DRQ74-220-R
DRQ74-220-R
    EATON(伊顿)
    SMD-4P,7.6x7.6mm
    21.73UH ±20% 2.13A
DRQ74-220-R 数据手册
Technical Data 4311 Effective April 2014 Supersedes December 2007 Coiltronics DRQ Series Dual winding, shielded inductors/transformers Applications • As a transformer: SEPIC, flyback • As an inductor: buck, boost, coupled inductor • DC-DC Converters • VRM inductor for CPU and DDR power supplies • Input and output filter chokes Environmental data Product description • Lead free, RoHS compliant • 125°C maximum total operating temperature • Dual winding inductors that can be used as either a single inductor, or in coupled inductor/transformer applications (1:1 turns ratio) • Four sizes of shielded drum core inductors • Windings can be connected in series or parallel, offering a broad range of inductance and current ratings • Peak current ratings from 0.13 to 56 amps • RMS current ratings from 0.128 to 17.9 amps • Inductance ratings from 0.33μH to 4.02mH • Surface mount • 200Vac Isolation between windings • Ferrite core material • Storage temperature range (Component): -40°C to +125°C • Operating temperature range: -40°C to +125°C (ambient + self-temperature rise) • Solder reflow temperature: J-STD-020D compliant Packaging: • Supplied in tape and reel packaging (per reel): - DRQ73 1350 - DRQ74 1100 - DRQ125 600 - DRQ127 350 Pb The Coiltronics brand of magnetics (formerly of the Bussmann Division of Cooper Industries) is now part of Eaton’s Electrical Group, Electronics Division. Coiltronics is now part of Eaton Same great products plus even more. Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Product specifications Parallel Ratings Rated Inductance (μH) Part Number OCL1 ±20% (μH) Irms2 Amps Isat3 Amps Peak DCR Ω4 typ. Volt5 μ-Sec Irms2 Amps Isat3 Amps Peak DCR Ω4 typ. Volt5 μ-Sec DRQ73-R33-R 0.33 0.306 6.19 14.4 0.0074 1.98 1.224 3.10 7.18 0.0296 3.96 DRQ73-1R0-R 1.00 0.992 5.25 7.97 0.0103 3.56 3.968 2.63 3.99 0.0411 7.12 DRQ73-1R5-R 1.50 1.482 4.64 6.52 0.0132 4.36 5.928 2.32 3.26 0.0527 8.72 DRQ73-2R2-R 2.20 2.070 4.11 5.52 0.0167 5.15 8.280 2.06 2.76 0.0669 10.3 DRQ73-3R3-R 3.30 3.540 3.31 4.22 0.0259 6.73 14.16 1.66 2.11 0.1035 13.5 DRQ73-4R7-R 4.70 4.422 3.09 3.78 0.0297 7.52 17.69 1.55 1.89 0.1188 15.0 DRQ73-6R8-R 6.80 6.480 2.55 3.12 0.0435 9.11 25.92 1.28 1.56 0.1742 18.2 DRQ73-8R2-R 8.20 8.930 2.19 2.66 0.0592 10.7 35.72 1.10 1.33 0.2368 21.4 DRQ73-100-R 10.0 10.30 2.08 2.47 0.0656 11.5 41.20 1.04 1.24 0.2623 23.0 DRQ73-150-R 15.0 15.01 1.83 2.05 0.0844 13.9 60.04 0.916 1.03 0.339 27.8 DRQ73-220-R 22.0 22.65 1.62 1.67 0.107 17.0 90.60 0.811 0.83 0.429 34.0 