AMP-220
AMP-220
    AMPROBE(安博)
    600AACDCTRMSCLAMPMULTIMETER
AMP-220 数据手册
AMP-200 Series TRMS Clamp Meters The Modern Evolution of the Professional Clamp Meter Amprobe’s AMP-210 and AMP-220 600 A TRMS Clamp Meters offer a complete range of measuring functions for today’s modern electrical environments. Both models feature True-RMS sensing, low pass filters and fast response processors for quick, error-free measurements. The Amp-Tip function allows for precise measurement of current down to the tenth of an Amp, enabling accurate current measurement of both large and small diameter wires. AMP-200 Series Features • True-RMS • Low Pass Filter • Amp-Tip Functions • Non-Contact Voltage Detection (NCV) • Audible Continuity and Diode Test • Data Hold, Relative Zero • Large LCD Backlit Display • Safety Rated: CAT III 600 V AMP-210 AC Clamp Meter Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) AMP-220 AC/DC Clamp Meter ©2014 Amprobe® For detailed specifications and ordering go to www.Amprobe.com 6003569 B AMP-200 Series Product Details True-RMS for accurate voltage measurements in noisy environments. Low pass filter for current and voltage measurements on variable frequency drives. Amp-Tip function for precise low current measurement of small diameter wires down to 0.1 Amp to help with electrical system troubleshooting. Non-contact voltage detection (NCV) Measurements: Audible continuity and diode test Data hold, relative zero, MAX/MIN/AVG mode Voltage Up to 600 V AC/DC Resistance Up to 60.00 kΩ AC current Up to 600 A Capacitance Up to 2500 µF DC Current Up to 600 A (AMP-220 only) Large LCD backlit display Frequency 5.00 to 999.9 Hz Safety rated CAT III 600 V AMP-200 Series Applications AMP-210 AC Clamp Meter • Accurate measurement of current, voltage and frequency on all electrical systems including distorted, non-sinusoidal signals (True-RMS function) and variable frequency drives (low-pass filter). • Capacitance measurement for start and run motor capacitors. AMP-220 AC/DC Clamp Meter • Low pass filter allows measurement of current and voltage on variable frequency drives (motors with speed controlled by frequency). Without this feature, the meter would provide erroneous readings when measuring voltage and current. • Resistance and continuity functions to verify quality of electrical connections and to check if motor and transformer coils are working properly. Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2014 Amprobe® For detailed specifications and ordering go to www.Amprobe.com 6003569 B AMP-200 and AMP-300 Detailed Specifications Model AMP-210 AMP-220 AMP-310 AMP-320 AMP-330 AC Clamp Meter Electrical AC/DC Clamp Meter Electrical AC Clamp Meter HVAC AC/DC Clamp Meter Electrical Motor Maintenance AC/DC 1000 A Clamp Meter Industrial Motor Maintenance CAT IV 600 V, CAT III 1000 V Safety Rating CAT III 600 V CAT III 600 V CAT III 600 V CAT III 600 V Jaw Opening 1.18 in (30 mm) 1.37 in (35 mm) 1.18 in (30 mm) 1.37 in (35 mm) 2.0 in (51 mm) AC Voltage (True-RMS) Range: 0 to 600.0 V Accuracy: ±1.0% + 5LSD (50 to 60 Hz) Range: 0 to 600.0 V Accuracy: ±1.0% + 5LSD (50 to 60 Hz) Range: 0 to 1000 V Accuracy: ±0.8% + 5LSD (50 to 60 Hz) ±1.5% + 5LSD (20 to 200 Hz) ±10% + 5LSD (200 to 400 Hz) DC Voltage Range: 0 to 600.0 V Accuracy: ±1.0% + 5LSD Range: 0 to 600.0 V Accuracy: ±1.0% + 5LSD Range: 0 to 1000 V Accuracy: ±0.8% + 5LSD AC+DC Voltage AC Current (True-RMS) – Range: 0 to 600.0 V Accuracy: 1.2% ± 7LSD (DC, 50 to 60 Hz) Range: 0 to 600.0 A Accuracy: ±1.8% + 5LSD (50 to 100 Hz) ±2.0% + 5LSD (100 to 400 Hz) – Range: 0 to 1000 V Accuracy: ±1.0% + 7LSD (50 to 60 Hz) ±1.8% + 7LSD (DC, 40 to 200 Hz) ±12% + 7LSD (200 to 400 Hz) Range: 0 to 600.0 V Accuracy: 1.2% ± 7LSD (DC, 50 to 60 Hz) Range: 0 to 600.0 A Accuracy: ±1.8% + 5LSD (50 to 100 Hz) ±2.0% + 5LSD (100 to 400 Hz) Range: 0 to 1000 A Accuracy: ±1.8% + 5LSD (40 to 100 Hz) ±2.2% + 5LSD (100 to 400 Hz) DC Current – Range: 0 to 600.0 A Accuracy: ±2.0% + 5LSD – Range: 0 to 600.0 A Accuracy: ±2.0% + 5LSD Range: 0 to 1000 A Accuracy: ±1.8% + 5LSD AC+DC Current – Range: 0 to 600.0 A Accuracy: ±2.2% + 7LSD (DC, 50 to 100 Hz) ±2.7% + 7LSD (100 to 400 Hz) – Range: 0 to 600.0 A Accuracy: ±2.2% + 7LSD (DC, 50 to 100 Hz) ±2.7% + 7LSD (100 to 400 Hz) Range: 0 to 1000 A Accuracy: ±2.2% + 7LSD (DC, 40 to 100 Hz) ±2.5% + 7LSD (100 to 400 Hz) Precise Low Current AC Precise Low Current DC Precise Low Current AC+DC Range: 0 to 60.00 A Accuracy: ±1.5% + 5LSD (50 to 60 Hz) – Range: 0 to 60.00 A Accuracy: ±2.0% + 5LSD – Range: 0 to 60.00 A Accuracy: ±2.0% + 5LSD (DC, 50 to 60 Hz) Range: 0 to 60.00 A Accuracy: ±1.5% + 5LSD (0.00 to 20.00 A, 40 to 100 Hz) ±2.0% + 5LSD (0.00 to 20.00 A, 100 to 400 Hz) ±3.0% + 5LSD (20.00 to 60.00 A, 40 to 100 Hz) ±3.0% + 5LSD (20.00 to 60.00 A, 100 to 400 Hz) Range: 0 to 60.00 A Accuracy: ±1.5% + 5LSD (50 to 60 Hz) – Range: 0 to 60.00 A Accuracy: ±2.0% + 5LSD Range: 0 to 60.00 A Accuracy: ±1.5% + 5LSD (0.00 to 20.00 A) ±3.0% + 5LSD (20.00 to 60.00 A) – Range: 0 to 60.00 A Accuracy: ±2.0% + 5LSD (DC, 50 to 60 Hz) Range: 0 to 60.00 A Accuracy: ±2.0% + 7LSD (0.00 to 20.00 A, DC, 40 to 100 Hz) ±2.2% + 7LSD (0.00 to 20.00 A, 100 to 400 Hz) ±3.0% + 7LSD (20.00 to 60.00 A, DC, 40 to 100 Hz) ±3.0% + 7LSD (20.00 to 60.00 A, 100 to 400 Hz) Frequency Range: 5.00 to 999.9 Hz Accuracy: ±1.0% + 5LSD (600 V range) Range: 50.0 to 400.0 Hz Accuracy: ±1.0% + 5LSD (600 A range) Range: 5.00 to 999.9 Hz Accuracy: ±1.0% + 5LSD (600 V range) Range: 50.0 to 400.0 Hz Accuracy: ±1.0% + 5LSD (600 A range) Range: 5.00 to 999.9 Hz Accuracy: ±1.0% + 5LSD (1000 V range) Range: 40.0 to 400.0 Hz Accuracy: ±1.0% + 5LSD (1000 A range) Resistance Range: 0.0 to 60.00 kΩ Accuracy: ±1.0% + 5LSD Range: 0.0 to 60.00 kΩ Accuracy: ±1.0% + 5LSD Capacitance Range: 0.0 to 2500 µF Accuracy: ±2.0% + 4LSD Range: 0.0 to 2500 µF Accuracy: ±2.0% + 4LSD ON ≤ 10 Ω OFF > 250 Ω ON ≤ 10 Ω OFF > 250 Ω 10V to 1000V AC, 50/60Hz 10V to 1000V AC, 50/60Hz Continuity Beeper Non-Contact Voltage True-RMS • • • • • Low Pass Filter • • • • • Autoranging • • • • • Relative Zero • • • • • MAX/MIN/AVG • • • • • Diode Test • • • • • Data Hold • • • • • Backlight • • • • • Auto Power Off • • • • • – – Range: 0.0 to 2000 µA Accuracy: ±1.0% + 5LSD – – Range: -40.0 to 752°F, -40.0 to 400°C Accuracy: -40.0 to 14.0°F (±1.0% +3.0°F), >14.0 to 99.9°F (±1.0% +1.5°F) 100 to 752°F (±1.0% +2°F), -40.0 to -10.0°C (±1.0% +1.5°C) >-10.0 to 99.9°C (±1.0% +0.8°C), 100 to 400°C (±1.0% + 1°C) – – Rotation-R for mains supply Rotation-M for motors 300 Series: DC Microamps Temperature* (Type K thermocouple) *Error does not include Type-K thermocouple errors 3-Phase and Motor Rotation Indication Inrush Current – – • • • Peak Hold (Crest) – – – – • Work Light – – – – • Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2014 