E32D500HPN104MDA5M
E32D500HPN104MDA5M
    NCC(贵弥功)
    DIP
    CAP ALUM 100000UF 20% 50V SCREW
E32D500HPN104MDA5M 数据手册
U32D Series  Large Can  Screw Terminals  High Ripple  6.3 to 400VDC Voltage Range  Dimensions in Inches  RoHS Compliant  105C Maximum Temperature Summary of Specifications  Screw terminals: high and low post, English and Metric thread.  Capacitance range: 180µF to 2.2F.  Voltage range: 6.3 to 400VDC.  Category temperature range: 40C to 105C.  Leakage current: 0.02CV(µA) or 5mA, whichever is smaller, after 5 minutes at 25C.  Standard capacitance tolerance: 20%  Nominal case size (DL): D = 35mm (1.375”) to 89mm (3.500”); L = 41mm (1.625”) to 220mm (8.625”).  Rated lifetime: 2,000 hours at 105C with rated ripple current applied. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 117 U32D L ARGE CAN 105C The U32D series allows for extremely high ripple currents for applications such as inverter designs and motor controllers. This series of capacitors offers very large capacitance of up to 2.2F and a maximum temperature rating of 105C which allows a high operating temperature without sacrificing life. These capacitors are available with a variety of high current English or Metric thread terminals. Mounting options available are a three-footed clamp or bottom stud. (A special order two-footed clamp is also available for selected diameters.) All case size dimensions are based on inches. Custom designs are available upon request. U32D Series U32D Specifications - Screw Terminals Item Characteristics Category Temperature Range 40 to 105C Rated Voltage Range 6.3 to 400VDC Capacitance Range 180F to 2.2F at 25C, 120Hz Capacitance Tolerance 20% ( M ) at 25C, 120Hz Leakage Current I  0.02CV (A ) or 5mA, whichever is smaller, after 5 minutes at 25C. Rated Ripple Current Multipliers Ambient Temperature (C ) Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V ) ≤ 45C 65C 85C 105C 1.41 1.29 1.00 0.57 Frequency (Hz ) DC Rated Voltage 6.3 - 50V 63 - 80V 100V 160 - 250V 315 - 400V Endurance (Load Life) Case Diameter 50Hz 120Hz 300Hz 1kHz 10kHz 50kHz Ø 35 - Ø 76 0.95 1.00 1.03 1.05 1.09 1.12 Ø 35 0.90 1.00 1.06 1.10 1.18 1.22 Ø 51- Ø 76 0.95 1.00 1.03 1.05 1.09 1.12 Ø 35 0.82 1.00 1.12 1.22 1.30 1.33 Ø 51 0.90 1.00 1.06 1.10 1.18 1.22 Ø 63 - Ø 76 0.95 1.00 1.03 1.05 1.09 1.12 Ø 35 0.80 1.00 1.19 1.34 1.46 1.52 Ø 51- Ø 63 0.81 1.00 1.14 1.26 1.36 1.41 Ø 76 0.82 1.00 1.12 1.22 1.30 1.33 Ø 35 - Ø 89 0.80 1.00 1.19 1.34 1.46 1.52 The following specifications shall be satisfied when the capacitors are restored to 25C after subjecting them to DC voltage for 2,000 hours at 105C with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ 20% from initial measurement ESR change : ≤ 200% of initial specified limit Leakage current : ≤ initial specified limit The following specifications shall be satisfied when the capacitors are restored to 25C after exposing them for 500 hours at 105C without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change: ≤ 20% from initial measurement ESR change : ≤ 200% of initial specified limit Leakage current : ≤ initial specified limit L ARGE CAN 105C U32D Shelf Test 118 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U32D Series Diagram of Dimensions - Screw Terminals Unit: inches (mm) Large Can / Screw Terminals