DRQ73-330-R 33.0 34.41 1.31 1.35 0.166 21.0 137.6 0.653 0.68 0.665 42.0 DRQ73-470-R 47.0 48.62 1.08 1.14 0.241 24.9 194.5 0.542 0.57 0.965 49.8 DRQ73-680-R 68.0 68.91 0.89 0.96 0.358 29.7 275.6 0.444 0.48 1.43 59.4 DRQ73-820-R 82.0 80.37 0.86 0.89 0.384 32.1 321.5 0.430 0.44 1.54 64.2 DRQ73-101-R 100 101.4 0.73 0.79 0.527 36.0 405.6 0.367 0.39 2.11 72.0 DRQ73-151-R 150 150.9 0.58 0.65 0.851 44.0 603.6 0.289 0.32 3.41 88.0 DRQ73-221-R 220 223.3 0.52 0.53 1.05 53.5 893.2 0.260 0.27 4.20 107 DRQ73-331-R 330 325.5 0.42 0.44 1.59 64.5 1302 0.211 0.22 6.36 129 DRQ73-471-R 470 465.8 0.35 0.37 2.36 77.2 1863 0.173 0.18 9.44 154 DRQ73-681-R 680 676.5 0.29 0.31 3.47 93.1 2706 0.143 0.15 13.88 186 DRQ73-821-R 820 821.7 0.27 0.28 3.93 103 3287 0.134 0.14 15.72 206 DRQ73-102-R 1000 995.0 0.26 0.25 4.34 113 3980 0.128 0.13 17.36 226 1. Open Circuit Inductance Test Parameters: 100kHz, 0.25 Vrms, 0.0 Adc Parallel: (1,2 -4,3) Series: (1-4) tie (2-3) 2. RMS current for an approximate DT of 40°C without core loss. It is recommended that the temperature of the part not exceed 125°C. 3. Peak current for approximately 30% roll-off at 20°C 4. DCR limits @ 20°C 5. Applied Volt-Time product (V-μS) across the inductor. This value represents the applied V-μS at 100KHz necessary to generate a core loss equal to 10% of the total losses for a 40°C temperature rise. 2 Series Ratings OCL1 ±20% (μH) www.eaton.com/elx 6. Turns Ratio (1:3):(2-4) 1:1 7. Part number definition: DRQxxx-yyy-R - DRQxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant DRQ Series Dual winding, shielded inductors/transformers Technical Data 4311 Effective April 2014 Product specifications Parallel Ratings Part Number Rated Inductance (μH) OCL1 ±20% (μH) DRQ74-R33-R 0.33 DRQ74-1R0-R 1.00 DRQ74-1R5-R Series Ratings Irms2 Amps Isat3 Amps Peak Volt5 μ-Sec OCL1 ±20% (μH) DCR Ω4 Typ. Irms2 Amps Isat3 Amps Peak DCR Ω4 Typ. Volt5 μ-Sec 0.294 6.20 18.4 0.952 5.33 10.2 0.0074 1.71 1.176 3.10 9.18 0.0295 3.42 0.0100 3.08 3.808 2.66 5.10 0.0400 6.16 1.50 1.422 4.96 8.35 0.0115 3.76 5.688 2.48 4.17 0.0461 7.52 DRQ74-2R2-R 2.20 1.986 DRQ74-3R3-R 3.30 3.396 4.66 7.06 0.0130 4.45 7.944 2.33 3.53 0.0521 8.9 3.94 5.40 0.0183 5.81 13.58 1.97 2.70 0.0732 11.6 DRQ74-4R7-R 4.70 DRQ74-6R8-R 6.80 5.182 3.34 4.37 0.0254 7.18 20.73 1.67 2.19 0.102 14.4 7.344 2.60 3.67 0.0418 8.55 29.38 1.30 1.84 0.167 17.1 DRQ74-8R2-R 8.20 8.566 2.53 3.40 0.0441 9.23 34.26 1.27 1.70 0.177 18.5 DRQ74-100-R 10.0 9.882 2.41 3.17 0.0489 9.92 39.53 1.20 1.58 0.196 19.8 DRQ74-150-R 15.0 16.09 2.11 2.48 0.0637 12.7 64.36 1.05 1.24 0.255 25.4 DRQ74-220-R 22.0 21.73 1.75 