Technical Data 4313
Effective September 2018
Supersedes October 2015
CMS
Common mode inductors, surface mount
Applications
EMI filters
DC-DC brick power supplies
Discrete output supplies
Discrete and point-of-use power supplies (PUPS)
Environmental data
Product description
Three sizes of surface mount torroidal commonmode inductors that provide 300Vdc isolation
Inductance range from 5.5uH to 1600uH
Current range up to 7.0 Amps
Noise attenuation up to 44 dB
Frequency range up to 100 MHz
Meets UL94V-0 flammability standard
Ferrite core material
Storage temperature range: -40°C to +160°C
Operating ambient temperature range: -40°C to
+160°C (range is application specific)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb
CMS
Technical Data 4313
Effective Sepetember 2018
Product specifications
Part number
OCL (uH) minimum
(1-2) & (4-3)
I rms. Amperes
Max*
DCR (Ω) typ @
20°C (1-2)
DCR (Ω) typ @
20°C (4-3)
Leakage
Inductance (uH)
typ
Interwinding
Capacitance (pF) typ
CMS1-1-R
4.5
7.00
0.0027
0.0027
0.05
2.0
CMS1-2-R
8
5.70
0.0040
0.0040
0.09
2.1
CMS1-3-R
12.6
4.10
0.077
0.077
0.14
2.2
CMS1-4-R
18
3.80
0.0089
0.0089
0.20
2.3
CMS1-5-R
25
3.60
0.0100
0.0100
0.28
2.4
CMS1-6-R
32.8
3.10
0.0138
0.0138
0.36
2.5
CMS1-7-R
41.5
2.60
0.019
0.019
0.45
2.6
CMS1-8-R
51.2
2.20
0.026
0.026
0.056
2.7
CMS1-9-R
62
1.90
0.035
0.035
0.68
2.7
CMS1-10-R
73.7
1.65
0.048
0.048
0.81
2.8
CMS1-11-R
100
1.35
0.070
0.070
1.10
3.9
CMS1-12-R
131
1.15
0.100
0.100
1.45
3.0
CMS1-13-R
166
1.00
0.138
0.138
1.83
3.1
CMS1-14-R
205
0.85
0.186
0.186
2.25
3.2
CMS2-0-R
14
6.00
0.004
0.004
0.13
1.7
CMS2-1-R
25
5.35
0.005
0.005
0.22
2.0
CMS2-2-R
40
4.40
0.008
0.008
0.34
2.3
CMS2-3-R
57
3.60
0.012
0.012
0.47
2.5
CMS2-4-R
102
2.80
0.019
0.019
0.80
2.8
CMS2-5-R
160
2.30
0.029
0.029
1.25
3.1
CMS2-6-R
230
1.85
0.044
0.044
1.75
3.4
CMS2-7-R
270
1.60
0.060
0.060
2.00
3.6
CMS2-8-R
360
1.35
0.084
0.084
2.60
3.9
CMS2-9-R
460
1.10
0.120
0.120
3.30
4.3
CMS2-10-R
575
0.94
0.170
0.170
4.00
4.3
CMS2-11-R
700
0.80
0.230
0.230
5.00
4.6
CMS2-12-R
915
0.67
0.330
0.330
6.30
4.9
CMS2-13-R
1070
0.58
0.440
0.440
7.30
5.1
CMS2-14-R
1340
0.50
0.620
0.620
9.00
5.4
CMS3-1-R
28
5.70
0.005
0.005
0.31
2.80
CMS3-2-R
45
5.10
0.006
0.006
0.46
3.05
CMS3-3-R
64
4.75
0.007
0.007
0.64
3.30
CMS3-4-R
88
3.95
0.010
0.010
0.85
3.50
CMS3-5-R
146
3.10
0.017
0.017
1.30
3.70
CMS3-6-R
217
2.85
0.020
0.020
1.90
3.90
CMS3-7-R
258
2.45
0.027
0.027
2.20
4.15
CMS3-8-R
350
2.00
0.040
0.040
3.00
4.40
CMS3-9-R
400
1.70
0.053
0.053
3.30
4.65
CMS3-10-R
518
1.45
0.076
0.076
4.20
4.85
CMS3-11-R
648
1.20
0.107
0.107
5.10
5.10
CMS3-12-R
790
1.05
0.145
0.145
6.10
5.35
CMS3-13-R
1030
0.88
0.210
0.210
7.80
5.55
CMS3-14-R
1310
0.75
0.300
0.300
9.60
5.80
Definitions:
OCL = Open Circuit Inductance
DCR = Direct Current Resistance
Irms = rms current for approx. a 40°C temperature rise at an ambient temperature of 85°C.
*Operating Temperature: 160°C Max. Inductance values are sustained up to 160°C.