Case Dimensions ØD 0.080 (2.0) L 0.040 (1.0) F 0.010 (0.25) 1.375 (35.0) 1.625 (41) 2.125 (54) 2.625 (67) 3.125 (79) 3.625 (92) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 0.500 (12.7) 2.000 (50.8) 1.875 (48) 2.125 (54) 2.625 (67) 3.125 (79) 3.625 (92) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 0.875 (22.2) 2.500 (63.5) 3.125 (79) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 1.125 (28.6) E92 EA5 EB7 ED0 EE3 EN0 3.000 (76.2) 3.625 (92) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 8.625 (220) 1.250 (31.8) FA5 FB7 FE3 3.500 (89.0) 4.125 (105) 4.625 (117) 5.625 (143) 1.250 (31.8) Case Size Code A41 A54 A67 A79 A92 AA5 AB7 AD0 AE3 Vent F C48 C54 C67 C79 C92 CA5 CB7 CD0 CE3 S T J D79 DA5 DB7 DD0 DE3 Insulating Sleeve L H Insulating End Disk D Terminal Specifications Terminal Code ØD ØD inches (mm) C-E C-E C-E C-E D-E D-F D-F D-F D-F 1.375 – 3.000 (35.0 – 76.2) 1.375 – 3.000 (35.0 – 76.2) 1.375 – 3.000 (35.0 – 76.2) 1.375 – 3.000 (35.0 – 76.2) 2.500 – 3.000 (63.5 – 76.2) 2.500 – 3.500 (63.5 – 89.0) 2.500 – 3.500 (63.5 – 89.0) 2.500 – 3.500 (63.5 – 89.0) 2.500 – 3.500 (63.5 – 89.0) Minimum Thread Depth 10 - 32 NF- 2B 10 - 32 NF- 2B M5x0.8 - 6H M5x0.8 - 6H M5x0.8 - 6H 1/4 - 28 NF- 2B 1/4 - 28 NF- 2B M6x1- 6H M6x1- 6H 0.375 (9.5) 0.219 (5.6) 0.375 (9.5) 0.219 (5.6) 0.335 (8.5) 0.344 (8.7) 0.468 (11.9) 0.344 (8.7) 0.468 (11.9) H ØS ØT J 0.020 (0.5) 0.080 (2.0) 0.010 (0.25) 0.010 (0.25) 0.250 (6.4) 0.063 (1.6) 0.250 (6.4) 0.063 (1.6) 0.200 (5.0) 0.093 (2.4) 0.250 (6.4) 0.093 (2.4) 0.250 (6.4) LJ LJ LJ LJ LJ LJ LJ LJ LJ 0.313 (8.0) 0.313 (8.0) 0.313 (8.0) 0.313 (8.0) 0.512 (13.0) 0.689 (17.5) 0.689 (17.5) 0.689 (17.5) 0.689 (17.5) 0.438 (11.1) — 0.438 (11.1) 0.438 (11.1) 0.740 (18.8) — — — — United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 119 U32D Code Thread Size L ARGE CAN 105C HP LP HL ML CD CP CH CA CS Available Case Diameter U32D Series Mounting Hardware - Screw Terminals Type C: Three-Footed Clamp Unit: mm (inches) 360 3 30 455 15 D A B T J G K 5.10.5 (2 holes) (0.2010.020) R Clamp: Zinc with silver trivalent chromate post treatment. S Hardware: Screw, washer and hexagon nut included with each clamp. Type C: Clamp Dimensions G J K R S T A B 1.0 (0.040) 1.0 (0.040) 1.0 (0.040) 0.5 (0.020) 0.5 (0.020) 1.0 (0.040) 1.0 (0.040) 0.5 (0.020) Mounting Code Case ØD See Note 35.0 (1.375) — — — — — — — — C 50.8 (2.000) 31.8 (1.250) 36.5 (1.437) 13.3 (0.524) 4.5 (0.177) 7.1 (0.280) 19.1 (0.751) 9.5 (0.374) 0.8 (0.032) C 63.5 (2.500) 38.1 (1.500) 42.9 (1.689) 13.3 (0.524) 4.5 (0.177) 7.1 (0.280) 19.1 (0.751) 9.5 (0.374) 0.8 (0.032) C 76.2 (3.000) 44.5 (1.750) 49.2 (1.937) 13.3 (0.524) 4.5 (0.177) 7.1 (0.280) 19.1 (0.751) 9.5 (0.374) 1.0 (0.040) C 89.0 (3.500) 50.8 (2.000) 56.5 (2.224) 16.0 (0.630) 4.5 (0.177) 8.0 (0.313) 21.0 (0.827) 9.0 (0.354) 1.0 (0.040) Note: Type B two-footed clamp available upon request for Ø 35, Ø 50.8, Ø 63.5 and Ø 76.2. Consult UCC for specifications. U32D L ARGE CAN 105C Type S: Stud Mounting Q M N P R K T D Type S: Stud Mounting Dimensions 120 Mounting Code P 1.0 (0.040) T Thread Size M 1.0 (0.040) N 1.0 (0.040) ØK 2.0 (0.080) ØQ 1.0 (0.040) R 1.0 (0.040) S 16.0 (0.630) M12 19.0 (0.748) 18.0 (0.709) 30.0 (1.181) 22.0 (0.866) 1.40 (0.055) United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U32D Series Part Numbering System for U32D Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E 3 2 D 2 0 1 H P N 1 0 3 MD A 5 M 9 8 7 6 5 2 1 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 121 U32D 3 L ARGE CAN 105C 4 Supplement Code. Field 18. C = PET insulation with end disk. F = Coated can. M = Pb-free PVC insulation with end disk. Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. A = Ø 35mm ( Ø1.375”) C = Ø 50.8mm ( Ø 2.000”) D = Ø 63.5mm ( Ø 2.500”) E = Ø 76.2mm ( Ø 3.000”) F = Ø 89mm ( Ø 3.500”) The double character length code is inserted in fields 16 and 17. For lengths ≤ 99mm, insert the actual length rounded to nearest millimeter. For lengths of 100mm or more, insert the appropriate alpha numeric code as indicated below. 41 = 41mm (1.625”) 48 = 48mm (1.875”) 54 = 54mm (2.125”) 67 = 67mm (2.625”) 79 = 79mm (3.125”) 92 = 92mm (3.625”) A5 = 105mm (4.125”) B7 = 117mm (4.625”) D0 = 130mm (5.125”) E3 = 143mm (5.625”) N0= 220mm (8.625”) Capacitance Tolerance. Field 14. M = 20% Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10F or more. R indicates the decimal point for capacitance less than 10F (e.g. 1R0 = 1.0F; 100 = 10F; 101 = 100F; 102 = 1,000F; 103 = 10,000F ). Mounting Hardware. Field 10. N = None. B = Two-footed clamp. C = Three-footed clamp. S = Stud mount. Terminal Type. Fields 8 and 9. HP = High post 10-32 NF- 2B screw thread. LP = Low post 10-32 NF- 2B screw thread. HL = High post M5x0.8 screw thread. ML = Low post M5x0.8 screw thread. CD = UTE M5x0.8 screw thread. CP = Low post 1/4 -28 NF-2B screw thread. CH = High post 1/4 -28 NF-2B screw thread. CA = Low post M6x1 screw thread. CS = High post M6x1 screw thread. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 2R0 = 2.0VDC; 200 = 20VDC; 201 = 200VDC). Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters /digits, place a dash in field 4. For a series name with more than 3 letters /digits, refer to the individual series for the appropriate 3-field series name. Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 6.3 Volts 8 Volts Surge 10 Volts U32D L ARGE CAN 105C 13 Volts Surge 16 Volts 20 Volts Surge Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 39,000 68,000 82,000 120,000 150,000 180,000 220,000 82,000 120,000 180,000 220,000 330,000 390,000 470,000 560,000 390,000 560,000 820,000 680,000 820,000 1,000,000 1,200,000 2,200,000 E32D6R3HPN393MA41M E32D6R3HPN683MA54M E32D6R3HPN823MA67M E32D6R3HPN124MA79M E32D6R3HPN154MA92M E32D6R3HPN184MAA5M E32D6R3HPN224MAD0M E32D6R3HPN823MC48M E32D6R3HPN124MC54M E32D6R3HPN184MC67M E32D6R3HPN224MC79M E32D6R3HPN334MC92M E32D6R3HPN394MCA5M E32D6R3HPN474MCB7M E32D6R3HPN564MCE3M E32D6R3HPN394MD79M E32D6R3HPN564MDA5M E32D6R3HPN824MDB7M E32D6R3HPN684ME92M E32D6R3HPN824MEA5M E32D6R3HPN105MEB7M E32D6R3HPN125MED0M E32D6R3HPN225MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AA5 AD0 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 E92 EA5 EB7 ED0 EN0 39.9 24.0 19.5 14.5 12.2 11.8 9.1 22.1 16.2 11.3 9.2 7.7 6.4 6.0 4.9 8.7 6.3 5.7 8.3 7.2 6.6 6.1 4.0 7.03 9.62 10.87 13.76 15.53 18.10 20.93 11.19 13.53 17.11 20.41 24.76 27.19 30.87 35.78 22.54 29.81 32.97 26.88 30.40 33.32 36.04 56.03 33,000 56,000 68,000 100,000 120,000 150,000 180,000 68,000 100,000 150,000 180,000 270,000 390,000 470,000 330,000 470,000 560,000 