2.13 0.0925 14.7 86.92 0.874 1.07 0.371 29.4 DRQ74-330-R 33.0 33.01 1.41 1.73 0.143 18.1 132.0 0.702 0.87 0.574 36.2 DRQ74-470-R 47.0 49.64 1.15 1.41 0.216 22.2 198.6 0.573 0.71 0.865 44.4 DRQ74-680-R 68.0 69.67 1.03 1.19 0.265 26.3 278.7 0.517 0.60 1.06 52.6 DRQ74-820-R 82.0 80.95 0.91 1.11 0.345 28.4 323.8 0.453 0.55 1.38 56.8 DRQ74-101-R 100 101.6 0.86 0.99 0.383 31.8 406.4 0.430 0.49 1.53 63.6 DRQ74-151-R 150 150.0 0.69 0.81 0.591 38.6 600.0 0.346 0.41 2.37 77.2 DRQ74-221-R 220 227.0 0.56 0.66 0.907 47.5 908.0 0.279 0.33 3.63 95 DRQ74-331-R 330 335.6 0.45 0.54 1.41 57.8 1342 0.224 0.27 5.66 116 DRQ74-471-R 470 465.3 0.40 0.46 1.74 68.1 1861 0.202 0.23 6.97 136 DRQ74-681-R 680 671.2 0.33 0.38 2.58 81.7 2685 0.166 0.19 10.3 163 DRQ74-821-R 820 812.7 0.31 0.35 2.93 89.9 3251 0.156 0.17 11.7 180 DRQ74-102-R 1000 1009 0.27 0.31 3.89 100 4036 0.135 0.16 15.6 200 1. Open Circuit Inductance Test Parameters: 100kHz, 0.25 Vrms, 0.0 Adc Parallel: (1,2 -4,3) Series: (1-4) tie (2-3) 2. RMS current for an approximate DT of 40°C without core loss. It is recommended that the temperature of the part not exceed 125°C. 3. Peak current for approximately 30% roll-off at 20°C 4. DCR limits @ 20°C 5. Applied Volt-Time product (V-μS) across the inductor. This value represents the applied V-μS at 100KHz necessary to generate a core loss equal to 10% of the total losses for a 40°C temperature rise. 6. Turns Ratio (1:3):(2-4) 1:1 7. Part number definition: DRQxxx-yyy-R - DRQxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant www.eaton.com/elx 3 Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Product specifications Rated Parallel Ratings Part Number (μH) DRQ125-R47-R 0.47 0.456 17.6 33.0 0.0018 3.17 1.824 8.80 16.5 0.0078 6.34 DRQ125-1R0-R 1.00 0.894 15.0 23.6 0.0024 4.43 3.576 7.51 11.8 0.0096 8.86 DRQ125-1R5-R 1.50 1.478 13.8 18.3 0.0029 5.70 5.912 6.89 9.15 0.0114 11.40 DRQ125-2R2-R 2.20 2.208 10.9 15.0 0.0045 6.97 8.832 5.46 7.50 0.0182 13.9 DRQ125-3R3-R 3.30 3.084 9.26 12.7 0.0063 8.23 12.34 4.63 6.35 0.0253 16.5 DRQ125-4R7-R 4.70 5.274 7.18 9.71 0.0105 10.8 21.10 3.59 4.86 0.0420 21.6 DRQ125-6R8-R 6.80 6.588 6.64 8.68 0.0123 12.0 26.35 3.32 4.34 0.0492 24.0 DRQ125-8R2-R 8.20 8.048 5.54 7.86 0.0176 13.3 32.19 2.77 3.93 0.0705 26.6 DRQ125-100-R 10.0 9.654 5.35 7.17 0.0189 14.6 38.62 2.67 3.59 0.0757 29.2 DRQ125-150-R 15.0 15.35 4.27 5.69 0.0298 18.4 61.40 2.13 2.85 0.120 36.8 DRQ125-220-R 22.0 22.36 3.70 4.71 0.0396 22.2 89.44 1.84 2.36 0.159 44.4 DRQ125-330-R 33.0 33.74 3.28 3.84 0.0505 27.2 135.0 1.64 1.92 0.203 54.4 DRQ125-470-R 47.0 47.47 2.71 3.24 0.0740 32.3 189.9 