Electrical Characteristics:
OCL (1-2) 0.10Vrms, 100kHz, 0.0Adc: (See Chart)
2
www.eaton.com/electronics
OCL (4-3) 0.10Vrms, 100kHz, 0.0Adc: (See Chart)
DCR (1-2) typ @ 20°C: (See Chart)
DCR (4-3) typ @ 20°C: (See Chart)
Hipot rating: winding to winding: 300Vdc min. for 1 second.
Turns Ratio: (1-2):(4-3) 1:1
Technical Data 4313
CMS
Dimensions–mm
CMS1
RECOMMENDED PCB LAYOUT
TOP VIEW
SCHEMATIC
9.4 max
3
4
CMS1wwllyy R
F RONT VIEW
2
1:1
7.2 max
1
2.6 max
1
4
2
3
Pin 1 indicator
White dot
CMS2
CMS3
wwllyy = Date code R = Revision level
3
CMS
Technical Data 4313
Packaging Information
CMS1 CMS2
Supplied in tape and reel packaging, 2,000 parts per 13” diameter reel
(see note 1)
See note 1
min.
See note 6
Pin #1 indicator
+0.1/-0.0
7
See note 6
Bo
A
B
Ko= 2.7mm
A
Ao
Ko
Ao=9.3mm
+/-0.3
(see note 6)
min
A
1.75
Pin #1 Indicator
0.3Rad
max.
Bo=9.3mm
(see note 6)
+/-0.3
B
Ko=6.4mm
K
typ.
12.0
SECTION A-A
+0.1/-0.0
+/-0.05
1.75
A
+/-0.05
0.3Rad
max.
Supplied in tape and reel packaging, 800 parts per 13” diameter reel
6.7
12.0
A
SECTION A-A
Direction of feed
A
typ
User direction of feed
CMS3
Supplied in tape and reel packaging, 600 parts per 13” diameter reel
(see note 1)
+0.1/-0.0
+/-0.05
Ao=11.8mm
Bo=11.8mm
(see note 6)
min
A
1.75
Pin #1 Indicator
0.3Rad
max.
(see note 6)
+/-0.3
B
Ko=6.8mm
K
A
A
7.1
typ
16.0
SECTION A-A
Attenuation Curves
Attenuation
-5
Attenuation
CMS 1
-10
-7
-15
dB
dB
-10
-20
-25
-30
-35
-11
1
2
4
6
8
10
60
-1
-11
1
-14
2
4
dB
Attenuation
-10
-15
-20
-25
-30
-35
-40
-45
-50
CMS 3
-1
-11
1
-4
-7
-14
2
4
6
8
FREQUENCY (MHz)
6
8
10
FREQUENCY (MHz)
FREQUENCY (MHz)
4
-4 -7
-15
-20
-25
-30
-35
-40
-45
-50
-14
CMS 2
10
60
Technical Data 4313
CMS
Impedance Curves
350
300
250
200
150
100
50
Impedance
CMS1-1 & 4
4000
-4
-1
0.4
0.6
0.8
-14
1
2
3
4
6
8
-11
2000
0.4
0.6
CMS2 - 1 & 4
-1
0.6
0.8
1
2
4
6
8
10
16000
14000
12000
10000
8000
6000
4000
2000
3
4
6
8
10
CMS2 - 7,11, & 14
-11
-7
0.6
0.8
1
2
3
4
6
FREQUENCY (MHz)
CMS3 - 1 & 4
Impedance
CMS3 - 7,11, & 14
16000
-4
Z (Ohms)
Z (Ohms)
1600
1400
1200
1000
800
600
400
200
-14
0.4
FREQUENCY (MHz)
Impedance
1
Impedance
-4
0.4
0.8
FREQUENCY (MHz)
Z (Ohms)
Z (Ohms)
Impedance
-7
1000
FREQUENCY (MHz)
1800
1600
1400
1200
1000
800
600
400
200
CMS1 - 7,11, & 14
3000
Z (Ohms)
Z (Ohms)
Impedance
-1
0.6
0.8
1
2
3
4
FREQUENCY (MHz)
6
8
14000
12000
10000
8000
6000
4000
2000
-14
0.6
-11
0.8
1
2
3
-7
4
6
8
FREQUENCY (MHz)
5
Technical Data 4313
CMS
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“CMS2-11-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 800+21.49285800+2.79400
- 国内价格 香港价格
- 1+40.244081+5.23160
- 10+33.0607610+4.29780
- 25+30.5820925+3.97558
- 50+28.8350850+3.74847
- 100+27.18967100+3.53457
- 250+26.07710250+3.38994
- 国内价格 香港价格
- 800+23.24652800+3.02198
- 1600+21.926751600+2.85041
- 2400+21.304802400+2.76956
