BU-70
BU-70
    MUELLERELECTRIC
    CLIP ALLIGATOR STEEL 5 AMP
BU-70 数据手册
BU-70 Series (Alligator Clips with Short Crimp Tails) • Mueller Electric’s BU-70 is an alligator clip with a short crimp tail. Compatible with Mueller brand BU-72 series insulators. • Overall length 1.67” (42.86mm), overall height 0.44” (11.1mm), maximum jaw spread = 0.313” (7.9mm) • Can connect to wire up to 16 AWG via crimp, solder, and screw connections (depending on model). • Ratings: BU-70 / BU-70S 5 Amps BU-70C / BU-70CS 10 Amps • The BU-70 is sold under the following models: BU-70 Nickel-plated steel clip, wire can be soldered or crimped BU-70C Solid copper BU-70 BU-70CS Solid copper BU-30 with screw for wire connection BU-70S BU-70 with screw for wire connection BU-70C-EZZZ BU-70C with tapped hole for screw (not included) • RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-70 价格&库存
很抱歉,暂时无法提供与“BU-70”相匹配的价格&库存,您可以联系我们找货
BU-70
  • 1+6.974291+0.90400
  • 5+6.538405+0.84750
  • 10+6.3640410+0.82490
  • 20+6.1025020+0.79100
  • 100+5.75379100+0.74580
  • 1000+5.405071000+0.70060
库存:4
BU-70
    • 10+5.34647
    库存:420
    BU-70
    • 1+8.462461+1.09690
    • 10+7.4030610+0.95958
    • 25+7.1391625+0.92538
    • 100+6.96288100+0.90253
    • 500+6.78658500+0.87967
    • 1000+6.698451000+0.86825
    库存:515