1.35 1.62 0.297 64.6 DRQ125-680-R 68.0 67.91 2.22 2.70 0.101 38.6 271.6 1.11 1.35 0.440 77.2 DRQ125-820-R 82.0 86.89 2.05 2.39 0.128 43.7 347.6 1.03 1.20 0.515 87.4 DRQ125-101-R 100 102.7 1.78 2.20 0.170 47.5 410.8 0.892 1.10 0.682 95.0 DRQ125-151-R 150 151.1 1.48 1.81 0.248 57.6 604.4 0.739 0.905 0.991 115.2 DRQ125-221-R 220 216.8 1.19 1.51 0.384 69.0 867.2 0.594 0.755 1.54 138 DRQ125-331-R 330 332.6 1.06 1.22 0.482 85.5 1330 0.530 0.610 1.93 171 DRQ125-471-R 470 473.1 0.87 1.02 0.718 102 1892 0.434 0.510 2.87 204 DRQ125-681-R 680 679.8 0.70 0.85 1.10 122 2719 0.350 0.425 4.42 244 DRQ125-821-R 820 828.0 0.60 0.77 1.49 135 3312 0.301 0.385 5.96 270 DRQ125-102-R 1000 1008 0.57 0.70 1.69 149 4032 0.283 0.350 6.76 298 Inductance Irms2 Amps Isat3 Amps Peak DCR Ω4 typ. 1. Open Circuit Inductance Test Parameters: 100kHz, 0.25 Vrms, 0.0 Adc Parallel: (1,2 -4,3) Series: (1-4) tie (2-3) 2. RMS current for an approximate DT of 40°C without core loss. It is recommended that the temperature of the part not exceed 125°C. 3. Peak current for approximately 30% roll-off at 20°C 4. DCR limits @ 20°C 5. Applied Volt-Time product (V-μS) across the inductor. This value represents the applied V-μS at 100KHz necessary to generate a core loss equal to 10% of the total losses for a 40°C temperature rise. 4 Series Ratings OCL1 ±20% (μH) www.eaton.com/elx Volt5 μ-Sec OCL1 ±20% (μH) Irms2 Amps Isat3 Amps Peak DCR Ω4 typ. Volt5 μ-Sec 6. Turns Ratio (1:3):(2-4) 1:1 7. Part number definition: DRQxxx-yyy-R - DRQxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Product specifications Parallel Ratings Rated Inductance (μH) OCL1 ±20% (μH) DRQ127-R47-R 0.47 DRQ127-1R0-R 1.00 DRQ127-1R5-R Series Ratings Irms2 Amps Isat3 Amps Peak Volt5 μ-Sec OCL1 ±20% (μH) DCR Ω4 typ. Irms2 Amps Isat3 Amps Peak DCR Ω4 typ. Volt5 μ-Sec 0.419 17.9 56.0 0.821 15.5 40.0 0.00195 3.50 1.676 8.94 28 0.0078 7.00 0.00261 4.90 3.284 7.74 20 0.0104 9.80 1.50 1.357 13.5 31.1 0.00341 6.30 5.428 6.77 15.6 0.0137 12.60 DRQ127-2R2-R 2.20 2.027 DRQ127-3R3-R 3.30 2.831 12.5 25.5 0.00373 7.70 8.108 6.23 12.7 0.0161 15.4 10.4 21.5 0.00567 9.10 11.32 5.23 10.8 0.0229 18.2 DRQ127-4R7-R 4.70 DRQ127-6R8-R 6.80 4.841 8.25 16.5 0.00917 11.9 19.36 4.13 8.24 0.0367 23.8 7.387 7.34 13.3 0.0116 14.7 29.55 3.67 6.67 0.0465 29.4 DRQ127-8R2-R 8.20 8.861 6.32 12.2 0.0157 16.1 35.44 3.16 6.09 0.0627 32.2 DRQ127-100-R 10.0 10.47 6.04 11.2 0.0172 17.5 41.88 3.02 5.60 0.0686 35.0 DRQ127-150-R 15.0 14.09 5.03 9.66 0.0247 20.3 56.36 2.51 4.83 0.0990 40.6 DRQ127-220-R 22.0 22.93 4.00 7.57 0.0391 25.9 91.72 2.00 3.78 0.157 51.8 DRQ127-330-R 33.0 33.92 3.23 