680,000 560,000 680,000 820,000 1,000,000 1,800,000 E32D100HPN333MA41M E32D100HPN563MA54M E32D100HPN683MA67M E32D100HPN104MA79M E32D100HPN124MA92M E32D100HPN154MAB7M E32D100HPN184MAD0M E32D100HPN683MC48M E32D100HPN104MC54M E32D100HPN154MC67M E32D100HPN184MC79M E32D100HPN274MC92M E32D100HPN394MCB7M E32D100HPN474MCE3M E32D100HPN334MD79M E32D100HPN474MDA5M E32D100HPN564MDB7M E32D100HPN684MDD0M E32D100HPN564ME92M E32D100HPN684MEA5M E32D100HPN824MEB7M E32D100HPN105MED0M E32D100HPN185MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AB7 AD0 C48 C54 C67 C79 C92 CB7 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EN0 39.7 24.3 19.6 14.6 12.5 10.4 9.2 22.2 16.3 11.4 9.3 7.8 6.0 4.9 8.8 6.4 5.7 5.3 8.3 7.2 6.5 6.1 4.0 7.03 9.55 10.79 13.71 14.66 18.83 20.80 11.13 13.48 17.11 20.28 24.76 30.55 35.78 22.40 29.81 33.95 36.68 26.88 30.40 33.32 36.04 56.03 22,000 39,000 47,000 68,000 82,000 100,000 120,000 150,000 47,000 68,000 100,000 120,000 E32D160HPN223MA41M E32D160HPN393MA54M E32D160HPN473MA67M E32D160HPN683MA79M E32D160HPN823MA92M E32D160HPN104MAA5M E32D160HPN124MAD0M E32D160HPN154MAE3M E32D160HPN473MC48M E32D160HPN683MC54M E32D160HPN104MC67M E32D160HPN124MC79M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 A41 A54 A67 A79 A92 AA5 AD0 AE3 C48 C54 C67 C79 41.4 27.3 19.9 15.0 12.8 11.1 9.5 9.3 22.7 16.7 11.7 9.6 6.26 8.68 9.80 12.48 14.04 16.47 19.11 21.33 10.18 12.38 15.75 18.66 Capacitance (µF ) † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 122 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 16 Volts 20 Volts Surge 25 Volts 32 Volts Surge Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 180,000 220,000 270,000 330,000 220,000 330,000 390,000 470,000 390,000 470,000 560,000 680,000 820,000 1,200,000 E32D160HPN184MC92M E32D160HPN224MCA5M E32D160HPN274MCB7M E32D160HPN334MCE3M E32D160HPN224MD79M E32D160HPN334MDA5M E32D160HPN394MDB7M E32D160HPN474MDD0M E32D160HPN394ME92M E32D160HPN474MEA5M E32D160HPN564MEB7M E32D160HPN684MED0M E32D160HPN824MEE3M E32D160HPN125MEN0M 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  5.625 3.000  8.625 C92 CA5 CB7 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EE3 EN0 7.5 7.0 6.1 5.2 8.9 6.5 5.9 5.4 8.5 7.4 6.7 6.2 5.4 4.0 22.89 25.40 28.80 33.82 21.75 28.62 32.66 34.54 26.07 29.56 32.56 35.45 37.58 55.32 15,000 22,000 33,000 47,000 56,000 68,000 82,000 33,000 47,000 68,000 82,000 120,000 180,000 220,000 150,000 220,000 270,000 330,000 270,000 330,000 390,000 470,000 820,000 E32D250HPN153MA41M E32D250HPN223MA54M E32D250HPN333MA67M E32D250HPN473MA79M E32D250HPN563MA92M E32D250HPN683MAA5M E32D250HPN823MAD0M E32D250HPN333MC48M E32D250HPN473MC54M E32D250HPN683MC67M E32D250HPN823MC79M E32D250HPN124MC92M E32D250HPN184MCB7M E32D250HPN224MCE3M E32D250HPN154MD79M E32D250HPN224MDA5M E32D250HPN274MDB7M E32D250HPN334MDE3M E32D250HPN274ME92M E32D250HPN334MEA5M E32D250HPN394MEB7M E32D250HPN474MED0M E32D250HPN824MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AA5 AD0 C48 C54 C67 C79 C92 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 ED0 EN0 41.3 27.7 19.5 16.6 12.8 12.3 9.4 22.4 16.6 11.7 9.6 7.6 6.1 5.3 8.9 6.5 5.9 4.9 8.6 7.5 6.8 6.3 4.1 6.27 8.20 9.88 12.53 13.71 16.47 19.11 10.23 12.42 15.68 18.76 22.73 28.80 33.82 21.63 28.62 32.66 37.88 25.92 29.16 32.31 35.16 55.32 10,000 