ORDERING CODE
CHIP ANTENNA
RF
ANT
321612
A
5
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF/RG:
device
ANT : Antenna
FRA : Free Antenna
ECA : SMD Antenna
Per 2 digits of Length, Width,
Thickness
321612 =
Length =32
Width = 16
Thickness = 12
0 : 0.1 mm
1 : 1.0 mm
A: 2.4GHz ISM Band
E : GPS 1.5GHz
L : 2.4/5.2/5.8GHz Tri Band
W : WiMAX
Code from 0~9
dependent on
different electrical
specification
T: 7” Reeled
G: 13” Reeled
HIGH FREQUENCY MULTILAYER BAND PASS FILTER
RF
BPF
322515
A
4
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF device
BPF : Band Pass Filter
Thickness
322515 =
Length =32
Width = 25
Thickness = 15
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
W : WiMAX
K : ISM 5.2/5.8 Dual Band
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
HIGH FREQUENCY MULTILAYER BALANCED FILTER
RF
BPB
252009
A
7
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF/RG: device
BPB : Balanced Type
Band Pass Filter
Thickness
252009 =
Length =25
Width = 20
Thickness = 09
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
W : WiMAX
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
HIGH FREQUENCY MULTILAYER LOW PASS FILTER
RF
LPF
201211
A
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF device
LPF : Low Pass Filter
Thickness
201210 =
Length =20
Width = 12
Thickness = 11
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
HIGH FREQUENCY MULTILAYER HIGH PASS FILTER
RF
HPF
252009
L
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF device
HPF : High Pass Filter
Thickness
252009 =
Length =2.5
Width = 2.0
Thickness = 0.9
0 : 0.1 mm
1 : 1.0 mm
L : 2.4/4.9/5.2/5.8GHz
Multiband Application
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
BALUN TRANSFORMERS
RF
BLN
201208
A
4
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
Code from 0~9
dependent on different
electrical specification
T: 7” Reeled
G: 13” Reeled
RF/RG:
device
2
BLN : BALUN
Thickness
201208 =
Length =20
Width = 12
Thickness = 08
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
HIGH FREQUENCY
STRUCTURE AND PIN ASSOCIATED
STRUCTURE A
STRUCTURE B
STRUCTURE C
STRUCTURE D
STRUCTURE E
STRUCTURE F
V
STRUCTURE G
STRUCTURE H
STRUCTURE I
STRUCTURE J
STRUCTURE K
13
HIGH FREQUENCY
STRUCTURE AND DIMENSION
Unit: mm
Structure\
Dimension
L
W
T
A
B
C
D
E
F
G
H
I
0.70±0.10
0.20±0.20
0.55±0.20
0.50±0.20
0.25±0.20
0.20±0.20
0.80±0.10
0.20±0.20
0.55±0.20
0.50±0.20
0.20±0.20
0.20±0.20
1.00±0.10
0.20±0.20
0.50±0.20
0.50±0.20
0.25±0.20
0.20±0.20
1.05±0.10
0.25±0.20
0.50±0.20
0.50±0.20
0.25±0.20
0.25±0.20
1.20±0.10
0.25±0.20
0.50±0.20
0.50±0.20
0.25±0.20
0.25±0.20
2.05±0.20
0.70±0.20
0.25±0.20
0.50±0.20
0.50±0.20
0.25±0.20
0.25±0.20
3.20±0.20
2.50±0.10
1.50±0.10
0.40±0.20
0.60±0.20
0.70±0.20
0.20±0.15
0.40±0.20
1.00±0.10
0.50±0.10
0.40±0.10
0.30±0.10
0.30±0.10
0.35±0.10
0.15±0.10
0.15±0.10
0.50±0.10
0.35±0.10
0.30±0.10
0.15±0.10
0.15±0.10
0.30±0.10
0.60±0.10
0.45±0.15
0.45±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.45±0.15
0.70±0.15
0.20±0.10