6.22 0.0600 31.5 135.7 1.61 3.11 0.241 63.0 DRQ127-470-R 47.0 47.05 2.95 5.28 0.0719 37.1 188.2 1.47 2.64 0.288 74.2 DRQ127-680-R 68.0 66.48 2.44 4.44 0.105 44.1 265.9 1.22 2.22 0.421 88.2 DRQ127-820-R 82.0 79.75 2.09 4.06 0.143 48.3 319.0 1.04 2.03 0.573 96.6 DRQ127-101-R 100 99.31 1.96 3.64 0.163 53.9 397.2 0.980 1.82 0.653 107.8 DRQ127-151-R 150 144.9 1.59 3.01 0.247 65.1 579.6 0.796 1.51 0.989 130.2 DRQ127-221-R 220 221.5 1.29 2.43 0.376 80.5 886.0 0.645 1.22 1.50 161 DRQ127-331-R 330 323.6 1.04 2.01 0.574 97.3 1294 0.522 1.01 2.30 195 DRQ127-471-R 470 467.1 0.85 1.68 0.861 117 1868 0.427 0.838 3.44 234 DRQ127-681-R 680 676.7 0.76 1.39 1.08 141 2707 0.380 0.697 4.32 282 DRQ127-821-R 820 818.1 0.65 1.27 1.47 155 3272 0.325 0.633 5.88 310 DRQ127-102-R 1000 1005 0.61 1.14 1.66 172 4020 0.307 0.571 6.64 344 Part Number 1. Open Circuit Inductance Test Parameters: 100kHz, 0.25 Vrms, 0.0 Adc Parallel: (1,2 -4,3) Series: (1-4) tie (2-3) 2. RMS current for an approximate DT of 40°C without core loss. It is recommended that the temperature of the part not exceed 125°C. 3. Peak current for approximately 30% roll-off at 20°C 4. DCR limits @ 20°C 5. Applied Volt-Time product (V-μS) across the inductor. This value represents the applied V-μS at 100KHz necessary to generate a core loss equal to 10% of the total losses for a 40°C temperature rise. 6. Turns Ratio (1:3):(2-4) 1:1 7. Part number definition: DRQxxx-yyy-R - DRQxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant www.eaton.com/elx 5 Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Dimensions - mm DRQ73 Series Recommended Pad Layout Side View Top View 3.55 Max 1.00 1.73 1.00 0.40 0.40 • DRQ73 ### wllyy R 7.6 Max. 1.73 7.9 7.9 Dual Inductor Mode Bottom View Series Mode Schematic 6.1 0.73 Dual Inductor 0.60 Series Mode 1 7.6 Max. 2 L1 0.80 1 L2 2 L1 4 3 Parallel Mode L2 3 2 1 L1 4 L2 3 4 DRQ74 Series Recommended Pad Layout Side View Top View 4.45 Max • DRQ74 ### wllyy R 1.00 0.40 1.73 7.6 Max 7.9 7.9 Dual Inductor Mode Bottom View Series Mode Schematic 0.73 Dual Inductor 7.6 Max 0.60 1.73 1.00 0.40 1 2 L1 3 Parallel Mode Series Mode 1 L2 2 L1 4 3 1 2 L1 L2 4 3 L2 4 6.1 ### = Inductance value per family chart wllyy = Date code R = Revision level Dot indicates pin #1 DRQ Series Dual winding, shielded inductors/transformers Technical Data 4311 Effective April 2014 Dimensions - mm DRQ125 Series Side View Top View 6.00 Max DRQ125 ### wwlly y R 2 3.85 2.50 4 4 2 12.5 Max 3 0.50 3.85 1 • 1 Recommended Pad Layout 2.50 3 1 4 2 3 0.50 13.80 13.80 Dual Inductor Mode Series Mode Bottom View 2.05 Schematic 2.00 2 3 1 4 Dual Inductor 12.5 Max 1 2 L1 1 L2 3 10.0 Parallel Mode Series Mode L1 4 2 1 4 3 L1 L2 3 2 L2 4 DRQ127 Series Side View Top View 1 2 Recommended Pad Layout 8.0 Max • DRQ127 ### wwllyy R 2.50 4 2.50 12.5 Max 3 0.50 3.85 3.85 1 4 2 3 0.50 13.80 13.80 Dual Inductor Mode Series Mode Bottom View 2.05 Schematic 2.00 2 3 1 4 10.0 Dimensions in millimeters. 