RFS
RFS
MINIATURE
ALUMINUM
ELECTROLYTIC
CAPACITORS
FOR
AUDIO
MINIATURE
ALUMINUM
ELECTROLYTIC
CAPACITORS
FOR
AUDIO
SILMIC series Silk fiber using audio purpose capacitor
ELNA developed new raw material for the separate paper which use a silk fibers.
Therefore, this capacitor can give you high grade sound for your audio design.
Due to the silk fiber's pliability, the capacitor makes a dream of the high quality
sound.
For examples ;
To relieve the music's vibration energy.
To decrease the peak feeling sound at high compass and rough quality sound at
middle compass.
To increase massive sound at low compass.
For bipolar capacitors, consult with us.
Marking color : White print on a brown sleeve
Miniature High Grade Capacitors for Audio(SILMICⅠ
Ⅰ)
GREEN
CAP
All lead wires oxygen-free copper for extremely low distortion.
(Third high frequency distortion 10kHz,0.1A,-120dB or less)
"SILMIC II" mark on sleeve.
For
Audio
For higher grade
RFS
For higher grade
ROS
For higher grade
ROA
ROB
Specifications
Item
Performance
ー40 to +85
±20
Less than 0.01CV or 3 whichever is larger (after 5 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V)
Category temperature range (℃)
Tolerance at rated capacitance (%)
Leakage current (µA)
6.3
0.20
Rated voltage (V)
tanδ (max.)
Tangent of loss angle
(tanδ)
10
0.17
16
0.13
35
0.10
50
0.08
63
0.08
100
0.08
0.02 is added to every 1000µF increase over 1000µF
(20℃,120Hz)
Test time
Leakage current
Percentage of capacitance change
Tangent of the loss angle
Endurance (85℃)
(Applied ripple current)
1000 hours (with the polarity inverted every 250 hours)
The initial specified value or less
Within ±20% of initial value
150% or less of the initial specified value
Test time : 1000 hours. Other have same as endurance. Voltage application treatment : According to JIS C5101 -1
JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985)
Shelf life (85℃)
Applicable standards
Outline Drawing
Unit : mm
Vent (except φ5)
Sleeve
φd±0.05 copper wire (tinned)
Coefficient of Frequency for Rated Ripple Current
Rated voltage (V)
15min.
L+α max.
5
2.0
0.6
6.3
2.5
0.6
8
3.5
0.6
10
5.0
0.6
12.5
5.0
0.6
16
7.5
0.8
50・60
120
1k
10k
100k
0.8
0.8
0.8
0.8
0.8
1
1
1
1
1
1.1
1.5
1.2
1.6
1.2
1.2
1.7
1.3
1.9
1.3
1.2
1.7
1.3
1.9
1.3
Part numbering system (example : 25V100µF)
18
7.5
0.8
RFS
2.0
(φ10,16L or less : 1.5)
1.5
α
50 to 100
5
min.
Frequency (Hz)
CV (µF×WV)
All CV value
≤1000
1000<
≤1000
1000<
25 to 35
F±0.5
φD+0.5max.
6.3 to 16
φD
F
φd
25
0.10
(20℃,120Hz)
(20℃)
Series code
25
V
Rated voltage
symbol
101
M
Rated capacitance Capacitance
symbol
tolerance symbol
H4 #5 ̶
Casing
symbol
Taping (Forming)
symbol
Case symbol
Standard Ratings
Rated voltage (V)
Rated
capacitance (µF)
Item
Case
6.3
φD×L (mm)
10
16
25
35
50
63
100
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Rated ripple
Case
Case
Case
Case
Case
Case
Case
current
current
current
current
current
current
current
current
(mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms)
2.2
3.3
4.7
10
22
33
47
100
220
330
470
1000
2200
3300
5×11
5×11
6.3×11
8×11.5
10×12.5
10×16
10×20
12.5×20
55
65
80
135
240
290
390
710
5×11
5×11
6.3×11
5×11
6.3×11
8×11.5
10×16
10×20
12.5×20
16×25
16×35.5
18×40
50
65
70
75
85
145
260
350
455
835
1500
1980
5×11
35
5×11
6.3×11
5×11
6.3×11
55
70
70
90
5×11
6.3×11
5×11
6.3×11
5×11
6.3×11
25
30
35
40
5×11
6.3×11
25
30
5×11
22
5×11
30
8×11.5
40
5×11
6.3×11
35
40
10×12.5
60
75
10×16
95
10×20
155
5×11
25
5×11
30
5×11
6.3×11
5×11
6.3×11
35
60
60
80
5×11
6.3×11
35
55
8×11.5
75
8×11.5
95
10×12.5
130
10×16
140
8×11.5
8×11.5
120
10×12.5
140
10×16
175
10×20
190
12.5×20
220
8×11.5
125
8×11.5
140
10×12.5
170
10×16
210
10×20
225
12.5×25
285
10×12.5
10×20
12.5×20
12.5×25
16×31.5
18×40
215
385
545
710
1315
2150
10×16
12.5×20
12.5×25
16×25
16×35.5
270
505
675
940
1575
10×20
12.5×25
16×25
16×31.5
18×35.5
295
550
785
1030
1690
12.5×20
16×25
16×31.5
16×35.5
18×40
380
720
965
1210
1985
12.5×25
16×31.5
16×35.5
18×35.5
415
785
1010
1295
16×25
18×40
485
930
(Note) Rated ripple current : 85℃, 120Hz
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
169
CAT.No.2015/2016E
FOR AUDIO
ALUMINUM
Casing
Casing
Casing
Casing
Case
Case
Case
Case
φD×L (mm) Symbol φD×L (mm) Symbol φD×L (mm) Symbol φD×L (mm) Symbol
5×11
E3
10×12.5
H3
16×31.5
J7
12.5×20
Ⅰ5
6.3×11
F3
10×16
H4
16×35.5
J8
12.5×25
Ⅰ6
8×11.5
G3
10×20
H5
18×35.5
K8
16×25
J6
18×40
K9
很抱歉,暂时无法提供与“RFS-25V330MG3#5”相匹配的价格&库存,您可以联系我们找货
