PSM4-471P-02T0
PSM4-471P-02T0
    APITECHNOLOGIES
    PSM3
    CAPFEEDTHRU470PF200V3PSM
PSM4-471P-02T0 数据手册
DATA SHEET Surface Mount Low Pass Filters PSM Series PSM Feedthrough Pi Voltage Rating DC 200 VDC @ -55°C to +125°C DWV 700 VDC Current Rating 20 Amps (Feedthrough) max. 10 Amps (Pi) max. Insulation Resistance 1.0 GΩ @ 25°C Dissipation Factor 4.0% maximum D.C.R Max. .0005Ω, typ. .0002Ω * Capacitance values for insertion loss curves are displayed left to right in the order shown. DATA SHEET Surface Mount Low Pass Filters PSM Series PSM Ordering Information Example: PSM4-402Z-20T0 PSM 4 Style Circuit Configuration - PSM (Power) 1 ‑ Pi 4 - Feedthrough † Also available through Spectrum Control's authorized distributors. 402Z - Capacitance Code Value* Tolerance 680M 68 pF 101M 100 pF ±20% 131P 130 pF +100/-0% 471P 470 pF +100/-0% 821M 820 pF ±20% 102M 1000 pF ±20% 152M 1500 pF ±20% 252P 2500 pF +100/-0% 402Z 4000 pF +80/20% .01 µF +80/-20% 103Z** ±20% Technical Notes 20 T 0 Current Rating Packaging Tape and Reel T ‑ Tape and reel 10 ‑10 Amps (Pi) packaging 20 ‑ 20 Amps B ‑ Bulk packaging (Feedthrough) 0 ‑ 500 pieces 2 ‑ 2,000 pieces Note: Tape and reel packaging ‑ 500 pieces (7”) and 2,000 pieces (13”) PSM Tape and Reel Packaging .150 (3 .81) .013 (0 .33) .059 (1 .50) .157 (4 .00) .079 (2 .00) .295 (7 .50) .069 (1 .75) • Soldering recommendations supplied upon request • Reflow temperature limit is 250°C • Unit weight is approximately 0.4 grams • Tape and reel packaging available for automated assembly .320 (8 .13) .630 (16 .0) .315 (8 .00) .133 (3 .38) .059 (1 .50) Dimensions in inches (mm) PSM Recommended Board Pattern Solder paste pattern Recommended pad, must be able to support continuous signal current X = 0.350” minimum for 1 oz. copper (0.036 mm thickness) X = 0.200” minimum for 2 oz. copper (0.071 mm thickness) For low current (10 Amp or less) X = 0.130” minimum for 1 oz. copper (0.036 mm thickness for 10 Amp and 0.5 oz. copper - 0.018 mm Dimensions in inches (mm) DATA SHEET Multiline Surface Mount Array Integrated surface mount package with exceptional EMI protection of signal and power lines. Features Provide EMI filtered signal lines between system modules Reduce or eliminate the need to assemble filters at bulkhead Economical method to meet EMC requirements Improve reliability, every filter is 100% tested for key parameters Superior performance to chip level solutions Easy connection and installation Peak temperature +260°C for IR and FC reflow systems        Applications Telecommunication equipment Military and defense applications Industrial control panels Measuring and testing instruments Medical equipment      *Dimensions in inches Side View Filter Circuits Pi Top View Bottom View Suggested Capacitance Minimum Insertion Loss - Decibels (dB) 3dB Max. Working 50 ohm System per MIL-STD-220 (no load) Cut-Off Voltage DC Frequency -55°C to 500 1 5 10 30 50 100 300 500 1 Value Tolerance (MHz) +125°C KHz MHz MHz MHz MHz MHz MHz MHz MHz GHz Notes 100pF ± 20% 32 200V - - - - - - 3 12 18 25  Current Rating: 10 amps per line 470pF ± 20% 10.8 200V - - - - 4 8 15 30 30 25  Terminations: silver plated 1000pF ± 20% 5.4 200V - - - 2 10 17 28 30 30 25 