12.5 Max Dual Inductor 1 L1 3 Series Mode 2 L2 L1 4 3 Parallel Mode 2 1 1 L2 2 L1 4 L2 3 4 ### = Inductance value per family chart wwllyy = (date code) R = revision level Dot indicates pin #1 www.eaton.com/elx 7 Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Packaging information - mm DRQ73 Series Supplied in tape and reel packaging, 1350 parts per reel, 13" diameter reel. ACTUAL SIZE DRQ73 Ao=7.90mm Bo=7.90mm Ko=3.80mm Direction of Feed DRQ74 Series Supplied in tape and reel packaging, 1100 parts per reel, 13" diameter reel. Ø1.50 +0.1/-0.0 2.00 ±0.1 Ø1.50 Min. 4.00 A 1.75±0.10 1 2 7.50±0.1 DRQ74 ### B Bo ACTUAL SIZE DRQ74 4 3 Ao=7.90mm Bo=7.90mm Ko=4.70mm 16.00 ±0.3 A Ko Direction of Feed 12.00 0 Ao SECTION A-A DRQ125 Series Supplied in tape and reel packaging, 600 parts per reel, 13" diameter reel. 4.0 1.5 dia +0.1/-0.0 2.0 1.5 dia min A 1.7 1 2 11.5 • 24.0 +/-0.3 DRQ125 ### wwllyy B B0 K0 A0 SECTION A-A DRQ127 Series ACTUAL SIZE DRQ125 4 3 Ao=13.00mm Bo=13.00mm Ko=6.30mm Direction of Feed A 16.00 4.0 Supplied in tape and reel packaging, 350 parts per reel, 13" diameter reel. 1.5 dia +0.1/-0.0 2.0 1.5 dia min A 1.7 R0.3 max. 1 2 11.5 . K0 SECTION A-A Dimensions are in millimeters. 8 www.eaton.com/elx ACTUAL SIZE DRQ127 4 3 Ao=13.00mm Bo=13.00mm Ko=8.30mm 24.0 +/-0.3 DRQ127 ### wwllyy B B0 A0 20.00 Direction of Feed A R0.5 TYP. DRQ Series Dual winding, shielded inductors/transformers Technical Data 4311 Effective April 2014 Inductance characteristics OCL vs I sat DRQ73 100 90 80 OCL (%) 70 60 50 40 30 20 10 0 0 20 40 60 80 100 120 140 160 % of I sat OCL vs I sat DRQ74 100 OCL (%) 80 60 40 20 0 0 20 40 60 80 100 120 160 180 www.eaton.com/elx 9 140 % of I sat Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Inductance characteristics OCL vs I sat DRQ125 100 90 80 OCL (%) 70 60 50 40 30 20 10 0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 100 110 120 130 140 150 % of I sat OCL vs I sat DRQ127 100 90 80 OCL (%) 70 60 50 40 30 20 10 0 0 10 20 30 40 50 60 70 80 % of I sat 10 www.eaton.com/elx 90 DRQ Series Dual winding, shielded inductors/transformers Technical Data 4311 Effective April 2014 Core loss z KH 25 KH z 50 KH z 10 0 Hz 20 0K Hz 30 0K % of Losses from Irms (max) Irms Derating with Core Loss % of Applied