Amprobe® For detailed specifications and ordering go to www.Amprobe.com 6003569 B AMP-200 and AMP-300 General Specifications Model AMP-210 AMP-220 AMP-310 AMP-320 AMP-330 Display 3-5/6 digits 6000 counts 3-5/6 digits 6000 counts 3-5/6 digits 6000 counts 3-5/6 digits 6000 counts 3-5/6 digits 6000 counts Polarity Automatic Automatic Automatic Automatic Automatic Update Rate 5 per second nominal 5 per second nominal 5 per second nominal 5 per second nominal 5 per second nominal Operating Temperature 32 to 104°F (0 to 40°C) 32 to 104°F (0 to 40°C) 32 to 104°F (0 to 40°C) 32 to 104°F (0 to 40°C) 14 to 122°F (-10 to 50°C) Relative Humidity 80% at 30°C, 50% at 40°C 80% at 30°C, 50% at 40°C 80% at 30°C, 50% at 40°C 80% at 30°C, 50% at 40°C Non condensing at ≤10°C 90% at 10 to30°C 75% at 30 to 40°C 45% at 40 to 50°C Operating Altitude 0 to 2000 m 0 to 2000 m 0 to 2000 m 0 to 2000 m 0 to 2000 m 2 2 2 2 2 Storage Temperature -4 to 140°F (-20°C to 60°C), < 80% RH -4 to 140°F (-20°C to 60°C), < 80% RH -4 to 140°F (-20°C to 60°C), < 80% RH -4 to 140°F (-20°C to 60°C), < 80% RH -4 to 140°F (-20°C to 60°C), < 80% RH Temperature Coefficient Nominal 0.15 x (specified accuracy)/ °C @ (0°C to 18°C or 28°C to 40°C) Nominal 0.15 x (specified accuracy)/ °C @ (0°C to 18°C or 28°C to 40°C) Nominal 0.15 x (specified accuracy)/ °C @ (0°C to 18°C or 28°C to 40°C) Nominal 0.15 x (specified accuracy)/ °C @ (0°C to 18°C or 28°C to 40°C) Nominal 0.10 x (specified accuracy)/ °C @ (0°C to 18°C or 28°C to 50°C) Battery Two AAA 1.5 V battery Two AAA 1.5 V battery Two AAA 1.5 V battery Two AAA 1.5 V battery Two AA 1.5 V battery EMC Meets EN 61326-1:2006 Meets EN 61326-1:2006 Meets EN 61326-1:2006 Meets EN 61326-1:2006 Meets EN 61326-1:2006 UL/IEC/EN 61010-1 ed. 3.0, IEC/EN 61010-2-033 ed. 1.0, CAN/CSA C22.2 NO. 61010-1 ed. 3.0, IEC/EN 61010-2-032 ed. 3.0 & IEC/EN 61010-031 ed. 1.1 UL/IEC/EN 61010-1 ed. 3.0, IEC/EN 61010-2-033 ed. 1.0, CAN/CSA C22.2 NO. 61010-1 ed. 3.0, IEC/EN 61010-2-032 ed. 3.0 & IEC/EN 61010-031 ed. 1.1 UL/IEC/EN 61010-1 ed. 3.0, IEC/EN 61010-2-033 ed. 1.0, CAN/CSA C22.2 NO. 61010-1 ed. 3.0, IEC/EN 61010-2-032 ed. 3.0 & IEC/EN 61010-031 ed. 1.1 UL/IEC/EN 61010-1 ed. 3.0, IEC/ EN 61010-2-033 ed. 1.0, CAN/CSA C22.2 NO. 61010-1 ed. 3.0, IEC/ EN 61010-2-032 ed. 3.0 & IEC/EN 61010-031 ed. 1.1 UL/IEC/EN 61010-1 ed. 3.0, IEC/EN 61010-2-033 ed. 1.0, CAN/CSA C22.2 NO. 61010-1 ed. 3.0, IEC/EN 61010-2-032 ed. 3.0 & IEC/EN 61010031 ed. 1.1 Certification UL (c/us) and CE UL (c/us) and CE UL (c/us) and CE UL (c/us) and CE UL (c/us) and CE Dimensions (L x W x H): 8.62 x 3.03 x 1.46 in (219 x 77 x 37 mm) 8.82 x 3.03 x 1.46 in (224 x 77 x 37 mm) 8.62 x 3.03 x 1.46 in (219 x 77 x 37 mm) 8.82 x 3.03 x 1.46 in (224 x 77 x 37 mm) 10.16 x 3.70 x 1.73 in (258 x 94 x 44 mm) 208 g (0.46 lb) 254 g (0.56 lb) 208 g (0.46 lb) 254 g (0.56 lb) 420 g (0.93 lb) User’s Manual • • • • • Test Leads • • • • • Carrying Case • • • • Pollution Degree Safety Compliance Weight: Accessories Included: Batteries AAA (2) AAA (2) • AA (2) Alligator Clip Set – – • • • Banana plug K-type Thermocouple – – • • • Amprobe® info@amprobe.com Fluke Corporation, Everett, WA 98203 Tel: 877-AMPROBE (267-7623) For complete information about Amprobe test tools, visit www.Amprobe.com © 2014 Amprobe | Specifications subject to change without notice. Printed In U.S.A. 6003569 B
AMP-220 价格&库存
很抱歉,暂时无法提供与“AMP-220”相匹配的价格&库存,您可以联系我们找货
