CO2-100
CO2-100
    AMPROBE(安博)
    CO2 METER
CO2-100 数据手册
Data Sheet CO2-100 CO2 Hand-Held Meter Instant feedback with CO2 levels, with additional temperature and humidity measurement. Built in alarm warns against dangerous CO2 levels. The portable CO2-100 Air Quality meter is designed to measure air quality compliance in occupied spaces such as offices, production floors, schools or hospitals. n Low drift portable meter for checking indoor air quality n CO2 Measurement up to 9999 ppm n Triple display with simultaneous CO2, Temperature and relative humidity readings n Selectable display of Dew Point and Wet Bulb n Air Quality Analysis with displays of: n TWA display (time-weighted average) for 8 hrs period n 15 minutes STEL (short-term exposure limit) value No hassle warranty n High performance low drift sensor designed with NDIR (Non-Dispersive Infrared) waveguide technology n Easy to read large LCD display No waiting. n Manually calibratable No shipping charges. n Audible alarm threshold setting to setup warning against carbon dioxide level Our commitment to high-quality products and customer service is demonstrated by our industry exclusive “No Hassle” warranty. In the unlikely event that an Amprobe Test Tool requires warranty service, any of our local dealers are authorized to replace it, on the spot. n Backlight function for working in dark area n Optional PC download capabilities n Data Hold n Maximum, minimum, average functions n Long time drift compensation for accurate readings (note: $500 MSLP limit) Amprobe® Test Tools www.Amprobe.com CO2-100 CO2 Hand-Held Meter Data Sheet Specifications Measuring Range Temp. Range RH Range DP (Dew Point Temp.) WB (Wet Bulb Temp.) Resolution Accuracy Sensing Tech Humidity Warm-up Time Response Time Alarm sound level Operating condition Storage Condition Power Supply Battery Life Standard packing includes Dimension Weight CO2 0 ~ 9999 ppm 5001 ~ 9999 ppm (out of scale range) -10°C to 60°C (14°F to 140°F) 0% ~ 95% -20°C to 59.9°C (-4°F to 139.8°F) -5.0°C to 59.9°C (24.8°F to 139.8°F) 1ppm - CO2 concentration, 0.1°C / °F - Temp, 0.1% RH - Humidity ±30ppm±5% of reading(CO2) (0~5000ppm) others rang accuracy are not specified ; ±0.6°C / ±0.9°F, ±3% RH (at25°C ,10~90%) others ±5% for other RH range CO2 -NDIR sensor Rotronic capacitor type 30 seconds About 30 seconds 80 dB 0°C to 50°C (32°F to 122°F), 0 ~ 95% RH (avoid condensation) for CO2 -20°C to 60°C (-4°F to 140°F), 0~99%RH (avoid condensation) AA type (UM-3) x 4 pcs > 10 hours Meter, Manual, Batteries and Hard carrying case 210(L) x 70(W) x 58(H) mm ( 8.3 x 2.8 x 2.3 in) Approx. 182g (0.40 lb) Amprobe® Test Tools website: www.Amprobe.com email: info@amprobe.com Everett, WA 98203 Tel: 877-AMPROBE Amprobe® Test Tools Europe In den Engematten 14 79286 Glottertal, Germany Tel.: +49 (0) 7684 8009 - 0 ©2009 Amprobe Test Tools. All rights reserved. 7/2009 3520585 Rev A Amprobe® Test Tools www.Amprobe.com
CO2-100 价格&库存
很抱歉,暂时无法提供与“CO2-100”相匹配的价格&库存,您可以联系我们找货
