWG (mm2) Termination/connection styles Fuse mount screws Conductors Bussmann series fuse family and amp range Color RS32H Black RS32HWH 6-10 (16-5) Front connected 18 (2.03) White RS32HGN Green RS32P 690 600 18 (2.03) RS32PWH † Back stud connected _CIH07 (25-30 A) _H07C (25-30 A) CGL-_ (1-30 A) Black † White RS32PGN Green RS32PH 6-10 (16-5)† Front/back stud connected 18 (2.03)† Black † Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer. Dimensions — mm 31.8 70 6.4 CL TWO HOLES 19.1 TO CLEAR BUSHINGS 31.8 70 81 15 6.4 28.6 17.5 36.5 103.2 CL CL 36.5 3.2 5.56 73 3.2 3.2 103.2 3.2 M6 STUD 15 CL 15 5.6 6.4 22.2 2 HOLES TO TAKE M5 CHEESEHEAD FIXING SCREWS 6.4 TWO HOLES TO TAKE M5 CHEESEHEAD FIXING SCREWS TERMINALS ACCOMMODATE CABLES UP TO 16 Sq.mm Front connected Back stud connected 19.1 ONE HOLE TO CLEAR BUSHING 31.8 81 6.4 CL 70 28.6 M6 STUD CL 3.2 103.2 3.2 36.5 17.5 15 CL 5.56 6.2 6.4 TWO HOLES TO TAKE M5 CHEESEHEAD FIXING SCREWS 22.2 DIAMETER OF CABLE HOLE IN BASE CONTACT Front/back stud connected Accessories Catalog no. Use with GS fuse Padlockable inserts RS32LOCK — Red warning carriers RS32RED — Adaptors for GS fuses* GRS32-A GSA 5 to 20 A * One kit required per fuse. Eaton.com/bussmannseries 3 Technical Data 10083 Red Spot fuse holders for BS88 HRC industrial fuses Effective August 2018 63 amp holders Volts IEC Vac Catalog no. Min. torque lb-in (N•m) CSA Vac/dc RS63H Conductor AWG (mm2) 1-6 (50-13) RS63HWH RS63P 690 RS63PWH 600 † RS63PH Fuse mount screws Conductors Front connected Black White † Front/back stud connected Bussmann series fuse family and amp range Color 31 (3.50) Back stud connected 1-6 (50-13)† RS63PHWH Termination/connection styles _CIK07 (35-60 A) _K07C (40-60 A) CGL-_ (35-60 A) Black 18 (2.03) White Black 31 (3.50)† White † Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer. Dimensions — mm 75.4 2 HOLES TO TAKE M5 CHEESEHEAD FIXING SCREWS 34.9 23.8 TWO HOLES 19.1 TO CLEAR BUSHINGS 15 CL 75.4 84 6.4 35 15.85 28.6 CL 17.5 3.2 M8 STUD 109.5 36.5 52.4 3.2 51.6 6.4 CL 3.2 5.6 5.6 41.3 6.4 77.8 3.2 109.5 CL 15.85 15 9.50 6.4 TWO HOLES TO TAKE M5 CHEESEHEAD FIXING SCREWS TERMINALS ACCOMMODATE CABLES UP TO 50 Sq. mm Front connected Back stud connected 84 ONE HOLE 19.1 TO CLEAR BUSHING. 75.4 28.6 17.5 3.2 36.5 52.4 6.4 M8 STUD 109.5 3.2 16 35 6.4 15 5.6 TWO HOLES TO TAKE M5 CHEESEHEAD FIXING SCREWS. 9.5 23.8 DIAMETER OF CABLE HOLE IN BASE CONTACT TERMINALS ACCOMMODATE CABLE UP TO 50sq mm Front/back stud connected Accessories Catalog no. Use with GS fuse Padlockable Inserts RS63LOCK — Red Warning Carriers RS63RED — Adaptors for GS Fuses* GRS63-A GSA 25 to 50A * One kit required per fuse. 4 Eaton.com/bussmannseries Red Spot fuse holders for BS88 HRC industrial fuses Technical Data 10083 Effective August 2018 100 amp holders Volts Min. torque lb-in (N•m) IEC Vac Catalog no. CSA Vac/dc RS100H RS100HWH RS100P 690 600 Conductor AWG (mm2) Termination/connection styles 3/0-4 (70-21) Front connected † RS100PWH RS100PH Conductors White 22 (2.50) †† Front/back stud connected Color Bussmann series fuse family and amp range Black 35 (3.95) Back stud connected 3/0-4 (70-21)† Fuse mount screws Black White 35 (3.95)† _CIL14 (80-100 A) _L14C (80-100 A) CGL-_ (70-100 A) Black † Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer. Dimensions — mm TWO HOLES 23.8 TO CLEAR BUSHINGS 100±1.0 50.8 15 CL 100 87.3 31.8 9.5 22.2 CL M10 STUD 9.5 50.8 ±1.0 11.1 139.7 CL 11.1 11.1 11.1 139.7 ±1.0 46.8 7.15 CL 7.15 12.7 9.5 15.0 9.5 27.8 2 HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS TERMINALS ACCOMMODATE CABLES UP TO 70 sq. mm Front connected Back stud connected 23.8 ONE HOLE TO CLEAR BUSHING 87.3 9.5 50.8 100 31.8 M10 STUD 46.8 11.1 CL 11.1 139.7 22.2 CL CL 7.15 15 12.7 9.5 TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS 27.8 TERMINALS ACCOMMODATE CABLES UP TO 70 Sq .mm Front/back stud connected Accessories Catalog no. For Bussmann series fuses Padlockable inserts RS100LOCK — RS100RED — P5372-10 _CIH07 (25-30A) _CIK07 (35-60A) Red warning carriers Fuse adaptor kits* * One kit required per fuse. Eaton.com/bussmannseries 5 Technical Data 10083 Red Spot fuse holders for BS88 HRC industrial fuses Effective