2500pF +100/-0% 1.3 200V - - 4 9 22 32 40 30 30 25  Other capacitance values available 4000pF +100/-0% 0.8 200V - - 7 12 30 40 46 30 30 25 8000pF +100/-0% 0.4 200V - - 11 19 42 50 47 30 30 25 25nF +100/-0% 0.26 200V 4 9 22 40 60 60 60 30 30 25 50nF +100/-0% 0.13 200V 9 14 35 53 60 60 60 30 30 25 0.1µF +100/-0% 0.03 200V 14 18 45 60 60 60 60 30 30 25 DATA SHEET Three Terminal Chips Surface Mount EMI Filters Features • Excellent performance in high current applications • Non-polar, surface mountable • Superior filtering characteristics • Superb ability to withstand transient voltages and surge • Offers exceptional solderability and resistance to solder heat • Available in 0603, 0805, 1205, and 1806 body size • Two amp current rating available • Available lead free/RoHS Compliant Applications Temperature Coefficient COG (NPO) 0 ±/30 ppm/°C, -55 to +125°C +/-15% X7R -55 to +125°C YV5 -25 to +85˚C X5R -55 to +85˚C Insulation Resistance up to 100,000 pF 10000 Megohms 47,000 pF 5000 Megohms DC Resistance 0.4 Amp or less 0.3 ohm max. 1 Amp 0.08 ohm max. 2 Amp 0.04 ohm max. Rated Voltage up to 100 VDC Rated Current up to 2 Amps • Cellular telephones and base stations • Telecommunication equipment • Industrial electronic interface or programmable controllers • Electronic automotive equipment • Computer and peripheral equipment Circuit Schematic Typical Electrical Characteristics Capacitance Range COG (NPO) 22 pF to 470 pF X7R 470 pF to 47,000 pF YV5 220,000 pF X5R 100,000 pF Capacitance Tolerance COG (NPO) +50/-20% X7R +50/-20% YV5 +80/-20% X5R +/-20% DATA SHEET Three Terminal Chips Surface Mount EMI Filters Selection Guide Part Number Rated Rated IR DC Body Capacitance Capacitance Temp. Voltage Current (Megohms Resistance Size (In Picofarad) Tolerance Charact. (Volts DC) (Amps DC) Min.) (ohm Max.) Operating Temp. 22 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C 0603 47 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C 0603 100 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF0603C221SNNB-* 0603 220 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF0603X471SBNS-* 0603 470 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF0603X102SBNB-* 0603 1,000 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF0603X222SBNB-* 0603 2,200 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF0603X223SANC-* 0603 SF0603C220SBNS-* 0603 SF0603C470SBNS-* SF0603C101SBNS-* SF0603R104MAND-* 0603 22,000 +50/-20% X7R 25 0.5 10,000 0.15 -55/+125°C 100,000 +/-20% X7R 25 1.0 10,000 0.08 -55/+85°C SF0805C220SBNC-* 0805 22 +50/-20% COG 50 0.4 10,000 0.3 -55/+125°C SF0805C470SBNC-* 0805 47 +50/-20% COG 50 0.4 10,000 0.3 -55/+125°C SF0805C101SBNC-* 0805 100 +50/-20% COG 50 0.4 10,000 0.3 -55/+125°C SF0808C221SBNS-* 0805 22 +50/-20% COG 50 0.4 10,000 0.3 -55/+125°C SF0805X471SBNC-* 0805 470 +50/-20% X7R 50 0.4 10,000 0.3 -55/+125°C SF0805X102SBNC-* 0805 1,000 +50/-20% X7R 50 0.4 10,000 0.3 -55/+125°C SF0805X222SBNC-* 0805 SF0805X223SBND-* 0805 2,200 +50/-20% X7R 50 0.4 10,000 0.3 -55/+125°C 22,000 +50/-20% X7R 50 1.0 10,000 0.08 -55/+125°C SF1205C220SBNS-* 1205 22 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205C470SBNB-* 1205 47 