CMT1-7-R
CMT1-7-R
    EATON(伊顿)
    CMT1-7-R
CMT1-7-R 数据手册
Technical Data 4312 Effective October 2015 Supersedes March 2007 CMT Common mode inductors, through-hole Applications • Protects AC input from effects of switching regulators e v i t c e til f f E n , u d r d. e o u n 6 i e t t 1 n e Pb 0 l o 2 p c , e s i 1 d d D rch s e i e l d y b a n r a e l o i M nt a m v e m a v o t in rec n e No lacem p e r • Off-line power supplies • EMI filters • DC-DC converters • Computer, TV, audio and office equipment Environmental data Product description • Four sizes of through-hole off-line common mode inductors • Inductance range from 0.53 - 66 mH • Current range up to 6.5 Amps • Noise attenuation up to 68 dB • Frequency range up to 6 MHz • Meets UL94V-0 flammability standard • Ferrite core material • Storage temperature range (component): -40°C to +125°C • Operating temperature range: -40°C to +125°C (ambient + self-temperature rise). CMT Common mode inductors, through-hole  Technical Data 4312 Effective October 2015 Product specifications Part number OCL (mH) minimum (1-2) OCL (mH) minimum (4-3) l rms. Amperes max DCR (Ω) typ @ 20°C (1-2) DCR (Ω) typ @ 20°C (4-3) CMT1-1-R 66.0 66.0 0.74 1.20 1.20 CMT1-2-R 49.0 49.0 0.88 0.85 0.85 CMT1-3-R 28.0 28.0 1.13 0.50 0.50 CMT1-4-R 21 21 1.37 0.35 0.35 CMT1-5-R 13 13 1.76 0.20 0.20 CMT1-6-R 7.50 7.50 2.27 0.13 0.13 CMT1-7-R 4.20 4.20 2.89 0.08 0.08 CMT1-8-R 2.40 2.40 3.85 0.045 0.045 CMT1-9-R 1.85 1.85 4.53 0.033 0.033 CMT1-10-R 0.94 0.94 6.05 0.018 0.018 CMT2-1-R 30 30 1.50 0.350 0.350 CMT2-2-R 20 20 1.95 0.220 0.220 CMT2-3-R 12 12 2.45 0.135 0.135 CMT2-4-R 8.0 8.0 2.80 0.100 0.100 CMT2-5-R 6.0 6.0 3.40 0.070 0.070 CMT2-6-R 4.8 4.8 3.95 0.053 0.053 CMT2-7-R 3.2 3.2 4.40 0.042 0.042 CMT2-8-R 2.4 2.4 4.75 0.037 0.037 e v i t c e til f f E n , u d r d. e o u n 6 i e t t 1 n e 0 l o 2 p c , e s i 1 d d D rch s e i e l d y b a n r a e l o i M nt a m v e m a v o t in rec n e No lacem p e r CMT2-9-R 2.0 2.0 5.45 0.028 0.028 CMT2-10-R 1.6 1.6 5.75 0.026 0.026 CMT3-1-R 5.4 5.4 2.0 0.12 0.12 CMT3-2-R 3.5 3.5 2.6 0.08 0.08 CMT3-3-R 2.7 2.7 3.0 0.055 0.055 CMT3-4-R 1.3 1.3 4.0 0.032 0.032 CMT3-5-R 0.92 0.92 5.0 0.021 0.021 CMT3-6-R 0.53 0.53 6.5 0.013 0.013 CMT4-1-R 5.4 5.4 2.0 0.12 0.12 CMT4-2-R 3.5 3.5 2.6 0.08 0.08 CMT4-3-R 2.7 2.7 3.0 0.055 0.055 CMT4-4-R 1.3 1.3 4.0 0.032 0.032 CMT4-5-R 0.92 0.92 5.0 0.021 0.021 CMT4-6-R 0.53 0.53 6.5 0.013 0.013 Definitions: OCL = Open Circuit Inductance DCR = Direct Current Resistance Irms = rms current for 