2190E
2190E
    B&K
    100MHZDIGSTORAGEOSCILLOSCOPE
2190E 数据手册
Data Sheet 100 MHz Digital Storage Oscilloscope Model 2190E The 2190E combines performance and value all in one portable solution. With 100 MHz bandwidth and 1 GSa/s sample rate, these oscilloscopes offer advanced triggering capabilities, long waveform memory up to 40,000 points, and extensive features such as pass/fail limit testing, digital filtering, waveform recorder, and 32 automatic measurements. PC connectivity Features & Benefits ■ 100 MHz, I GSa/s sample rate ■ 800x480 pixel 7” TFT color display ■ Long waveform memory up to 40,000 points ■ Five different math functions – Add, Subtract, Multiply, Divide, and FFT ■ Versatile triggering capabilities including pulse width, line-selectable video, slope, and Engineered to allow you to see more of your signal under test, the 2190E widescreen 7” TFT display offers a significantly larger viewing area than typical economy oscilloscopes (5.7”). Maximize productivity with PC connectivity via LAN, and USB. The downloadable PC software lets you easily capture, save, and analyze measurement results. All oscilloscope parameters can be controlled via a PC without the need for programming. The 2190E oscilloscope is ideal for applications in education, design and debug, service and repair. alternating trigger PC software is provided (free download at B&K Precision’s website at www.bkprecision.com) for seamless integration between the oscilloscope and PC. Capture and transfer waveforms, screen images, setups and measurement results to a Windows PC via the USB device port on the back of the instrument. A USB host port on the front and rear allows for quick and easy screen saving. ■ 32 automatic measurements ■ Advanced tools include digital filter with adjustable limits, pass/fail testing, and waveform recorder mode ■ 12 different language user interfaces and context sensitive help ■ Special EDU mode allows educators to disable Auto set button, Measure menu, and Cursors menu ■ Front panel USB host port for saving and recalling waveform setups, data, and screen shots on a USB flash drive ■ LAN and USBTMC-compliant USB device port for remote PC control ■ GPIB connectivity with optional USB-to-GPIB adapter Technical data subject to change © B&K Precision Corp. 2019 www.bkprecision.com Digital Storage Oscilloscope Model 2190E The tools you need Powerful measurement functions Digital filtering Filter OFF Filter ON 3 Display and measure the input signal’s frequency spectrum. Select one of the 4 FFT windows: Rectangular, Hanning, Hamming, and Blackman. Use cursors to measure the spectral component’s magnitude and frequency. Filter out unwanted signal components such as various types of noise with built-in digital filters. Choose from Low-Pass, High-Pass, Band-Pass, and Band-Stop filters. Waveform recorder Delayed sweep/zoom Monitor and analyze long-term signal behavior by recording data continuously over an extensive period of time and playing it back for post acquisition analysis. Data is recorded in a sequence of up to 2500 frames. Use the oscilloscope’s delayed sweep feature to zoom in a particular area of a signal in real time while viewing the entire captured waveform simultaneously. Large internal storage Pass/Fail testing Minimize debug time by saving and recalling setups and waveforms from internal memory. Save and recall up to 20 different oscilloscope setups and 10 different waveforms. Generate user-defined pass/fail limits to quickly identify go/no go test results. www.bkprecision.com Digital Storage Oscilloscope Model 2190E Model 2190E Performance Characteristics Hardware Frequency Counter Reading Resolution 1 Hz Accuracy ±0.01% Range DC Couple, 10 Hz to 100 MHz Signal Types All trigger signals (except pulse width trigger and video trigger) Bandwidth 100 MHz Real Time Sampling Rate Single Channel: 1 GSa/s Dual Channel: 500 MSa/s (for timebase faster than 250 ns/div) Channels 2 Rise time < 3.5 ns Record Length 40,000 points when timebase is 2.5 ns to 50 ns (20,000 points for 100 ns to 50 ms timebase), 20,000 points for dual channel operation Vertical Resolution 8 bit Vertical Sensitivity 2 mV/div -10 V/div (1-2-5 order) DC Gain Accuracy
2190E 价格&库存
很抱歉,暂时无法提供与“2190E”相匹配的价格&库存,您可以联系我们找货
