CLJ-2-473
CLJ-2-473
    AMGIS
    CLJ-2-473
CLJ-2-473 数据手册
CLJ-2 Series • Miniature SMD Common Mode Double Chokes Features • Miniature, low cost SMD for pick and place compatability while providing consistent and reliable coplanarity • Other inductance values, higher current ratings and special types for operation at 150°C ambient are available upon request • High attenuation over a wide frequency range - CAN bus types to 500MHz • Available in Bifilar and Sector (Suffix S) winding • Materials: UL94-VO • Manufactured in an ISO-9001:2000, TS-16949:2002 and ISO-14001:2004 certified AMGIS facility • Fully RoHS compliant and meets lead free reflow level J-STD-020C Test frequency Nominal Inductance: measured @ 100kHz/20 mVrms Leakage Inductance: measured @ 100kHz, 100mVrms Test Equipment: HP4192A Electrical Specifications @ 25°C Nominal Voltage: 42Vac (50/60Hz), 80Vdc Operating Temperature: -25° to +85°C Storage Temperature: -40° to +125°C Climatic category: according to IEC68-1 25/85/56 Test voltage between windings: 500 Vrms Part Number OCL (μH) +50/-30% Weight: ~ 0.3 gram Packaging: Tape & Reel IN (mA) LL (μH) RCU (mOhms) VT (Vrms) Number of Data Lines 500 500 500 2 2 2 500 500 500 500 500 500 500 500 500 500 500 500 2 2 2 2 2 2 2 2 2 2 2 2 Sector Winding for CAN bus and similiar applications CLJ-2-060S CLJ-2-250S CLJ-2-510S 6 25 51 2500 800 800 0.40 0.95 2.00 70 110 160 Bifilar Winding for Data and Signal Lines 5 11 25 51 100 470 1000 2200 4700 10000 20000 47000 CLJ-2-050 CLJ-2-110 CLJ-2-250 CLJ-2-510 CLJ-2-101 CLJ-2-471 CLJ-2-102 CLJ-2-222 CLJ-2-472 CLJ-2-103 CLJ-2-203 CLJ-2-473 1200 500 500 500 500 500 500 400 200 200 140 100 0.05 0.05 0.08 0.10 0.11 0.10 0.16 0.12 0.19 0.36 1.00 1.00 56 80 110 148 315 290 275 345 940 1400 1800 3900 0.350 0.287 (8.90) (7.30) 0.100 (2.54) 0.185 0.146 (4.70) (3.70) CLJ2-XXX Wk/Yr Dimensions Suggested Pad Layout 0.394 (10.00) 0.213 (5.40) 0.039 (1.00) Bifilar Winding Sector (CLJ-2-XXXS) Winding Schematic 1 4 2 3 0.213 (5.40) 0.100 (2.54) 0.020 x 0.012 (0.50 x 0.30) Surface Coplanarity will be 0.004(0.10) maximum Dimensions: Inches (Millimeters) Tolerance: ±0.010 (0.25) unless specified otherwise See following page for typical impedance curves sales@alfamag.com AMGIS, LLC * 10830 Kinghurst Dr. Houston, TX 77099 Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com Toll Free: 877-762-6447 * www.amgistoroids.com CLJ-2 Series • Impedance Performance Impedance Performance CLJ-2 Series Double Chokes with Sector Winding Impedance in Ohms 10,000 1,000 100 10 1 100 1,000 10,000 100,000 1,000,000 Frequency in kHz 2 x 6μH 2 x 25μH 2 x 51μH Impedance Performance CLJ-2 Series Double Chokes with Bifilar Winding Impedance in Ohms 100,000 10,000 1,000 100 10 10 100 1000 10000 100000 Frequency in kHz 2x5μH 2x11μH 2x25μH 2x51μH 2x100μH 2x470μH 2x1.0mH 2x2.2mH 2x4.7mH 2x10mH 2x20mH 2x47mH AMGIS, LLC * 10830 Kinghurst Dr. Houston, TX 77099 Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com sales@alfamag.com Toll Free: 877-762-6447 * www.amgistoroids.com
CLJ-2-473 价格&库存
很抱歉,暂时无法提供与“CLJ-2-473”相匹配的价格&库存,您可以联系我们找货