0.20±0.10
0.30±0.15
0.45±0.15
0.70±0.15
0.15±0.10
0.15±0.10
0.30±0.15
0.40±0.15
0.80±0.15
0.20±0.10
0.20±0.10
0.30±0.15
0.45±0.15
1.10±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.50±0.15
1.00±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.45±0.15
0.45±0.15
1.10±0.15
0.25±0.15
0.25±0.15
0.30±0.15
2.00±0.20
2.50±0.20
A
1.60±0.15
0.80±0.15
0.70±0.10
0.50±0.10
1.20±015
B
0.90±0.10
0.60±0.10
2.00±.15
0.45±0.15
0.70±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.80±0.10
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.90±0.10
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.35±0.15
1.30±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.55±0.10
0.40±0.20
0.40±0.20
0.40±0.20
0.40±0.20
0.20±0.10
0.60±0.10
0.40±0.20
0.40±0.20
0.40±0.20
0.20±0.10
0.80±0.10
0.40±0.20
0.40±0.20
0.40±0.20
0.40±0.20
0.20±0.10
0.60±0.10
0.55±0.10
0.25±0.10
0.23±0.10
0.40±0.10
0.12±0.10 0.125±0.10
0.45±0.10
0.95±0.10 0.275±0.20 0.25±0.10
0.60±0.10 0.175±0.10 0.15±0.10
0.70 max
0.95±0.10 0.275±0.10 0.25±0.10
0.80±0.10
0.25±0.10
1.25±0.15
0.95±0.10
C
2.00±.15
1.20±0.20
1.60±0.15
0.80±0.15
2.00±.15
1.25±0.10
D
E
F
G
14
1.10±0.10
0.90±0.10
0.60±0.10
1.40±0.15
1.10±0.15
0.70±0.10 0.325±0.10 0.25±0.10
0.25±0.10
2.00±0.20
1.25±0.20
1.00 max. 0.325±0.10 0.25±0.10
0.25±0.10
0.40±0.10
0.55±0.15
0.50±0.15
1.60±0.15
0.80±0.15
0.60±0.10
0.55±0.15
0.80±0.10
0.95±0.10
0.90±0.10
2.00±0.15
0.18±0.10 0.205±0.10 0.25±0.10
0.25±0.10
0.25±0.10
0.35±0.15
0.50±0.15
0.20±0.15
0.50±0.15
0.35±0.15
0.50±0.15
0.20±0.15
0.40±0.10
0.30±0.10
0.30±0.10
0.15±0.10
0.30±0.10
0.35±0.10
0.15±0.10
0.95±0.10
0.40±0.10
0.30±0.10
0.30±0.10
0.15±0.10
0.30±0.10
0.35±0.10
0.15±0.10
1.25±0.10
2.50±0.20
2.00±0.20
0.90±0.10
1.70±0.20
0.60±0.20
0.30±0.20
0.40±0.20
0.15±0.10
0.60±0.10
0.50±0.10
0.15±0.10
H
1.60±0.15
0.80±0.10
0.60 max.
0.25±0.10
0.23±0.05
0.40±0.10
0.30±0.10
0.55±0.10
0.60±0.10
I
2.00±0.15
1.25±0.10
1.00 max.
1.80±0.10
0.35±0.10
0.25±0.10
0.25±0.10 0.275±0.10 0.35±0.10
J
2.50±0.15
2.00±0.15
0.90±0.10
0.30±0.10
0.40±0.10
0.55±0.10
0.40±0.10
0.90±0.10
0.30±0.10
K
3.20±0.20
2.50±0.20
1.80±0.20
0.95±0.20
0.60±0.20
0.30±0.15
0.70±0.15
1.20±0.15
2.00±0.15
0.25±0.10
HIGH FREQUENCY
ELECTRICAL SPECIFICATION
2.4GHz BAND WORKING FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
RBBPF1005040A1T
2.4~2.5
2.5
RFBPF1005040A3T
2.4~2.5
1.5max.(25℃)
1.7max.(-40~+85℃)
RFBPF1109060A0T
2.4~2.5
1.8
RFBPF1411060A1T
2.4~2.5
1.8
RFBPF1411060A2T
2.4~2.5
1.5
RBBPF1411060A3T
2.4~2.5
1.1
RFBPF1608060AA7M1U
2.4~2.5
0.95max.(25℃)
1.25max.(-40~+85℃)
RFBPF1608060ADT
2.4~2.5
1.8max.(25℃)
2.1max.(-40~+85℃)
RFBPF1608060AET
2.4~2.5
1.7max.(25℃)
2.0max.(-40~+85℃)
RFBPF1608070AFT
2.4~2.5
2.4max.(25℃)
2.7max.(-40~+85℃)
RFBPF1608070AWT
2.4~2.5
2.0max.(25℃)
2.2max.(-40~+85℃)
RFBPF1608050A0T
2.4~2.5
2.0max.(25℃)
2.2max.(-40~+85℃)
RFBPF1608060A1T
2.4~2.5
2.8
RFBPF1608060A7T
2.4~2.5
3.0
RFBPF1608060A8T
2.4~2.5
1.7
RFBPF1608070A3T
2.4~2.5
1.8max.(25℃)
2.1max.(-40~+85℃)
Attenuation
