RFBPB2012090A9T
RFBPB2012090A9T
    WALSIN(华新科)
    特性:小型封装尺寸:2.0×1.2×0.9 mm³。 低厚度。 低插入损耗。 高抑制率。 对二次谐波有高衰减抑制。 允许直流偏置。应用:2.4GHz ISM频段射频应用。 蓝牙、无线局域网802.11...
RFBPB2012090A9T 数据手册
Approval sheet RFBPB 2012(0805) Series – RoHS Compliance MULTILAYER CERAMIC BAND PASS FILTER - Balanced Type Halogens Free Product 2.4 GHz ISM Band Working Frequency P/N: RFBPB2012090A9T *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_RFBPB2012090A9T_V05 May 2016 Approval sheet FEATURES 1. Miniature footprint: 2.0 X 1.2 X 0.9 mm 2. Low Profile Thickness 3. Low Insertion loss 4. High Rejection Rate 5. High attenuation on 2 6. Allowable for DC biasing. 7. LTCC process nd 3 harmonic suppressed APPLICATIONS 1. 2.4GHz ISM band RF applications 2. Bluetooth, Wireless LAN 802.11b/g/n, HomeRF CONSTRUCTION Top view P3 P2 P1 P8 P4 P5 P6 PIN Definition PIN Definition P1 Unbalance Port P5 Balance Port P2 DC/GND P6 GND P3 NC P7 Balance Port P4 GND P8 GND P7 DIMENSIONS Figure Symbol Dimension (mm) L 2.00± 0.15 W 1.25 ± 0.10 T 0.90±0.10 A 0.20 ± 0.15 B 0.30 ± 0.10 C 0.35 ± 0.10 D 0.65 ± 0.10 E 0.20 ± 0.15 F 0.20 ± 0.15 G 0.30 ± 0.10 Top view Bottom view Side view Side view Page 2 of 7 ASC_RFBPB2012090A9T_V05 May 2016 Approval sheet ELECTRICAL CHARACTERISTICS RFBPB2012090A9T Specification Frequency range 2400 ~ 2500 MHz Insertion Loss 2.8 dB max. Phase Difference 180∘± 10∘ Amplitude Difference 2 .0 dB Max 35dB min. @ 880 ~ 960 MHz Attenuation 30dB min. @ 1575 MHz 25dB min. @ 1710~1880 MHz 30dB min. @ 4800~5000 MHz VSWR 2.1 max. Impedance (Unbalanced) 50 Ω Impedance ( Balanced ) Conjugate match to BC series of Bluetooth chipset Operation Temperature Range -40 C ~ +85 C Moisture sensitivity levels o o LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Typical Electrical Chart SOLDER LAND PATTERN Figure Unit: mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_RFBPB2012090A9T_V05 May 2016 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Solder:Sn3Ag0.5Cu for lead-free Leaching *Solder bath temperature:260  5C (Resistance to *Leaching immersion time:30  0.5 sec dissolution of Loss of metallization on the edges of each electrode shall not exceed 25%. Solder : SN63A metallization) IEC 60068-2-58 Resistance to soldering *Preheating temperature:120~150℃, No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under heat JIS C 0050-5.4 *Immersion time:101 sec the operational temperature range within -40 ~ 85°C. Solder:Sn3Ag0.5Cu for lead-free Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. Customer’s specification. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 Bending test JIS C 0051- 7.4.1 *Pressurizing force: 5N(≦0603);10N(>0603) No remarkable damage or removal of the termination. *Test time:10±1 sec The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_RFBPB2012090A9T_V05 May 2016 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_RFBPB2012090A9T_V05 May 2016 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF BPB 201209 0 Walsin Product Code Dimension code RF device BPB : Balanced Type Per 2 digits of Length, Width, Thickness : Band Pass Filter e.g. : A Unit of dimension 0 : 0.1 mm 9 T Application Specification Packing A : 2.4GHZ ISM Band Design Code T: 7” Reeled 1 : 1.0 mm 201209 = Length 20, Width 12, Thickness 0.9 Minimum Ordering Quantity: 2000 pcs per reel. By 7” Reeled package PACKAGING Plastic Tape specifications (unit :mm) Index Ao Bo ΦD T W Dimension (mm) 1.35 ± 0.10 2.30 ± 0.10 1.55 ± 0.10 0.95 ± 0.10 8.00 ± 0.30 Index E F Po P1 P2 Dimension (mm) 1.75 ± 0.10 3.50± 0.05 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.10 Page 6 of 7 ASC_RFBPB2012090A9T_V05 May 2016 Approval sheet Reel dimensions C A B Index A B C Dimension (mm) 178 60.0 13.5 Typing Quantity: 2000 pieces per 7" reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be confirmed. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : -10 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFBPB2012090A9T_V05 May 2016
RFBPB2012090A9T 价格&库存
很抱歉,暂时无法提供与“RFBPB2012090A9T”相匹配的价格&库存,您可以联系我们找货