18,000 22,000 33,000 39,000 47,000 56,000 68,000 22,000 33,000 47,000 68,000 82,000 100,000 120,000 150,000 100,000 150,000 220,000 E32D350HPN103MA41M E32D350HPN183MA54M E32D350HPN223MA67M E32D350HPN333MA79M E32D350HPN393MA92M E32D350HPN473MAA5M E32D350HPN563MAB7M E32D350HPN683MAE3M E32D350HPN223MC48M E32D350HPN333MC54M E32D350HPN473MC67M E32D350HPN683MC79M E32D350HPN823MC92M E32D350HPN104MCA5M E32D350HPN124MCB7M E32D350HPN154MCE3M E32D350HPN104MD79M E32D350HPN154MDA5M E32D350HPN224MDB7M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 45.8 26.7 21.6 15.7 13.6 11.8 10.4 8.9 24.1 17.4 12.4 9.4 7.9 6.9 6.1 5.2 8.8 6.5 5.8 5.94 8.33 9.40 12.14 13.60 15.95 17.35 20.57 9.86 12.15 15.34 18.76 22.26 24.82 28.03 33.12 21.88 28.84 32.08 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 123 U32D Nominal Case Size* DL (inches) L ARGE CAN 105C 35 Volts 44 Volts Surge Global Part Number† Capacitance (µF ) U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 35 Volts 44 Volts Surge 50 Volts U32D L ARGE CAN 105C 63 Volts Surge 63 Volts 79 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 220,000 270,000 330,000 390,000 560,000 E32D350HPN224ME92M E32D350HPN274MEB7M E32D350HPN334MED0M E32D350HPN394MEE3M E32D350HPN564MEN0M 3.000  3.625 3.000  4.625 3.000  5.125 3.000  5.625 3.000  8.625 E92 EB7 ED0 EE3 EN0 8.3 6.6 6.2 5.4 4.0 25.19 32.81 35.45 37.90 56.03 5,600 10,000 15,000 18,000 22,000 27,000 33,000 39,000 15,000 18,000 27,000 39,000 56,000 68,000 82,000 100,000 68,000 100,000 120,000 150,000 120,000 150,000 180,000 220,000 330,000 E32D500HPN562MA41M E32D500HPN103MA54M E32D500HPN153MA67M E32D500HPN183MA79M E32D500HPN223MA92M E32D500HPN273MAA5M E32D500HPN333MAB7M E32D500HPN393MAE3M E32D500HPN153MC48M E32D500HPN183MC54M E32D500HPN273MC67M E32D500HPN393MC79M E32D500HPN563MC92M E32D500HPN683MCB7M E32D500HPN823MCD0M E32D500HPN104MCE3M E32D500HPN683MD79M E32D500HPN104MDA5M E32D500HPN124MDB7M E32D500HPN154MDE3M E32D500HPN124ME92M E32D500HPN154MEA5M E32D500HPN184MEB7M E32D500HPN224MEE3M E32D500HPN334MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CB7 CD0 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 EE3 EN0 52.2 30.3 21.3 17.9 15.1 12.9 12.5 9.7 24.3 19.4 13.4 10.1 8.5 6.5 5.8 5.6 9.4 6.8 5.9 5.1 8.9 7.8 6.5 5.7 4.0 5.66 7.25 9.01 10.92 12.58 15.23 17.22 20.56 10.01 11.50 14.97 19.30 22.56 27.67 29.50 34.03 24.55 31.43 34.04 37.63 33.88 36.22 38.22 44.44 65.97 4,700 6,800 10,000 12,000 15,000 18,000 22,000 27,000 10,000 12,000 22,000 27,000 39,000 47,000 56,000 68,000 47,000 68,000 82,000 100,000 82,000 100,000 120,000 150,000 220,000 E32D630HPN472MA41M E32D630HPN682MA54M E32D630HPN103MA67M E32D630HPN123MA79M E32D630HPN153MA92M E32D630HPN183MAA5M E32D630HPN223MAB7M E32D630HPN273MAD0M E32D630HPN103MC48M E32D630HPN123MC54M E32D630HPN223MC67M E32D630HPN273MC79M E32D630HPN393MC92M E32D630HPN473MCB7M E32D630HPN563MCD0M E32D630HPN683MCE3M E32D630HPN473MD79M E32D630HPN683MDA5M E32D630HPN823MDB7M E32D630HPN104MDE3M E32D630HPN823ME92M E32D630HPN104MEA5M E32D630HPN124MEB7M E32D630HPN154MEE3M E32D630HPN224MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AD0 C48 C54 C67 C79 C92 CB7 CD0 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 EE3 EN0 57.1 33.8 23.9 20.1 16.6 14.3 12.3 12.1 26.7 21.5 14.8 10.8 9.1 6.9 6.2 6.0 9.6 6.9 6.2 5.2 8.9 7.7 6.9 