( dB min. )
25(824~960 MHz)
20(1710~1910 MHz)
20(4800~5000 MHz)
15(7200~7500 MHz)
13(824~915MHz)
5(1545~1605MHz)
34(4800~5000MHz)
20(7200~7500 MHz)
35(824~960MHz)
38(1545~1605MHz)
20(1710~1990MHz)
8(2110~2170MHz)
35(3600 MHz)
35(4800~5000 MHz)
35(7200~7500 MHz)
40(824~960MHz)
40(1545~1605MHz)
20(1710~1990MHz)
8(2110~2170MHz)
35(3600 MHz)
35(4800~5000 MHz)
35(7200~7500 MHz)
30(500~960MHz)
25(1500~1650MHz)
19(3200~3300MHz)
40(4800~5000 MHz)
30(7200~7500 MHz)
20( 50~960MHz)
10( 1710~1990MHz)
9( 3600 MHz)
22( 4800~7200 MHz)
20(500~960 MHz)
23(3200 MHz)
30(4800~5000 MHz)
32(7200~7500 MHz)
22.5(200~1300MHz)
5.5(2000MHz)
10.5(3000MHz)
23.5(3600~3800MHz)
35(4800~5000MHz)
35(7200~7500MHz)
25(880 MHz)
20(3200 MHz)
35(4800~5000 MHz)
25(7200~7500 MHz)
24.5(80~960MHz)
20(1710~1990 MHz)
8.5(2170 MHz)
15(4800~5000 MHz)
20(7200~7500 MHz)
30 (960 MHz)
25(1910 MHz)
20(1990 MHz)
25(4800 MHz)
15(7200 MHz)
20(960 MHz)
20(1910 MHz)
15(1990 MHz)
18(4800 MHz)
25(7200 MHz)
25(695~800MHz)
20(1910MHz)
35(3200MHz)
20(4800~5000MHz)
20(7200~7500MHz)
25(695~800MHz)
20(1910MHz)
35(3200MHz)
20(4800~5000MHz)
20(7200~7500MHz)
30(880~915MHz)
30(1710~1785MHz)
25(1850~1910MHz)
25(4800~5000MHz)
15(7200~7500MHz)
27(800~900 MHz)
25(4800~5000 MHz)
30(7200~7500 MHz)
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
1.00x0.50x0.40
B
2.1
50
1.00x0.50x0.40
B
2.0
50
1.10x 0.90x0.60
E
2.0
50
1.40x1.10x0.60
E
2.0
50
1.40x1.10x0.60
E
2.0
50
1.40x1.10x0.60
E
2.0
50
1.60x0.80x0.60
H
2.0
50
1.60x0.80x0.60
B
2.0
50
1.60x0.80x0.60
F
2.0
50
1.60x0.80x0.70
B
2.0
50
1.60x0.80x0.70
B
2.0
50
1.60x0.80x0.50
B
2.0
50
1.60x0.80x0.60
B
2.0
50
1.60x0.80x0.60
B
2.0
50
1.60x0.80x0.60
B
2.0
50
1.60x0.80x0.70
B
15
HIGH FREQUENCY
Frequency
Range(GHz)
Insertion Loss
(dB)
RFBPF2012080AM0T62
2.4~2.5
1.8max.(25℃)
2.0max.(-40~+85℃)
RFBPF2012080AC2T00
2.4~2.5
1.35max.
RFBPF2012090AS1T35
2.4~2.5
0.9max.(25℃)
1.1max.(-40~+85℃)
RFBPF2012060AAT
2.4~2.5
1.5max.(25℃)
1.8max.(-40~+85℃)
RFBPF2012040ABT
2.4~2.5
2.5
RFBPF2012050ACT
2.4~2.5
2.5
RFBPF2012080ADT
2.4~2.5
1.5max.(25℃)
1.7max.(-40~+85℃)
RFBPF2012080AFT
2.4~2.5
1.8max.(25℃)
2.0max.(-40~+85℃)
RFBPF2012080AGT
2.4~2.5
1.8max.(typ.1.5)
RFBPF2012040AHT
2.4~2.5
2.5
RBBPF2012050AHT
2.4~2.5
2.5max.(typ.2.2)
Part Number
16
Attenuation
( dB min. )
30(860~960MHz)
30(1545~1605MHz)
35(1710~1990MHz)
30(2170MHz)
30(4800~5000MHz)
30(804~828MHz)
20(1608~1656MHz)
30(3216~3312MHz)
40(4020~4140MHz)
20(4824~4968MHz)
20(5628~5796MHz)
20(6432~6624MHz)
35(7200~7500MHz)
20(7500~10000MHz
28(824~960MHz)
30(1570~1580MHz)
15(1710~1910MHz)
9.5(1910~1990MHz)
25(4800~5000MHz)
25(7200~7500MHz)
30(880~960MHz)
25(1710~1910MHz)
25(4800~5000MHz)
30(7200~7500MHz)
30(824~849MHz)
30(880~915MHz)
30(1545~1605MHz)
30(1565~1585MHz)
35(1710~1785MHz)
40(1850~1910MHz)
32(1920~1980MHz)
7(3168~4752MHz)
11(3300~3800MHz)
35(4800~4967MHz)
26(5150~6000MHz)
23(7200~7450MHz)
35(824~960MHz)
38(1710~1910MHz)
25(4880~5000MHz)
20(7200~7500MHz)
30(860~960MHz)
30(1545~1605MHz)
30(1710~1990MHz)
30(2170MHz)(typical)