August 2018 200 amp holders Volts Catalog no. Min. torque lb-in (N•m) IEC Vac CSA Vac/dc RS200H 250 kcmil-2/0 (120-67) RS200HWH RS200P Conductor AWG (mm2) 690 600 † RS200PWH RS200PH Termination/connection styles Conductors Front connected 222 (25.08) Back stud connected 250 kcmil-2/0 (120-67)† Color Bussmann series fuse family and amp range Black White 22 (2.50) † Front/back stud connected Fuse mount screws Black _M09C (125-200 A) CGL-_ (110-200 A) White 222 (25.08)† Black † Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer. Dimensions — mm TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREW 19.1 CL 136.5 95.3 CL 171.5 28.6 CL 28.6 215.9 215.9 9.53 CL 28.6 28.6 85.7 25.4 CL 69.9 22.2 31.8 22.2 136.5 M12 STUD 2 HOLES TO TAKE M6 CHEESE HEAD FIXING SCREWS 19.1 69.9 9.53 22.2 19.1 19.1 27mm TWO HOLES TO CLEAR BUSHINGS TERMINALS ACCOMMODATE CABLES UP TO 120 Sq. mm Front connected Back stud connected HOLE 27mm TO CLEAR BUSHING 136.5 19.1 69.9 95.3 28.6 CL 28.6 215.9 9.53 22.2 16.3 19.1 TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS Front/back stud connected 6 Eaton.com/bussmannseries 31.8 TERMINALS ACCOMMODATE CABLES UP TO 70 Sq .mm M12 STUD 85.7 25.4 22.2 CL 31.8 22.2 16.3 Red Spot fuse holders for BS88 HRC industrial fuses Technical Data 10083 Effective August 2018 400 amp holders Volts Min. torque lb-in (N•m) IEC Vac Catalog no. CSA Vac/dc RS400 RS400P 690 Conductor AWG (mm2) Termination/connection styles Conductors 500-250 kcmil (240-127) Front connected 222 (25.08) 600 † RS400PH Back stud connected 500-250 kcmil (240-127)† Fuse mount screws Color Bussmann series fuse family and amp range 53 (6.00) Black _P11C (250-400A) CGL-_ (225-400A) † Front/back stud connected 222 (25.08)† † Back stud connection requires use of customer supplied terminal lugs. Minimum/maximum conductor size and torque per terminal lug manufacturer. Dimensions — mm 192 151 98.4 192 TWO Ø35 HOLES TO CLEAR BUSHINGS CL 98.4 114.3 151 38.1 31.8 31.8 139.7 CL 254 CL M16 STUD 31.8 A A 70 254.0 70 31.8 57.2 CL 31.8 57.2 21 TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS 36.5 TERMINALS ACCOMMODATE CABLES UPTO 240sq.mm 27 27 DETAIL A 27 27 DETAIL A Front connected Back stud connected 192 Ø35 HOLES TO CLEAR BUSHING CL 114.3 151 38.1 254 CL M16 STUD 70 31.8 31.8 57.2 98.4 A 31.8 21 TWO HOLES TO TAKE M6 CHEESEHEAD FIXING SCREWS 27 36.5 TERMINALS ACCOMMODATE CABLES UPTO 240sq.mm 27 DETAIL A Front/back stud connected Accessories Adaptors for Bussmann series fuses* Catalog no. For Bussmann series fuse TCA2 _M09C (125-200A) * One kit required per fuse. Eaton.com/bussmannseries 7 Technical Data 100038801 Red Spot fuse holders for BS88 HRC industrial fuses Effective August 2018 Red Spot holder accessories Padlockable inserts Fuse adaptor kits Padlockable Insert fits into fuse holder and accepts small padlock. Fuse adaptors mount on the fuse carrier to accept a smaller dimensioned fuse. Fuse holder Catalog no. RS20 RS20LOCK RS32 RS32LOCK RS63 RS63LOCK RS100 RS100LOCK Fuse holder Catalog no.* Use with Bussmann series fuse RS100 P5372-10 _CIH07 (25-30A) _CIK07 (35-60A) RS400 TCA2 _MC09C (125-200A) * One kit required per fuse. Red warning carriers Adaptors for GS fuses Red warning carriers replaces the regular fuse carrier and cannot hold a fuse. Adaptors for GS fuses mount on the fuse carrier to accept a smaller dimensioned fuse. Includes label to indicate use of GS fuse. Fuse Holder Catalog no. Fuse holder Catalog no.** Use with GS fuse RS20 RS20RED RS32 GRS32-A GSA 5 to 20A RS32RED RS63 GRS63-A GSA 25 to 50A RS32 RS63 RS63RED RS100 RS100RED * One kit required per fuse. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2018 Eaton All Rights Reserved Printed in USA Publication No. 10083 - BU-MC13988 August 2018 Eaton, Bussmann, Quik-Spec and CUBEFuse are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. NEC is a registered trademark of the National Fire Protection Association, Inc. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
RS63PWH 价格&库存
很抱歉,暂时无法提供与“RS63PWH”相匹配的价格&库存,您可以联系我们找货
RS63PWH
  • 10+3711.7707410+480.52082
RS63PWH
    • 1+385.64522
    • 5+375.26262
    • 25+362.49526
    • 50+354.27874
    • 100+346.62457
    库存:5
