RJ6W104
RJ6W104
    COPAL(日电产 科宝电子)
    精密微调电阻 100KΩ ±10% 1/2W ±100ppm/℃
RJ6W104 数据手册
SINGLE TURN CERMET TRIMMERS RJ-6 RJ-6 構造図 RoHS compliant INTERNAL STRUCTURE ① ② ⑩ ③ ④ ⑤ ⑨ ⑥ ⑦ Part name ⑧ Material ■ FEATURES ① Rotor Polybutyleneterephthalate ● ● ● ● ● ② Cover Stainless steel ③ “O” ring Silicone rubber ④ Electrode Ag-Pd cermet ⑤ Resistive element RuO2 cermet ⑥ Base element Ceramic ⑦ Terminal pin Nickel, Gold-plated ⑧ Adhesive ⑨ Wiper Multi metal alloy ⑩ Rubber cushion Silicone rubber RoHS compliant Wide resistance range from 10 Ω to 5 MΩ Low contact resistance variation (1 % maximum) Precious metal alloy wiper Resin material is UL Recognized 94V-0 Epoxy ■ PART NUMBER DESIGNATION R J - 6 P 1 0 k Ω( 1 0 3 )  Resistance code Series name  Resistance value Product shape P:Top adjustment W:Top adjustment F:Rear adjustment S:Side adjustment X:Side adjustment ※ Please refer to the LIST OF PART NUMBERS when placing orders. 表 RJ-6 CERMET TRIMMERS ■ LIST OF PART NUMBERS Adjustment Shape of terminal (Top view) position ② Top adjustment ① ③ ② ① ③ 〈Nominal resistance values〉 Form of packaging Pieces in package Plastic bag ① ③ ③ ① Rear adjustment 2 kΩ 5 kΩ 10 kΩ 100 kΩ 200 kΩ → 250 kΩ 500 kΩ 1 MΩ 2 MΩ → 5 MΩ ※ The above part numbers are all available with the respective combination of (Fig. 1). ※ Verify the above part numbers when placing orders. RJ-6W RJ-6S 50 pcs./pack The products indicated by of order basis. → mark are manufactured upon receipt RJ-6X ② ③ 20 kΩ → 25 kΩ 50 kΩ 1 k Ω Fig. 1 RJ-6P ② Side adjustment (↑Adjustment direction) → 10 Ω → 20 Ω 50 Ω 100 Ω 200 Ω 500 Ω ① ② → RJ-6F ■ MECHANICAL CHARACTERISTICS ■ ELECTRICAL CHARACTERISTICS Nominal resistance range Resistance tolerance 10 Ω ~ 5 MΩ Mechanical angle 270 ° (1 turn) Operating torque 2~15 mN·m {20 ~ 153 gf·cm} Stop strength 50 mN·m {510 gf·cm} minimum ± 10 % Rotational life Power ratings 0.5 W (70 °C) 0 W (120 °C) Resistance law Linear law Terminal to strength Maximum input voltage DC200 V or power rating, whichever is smaller 200 cycles 10 Ω ~ 200 Ω [ΔR/R ≦ ± (0.5 Ω +3 %)] 500 Ω ~ 5 MΩ [ΔR/R ≦ ± (0.5 Ω +2 %)] 10 N {1.02 kgf} minimum (Tensile strength) Thrust rotor 10 N {1.02 kgf} minimum Solderability 245 ± 3 °C, 2 ~ 3 s { }:Reference only Maximum wiper current 100 mA or power rating, whichever is smaller Effective electrical angle 230 ° (1 turn) End resistance 1 % or 2 Ω , whichever is greater C.R.V. 1 % or 3 Ω , whichever is greater Operating temp. range Temp. coefficient Insulation resistance Dielectric strength Net weight −55 ~ 120 °C 10 Ω , 20 Ω , 5 MΩ : ± 250 10 /°C maximum 50 Ω ~ 2 MΩ : ± 100 10-6/°C maximum -6 ■ ENVIRONMENTAL CHARACTERISTICS Test item Thermal shock Humidity Shock Test conditions Specifications −65 ~ 125 °C (0.5 h), 5 cycles −10 ~ 65 °C (80 ~ 98 %), 10 cycles, 240 h 981 m/s2, 6 ms 6 directions for 3 times each [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] 1000 MΩ minimum (DC500 V) Vibration (Amplitude) 1.52 mm or (Acceleration) 196 m/s2, 10 ~ 2000 Hz, 3 directions, 12 times each AC900 V, 60 s Load life 70 °C, 0.5 W, 1000 h Approx. 