30(4800~5000MHz)
30(824~915MHz)
30(1545~1605MHz)
35(1710~1990MHz)
30(2170MHz)
30(4800~4967MHz)
25(5150~6000MHz)
20(7200~7450.5MHz)
35(824~960MHz)
28(1545~1605MHz)
30(1710~1990MHz)
30(2170MHz)
6(3200MHz)
30(4800~4967MHz)
20(5150~6000MHz)
18(7200~7450MHz)
25(746~764MHz)
30(824~849MHz)
26(869~960MHz)
28(1570~1580MHz)
28(1710~1785MHz)
30(1850~1910MHz)
30(1930~1990MHz)
30(2110~2170MHz)
15(3300~3800MHz)
35(4800~5000MHz)
20(7200~7450.5MHz)
25(746~764MHz)
30(824~849MHz)
26(869~960MHz)
28(1570~1580MHz)
28(1710~1785MHz)
30(1850~1910MHz)
30(1930~1990MHz)
25(2110~2170MHz)
15(3300~3800MHz)
35(4800~5000MHz)
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
2.00x1.20x0.80
D
2.0
50
2.00x1.25x0.80
G
2.0
50
2.00x1.25x0.90
G
2.0
50
2.00x1.20x0.60
C
2.0
50
2.00x1.20x0.40
D
2.0
50
2.00x1.20x0.55
C
2.0
50
2.00x1.25x0.80
D
2.0
50
2.00x1.25x0.80
D
2.0
50
2.00x1.25x0.80
D
2.0
50
2.00x1.25x0.45
D
2.0
50
2.00x1.25x0.45
D
HIGH FREQUENCY
Frequency
Range(GHz)
Insertion Loss
(dB)
RFBPF2012090ALT
2.4~2.5
1.0max.(25℃)
1.2max.(-40~+85℃)
RFBPF2012090AMT
2.4~2.5
2.6
Part Number
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
2.00x1.25x0.90
G
2.0
50
2.00x1.20x0.90
B
2.0
50
2.00x1.20x1.00
I
2.0
50
2.00x1.20x0.90
B
2.0
50
2.00x1.20x0.90
B
2.0
50
2.00x1.20x1.00
I
2.0
50
2.00x1.20x0.90
E
2.0
50
2.00x1.20x0.90
B
2.0
50
2.00x1.20x0.90
B
2.0max.(25℃)
2.2max.(-40~+85℃)
25(746~764MHz)
30(824~849MHz)
26(869~960MHz)
28(1570~1580MHz)
28(1710~1785MHz)
30(1850~1910MHz)
30(1930~1990MHz)
25(2110~2170MHz0
15(3300~3800MHz)
35(4800~5000MHz)
20(7200~7450.5MHz)
2.0
50
2.00x1.25x0.45
D
3.5
30(880~960MHz)
30(1710~1990MHz)
20(2110~2170MHz)
30(4800~5000MHz)
30(7200~7500MHz)
2.0
50
2.00x1.20x0.80
C
2.8
(typ.2.5)
40(DC~1600MHz)
35(1710MHz)
25(1900MHz)
12(2100MHz)
8(2170MHz)
30(3100MHz)
40(4800~5000MHz)
20(7200~7500MHz)
2.0
50
2.00x1.20x0.80
B
2.8
30(960MHz)
30(1600MHz)
20(1990MHz)
35(3200MHz)
40(4800MHz)
25(7200MHz)
2.0
50
2.00x1.20x0.60
B
RFBPF2012100ANT
2.4~2.5
2.3max.(25℃)
2.6max.(-40~+85℃)
RFBPF2012090AQT
2.4~2.5
1.2
RFBPF2012090ART
2.4~2.5
1.0
RFBPF2012100AVT
2.4~2.5
2.3max.(25℃)
2.6max.(-40~+85℃)
RBBPF2010A108Q1C
2.4~2.5
1.3
RFBPF2012090A1T
2.4~2.5
1.7
RFBPF2012090A2T
2.4~2.5
1.4
RFBPF2012040A3T
RFBPF2012080A6T
RFBPF2012080A7T
RFBPF2012060A9T
2.4~2.5
2.4~2.5
2.4~2.5
2.4~2.5
Attenuation
( dB min. )
28(824~960MHz)
28(1570~1580MHz)
23(1710~1910MHz)
17(1920~1990MHz)
25(4800~5000MHz)
40(880~960MHz)
38(1710~1990MHz)
16(2170MHz)
30(4800~5000MHz)
25(7200~7500MHz)
40(699~960MHz)
40(1428~1448MHz)
40(1476~1607MHz)
40(1710~1785MHz)
33(1805~1880MHz)
30(1880~1915MHz)
30(1920~1990MHz)
22(2110~2170MHz)
25(4800~5000MHz)
35(7200~7500MHz
20(1600MHz)
25(3200MHz)
20(4800~5000MHz)
20(1600MHz)
25(3200MHz)
40(699~960MHz)
40(1428~1448MHz)
40(1476~1607MHz)
40(1710~1785MHz)
33(1805~1880MHz)
30(1880~1915MHz)
30(1920~1990MHz)
25(4800~5000MHz)
30(7200~7500MHz
38(50~960MHz)
17(1710~1910MHz)
5(3200MHz)
30(4800~5000MHz)
25(7200~7500MHz)
30(900MHz)
20(1850MHz)
30(4800MHz)
30(824~960MHz)
