SINGLE TURN CERMET TRIMMERS
RJ-6
RJ-6 構造図
RoHS compliant
INTERNAL STRUCTURE
①
②
⑩
③
④
⑤
⑨
⑥ ⑦
Part name
⑧
Material
■ FEATURES
①
Rotor
Polybutyleneterephthalate
②
Cover
Stainless steel
③
“O” ring
Silicone rubber
④
Electrode
Ag-Pd cermet
⑤
Resistive element
RuO2 cermet
⑥
Base element
Ceramic
⑦
Terminal pin
Nickel, Gold-plated
⑧
Adhesive
⑨
Wiper
Multi metal alloy
⑩
Rubber cushion
Silicone rubber
RoHS compliant
Wide resistance range from 10 Ω to 5 MΩ
Low contact resistance variation (1 % maximum)
Precious metal alloy wiper
Resin material is UL Recognized 94V-0
Epoxy
■ PART NUMBER DESIGNATION
R J - 6 P 1 0 k Ω( 1 0 3 )
Resistance code
Series name
Resistance value
Product shape
P:Top adjustment
W:Top adjustment
F:Rear adjustment
S:Side adjustment
X:Side adjustment
※ Please refer to the LIST OF PART NUMBERS when placing orders.
表
RJ-6
CERMET TRIMMERS
■ LIST OF PART NUMBERS
Adjustment Shape of terminal
(Top view)
position
②
Top adjustment
①
③
②
①
③
〈Nominal resistance values〉
Form of packaging
Pieces in
package
Plastic bag
①
③
③
①
Rear
adjustment
2 kΩ
5 kΩ
10 kΩ
100 kΩ 200 kΩ → 250 kΩ 500 kΩ
1 MΩ
2 MΩ
→ 5 MΩ
※ The above part numbers are all available with the respective
combination of (Fig. 1).
※ Verify the above part numbers when placing orders.
RJ-6W
RJ-6S
50 pcs./pack
The products indicated by
of order basis.
mark are manufactured upon receipt
RJ-6X
②
③
20 kΩ → 25 kΩ 50 kΩ
1 k Ω
Fig. 1
RJ-6P
②
Side
adjustment
(↑Adjustment
direction)
→ 10 Ω → 20 Ω 50 Ω 100 Ω 200 Ω 500 Ω
①
②
→ RJ-6F
■ MECHANICAL CHARACTERISTICS
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
Resistance tolerance
10 Ω ~ 5 MΩ
Mechanical angle
270 ° (1 turn)
Operating torque
2~15 mN·m {20 ~ 153 gf·cm}
Stop strength
50 mN·m {510 gf·cm} minimum
± 10 %
Rotational life
Power ratings
0.5 W (70 °C) 0 W (120 °C)
Resistance law
Linear law
Terminal to strength
Maximum input voltage DC200 V or power rating, whichever is smaller
200 cycles
10 Ω ~ 200 Ω [ΔR/R ≦ ± (0.5 Ω +3 %)]
500 Ω ~ 5 MΩ [ΔR/R ≦ ± (0.5 Ω +2 %)]
10 N {1.02 kgf} minimum
(Tensile strength)
Thrust rotor
Solderability
245 ± 3 °C, 2 ~ 3 s
{ }:Reference only
Maximum wiper current 100 mA or power rating, whichever is smaller
Effective electrical angle
230 ° (1 turn)
End resistance
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
Dielectric strength
Net weight
−55 ~ 120 °C
10 Ω , 20 Ω , 5 MΩ : ± 250 10 /°C maximum
50 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
-6
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Thermal shock
Humidity
Shock
Test conditions
Specifications
−65 ~ 125 °C (0.5 h),
5 cycles
−10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
1000 MΩ minimum (DC500 V)
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
AC900 V, 60 s
Load life
70 °C, 0.5 W, 1000 h
Approx. 0.60 g (RJ-6P, W)
Approx. 0.80 g (RJ-6S, X)
Approx. 1.01 g (RJ-6F)
Low temp. operation
− 55 °C, 2 h
High temp. exposure
120 °C, 250 h
Immersion seal
85 °C, 60 s
Flow
Soldering heat
[ΔR/R ≦ 1 %]
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 1 %]
[S.S. ≦ 2 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
260 ± 3 °C, 5 ~ 6 s, two times maximum
[ΔR/R ≦ 1 %]
Manual soldering
380 ± 10 °C, 3 ~ 4 s
ΔR/R:Change in total resistance
S.S. :Setting stability
RJ-6
CERMET TRIMMERS
■ MAXIMUM INPUT RATINGS
Nominal resistance values ( Ω )
Resistance code
10
100
200
500
Maximum input voltage (V)
Maximum wiper current (mA)
100 1.00 100
200 2.00 100
500 5.00 100
101
7.07
70.7
201
10.0
50.0
501
15.8
31.6
1 k
102
22.4
22.4
2 k
202
31.6
15.8
5 k
502
50.0
10.0
10 k
103
70.7
7.07
20 k
203
100
5.00
25 k
253
112
4.48
50 k 503 158 3.16
100 k
200 k
250 k
500 k
1 M
2 M
5 M
104
204
254
504
105
205
505
RJ-6P 外形図
200
200
200
200
200
200
200
■ OUTLINE DIMENSIONS
2.00
1.00
0.80
0.40
0.20
0.10
0.04
The products indicated by → mark are
manufactured upon
receipt of order
basis.
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
● RJ-6P
Top adjustment
①
0.5 W × 2.6 L × 0.8 D
Resistance code &
Production date code
3 –φ0.4±0.05
2
②
Φ 7 +0.3
270˚ Nom.
5.3
5.8
Resistance code &
270˚ Nom.
72
2.5 2.5
3
1
2
3 –φ0.4±0.05
1.3±0.2
● RJ-6W
Top adjustment
5
2.
J-6S 外形図
5.3
5.8
● RJ-6S
Side adjustment
0.5±0.2
Φ 7 +0.3
7±2
3.5
3
1
Resistance code &
Adjustment
1
2
3
6±2
0.5
2.5 2.5
7 +0.4
3 –φ0.4±0.05
1.1±0.2
2.5
8.7+0.3
0.6
270˚ Nom.
6.6+0.4
–0.1
RJ-6W 外形図
③
CW rotation
★Pin pitch in W
type is
different from P type.
X 外形図
RJ-6
CERMET TRIMMERS
● RJ-6X
Side adjustment
①
Resistance code &
-6F 外形図
7 +0.4
8.5±2
0.5
2.5 2.5
★ Pin position & stopper position of X type are different from S type.
3 –φ0.4±0.05
3
2
1
● RJ-6F
Rear adjustment
< Semi-standard products >
4.4
2
5.5±2
7.6
0.6
4.4
Φ 10.5 max.
4.4
1
3
270˚ Nom.
3 –Φ 0.4±0.05
Resistance code &
■PACKAGING SPECIFICATIONS
②
1.1±0.2
2.5
8.7+0.3
0.6
Adjustment
6.6 +0.4
–0.1
270˚ Nom.
③
CW rotation
● Unit of bulk pack in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. (RJ-6F is 100 pcs.) per box.
很抱歉,暂时无法提供与“RJ6X100”相匹配的价格&库存,您可以联系我们找货