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205C101SBNB-* 1205 100 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205C221SBNB-* 1205 220 +50/-20% COG 50 0.3 10,000 0.3 -55/+125°C SF1205X471SBNB-* 1205 470 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X102SBNB-* 1205 1,000 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X222SBNB-* 1205 2,200 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X223SBNB-* 1205 22,000 +50/-20% X7R 50 0.3 10,000 0.3 -55/+125°C SF1205X473SBND-* 1205 47,000 +50/-20% X7R 50 1.0 5,000 0.08 -55/+125°C 22 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C220SDNB-* 1806 SF1806C470SDNB-* 1806 47 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C101SDNB-* 1806 100 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C221SDNB-* 1806 220 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806C471SDNB-* 1806 470 +50/-20% COG 100 0.3 10,000 0.3 -55/+125°C SF1806X102SDNB-* 1806 1,000 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C SFI1806X222SDNB-* 1806 2,200 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C SF1806X103SDNB-* 1806 10,000 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C SF1806X223SDNB-* 1806 22,000 +50/-20% X7R 100 0.3 10,000 0.3 -55/+125°C 1806 220,000 +80/-20% Y5V† 50 2.0 1,000 0.048 -25/+85°C 2 AMP FILTER SF1806Y224ZBNE-* Bold Part Number = High Current Applications † = Temperature Characteristic is +30/-80% -* = Denotes Packaging Style. Replace with T for Tape and Reel DATA SHEET Three Terminal Chips Surface Mount EMI Filters Insertion Loss (Per MIL-STD-220) DATA SHEET Three Terminal Chips Surface Mount EMI Filters Mechanical Dimensions Dimensions in inches (mm) Body Length (L) Body Width (W) Body Thickness (T) End Terminal Length (LE) Middle Terminal Length (LM) 0.063 +/- 0.006 (1.60 +/- 0.15) 0.079 +/- 0.008 (2.0 +/- 0.2) 0.031 +/- 0.006 (0.80 +/- 0.15) 0.049 +/- 0.008 (1.25 +/- 0.2) 0.023 +/- 0.006 (0.6 +/- 0.15) 0.032 +/- 0.008 (0.8 +/- 0.2) 0.008 +/- 0.006 (0.2 +/- 0.15) 0.012 +/- 0.008 (0.3 +/- 0.2) 0.020 +/- 0.006 (0.5 +/- 0.15) 0.024 +/- 0.008 (0.6 +/- 0.2) SF1205 0.126 +/- 0.008 (3.2 +/- 0.2) 0.049 +/- 0.008 (1.25 +/- 0.2) 0.028 +/- 0.008 (0.7 +/- 0.2) 0.016 +/- 0.012 (0.4 +/- 0.3) 0.043 +/- 0.012 (1.1 +/- 0.3) SF1806 0.177 +/- 0.012 (4.5 +/- 0.3) 0.063 +/- 0.012 (1.6 +/- 0.3) 0.039 +/- 0.012 (1.0 +/- 0.3) 0.020 +/- 0.012 (0.5 +/- 0.3) 0.055 +/- 0.012 (1.4 +/- 0.3) Body Style/Size SF0603 SF0805 Ordering Information Example: SF0805C221SBNCT This part number represents a three terminal chip with a body size of 0805 with a COG (NPO) dielectric. The capacitance is 220 pF with a capacitance tolerance of +50%/-20%. Voltage rating is 50 Volts DC. It has nickel barrier, solder plated terminations and a current rating of 0.4 Amp, (400 milliamps). The parts are taped and reeled. SF 0805 Size 0603 0805 1205 1806 Style SF C 221 S B N Rated Voltage Capacitance A - 25 Code B - 50 First two numbers D - 100 are significant the third number refers to number Termination Capacitance Ceramic of zeros N - Ni Barrier, Tolerance C - COG Solder S - +50%/-20% X - X7R Plated Z - +80%/-20% Y - Y5V M - +/- 20% R - X5R C Current Rating B - 0.3 A C - 0.4 A D - 1A E - 2A F - 3A G - 4A H - 5A I - 6A T Packaging T - Tape & Reel DATA SHEET Three Terminal Chips Surface Mount EMI Filters Soldering Instructions Reflow Soldering Body Style/Size SF0603 SF0805 SF1205 SF1806 Board Pattern Dimensions in inches (mm) Dimension A B C 0.020 0.047 0.031 (0.5) (1.2) (0.8) 0.024 0.059 0.039 (0.6 ) (1.59) (1.0) 0.051 0.091 0.047 (1.3) (2.3) (1.2) 0.079 0.138 0.051 (2.0) (3.5) (1.3) Flow Soldering Body Style/Size SF0603 SF0805 SF1205 SF1806 Board Pattern Dimensions in inches (mm) Dimension A C D E F B 0.020 0.031 0.047 0.031 0.071 0.016 (1.2) (0.8) (1.8) (0.4) (0.8) (0.5) 0.024 0.031 0.059 0.039 0.087 0.024 (1.5) (1.0) (2.2) (0.6 ) (0.8) (0.6 ) 0.051 0.059 0.091 0.047 0.118 0.024 (2.3) (1.2) (3.0) (0.6) (1.5) (1.3) 0.059 0.079 0.138 0.051 0.118 0.024 (3.5) (1.3) (3.0) (0.6) (1.5) (1.5) Reflow Soldering Flow Soldering General Soldering Notes • Use mild flux (less than 0.2% by weight of Chlorine), preferable rosin based. If water soluble, wash thoroughly to assure all residue is removed from the underside of components. • High soldering temperatures and long soldering times can cause leaching of the termination and adversely affect adhesion. These conditions can also decrease capacitance value. Use the above recommended solder temperature cycle. • Due to the mechanical characteristic of ceramic composition, aggressive thermal shock will degrade performance. Preheat the assembly before soldering using the above solder temperature profile as a guide. • Ultrasonic Cleaning When using an ultrasonic cleaning method, the following range is recommended: Frequency: Not to exceed 28kHz Output Power: Not to exceed 20W/liter Cleaning Time: 5 minutes max DATA SHEET Three Terminal Chips Surface Mount EMI Filters Package Quantities Body Style/Size Tape and Reel SF0603 SF0805 SF1205 SF1806 4,000 units/reel 4,000 units/reel 4,000 units/reel 2,000 units/reel Chip Cavity Body Style/ Size Length Width A B 0.039 0.075 SF0603 +/-0.00? +/-0.00? (1.0 +/-0.?) (1.9 +/-0.?) 0.064 0.091 SF0805 +/-0.008 +/-0.008 (1.62 +/-0.2) (2.3 +/-0.2) 0.067 0.138 SF1205 +/-0.008 +/-0.008 (1.70 +/-0.2) (3.5 +/-0.2) Tape Center Indexing Width to End to End w F E 0.0315 0.138 0.069 +/-0.012 +/-0.002 +/-0.004 (8.0 +/-0.3) (3.5 +/-0.05) (1.75 +/-0.1) 0.0315 0.138 0.069 +/-0.012 +/-0.002 +/-0.004 (8.0 +/-0.3) (3.5 +/-0.05) (1.75 +/-0.1) 0.0315 0.138 0.069 +/-0.012 +/-0.002 +/-0.004 (8.0 +/-0.3) (3.5 +/-0.05) (1.75 +/-0.1) Dimensions in inches (mm) Center to Center C 0.157 +/-0.004 (4.0 +/-0.1) 0.157 +/-0.004 (4.0 +/-0.1) 0.157 +/-0.004 (4.0 +/-0.1) Holes Indexing to Center C 0.079 +/-0.004 (2.0 +/-0.1) 0.079 +/-0.004 (2.0 +/-0.1) 0.079 +/-0.004 (2.0 +/-0.1) Hole Diameter Indexing to Indexing C 0.157 +/-0.008 (4.0 +/-0.1) 0.157 +/-0.008 (4.0 +/-0.1) 0.157 +/-0.008 (4.0 +/-0.1) Indexing D1 0.059 +0.004/0 (1.5 +0.1/-0) 0.059 +0.004/0 (1.5 +0.1/-0) 0.059 +0.004/0 (1.5 +0.1/-0) Thickness Carrier Overall Tape T (Max.) T1 (Max.) 0.039 0.048 (1.1) 0.048 (1.0) 0.039 (1.1) 0.048 (1.0) 0.039 (1.1) (1.0) Plastic Reel Dimensions Body Style/Size Diameter (Max.) Width (Max.) SF0603 SF0805 SF1205 SF1806 7.00 (180) 7.00 (180) 7.00 (180) 7.00 (180) 0.46 (11.5) 0.46 (11.5) 0.46 (11.5) 0.46 (11.5) Chip Cavity Dimensions in inches (mm) Tape Holes Thickness