30(1710~1910MHz)
20(1920~1990MHz)
6(2110~2170MHz)
20(4800~5000MHz)
17
HIGH FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
RFBPF2520090ACT
2.4~2.5
2.1max.(25℃)
2.3max.(-40~+85℃)
RFBPF2520070AMT
2.4~2.5
2.0max.(25℃)
2.2max.(-40~+85℃)
RFBPF2520080AUT
2.4~2.5
2.2
RFBPF2520120A1T
2.4~2.5
1.7
RFBPF2520120A2T
2.4~2.5
2.1
RFBPF2520120A3T
2.4~2.5
≦1.2(25℃)
RFBPF2520120A4T
2.4~2.5
≦1.7(25℃)
RFBPF2520100A5T
2.4~2.5
2.0
RFBPF2520100A6T
2.4~2.5
1.4
RFBPF3225150A3T
2.4~2.5
2.5
RFBPF3225150A4T
2.4~2.5
2.0
RFBPF3225150A5T
2.4~2.5
1.8
Attenuation
( dB min. )
43(806~960MHz)
43(1570~1580 MHz)
43(1710~1990 MHz)
20(2110~2170MHz)
30(4800~5000 MHz)
25(7200~7500MHz)
45(824~960 MHz)
45(1570~1580 MHz)
45(1710~1785 MHz)
40(1805~1850 MHz)
35(1850~1910 MHz)
35(1920~1990 MHz)
25(2110~2170 MHz)
5(2750~3000 MHz)
15(3000~4800 MHz)
30(4800~5000 MHz)
30(5150~5850 MHz)
20(7200~7500 MHz)
30(900 MHz)
30(1850 MHz)
33(2170 MHz)
35(4800 MHz)
25(7200 MHz)
30(900/1850 MHz)
20(2100 MHz)
40(4800 MHz)
25(7200 MHz)
30(900/1850 MHz)
30(4800 MHz)
30(900/1850 MHz)
25(4800 MHz)
30(900/1850 MHz)
25(4800 MHz)
40(900 MHz)
35(3200 MHz)
30(1990 MHz)
20(2100 MHz)
40(4800 MHz)
25(7200 MHz)
35(1900/4800 MHz)
40(1500 MHz)
30(2100 MHz)
30(4800 MHz)
30(900 MHz)
30(1850 MHz)
20(2100 MHz)
30(4800 MHz)
30(900 MHz)
30(1850MHz)
20(2100 MHz)
30(4800 MHz)
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
2.50x2.00x0.90
G
2.0
50
2.50x2.00x0.70
A
2.0
50
2.50x2.00x0.80
A
2.0
50
2.50x2.00x1.20
A
2.0
50
2.50x2.00x1.20
A
2.0
50
2.50x2.00x1.20
A
2.0
50
2.50x2.00x1.20
A
2.0
50
2.50x2.00x1.00
A
2.0
50
2.50x2.00x1.00
A
1.7
3.20x2.50x1.50
A
2.0
50
3.20x2.50x1.50
A
2.0
50
3.20x2.50x1.50
A
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
1.10x0.90x0.60
E
2.0
50
1.40x1.10x0.70
E
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
50
2.50x2.00x0.90
J
1558 ~ 1606 MHz GNSS Band Applications
Part Number
Frequency
Range (MHz)
Insertion Loss
(dB)
RFBPF1109060E0T
1550~1610
1.9max.
RFBPF1411070E0T
1558~1606
1.8max.
Attenuation
( dB min. )
25(960MHz)
8(1850MHz)
15(1990MHz)
20(2170MHz)
35(2400~2500MHz)
35(3400~3800MHz)
30(824~849 MHz)
30(880~915 MHz)
22(1850~1910 MHz)
22(1920~1980 MHz)
30(2400MHz)
860~960MHz/1805~2025 MHz Band Application
Part Number
Frequency
Range (MHz)
Insertion Loss
(dB)
869~960
0.7max.(25℃)
0.75max.(-40~+85℃)
1805~2025
1.1max.(25℃)
1.2max.(-40~+85℃)
RFBPF2520090B08Q1C
18
Attenuation
( dB min. )
25(430~490MHz)
10(1700~1900MHz)
20(2400~2500MHz)
20(4905~5845MHz)
25(900~1015MHz)
15(2400~2500MHz)
15(3610~3980MHz)
20(4905~5845MHz)
1.9
2.0
HIGH FREQUENCY
5GHz BAND WORKING FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
RFBPF1608060K2T
4.9~5.84
1.5max.(25℃)
1.7max.(-40~+85℃)
RFBPF1608060K68Q1C
4.9~5.9
1.3
RFBPF1608060K78D1T
5.15~5.95
0.8
RFBPF1608060K88Q1C
5.15~5.95
0.7
(typ.0.6)
RFBPF1608060KG8D1T
5.15~5.95
0.8
RFBPF2012100KST
4.9~5.9
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
1.60x0.80x0.70
B
2.0
50
1.60x0.80x0.60
D
1.67
50
1.60x0.80x0.60
D
1.5
50
1.60x0.80x0.60
D
1.67