5.7 4.0 5.18 6.68 7.36 8.92 10.39 12.44 14.06 16.36 8.18 9.39 13.52 16.06 20.62 23.00 26.34 30.31 22.05 29.84 29.93 32.23 29.71 34.67 35.58 39.63 53.86 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 124 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 80 Volts 100 Volts Surge Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 2,200 3,900 4,700 6,800 8,200 10,000 12,000 4,700 6,800 10,000 12,000 18,000 22,000 27,000 33,000 22,000 33,000 39,000 47,000 39,000 47,000 56,000 68,000 120,000 E32D800HPN222MA41M E32D800HPN392MA54M E32D800HPN472MA67M E32D800HPN682MA79M E32D800HPN822MA92M E32D800HPN103MAA5M E32D800HPN123MAD0M E32D800HPN472MC48M E32D800HPN682MC54M E32D800HPN103MC67M E32D800HPN123MC79M E32D800HPN183MC92M E32D800HPN223MCA5M E32D800HPN273MCB7M E32D800HPN333MCE3M E32D800HPN223MD79M E32D800HPN333MDA5M E32D800HPN393MDB7M E32D800HPN473MDD0M E32D800HPN393ME92M E32D800HPN473MEA5M E32D800HPN563MEB7M E32D800HPN683MED0M E32D800HPN124MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AA5 AD0 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EN0 67.0 44.2 31.7 23.0 19.5 19.0 14.0 34.3 24.6 17.0 14.0 10.4 9.9 8.5 7.2 10.6 7.6 6.8 6.1 8.9 7.7 6.9 6.4 4.2 4.09 5.84 6.51 8.67 9.92 10.36 12.19 6.27 7.90 10.19 11.97 15.66 18.36 21.35 25.86 16.52 22.84 23.76 25.31 23.66 27.45 31.38 33.51 52.62 1,500 2,700 3,900 4,700 5,600 6,800 8,200 10,000 3,900 4,700 6,800 10,000 12,000 15,000 18,000 22,000 15,000 22,000 27,000 33,000 39,000 27,000 33,000 39,000 47,000 56,000 82,000 E32D101HPN152MA41M E32D101HPN272MA54M E32D101HPN392MA67M E32D101HPN472MA79M E32D101HPN562MA92M E32D101HPN682MAA5M E32D101HPN822MAB7M E32D101HPN103MAE3M E32D101HPN392MC48M E32D101HPN472MC54M E32D101HPN682MC67M E32D101HPN103MC79M E32D101HPN123MC92M E32D101HPN153MCA5M E32D101HPN183MCB7M E32D101HPN223MCE3M E32D101HPN153MD79M E32D101HPN223MDA5M E32D101HPN273MDB7M E32D101HPN333MDD0M E32D101HPN393MDE3M E32D101HPN273ME92M E32D101HPN333MEA5M E32D101HPN393MEB7M E32D101HPN473MED0M E32D101HPN563MEE3M E32D101HPN823MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DD0 DE3 E92 EA5 EB7 ED0 EE3 EN0 80.9 45.9 37.2 27.1 23.1 19.5 19.2 14.1 39.9 28.7 20.0 14.5 12.2 10.2 9.8 7.5 11.9 8.5 7.4 6.6 6.3 9.3 8.0 7.2 6.6 6.1 4.3 4.14 5.95 7.26 8.82 10.04 11.03 11.80 13.44 6.59 7.59 9.70 12.62 14.77 17.51 20.13 24.38 15.26 20.85 24.22 28.05 31.82 21.56 25.20 28.69 30.09 34.25 50.23 820 1,500 1,800 2,700 3,900 4,700 5,600 E32D161HPN821MA41M E32D161HPN152MA54M E32D161HPN182MA67M E32D161HPN272MA79M E32D161HPN392MAA5M E32D161HPN472MAD0M E32D161HPN562MAE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  4.125 1.375  5.125 1.375  5.625 A41 A54 A67 A79 AA5 AD0 AE3 184.8 101.2 83.3 56.8 40.0 33.4 28.6 2.50 3.62 4.03 5.46 7.47 8.81 10.06 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 125 U32D 160 Volts 200 Volts Surge Global Part Number† L ARGE CAN 105C 100 Volts 125 Volts Surge Capacitance (µF ) U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 160 Volts 200 Volts Surge 200 Volts U32D L ARGE CAN 105C 250 Volts Surge 250 Volts 300 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 2,200 2,700 3,900 5,600 6,800 8,200 10,000 12,000 8,200 12,000 18,000 18,000 22,000 27,000 47,000 E32D161HPN222MC48M E32D161HPN272MC54M E32D161HPN392MC67M E32D161HPN562MC79M E32D161HPN682MC92M E32D161HPN822MCA5M