Hole Diameter Center Indexing Center Indexing Indexing Carrier Length Width Width to End to End to Center to Center to Indexing Center Indexing Overall Tape A B w D (Min.) F E C C C D1 T (Max.) T1 (Max.) 0.059 0.039 0.071 0.185 0.472 0.217 0.069 0.157 0.079 0.157 0.059 0.048 +/-0.008 +/-0.002 +/-0.004 +/-0.004 +/-0.004 +/-0.008 +0.004/0 SF1806 +/-0.008 +/-0.008 (1.5) (1.5 +0.1/-0) (1.1) (1.0) (1.80+/-.02) (4.70 +/-0.2) (12.0+/-0.2) (5.5 +/-0.05) (1.75 +/-0.1) (4.0 +/-0.1) (2.0 +/-0.1) (4.0 +/-0.1) Body Style/ Size DATA SHEET SA Series Surface Mount Filter Arrays Features • The filters structure minimizes residual inductance with a high self resonant frequency, ensuring large insertion loss in a wide band. • The common ground electrode built into the chip ensures complete grounding of all lines at the ground on both ends. The filter is designed to control cross talk. • An optimum constant can be selected from the capacity range of 22-22,000 pF to best suit the frequency. Circuit Schematic • Solder plated nickel barrier terminations offer good solderability and resistance to soldering heat. • Available lead free/RoHS compliant Applications • Computer peripheral equipment • Telecommunications equipment • Power amplifiers • Power supplies • Temperature and motor controls Typical Electrical Characteristics Rated Voltage 25 VDC to 50 VDC Rated Current 0.3 Amps IR 10,000 MΩ Min. DC Resistance 0.3Ω Max. Temperature Range -55°C to +125°C Capacitance Range 22 pF to 22,000 pF Capacitance Tolerance ±20% Specifications Part Number SA1206C220 SA1206C470 SA1206C101 SA1206C221 SA1206R471 SA1206R102 SA1206R222 SA1206R223 Rated Voltage (@ 50/60Hz) 50 VDC 25 VDC Rated Current 0.3A DC Temperature Characteristic C C C C U R R R IR 10,000MΩ min. DC Resistance 0.3Ω max. Operating Temp. -55/+125°C Capacitance (pF) 22 47 100 220 470 1,000 2,200 22,000 DATA SHEET SA Series Surface Mount Filter Arrays Ordering Information SA 1206 C 220 Temperature Characteristics C +/- 30 ppm/°C R +/- 15% U -750 +/- 120 ppm/°C Style SA Series Size 1206 Capacitance 22pF 47pF 100pF 220pF 470pF 1,000pF 2,000pF 22,000pF M Capacitance Tolerance M = +/- 20% B N B Termination N = Ni Barrier Solder Plated Rated Voltage (VDC) A = 25 B = 30 Packaging T - Tape and reel 4,000 pc/reel B - Bulk pack 1,000 pcs/bag
PSM4-471P-02T0
1. 物料型号:文档列出了多种型号的EMI滤波器,包括但不限于: - 三端子芯片(Three Terminal Chips) - SA系列阵列(SA Series Arrays) - MSM迷你表面安装(MSM Mini-Surface Mount) - PSM功率表面安装(PSM Power Surface Mount) - MSP迷你表面安装电源滤波器(MSP Mini Surface Mount Power Filters) - MPC系列微型PCB电源滤波器(MPC Series Miniature PCB Power Filters)
2. 器件简介:这些滤波器设计用于提供高性能的EMI过滤选项,同时最小化PCB占用空间。它们适用于多种PCB应用,包括汽车电子、数字音视频设备、计算机、外设、通信、开关电源和高电流总线。
3. 引脚分配:文档提供了详细的引脚分配图和机械尺寸,包括端子长度和宽度。
4. 参数特性:包括电容范围、电容公差、温度系数、绝缘电阻、直流电阻和额定电压等。
5. 功能详解:每种型号的滤波器都有其特定的应用和性能特点,例如三端子芯片在高电流应用中提供卓越的性能,SA系列阵列设计用于最小化残余电感,PSM系列滤波器设计用于有效过滤高达20安培电流的EMI/RFI。
6. 应用信息:滤波器适用于多种应用,如移动电话和基站、电信设备、工业电子接口或可编程控制器、汽车电子设备、计算机和外设设备等。
7. 封装信息:提供了不同尺寸的封装信息,如0603、0805、1205和1806,以及它们的引脚分配和机械尺寸。
8. 订购信息:给出了订购时使用的部件编号示例和说明,包括尺寸、电容值、电容公差、电压等级、电流等级和封装方式。
9. 焊接说明:提供了焊接时的一般注意事项、推荐的焊接温度曲线、推荐的板图案尺寸以及超声波清洗的推荐参数。
10. 电气特性:包括典型电气特性图表,展示了不同型号滤波器在不同频率下的插入损耗。
PSM4-471P-02T0 价格&库存
很抱歉,暂时无法提供与“PSM4-471P-02T0”相匹配的价格&库存,您可以联系我们找货