50
1.60x0.80x0.60
D
30(3450 MHz)
20(11000 MHz)
2.0
50
2.00x1.20x1.00
B
RFBPF2012100K0T
4.9~5.9
30(3450 MHz)
20(11000 MHz)
2.0
50
2.00x1.20x1.00
B
RFBPF2012100K1T
5.15~5.9
3.0
(typ.2.5)
2.0
50
2.00x1.20x1.00
B
RFBPF2012090K5T
4.9~5.85
2.2
2.0
50
2.00x1.20x0.90
B
RFBPF2012100K3T
4.9~5.85
1.8max.(25℃)
2.1max.(-40~+85℃)
2.0
50
2.00x1.20x0.95
B
RFBPF2012100K6T
5.15~5.85
1.6max.(25℃)
1.8max.(-40~+85℃)
2.0
50
2.00x1.20x0.95
B
RFBPF2012090K9T
5.725~5.85
2.0
2.0
50
2.00x1.20x0.95
B
RFBPF2520090K1T
4.9~5.85
1.2
47(824 MHz)
47(1500 MHz)
47(1910 MHz)
15(9800 MHz)
2.0
50
2.50x2.00x0.90
A
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
29(880~915 MHz)
29(1710~1785 MHz)
21(1850~1910 MHz)
15(1920~1980 MHz)
18(4600~4780 MHz)
23(6900~7170 MHz)
2.0
50
1.60x0.80x0.70
B
1.5(4.90GHz)
1.5(5.25GHz)
1.5(5.85GHz)
1.7(4.90GHz)
1.5(5.25GHz)
1.5(5.85GHz)
Attenuation
( dB min. )
33(100~2170 MHz)
29(2170~2500 MHz)
32(9800~12000 MHz)
38(30~2700MHz)
16(3453~3547MHz)
33(3667~3883MHz)
9(6900~7093MHz)
32(7333~7750MHz)
40(10600~11650MHz)
18(15540~17760MHz)
40(30~2700MHz)
45(3400~3800MHz)
20(7250~7800MHz)
20(10300~11700MHz)
35(30~2700MHz)
30(3400~3800MHz)
12(7250~7800MHz)
20(10300~11700MHz)
40(30~2700MHz)
45(3400~3800MHz)
20(6900MHz)
20(7250~7800MHz)
20(10300~11700MHz)
35(4000MHz)
35(4500MHz)
40(4600MHz)
35(340~1195 MHz)
19(2140~3580 MHz)
25(6855~7150 MHz)
20(8570~8930 MHz)
30(500 MHz)
35(3450 MHz)
30(4000 MHz)
20(4200 MHz)
15(9800 MHz)
15(11700 MHz)
30(500 MHz)
40(2000 MHz)
35(3450 MHz)
30(4000 MHz)
20(4200 MHz)
30(500 MHz)
30(4000 MHz)
20(4200 MHz)
32(5000 MHz)
15(9800 MHz)
15(11750 MHz)
WiMAX BAND WORKING FREQUENCY
Part Number
RFBPF16082G3W0T
Frequency
Range(GHz)
2.3~2.39
19
HIGH FREQUENCY
MoCA / Docsis Application
Part Number
Frequency
Range(MHz)
Insertion Loss
(dB)
RFBPF3225180Y1T
975~1025
3.0
RFBPF3225200Y07B1U
475~675
2.5max.(25℃)
2.7max.(-40~+85℃)
RBBPF3225180Y27B1U
400~700
2.0
RFBPF3225180C07B1U
1125~1675
1.8max.(25℃)
2.0max.(-40~+85℃)
RBBPF3225180C67B1U
1125~1675
2.0
RBBPF3225180C77B1U
1125~1225
2.0
Attenuation
( dB min. )
30(54~870 MHz)
30(1125~1675 MHz)
30(2300 MHz)
60(2.5 MHz)
40(2.5~100 MHz)
35(100~200 MHz)
35(200~300 MHz)
8(300~400 MHz)
57(950 MHz)
47(950~2025 MHz)
41(2025~2500 MHz)
35(2500~3000 MHz)
42(1~200 MHz)
30(950~2150 MHz)
35(2150~3000 MHz)
27(3000~5900 MHz)
30(5~864 MHz)
34(864~1002 MHz)
32(2300~3000 MHz)
40(1~900 MHz)
25(900~1002 MHz)
35(2000~2500 MHz)
27(2500~5900 MHz)
33(1~900 MHz)
25(900~1002 MHz)
25(1350~1675 MHz)
35(2000~2500 MHz)
27(2500~5900 MHz)
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
75
3.20x2.50x1.80
K
2.0
75
3.20x2.50x1.80
K
2.0
50
3.20x2.50x1.80
K
2.0
75
3.20x2.50x1.80
K
2.0
50
3.20x2.50x1.80
K
2.0
50
3.20x2.50x1.80
K
LTE Band Application
Part Number
Frequency
Range(MHz)
Band
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
RFBPF1109B101T
2110~2170
B1
1.7
25(4280MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B201T
1930~1990
B2
1.7
25(3920MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B301T
