02-42
02-42
    GRAYHILLINC.
    BANANA TEST CLIP
02-42 数据手册
Test Clips SERIES 02 FEATURES • Rapid, Easy Connections • Hex Nut for Adjusting Tension • Choices of Sizes and Styles Ultra-Miniature DIMENSIONS Miniature Standard Size In Inches (and millimeters) Ultra Miniature Miniature 02-41 and 02-42 02-20 Threaded Stud .125 (3,18) .125 (3,18) .406 (10,31) .218 (5,54) .406 (10,31) PANEL AREA EXCLUSIVE OF NUTS: FOR 1 CLIP 3/16" X 1/8" (4,76 X 3,17) FOR DOUBLE 1/4" X 1/8" (6,35 X 3,17) 02-24 Insulated .406 (10,31) All dimensions are reference. A Max. panel thickness .250 (6,35) Termination Hardware Standard Size Threadless #6-32 UNC-2A THREAD HEX NUTS .250 (6,35) ACROSS FLATS, .094 (2,39) THICK Panel thickness .062 (1,57) to .187 (4,75) All dimensions are reference. Standard Size 02-60 02-0 Threaded Stud .312 (7,92) .312 (7,92) 02-4 Insulated .550 (13.97) 02-1 Standard Banana Plug .550 (13.97) 1.250 (31,75) 1.250 (31,75) 1.144 (29,06) 1.125 (28,58) .312 (7,92) TAPPED FOR #8-32 UNC-2A THREADED SCREW TO ADJUST TENSION .312 (7,92) A HEX NUTS .344 (8,74) ACROSS FLATS, .125 (3,18) THICK B .937 (23,80) .375 (9,53) DIA. .500 (12,7) DIA. #8-32 UNC-2A THREAD SCREW NOT INCLUDED All dimensions are reference. .550 (13.97) A = .063 (1,60) B = .094 (2,39) .187 (4,75) .576 (14,63) .937 (23,80) B .250 (6,35) DIA. .375 (9,53) DIA. #6-32 UNC-2A THREAD HEX NUTS .250 (6,35) ACROSS FLATS, .094 (2,39) THICK .625 (15,88) .360 (9,14) .360 (9,14) #2-56 UNC-2A THREAD HEX NUTS .187 (4,75) ACROSS FLATS .062 (1,57) THICK .406 (10,31) A = .062 (1,57) B = .093 (2,36) .719 (18,26) .719 (18,26) .375 (9,53) 02-21 Standard Banana Plug #8-32 UNC-2A THREAD HEX NUTS .344 (8,74) ACROSS FLATS, .125 (3,18) THICK Max. panel thickness .250 (6,35) All dimensions are reference. STANDARD OPTIONS SPECIFICATIONS ORDERING INFORMATION Standard Size Threaded Stud Clip can be made of Stainless Steel or Inconel X material. Not available through Distributors. Materials and Finishes Order using part numbers shown in dimensions. Studs: Nickel-plated steel except for 02-41 and 02-42 which are nickel-plated brass Rivets and Nuts: Nickel-plated brass Spring Clips: Nickel-plated brass except for 02-41 and 02-42 which are nickel-plated beryllium copper Insulators: Thermoset plastic Termination Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 5 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
02-42
1. 物料型号:文档中提到了多种型号,例如Ultra Miniature 02-41和02-42,Standard Size Threadless 02-60,Standard Size 02-4 02-1,以及Insulated Standard Banana Plug。
2. 器件简介:文档描述了测试夹具的多种尺寸和样式,包括超小型和标准尺寸,以及它们的特点,如易于连接和调整张力。
3. 引脚分配:文档中提到了不同的引脚配置,例如#6-32 UNC-2A螺纹和#8-32 UNC-2A螺纹。
4. 参数特性:提供了详细的尺寸信息,包括面板厚度、螺母尺寸、螺钉尺寸等,所有尺寸均为参考值。
5. 功能详解:文档解释了测试夹具的功能,如用于调整张力的六角螺母和不同尺寸的测试夹具。
6. 应用信息:文档提到了测试夹具的多种应用,但没有提供具体的应用场景。
7. 封装信息:提供了材料和表面处理的信息,例如镍镀钢、镍镀黄铜、镍镀铍铜等。
8. 订购信息:提供了订购部件的型号和如何从Grayhill分销商处订购的信息。
02-42 价格&库存
很抱歉,暂时无法提供与“02-42”相匹配的价格&库存,您可以联系我们找货
