17100-100
17100-100
    AVENTOOLS(艾文)
    SOLDERPOT100W
17100-100 数据手册
Lead Free Solder Pot 100W The Aven Lead Free Solder Pot is ideal for tinning the ends of stranded wire leads, pre-tinning small electrical parts, re-tinning soldering iron tips and dip soldering small circuit boards. The variable temperature heating element liquifies solder quickly and provides excellent thermal stability. The crucible, with a holding capacity of 250g, is made from stainless steel with titanium plating, featuring corrosion resistance and prolonged service life. The Aven Lead Free Solder Pot is suitable for melting solder, plastic, resin and more. Features • Heating element liquifies solder quickly and provides excellent thermal stability • Crucible is made from stainless steel with titanium plating, featuring corrosion resistance and prolonged service life • Suitable for melting solder, plastic, resin and more • Ideal for tinning ends of stranded wire leads, pre-tinning small electrical parts and dip soldering small circuit boards • Pot solder capacity:250g sales@aveninc.com LEAD FREE SOLDER POT 100W RATING POWER 100W TEMPERATURE RANGE MELTING TIME 8 minutes MAX SOLDER WEIGHT SOLDER POT SIZE WEIGHT 200-400°C (392-752°F) 250g (0.55 lbs.) 36mm (1.42”) diameter 0.91kg (2 lbs.) Part # Description 17100-100 Lead Free Solder Pot 100W aveninc.com 734.973.0099
17100-100 价格&库存
很抱歉,暂时无法提供与“17100-100”相匹配的价格&库存,您可以联系我们找货