1805~1880
B3
1.4
25(3685MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B501T
869~894
B5
0.9
12(1763MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B701T
2620~2690
B7
1.2
25(5310MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B801T
925~960
B8
0.9
12(1885MHz)
2
50
1.10x0.90x0.60
E
TYPICAL ELECTRICAL CHARACTERISTICS
RFBPF1005040A1T
RFBPF1005040A3T
RFBPF1109060A0T
RFBPF1411060A1T
HIGH FREQUENCY
RFBPF1411060A2T
RBBPF1411060A3T
RFBPF1608060AA7M1U
RFBPF1608060ADT
dB(S(2,1))
dB(S(1,1))
-10
-20
-30
-40
-50
2
3
4
5
6
7
8
9
Frequency (GHz)
RFBPF1608060AET
RFBPF1608070AFT
dB(S(2,1))
dB(S(1,1))
-20
S-Parameter (dB)
S-parameter (dB)
-10
-30
-40
-50
-60
-70
0.5
1.5
2.5
3.5
4.5
5.5
Frequency (GHz)
7.5
Frequency (GHz)
RFBPF1608050A0T
S-Parameter (dB)
RFBPF1608070AWT
6.5
Frequency (GHz)
RFBPF1608060A1T
RFBPF1608060A7T
21
HIGH FREQUENCY
RFBPF1608060A8T
RFBPF2012080AM0T62
RFBPF2012080AC2T00
RFBPF2012090AS1T35
S-Parameter (dB)
-10
-20
-30
-40
-50
-60
-70
-80
2
3
4
5
6
7
8
9
10
Frequency (GHz)
22
RFBPF2012040ABT
RFBPF2012050ACT
RFBPF2012080ADT
RFBPF2012080AFT
RFBPF2012080AGT
RFBPF2012040AHT
HIGH FREQUENCY
RFBPF2012090ALT
S-Parameters
RBBPF2012050AHT
RFBPF2012090AMT
RFBPF2012100ANT
dB(S(2,1))
dB(S(1,1))
S-parameter (dB)
-10
-20
-30
-40
-50
-60
-70
0.5
1.5
2.5
3.5
4.5
5.5
6.5
7.5
Frequency (GHz)
RFBPF2012090AQT
RFBPF2012090ART
RFBPF2012100AVT
RBBPF2010A108Q1C
dB(S(2,1))
dB(S(1,1))
S-parameter (dB)
-10
-20
-30
-40
-50
-60
-70
0.5
1.5
2.5
3.5
4.5
5.5
6.5
7.5
Frequency (GHz)
RFBPF2012090A1T
RFBPF2012090A2T
23
HIGH FREQUENCY
RFBPF2012040A3T
RFBPF2012080A7T
RFBPF2520090ACT
RFBPF2520070AMT
dB(S(2,1))
dB(S(1,1))
S-parameter (dB)
-10
-20
-30
-40
-50
-60
-70
0.5
1.5
2.5
3.5
4.5
5.5
6.5
7.5
8.5
Frequency (GHz)
RFBPF2520080AUT
RFBPF2520100A5T
RFBPF2520100A6T
RFBPF1608060K2T
dB(S(2,1))
dB(S(1,1))
S-parameter (dB)
-10
-20
-30
-40
-50
-60
1
3
5
7
9
Frequency (GHz)
RFBPF1608060K68Q1C
24
RFBPF1608060K788Q1C
11
HIGH FREQUENCY
RFBPF1608060K88Q1C
RFBPF1608060KG8D1T
RFBPF2012100KST
RFBPF2012090K5T
dB(S(2,1))
dB(S(1,1))
-10
-20
-30
-40
-50
0.5
2.5
4.5
6.5
8.5
10.5
freq, GHz
RFBPF2012100K3T
RFBPF2012100K6T
RFBPF2012090K9T
RFBPF2520090K1T
dB(S(2,2))
dB(S(2,1))
dB(S(1,1))
-20
-40
-60
-80
4
6
8
10
12
freq, GHz
RFBPF1109060E0T
RFBPF1411070E0T
25
HIGH FREQUENCY
RFBPF2520090B08Q1C
Low Band
Low-Band
-10
-10
-10
-20
-30
-40
-50
-30
-40
-50
-60
-60
-70
-70
2
3
4
S-Parameter (dB)
S-Parameter (dB)
-20
-30
-40
-50
50
Frequency (GHz)
61
72
83
Frequency (GHz)
High-Band
-20
-30
-40
-50
-60
-60
-70
4
05
High Band
High-Band
S-Parameter (dB)
S-Parameter (dB)
Low-Band
16
27
38
4
-70
50
61
72
83
4
5
6
7
8
Frequency (GHz)
Frequency (GHz)
RFBPF3225180Y1T
RFBPF3225200Y07B1U
RBBPF3225180Y27B1U
RFBPF3225180C07B1U
S-Parameter (dB)
-10
-20
-30
-40
-Insertion Loss
-Return Loss
-50
-60
0.5
1.0
1.5
2.0
Frequency (GHz)
26
RBBPF3225180C67B1U
RBBPF3225180C77B1U
RFBPF1109B101T
RFBPF1109B201T
2.5
3.0
HIGH FREQUENCY
RFBPF1109B301T
RFBPF1109B501T
RFBPF1109B701T
RFBPF1109B801T
