Effective January 2020
Supersedes May 2016
Technical Data 4376
HV Supercapacitors
Cylindrical cells
HALOGEN
Pb HF
FREE
Features
Ultra low ESR for high power density
UL recognized
Applications
Description
Eaton supercapacitors are high reliability, high
power, ultra-high capacitance energy storage
devices utilizing electric double layer capacitor
(EDLC) construction combined with proprietary
materials and processes. This combination of
advanced technologies allows Eaton to offer a
wide variety of capacitor solutions tailored to
applications for backup power, pulse power and
hybrid power systems. They can
be applied as the sole energy storage or in
combination with batteries to optimize cost, life
time and run time. System requirements can
range from a few microwatts to megawatts. All
products feature low ESR for high power density
with environmentally friendly materials for a
green power solution. Eaton supercapacitors are
maintenance-free with design lifetimes up to 20
years* and operating temperatures down to -40 °
C and up to +85 °C.
Electric, Gas, Water smart meters
Controllers
RF radio power
Solar capture
Storage servers
Pulse power
Backup power
*Supercapacitor lifetimes vary based on
charge voltage and temperature. See Eaton’s
application guidelines or contact your local
Eaton sales representative for more
information on lifetime estimates
HV supercapacitors
Cylindrical cells
Technical Data 4376
Ratings
Capacitance
1.0 F to 100 F
Maximum working voltage
2.7 V
Surge voltage
3.0 V
Capacitance tolerance
-10% to +30%
Operating temperature range
-40 °C to +65 °C
Extended temperature range
-40 °C to +85 °C (with linear voltage derating to 2.3 V @ +85 °C)
Specifications
Capacitance1 (F)
Part number
Maximum
initial ESR1
(Ω)
Nominal
leakage
current2
(µA)
Stored energy3
(mWh)
Peak
power4 (W)
Pulse
current5
(A)
Continuous
current6 (A)
Typical
thermal
resistance7,
Rth (°C/W)
Short
circuit
current8
(A)
1
HV0810-2R7105-R
0.200
10
1.0
9.1
1.1
0.8
120
14
3
HV0820-2R7305-R
0.080
15
3.0
23
3.3
1.6
76
34
5
HV1020-2R7505-R
0.040
46
5.6
2.3
73
68
6
HV0830-2R7605-R
0.040
46
6.5
2.8
47
68
10
HV1030-2R7106-R
0.034
23
10
54
10
3.3
40
79
15
HV1325-2R7156-R
0.030
23
15
61
14
3.1
53
90
25
HV1625-2R7256-R
0.027
45
25
68
47
100
35
HV1245-2R7356-R
0.020
51
35
91
28
5.8
22
135**
35
HV1635-2R7356-R
0.024
51
35
76
26
4.0
39
113
60
HV1840-2R7606-R
0.018
110
61
101
39
5.7
26
150**
100
HV1860-2R7107-R
0.012
260
101
152
61
11
10
225**
** Repeated short circuit current will permanently damage the leads and cause an open failure.
Performance
Parameter
Capacitance change
(% of initial value)
ESR
(% of maximum initial value)
Life (1000 hours @ +65 °C @ 2.7 Vdc)
≤ 30%
≤ 200%
Storage (3 years, uncharged,
很抱歉,暂时无法提供与“HV1245-2R7356-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 型号:HV1245-2R7356-R
- 品牌:EATON(伊顿)
- 封装:插件,12.5x49mm
- 描述:超级电容器是高可靠性、高功率、超高电容的储能装置,采用双电层电容器(EDLC)结构,结合专有材料和工艺。这种先进技术的结合使其能够提供各种适用于备用电源、脉冲电源和混合动力系统的电容器解决方案。它们可以单独用作储能装置,也可以与电池结合使用,以优化成本、使用寿命和运行时间。系统要求的功率范围可以从几微瓦到兆瓦。所有产品都具有低等效串联电阻(ESR),以实现高功率密度,并采用环保材料,提供绿色电源解决方案。超级电容器无需维护,设计使用寿命长达20年,工作温度范围为 40°C至 +85°C。
- 国内价格
- 1+50.50080
- 10+46.45556
- 30+40.90565
- 100+40.29783
- 国内价格
- 1+56.64396
- 5+49.84046
- 10+45.08519
- 20+40.34190
- 40+36.32927
- 50+35.39499
- 100+33.07126
- 1000+30.36423
- 国内价格 香港价格
- 1+66.298541+8.61529
