SURFACE MOUNT CERMET TRIMMERS
INTERNAL STRUCTURE
Part name
■ FEATURES
RoHS compliant
Fine adjustment is possible
Automatic mounting is possible (Taping)
Reflow soldering is possible
Sealed construction (Washable: Refer to page 698.)
Resin material is UL Recognized 94V-0
Material
①
Housing
②
Base element
③
Electrode
Ag-Pd cermet
④
Resistive element
RuO2 cermet
⑤
Adhesive
⑥
Wiper
⑦
Terminal pin
⑧
Rotor gear
⑨
Shaft
Polyphenylenesulphide
Ceramic
Copper alloy, Sn-Cu-plated
Polyamide
Brass, Nickel-plated
■ PART NUMBER DESIGNATION
S M - 3 □ T W 1 kΩ ( 1 0 2 )
Series name
Resistance code
Electrical turn
Resistance value
Blank:11 turns
1:5 turns
Form of packaging
T:Taping (Reel)
Blank:Bulk in plastic bag
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Product shape (Shape of terminal)
A:J-hook (Side adjustment)
B:Gull wing(Side adjustment)
W:J-hook (Top adjustment)
SM-3/31
SURFACE MOUNT TRIMMERS
■ LIST OF PART NUMBERS
Adjustment
position
Electrical turns
〈Nominal resistance values〉
Top adjustment
11
Side adjustment
Top adjustment
5
Side adjustment
Taping (reel)
Plastic bag
W
(J-hook)
SM-3TW
SM-3W
A
(J-hook)
SM-3TA
SM-3A
B
(Gull wing) SM-3TB
SM-3B
W
(J-hook)
SM-31TW
SM-31W
A
(J-hook)
SM-31TA
SM-31A
B
(Gull wing) SM-31TB
SM-31B
500 pcs./reel
Pieces in package
100 Ω
2 kΩ
5 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
200 Ω
500 Ω
1 kΩ
2 MΩ
10 kΩ
■ MECHANICAL CHARACTERISTICS
50 Ω ~ 2 MΩ
Operating torque
5 mN·m {51 gf·cm} maximum
± 20 %
Mechanical stop
Clutch action
Resistance tolerance
Fig. 1
※ The above part numbers are all available with the respective combination
of (Fig. 1).
※ Verify the above part numbers when placing orders.
※ Taping specification is not sold separately and must be purchased in reel units.
50 pcs./pack
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
50 Ω
20 kΩ
Form of packaging
Shape of terminal
Power ratings
0.125 W (70 °C) 0 W (150 °C)
Rotational life
200 cycles [ Δ R/R ≦ ± (2 Ω +3 %)]
Resistance law
Linear law
Thrust to shaft
5 N {0.51 kgf} minimum
Maximum input voltage
DC200 V or power rating, whichever is smaller
Solderability
245 ± 3 °C, 2 ~ 3 s
Maximum wiper current
100 mA or power rating, whichever is smaller
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Effective electrical turn
11 turns (SM-3) / 5 turns (SM-31)
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
End resistance
1 % or 3 Ω, whichever is greater
C.R.V.
3 % or 3 Ω, whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
± 100 10-6/°C maximum
100 MΩ minimum (DC500 V)
AC600 V, 60 s
Net weight
Approx. 0.10 g
Temperature
〈Reflow profile for soldering heat evaluation〉
250
Peak : 250 0 ℃
200
Pre Heating Zone
100
50
+5
Over 230 ℃
180 ℃
150 ℃
5 N {0.51 kgf} 10 s
{ }:Reference only
− 65 ~ 150 °C
Dielectric strength
150
Pull-off strength
90±30 s
30±10 s
Heating time
Soldering Zone
Reflow : two times maximum
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Specifications
Thermal shock
− 65 ~ 150 °C (0.5 h), 5
cycles
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
Humidity
Shock
− 10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.125 W, 1000 h
Low temp. operation
− 65 °C, 2 h
High temp. exposure
150 °C, 250 h
Immersion seal
85 °C, 60 s
Reflow : Peak temperature 255 °C
Soldering heat (Please refer to the profile below.)
Manual soldering:350 ± 10 °C, 3 ~ 4 s
[ Δ R/R ≦ 3 %]
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
[ Δ R/R ≦ 1 %]
Δ R/R:Change in total resistance
S.S. :Setting stability
SM-3/31
■ MAXIMUM INPUT RATINGS
(Ω)
Resistance code
(V)
(mA)
50
100
200
500
500
101
201
501
2.50
3.53
5.00
7.91
50.0
35.4
25.0
15.8
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
11.2
15.8
25.0
35.4
50.0
79.1
11.2
7.91
5.00
3.54
2.50
1.58
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
112
158
200
200
200
1.12
0.79
0.40
0.20
0.10
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
● SM-3W/31W
● SM-3A/31A
● SM-3B/31B
(Unit : mm)
1.3
1.3
1.3
4
1.6
1.6
1.3
2.43
3.12
1.6
1.6
2
1.3
2.8
0.9
2.8
2
0.9
0.9
2.8
※ Also available to place as the above.
0.9
2.8
Note) The zero point is the center of mounting.
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● SM-3W/31W
Top adjustment
①
③
CW rotation
②
Resistance code & Production date code
①
0.8
③
1
2.3
3.2
3.5
3.9
0.6
2.8
②
3.9
4.2
0.4W × 1.3L × 0.3D
0.8
Note the terminal position.
SM-3/31
● SM-3A/31A
Side adjustment
● SM-3B/31B
Side adjustment
①
③
CW rotation
Resistance code &
②
Resistance code &
2.5
2.5
0.4W × 1.3L × 0.3D
0.4W × 1.3L × 0.3D
3.9
③
3.9
1
2.8
5.3
3 – 0.8
2 – 0.6
①
3.4
②
3.9
3.4
3 – 0.8
②
3.9
4.4
1
③
2 – 0.6
2.8
①
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
● Taping version is boxed with one reel.
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the dia-grams below.
● EMBOSSED TAPE DIMENSIONS
● REEL DIMENSIONS
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
Empty
Filled
(Unit: mm)
Empty
13
Head
21±0.8
2±0.5
20 pitches min.
60
40 mm min.
Leader
Direction of feed
+1
End
+1
400 mm min.
13±0.2
180 –1.5
15.4±1
SM-3/31
● SM-3TW/31TW
4±0.1
Φ
③
A
.1
+0 0
5
1.
1.75±0.1
2±0.05
0.4±0.1
A
②
8±0.1
+0.3
12 –0.1
5.5±0.05
Installation example
(SM-3W)
①
Cross section A-A
4.7
(SM-3A)
5.5±0.05
①
0.4±0.1
+0.3
③
12 –0.1
.1
+0 0
5
1.
Φ
4±0.1
2±0.05
A
1.75±0.1
● SM-3TA/31TA
A
②
3.9
8±0.1
Cross section A-A
.1
+0 0
5
1.
Φ
4±0.1
2±0.05
A
③
1.75±0.1
● SM-3TB/31TB
0.4±0.1
(SM-3B)
A
②
8±0.1
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
+0.3
12 –0.1
5.5±0.05
①
3.9
Cross section A-A
很抱歉,暂时无法提供与“SM31TW204”相匹配的价格&库存,您可以联系我们找货