For more information, please contact with local sales representative
All specifications are subject to change without notice
27
HIGH FREQUENCY
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-2
STRUCTURE B
Unit: mm
Structure\
Dimension
A
L
W
T
A
B
C
D
E
F
G
1.60±0.15
0.80±0.15
0.60±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.20±0.15
0.30±0.15
1.20±0.10
0.40±0.10
0.175±0.10
0.35±0.15
0.30±0.15
0.65±0.10
0.20±0.10
0.20±0.15
0.50±0.10
0.50±0.10
0.20±0.15
0.30±0.15
0.35±0.15
0.65±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.60±0.10
0.20±0.15
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.50±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.30±0.10
0.63±0.10
0.20±0.15
0.20±0.15
0.50±0.10
2.00±0.15
0.90±0.10
0.20±0.15
0.30±0.10
0.35±0.10
1.25±0.15
B
28
1.00±0.10
0.20±0.15
1.10±0.10
0.20±0.15
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.10
0.20±0.15
0.50±0.10
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.55±0.10
0.50±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.50±0.10
2.50±0.20
2.00±0.20
0.85±0.10
0.35±0.20
0.40±0.10
0.30±0.10
0.70±0.20
0.15(Typical)
0.15(Typical)
1.20±0.20
2.00±0.15
1.25±0.10
0.60±0.10
0.20±0.10
0.30±0.15
0.25±0.15
0.65±0.10
0.25±0.10
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Walsin:
RFBPF2520100A6T RFBPF2520100A5T RFBPF1608070A0T RFBPF3225150A4T RFBPF2012080A5T
RFBPF2012090A1T RFBPF2520120A2T RFBPF2520120A1T RFBPF2520120A4T RFBPF3225150A5T
RFBPF2520120A3T RFBPF2012100K0T RFBPF2012100C67B1U WDBPF5235180K3T RFBPF1608060AC8T37
WDBPF5697360K2T RFBPF1608060K68Q1C RFBPF1608060AM1T59 RFBPF2012080AC2T00
RFBPF3225180C07B1U RFBPF1608060A1T RFBPF1608060K88Q1C RFBPF1608060K98Q1C
RBBPF3225180C67B1U RFBPF1608060AET RFBPF3225200Y07B1U RFBPF1608060AA7M1U RFBPF2012040ABT
RFBPF1608060ABT RFBPF2520070AMT RFBPF2012080AFT RFBPF1608060K78Q1C RFBPF1608060AAT
RFBPF1606K16T RFBPF2008A62T RFBPF2009A19T RFBPF2012100KMT RBBPF2012050AHT
RFBPF2520080AUT RFBPF2520080Y0T RFBPF2520090ACT RFBPF2520090K1T RFBPF2520090K2T
RFBPF2520120A17K1U RFBPF2012100K7T RFBPF2012100KST RFBPF20122G5W0T RFBPF2520070S0T
RFBPF2520080A7T RFBPF2520080A9T RFBPF2012090K5T RFBPF2012090K8T RFBPF2012100K1T
RFBPF2012100K2T RFBPF2012100K3T RFBPF2012100K6T RFBPF2012090ALT RFBPF2012090AMT
RFBPF2012090AQ9D1T RFBPF2012090AQT RFBPF2012090ART RFBPF2012090AS1T35 RFBPF2012080A7T
RFBPF2012080ADT RFBPF2012080AGT RFBPF2012080AL1T51 RFBPF2012090A17B1U RFBPF2012090A2T
RFBPF2012040AB7B1U RFBPF2012040AHT RFBPF2012050ACT RFBPF2012060A9T RFBPF2012060AAT
RFBPF2012070AET RFBPF1608070A5T RFBPF1608070AWT RFBPF1608080A07B1U RFBPF16082G3W0T
RFBPF16082G6W0T RFBPF16083G5W0T RFBPF1608060APT RFBPF1608060AUT RFBPF1608060K0T
RFBPF1608060K1T RFBPF1608060K2T RFBPF1608070A3T RFBPF1608050A4T RFBPF1608060A2T
RFBPF1608060A5T RFBPF1608060A6T RFBPF1608060A7T RFBPF1608060A8T RFBPF1005040A0T
RFBPF1005040A1T RFBPF1005040AUT RFBPF1608040A5T RFBPF1608040A6T RFBPF1608050A0T
RFBPF2012080AC2T20
很抱歉,暂时无法提供与“RFBPF1608060AM1T59”相匹配的价格&库存,您可以联系我们找货