40°C max temperature rise at worst case ambient temperature of 85°C. 2 www.eaton.com/elx Electrical Characteristics: OCL (1-2) 0.10Vrms, 10kHz, 0.0Adc: (See Chart) OCL (4-3) 0.10Vrms, 10kHz, 0.0Adc: (See Chart) DCR (1-2) typ @ 20°C: (See Chart) DCR (4-3) typ @ 20°C: (See Chart) Hipot rating: winding to winding: 2400 Vac for 1 second. Turns Ratio: (1-2):(4-3) 1:1 CMT Common mode inductors, through-hole Technical Data 4312 Effective October 2015  Dimensions–mm CMT1 FRONT VIEW SIDE VIEW 29.5 max CMT1-X wwll yy R BOTTOM VIEW RECOMMENDED PCB LAYOUT SCHEMATIC 0.80 dia 1.15 dia ± 0.13 4 1 2 3 1 4 36.5 max 2 3 13.0 ± 0.20 3 3 3 4 10.00 13.00 CMT2 e v i t c e til f f E n , u d r d. e o u n 6 i e t t 1 n e 0 l o 2 p c , e s i 1 d d D rch s e i e l d y b a n r a e l o i M nt a m v e m a v o t in rec n e No lacem p e r FRONT VIEW 36.5 max SIDE VIEW CMT2 wwll yy R RECOMMENDED PCB LAYOUT BOTTOM VIEW 3.00 dia ± 0.13 15.0 ± 0.20 44.5 max 3 21.0 ±0.2 CMT3 3 TOP VIEW Pin #1 Indicator 1 25.0 max Dia 5 typ 15.0 ±0.20 3 4 2 3 3 RECOMMENDED PCB LAYOUT 15.0 ±0.20 ØDia 1 1 y dia 3 4 2 Pin #1 indicator BOTTOM VIEW SIDE VIEW 2 4 21.0 ± 0.20 4 15.0 ±0.2 1 26.5 max 4 1 3 2 SCHEMATIC 3 2 component side 3.2 2 1.2 dia 4 1 4.0 ± 1.0 2 Pin #1 indicator 3.8 typ 2 4 22.0 max component side 10.0 ± 0.20 1 15.0 ± 0.20 2 z dia CMT3-1 CMT3-2 CMT3-3 CMT3-4 CMT3-5 CMT3-6 component side 3 4 2 "Y" Dia ref 0.58 0.64 0.71 0.80 0.89 0.99 "Z" Dia ref 0.83 0.90 0.97 1.06 1.15 1.25 15.0 ± 0.20 14 max CMT4 FRONT VIEW 25.0 max BOTTOM VIEW SIDE VIEW 4 5.0 typ 1 Pin #1 indicator 12.00 1 3 2 1 y dia 1 CMT4-x wwllyy - R 25.5 max 4 RECOMMENDED PCB LAYOUT 15.4 max 11.00 11.0 ± 0.20 z dia 4 component side 2 3 CMT4-1 CMT4-2 CMT4-3 CMT4-4 CMT4-5 CMT4-6 "Y" Dia ref 0.58 0.64 0.71 0.80 0.89 0.99 "Z" Dia ref 0.83 0.90 0.97 1.06 1.15 1.25 12.0 ± 0.20 2 (1) All Dimensions are in millimeters unless otherwise specified (2) Tolerances are +/- 0.20mm unless stated otherwise. (3) wwllyy = (Date Code) R = (Revision Level) Schematic is the same for all the series www.eaton.com/elx 3 CMT Common mode inductors, through-hole  Technical Data 4312 Effective October 2015 Attenuation Curves Attenuation CMT1 0 -6 -7 -8 -9 -10 -10 dB -20 -30 -40 -50 -60 e v i t c e til f f E n , u d r d. e o u n 6 i e t t 1 n e 0 l o 2 p c , e s i 1 d d D rch s e i e l d y b a n r a e l o i M nt a m v e m a v o t in rec n e No lacem p e r -1 -2 -3 -70 0.06 0.1 -4 -5 0.2 0.6 1 2 4 FREQUENCY (MHz) dB Attenuation CMT2 -20 -25 -30 -35 -40 -45 -50 -55 -60 -65 -70 -6 -7 -8 -9 -10 -1 -2 -3 -4 -5 0.08 0.1 0.15 0.2 0.3 0.4 0.5 0.6 0.7 0.8 4 6 FREQUENCY (MHz) Attenuation CMT3 & CMT4 -10 -15 -5 -20 -6 dB -25 -30 -3 -35 -4 -40 -45 -50 0.06 -1 0.1 -2 0.2 0.4 0.6 0.8 1 FREQUENCY (MHz) 4 www.eaton.com/elx 2 CMT Common mode inductors, through-hole Technical Data 4312 Effective October 2015  Impedance Curves Impedance 100 CMT1 - 1 thru - 5 -1 90 -2 80 18 Z (K Ohm) 50 40 30 -4 10 0.1 0.2 0.3 0.4 40 20 0 0.5 0.6 0.7 0.8 0.2 0.4 Impedance CMT2 - 1 thru - 5 25 -1 -2 -3 -5 -6 0.1 0.2 0.3 0.4 0.5 0.6 5 0 0.06 1.4 -7 -8 15 10 5 -9 -10 0 0.7 0.05 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.2 1.4 1.6 FREQUENCY (MHz) Impedance CMT3 & CMT4 3.5 -1 -3 3 -4 -5 -6 2.5 -2 Z (K Ohm) Z (K Ohm) 10 1 CMT2 - 6 thru -10 20 -4 Impedance CMT3 & CMT4 15 0.8 FREQUENCY (MHz) FREQUENCY (MHz) 20 0.6 e v i t c e til f f E n , u d r d. e o u n 6 i e t t 1 n e 0 l o 2 p c , e s i 1 d d D rch s e i e l d y b a n r a e l o i M nt a m v e m a v o t in rec n e No lacem p e r 0.05 25 -9 6 0.05 0.9 Z (K Ohm) Z (K Ohm) 60 10 8 2 FREQUENCY (MHz) Impedance 80 -10 -8 0 0.05 100 12 4 -5 0 120 -7 14 60 20 CMT1 - 6 thru -10 -6 16 -3 70 Z (K Ohm) Impedance 20 2 1.5 1 0.5 0.1 0.2 0.4 0.6 FREQUENCY (MHz) 0.8 1 2 0 0.06 0.1 0.2 0.4 0.6 0.8 FREQUENCY (MHz) 1 2 4 www.eaton.com/elx 5 CMT Common mode inductors, through-hole  Technical Data 4312 Effective October 2015 Wave solder profile tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin e v i t c e til f f E n , u d r d. e o u n 6 i e t t 1 n e 0 l o 2 p c , e s i 1 d d D rch s e i e l d y b a n r a e l o i M nt a m v e m a v o t in rec n e No lacem p e r Preheat area Cool down area Time Reference EN 61760-1:2006 Profile Feature Standard SnPb Solder Lead (Pb) Free Solder • Temperature min. (Tsmin) 100°C 100°C • Temperature typ. (Tstyp) 120°C 120°C • Temperature max. (Tsmax) 130°C 130°C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150°C max. 150°C max. Peak temperature (TP)* 235°C – 260°C 250°C – 260°C 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max 4 minutes 4 minutes Preheat Time at peak temperature (tp) Ramp-down rate Time 25°C to 25°C Manual solder 350°C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/elx © 2015 Eaton All Rights Reserved Printed in USA Publication No. 4312 October 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
CMT1-7-R 价格&库存
很抱歉,暂时无法提供与“CMT1-7-R”相匹配的价格&库存,您可以联系我们找货
CMT1-7-R
    • 1+175.99680
    • 180+70.23240
    • 480+67.87800
    • 1020+66.72240
    CMT1-7-R
    • 60+77.6893160+10.05607