E32D161HPN103MCB7M E32D161HPN123MCE3M E32D161HPN822MD79M E32D161HPN123MDA5M E32D161HPN183MDB7M E32D161HPN183ME92M E32D161HPN223MEB7M E32D161HPN273MED0M E32D161HPN473MEN0M 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 3.000  3.625 3.000  4.625 3.000  5.125 3.000  8.625 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 E92 EB7 ED0 EN0 74.6 59.6 41.1 29.4 24.0 20.5 17.0 14.3 22.6 15.8 11.8 14.7 11.3 9.9 6.2 4.29 4.98 6.36 8.18 9.63 11.21 12.99 15.60 11.28 15.40 19.77 19.68 24.09 27.93 46.58 680 1,000 1,500 1,800 2,200 2,700 3,300 3,900 1,500 2,200 3,300 3,900 5,600 8,200 10,000 6,800 10,000 12,000 15,000 12,000 15,000 18,000 22,000 33,000 E32D201HPN681MA41M E32D201HPN102MA54M E32D201HPN152MA67M E32D201HPN182MA79M E32D201HPN222MA92M E32D201HPN272MAA5M E32D201HPN332MAB7M E32D201HPN392MAD0M E32D201HPN152MC48M E32D201HPN222MC54M E32D201HPN332MC67M E32D201HPN392MC79M E32D201HPN562MC92M E32D201HPN822MCB7M E32D201HPN103MCE3M E32D201HPN682MD79M E32D201HPN103MDA5M E32D201HPN123MDB7M E32D201HPN153MDE3M E32D201HPN123ME92M E32D201HPN153MEA5M E32D201HPN183MEB7M E32D201HPN223MEE3M E32D201HPN333MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AD0 C48 C54 C67 C79 C92 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 EE3 EN0 192.4 128.5 86.3 71.8 59.1 48.7 40.4 34.7 110.7 63.1 42.2 35.2 25.1 17.8 14.8 23.6 16.5 13.8 11.5 16.4 13.7 11.9 9.8 6.8 2.28 2.96 3.68 4.46 5.14 6.22 7.03 8.03 4.09 5.19 6.76 7.88 10.09 13.59 16.44 10.27 14.06 16.14 19.74 16.07 18.99 21.79 26.29 39.03 470 820 1,200 1,500 1,800 2,200 2,700 3,300 1,200 1,500 2,200 3,300 3,900 4,700 5,600 6,800 5,600 8,200 E32D251HPN471MA41M E32D251HPN821MA54M E32D251HPN122MA67M E32D251HPN152MA79M E32D251HPN182MA92M E32D251HPN222MAA5M E32D251HPN272MAB7M E32D251HPN332MAE3M E32D251HPN122MC48M E32D251HPN152MC54M E32D251HPN222MC67M E32D251HPN332MC79M E32D251HPN392MC92M E32D251HPN472MCA5M E32D251HPN562MCB7M E32D251HPN682MCD0M E32D251HPN562MD79M E32D251HPN822MDA5M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.125 2.500  3.125 2.500  4.125 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CD0 D79 DA5 273.0 155.3 106.5 85.3 71.3 58.8 48.5 40.0 112.1 88.4 60.1 41.0 34.6 29.0 24.7 20.7 27.7 19.3 1.89 2.68 3.29 3.53 4.02 4.86 5.51 6.69 3.17 3.71 4.78 6.28 7.29 8.49 9.72 11.24 9.32 12.73 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 126 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 250 Volts 300 Volts Surge 315 Volts 365 Volts Surge Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 10,000 12,000 10,000 12,000 15,000 18,000 27,000 E32D251HPN103MDB7M E32D251HPN123MDE3M E32D251HPN103ME92M E32D251HPN123MEA5M E32D251HPN153MED0M E32D251HPN183MEE3M E32D251HPN273MEN0M 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 DB7 DE3 E92 EA5 ED0 EE3 EN0 18.5 13.6 18.8 15.9 12.7 11.2 7.7 14.74 17.65 14.67 16.99 20.82 23.78 35.30 220 330 470 680 820 1,000 1,200 470 680 1,000 1,200 1,800 2,200 2,700 3,300 2,200 3,300 3,900 4,700 3,900 4,700 5,600 6,800 8,200 12,000 E32D3B1HPN221MA41M E32D3B1HPN331MA54M E32D3B1HPN471MA67M E32D3B1HPN681MA79M E32D3B1HPN821MA92M E32D3B1HPN102MAA5M E32D3B1HPN122MAD0M E32D3B1HPN471MC48M E32D3B1HPN681MC54M E32D3B1HPN102MC67M E32D3B1HPN122MC79M E32D3B1HPN182MC92M E32D3B1HPN222MCA5M E32D3B1HPN272MCB7M E32D3B1HPN332MCE3M E32D3B1HPN222MD79M E32D3B1HPN332MDA5M