Engineering Bulletin
No.773A / Aug.2006
RoHS
Electric Double Layer Capacitor
2.5V Power type
Compliant
@ With the original electrode process, high energy density implementation is possible
@ Charge/discharge efficiency are higher than in batteries
@ Environment-friendly
@ Suited for electricity storage, battery assistance, short-term backups, etc.
?SPECIFICATIONS
Items
Specifications
Operating Temperature
Rated Voltage
Capacitance Tolerance
Temperature
Characteristics
Load Life Test
Bias Humidity Test
-25C to +60C
2.5Vdc
(at 20C)
P10% (K)
Capacitance change [P30% of the initial measured value at 20C
Internal Resistance
(at -25C)
[600% of the value given in the Ratings Tables
After the capacitors are subjected to the rated DC voltage at 60C for 2,000 hours, the following specifications shall be
satisfied when the capacitors are restored to 20C.
Internal Resistance
[200% of the value given in the Ratings Table
After the capacitors are subjected to the rated DC voltage at 40C and 90 to 95%RH for 500 hours, the following
specifications shall be satisfied when restoring to 20C.
Internal Resistance
[200% of the value given in the Ratings Tables
?STANDARD RATINGS
Rated
Voltage
[V]
Capacitance
[F]
2.5
350
700
1,400
2,100
Case Size
F
[mm]
L [mm]
fD [mm]
65
105
150
150
35
40
50
12.7
17.0
22.4
G
[mm]
6.0
7.0
Internal
Resistance*
[mo]
Weight**
[g]
Part No.
8
5
2.5
1.8
90
160
280
420
DDLC2R5LGN351KA65S
DDLC2R5LGN701KAA5S
DDLC2R5LGN142KBF0S
DDLC2R5LGN212KCF0S
* typical data (at 20C)
** reference data
?DIMENSIONS [mm]
Safety Valve
FP1
Sleeve
FD+1.5max
Terminal type CE331
Plus hexagon-headed screw : M5B0.8B10
Maximum screw tightening torque : 3.23Nm
L+4max
GP1
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
D DLC AAA LG N AAA K AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 700F:701, 1,400F:142)
Mounting Clamp code (B, C)
Terminal code
Voltage code (ex. 2.3V:2R3, 2.5V:2R5)
Series code
Category
Please refer to "A guide to global code (screw-mount terminal type)"
Special designs are available on requests.
6
1375
Note : The specifications are subject to change without notice
NIPPON CHEMI-CON CORPORATION
No.773A / Aug.2006
?Temperature dependance of Capacitance & DCIR
800
120
700
100
DDCIR (%)
DC (%)
600
80
60
40
500
400
300
200
-15
-5
5
15
Temperature (C)
-15
-5
5
15
Temperature (C)
?60c Load Life Test
DC (%)
-20
-30
1,000
1,500
2,000
1,500
2,000
Time (hrs)
100
DDCIR (%)
80
60
40
1,000
Time (hrs)
1375
7
很抱歉,暂时无法提供与“DDLC2R5LGN351KA65S”相匹配的价格&库存,您可以联系我们找货