0.60 g (RJ-6P, W) Approx. 0.80 g (RJ-6S, X) Approx. 1.01 g (RJ-6F) Low temp. operation − 55 °C, 2 h High temp. exposure 120 °C, 250 h Immersion seal 85 °C, 60 s Flow Soldering heat [ΔR/R ≦ 1 %] [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] [ΔR/R ≦ 2 %] [S.S. ≦ 1 %] [ΔR/R ≦ 1 %] [S.S. ≦ 2 %] [ΔR/R ≦ 2 %] [S.S. ≦ 2 %] No leaks (No continuous bubbles) 260 ± 3 °C, 5 ~ 6 s, two times maximum [ΔR/R ≦ 1 %] Manual soldering 380 ± 10 °C, 3 ~ 4 s ΔR/R:Change in total resistance S.S. :Setting stability RJ-6 CERMET TRIMMERS ■ MAXIMUM INPUT RATINGS Nominal resistance values ( Ω ) Resistance code → 10 → 20 50 100 200 500 Maximum input voltage (V) Maximum wiper current (mA) 100 1.00 100 200 2.00 100 500 5.00 100 101 7.07 70.7 201 10.0 50.0 501 15.8 31.6 1 k 102 22.4 22.4 2 k 202 31.6 15.8 5 k 502 50.0 10.0 10 k 103 70.7 7.07 20 k 203 100 5.00 → 25 k 253 112 4.48 50 k 503 158 3.16 → → 100 k 200 k 250 k 500 k 1 M 2 M 5 M 104 204 254 504 105 205 505 RJ-6P 外形図 200 200 200 200 200 200 200 ■ OUTLINE DIMENSIONS 2.00 1.00 0.80 0.40 0.20 0.10 0.04 The products indicated by → mark are manufactured upon receipt of order basis. Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● RJ-6P Top adjustment ① 0.5 W × 2.6 L × 0.8 D Resistance code & Production date code 3 –φ0.4±0.05 2 ② Φ 7 +0.3 0 2.5 270˚ Nom. 5.3 5.8 Resistance code & Production date code 0.5 W × 2.6 L × 0.8 D 270˚ Nom. 72 2.5 2.5 3 1 2 3 –φ0.4±0.05 ) 1.3±0.2 ● RJ-6W Top adjustment 5 2. J-6S 外形図 5.3 5.8 ● RJ-6S Side adjustment 0.5±0.2 Φ 7 +0.3 0 ( 7±2 3.5 3 1 Resistance code & Production date code Adjustment 1 2 3 6±2 0.5 2.5 2.5 7 +0.4 0 3 –φ0.4±0.05 1.1±0.2 2.5 8.7+0.3 0 5.2 0.6 0.5 W × 2.6 L × 0.8 D 270˚ Nom. 6.6+0.4 –0.1 RJ-6W 外形図 ③ CW rotation ★Pin pitch in W type is different from P type. X 外形図 RJ-6 CERMET TRIMMERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● RJ-6X Side adjustment ① Resistance code & Production date code -6F 外形図 7 +0.4 0 8.5±2 0.5 2.5 2.5 ★ Pin position & stopper position of X type are different from S type. 3 –φ0.4±0.05 3 2 1 ● RJ-6F Rear adjustment < Semi-standard products > 4.4 2 5.5±2 7.6 0.6 4.4 Φ 10.5 max. 4.4 1 3 270˚ Nom. 3 –Φ 0.4±0.05 Resistance code & Production date code 0.5 W × 2.6 L × 0.8 D ■PACKAGING SPECIFICATIONS ② 1.1±0.2 2.5 8.7+0.3 0 5.2 0.6 Adjustment 6.6 +0.4 –0.1 270˚ Nom. 0.5 W × 2.6 L × 0.8 D ③ CW rotation ● Unit of bulk pack in a plastic bag is 50 pcs. per pack. ● Boxing of bulk in a plastic bag is performed with 200 pcs. (RJ-6F is 100 pcs.) per box.
RJ6W104
- 物料型号:RJ-6P、RJ-6W、RJ-6S、RJ-6X、RJ-6F,分别代表不同的调整位置和封装形式。 - 器件简介:该电位器符合RoHS标准,具有宽广的电阻范围(10Ω至5MΩ)和低接触电阻变化(最大1%)。 - 引脚分配:文档中未明确列出引脚分配,但提供了外形尺寸和端子强度信息。 - 参数特性:包括标称电阻范围、电阻公差、功率等级、电阻规律、最大输入电压和电流、有效电气角度、末端电阻、C.R.V.、工作温度范围、温度系数、绝缘电阻和耐压。 - 功能详解:电位器具有RoHS合规性、宽广的电阻范围、低接触电阻变化、贵金属合金触点、UL认证的树脂材料等特性。 - 应用信息:文档中未明确列出应用信息,但根据电位器的特性,它们通常用于精密调整和校准电路。 - 封装信息:提供了不同型号的外形尺寸和公差,以及包装规格,如每袋50个,每箱200个(RJ-6F为100个)。
RJ6W104 价格&库存
很抱歉,暂时无法提供与“RJ6W104”相匹配的价格&库存,您可以联系我们找货
