28B0268-000
28B0268-000
    LAIRD(莱尔德)
    FILTER_D6.78X14.22MM
    Solid Free Hanging Ferrite Core 138 Ohm @ 100MHz ID 0.157" Dia (3.99mm) OD 0.267" Dia (6.78mm) Lengt...
28B0268-000 数据手册
Laird Technologies Web site: www.LairdTech.com Item # 28B0268-000, Broadband Solid Ferrite Cores for Round Cables and Wiring Harnesses Broadband Solid Ferrite Cores for Round Cables and Wiring Harnesses     Laird Technologies' Cylindrical EMI suppression ferrites provide a cost effective means of reducing common and differential mode EMI. These cores are most frequently used to suppress common mode EMI on the internal and external cable assemblies of electronic equipment. By decreasing the levels of EMI radiated by internal cables, ferrite cores can reduce the cost and amount of overall shielding required to confine EMI within a product's enclosure. They may also be successfully used on power cables that carry digital or analog signaling. To achieve maximum EMI filtering performance in a given application, select a ferrite with an inner diameter most closely matching the outer diameter of the wire or wire bundle to be filtered. The in-circuit impedance may be substantially increased by passing 2 turns of the wire conductor through the ferrite core. A typical common mode application might have two conductors passed through a ferrite core. With equal and opposite currents flowing through the core, zero net bias is established through the component, and maximum impedance is thus realized from the ferrite. SPECIFICATIONS Figure Number  1 Typical Z Ohms at 25 MHz  65 Nominal Z Ohms at 100 MHz  138 Typical Z Ohms at 300 MHz  260 Dimension A  6.78 mm 0.267 in Dimension B  3.99 mm 0.157 in Dimension C  14.22 mm 0.560 in Material Type  Broad Band Material Product Type Code  Round Cylindrical Cores 7/25/2011 | Page 1 of 2 Part Size Code Additional Description  0268  Standard Part 7/25/2011 | Page 2 of 2
28B0268-000 价格&库存
很抱歉,暂时无法提供与“28B0268-000”相匹配的价格&库存,您可以联系我们找货