E32D3B1HPN392MDB7M E32D3B1HPN472MDD0M E32D3B1HPN392ME92M E32D3B1HPN472MEA5M E32D3B1HPN562MEB7M E32D3B1HPN682MED0M E32D3B1HPN822MEE3M E32D3B1HPN123MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AD0 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EE3 EN0 750.3 492.0 343.8 237.8 197.2 161.9 134.9 354.0 243.1 164.1 135.9 91.0 75.0 61.3 50.3 77.0 51.7 43.7 36.9 45.7 38.2 32.4 27.2 23.1 16.0 1.59 2.08 2.52 3.36 3.14 8.46 9.96 2.80 3.53 3.72 4.37 5.72 6.70 7.80 9.44 6.75 9.32 10.63 12.22 10.58 12.28 14.03 16.19 18.53 27.17 180 330 470 560 680 820 1,000 1,200 470 680 1,000 1,200 1,800 2,200 2,700 2,200 3,300 3,900 4,700 3,900 4,700 5,600 6,800 10,000 E32D351HPN181MA41M E32D351HPN331MA54M E32D351HPN471MA67M E32D351HPN561MA79M E32D351HPN681MA92M E32D351HPN821MAA5M E32D351HPN102MAB7M E32D351HPN122MAD0M E32D351HPN471MC48M E32D351HPN681MC54M E32D351HPN102MC67M E32D351HPN122MC79M E32D351HPN182MC92M E32D351HPN222MCB7M E32D351HPN272MCD0M E32D351HPN222MD79M E32D351HPN332MDA5M E32D351HPN392MDB7M E32D351HPN472MDE3M E32D351HPN392ME92M E32D351HPN472MEA5M E32D351HPN562MEB7M E32D351HPN682MED0M E32D351HPN103MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AD0 C48 C54 C67 C79 C92 CB7 CD0 D79 DA5 DB7 DE3 E92 EA5 EB7 ED0 EN0 882.3 475.0 332.0 277.6 228.5 189.6 156.0 130.0 342.0 235.0 156.0 131.3 88.0 71.9 59.0 75.0 50.0 42.0 35.0 44.0 37.0 32.0 27.0 17.9 1.43 2.08 2.52 3.05 3.36 3.43 3.87 4.45 2.80 3.53 3.72 4.37 5.72 7.04 8.18 6.75 9.32 10.63 12.76 10.58 12.28 14.03 16.19 24.81 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 127 U32D Global Part Number† L ARGE CAN 105C 350 Volts 400 Volts Surge Capacitance (µF ) U32D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 350 Volts 400 Volts Surge 400 Volts 450 Volts Surge Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 5,600 6,800 8,200 E32D351LLN562MFA5M E32D351LLN682MFB7M E32D351LLN822MFE3M 3.500  4.125 3.500  4.625 3.500  5.625 FA5 FB7 FE3 35.0 30.0 24.0 15.40 17.28 21.00 180 270 390 470 680 820 1,000 390 560 820 1,000 1,500 2,200 2,700 1,800 2,700 3,300 3,900 3,300 3,900 4,700 5,600 10,000 4,700 5,600 6,800 E32D401HPN181MA41M E32D401HPN271MA54M E32D401HPN391MA67M E32D401HPN471MA79M E32D401HPN681MA92M E32D401HPN821MAB7M E32D401HPN102MAD0M E32D401HPN391MC48M E32D401HPN561MC54M E32D401HPN821MC67M E32D401HPN102MC79M E32D401HPN152MC92M E32D401HPN222MCB7M E32D401HPN272MCE3M E32D401HPN182MD79M E32D401HPN272MDA5M E32D401HPN332MDB7M E32D401HPN392MDD0M E32D401HPN332ME92M E32D401HPN392MEA5M E32D401HPN472MEB7M E32D401HPN562MED0M E32D401HPN103MEN0M E32D401LLN472MFA5M E32D401LLN562MFB7M E32D401LLN682MFE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 3.500  4.125 3.500  4.625 3.500  5.625 A41 A54 A67 A79 A92 AB7 AD0 C48 C54 C67 C79 C92 CB7 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EN0 FA5 FB7 FE3 806.0 528.4 364.1 301.2 209.0 172.9 142.0 374.9 259.0 176.0 143.3 96.0 66.0 54.0 82.0 55.0 45.4 39.0 48.0 40.3 34.0 29.0 17.0 36.0 32.0 25.0 1.43 1.88 2.30 2.79 2.86 3.50 4.06 2.55 3.21 3.37 3.99 5.22 7.04 8.54 6.10 8.43 9.78 11.13 9.73 11.18 12.86 14.69 24.81 15.19 16.73 20.58 Capacitance (µF ) U32D L ARGE CAN 105C † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 128 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com
E32D500HPN104MDA5M 价格&库存
很抱歉,暂时无法提供与“E32D500HPN104MDA5M”相匹配的价格&库存,您可以联系我们找货