Volt-µSecond www.eaton.com/elx 11 Technical Data 4311 DRQ Series Dual winding, shielded inductors/transformers Effective April 2014 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Package Thickness Temperature TL 25°C Preheat A T smax Table 1 - Standard SnPb Solder (T c) t Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin Package Thickness 2.5mm ts Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020D Profile Feature Preheat and Soak Standard SnPb Solder 100°C • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. North America Eaton’s Electrical Group Electronics Division 1225 Broken Sound Parkway NW Suite F Boca Raton, FL 33487-3533 Tel: 1-561-998-4100 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Eaton’s Electrical Group Electronics Division P.O. Box 14460 St. Louis, MO 63178-4460 Tel: 1-636-394-2877 Fax: 1-636-527-1607 Europe Eaton’s Electrical Group Electronics Division Burton-on-the-Wolds Leicestershire, LE 12 5th UK Phone: +44 (0) 1509 882 600 Fax: +44 (0) 1509 882 786 Eaton’s Electrical Group Electronics Division Avda Santa Eulalia, 290 Terrassa, Barcelona 08223 Spain Phone: +34-93-736-2813 Fax: +34-93-783-5055 Asia Pacific Eaton’s Electrical Group Electronics Division No.2, #06-01 Serangoon North Avenue 5 Singapore 554911 Tel: +65 6645 9888 Fax: +65 6728 3155 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton’s Electrical Group Electronics Division 114 Old State Road Ellisville, MO 63021 United States www.eaton.com/elx 12 www.eaton.com/elx © 2014 Eaton All Rights Reserved Publication No. 4311 — BU-SB14113 April 2014 Eaton is a registered trademark. All other trademarks are property of their respective owners.
DRQ74-220-R
物料型号: - DRQ系列包含多种型号,包括DRQ125、DRQ73、DRQ74和DRQ127。
器件简介: - 这些电感器采用无铅材料,符合RoHS标准,最大工作温度为125°C。 - 双绕组设计使其可以用作单个电感器或耦合电感器/变压器(1:1匝比)。 - 提供四种尺寸的屏蔽鼓芯电感器。 - 绕组可以串联或并联连接,提供广泛的电感和电流等级。 - 峰值电流等级从0.13到56安培,RMS电流等级从0.128到17.9安培。 - 电感值从0.33μH到4.02mH不等。 - Coiltronics品牌现为Eaton电气集团的一部分。
引脚分配: - 引脚分配信息在文档中未明确列出,但通常这类电感器会有两个主要引脚用于连接电路。
参数特性: - 电感值、峰值电流、RMS电流、直流电阻(DCR)、电压-微秒产品(Volt5 u-Sec)等参数在表格中详细列出。
功能详解: - 作为变压器:SEPIC、反激(flyback)。 - 作为电感器:降压(buck)、升压(boost)、耦合电感器。 - 用于DC-DC转换器、CPU和DDR电源的VRM电感器、输入和输出滤波扼流圈。
应用信息: - 适用于各种电源转换和电源管理应用。
封装信息: - 提供胶带和卷轴包装,每卷数量不同,例如DRQ73每卷1350个,DRQ74每卷1100个,DRQ125每卷600个,DRQ127每卷350个。
环境数据: - 存储温度范围:-40°C至+125°C。 - 工作温度范围:-40°C至+125°C(环境温度+自温升)。 - 焊接回流温度:符合J-STD-020D标准。
技术数据: - 详细列出了不同型号的额定电感、并联和串联评级、DCR典型值、电压-微秒产品等。
尺寸信息: - 提供了DRQ73、DRQ74、DRQ125和DRQ127系列的推荐垫布局和尺寸图。
核心损耗: - 提供了核心损耗与频率、电压-微秒产品的关系图。
焊接回流曲线: - 提供了标准SnPb焊料和无铅焊料的焊接回流曲线。
联系信息: - 提供了Eaton电气集团电子部门的北美、欧洲、亚太地区的联系信息。
DRQ74-220-R 价格&库存
很抱歉,暂时无法提供与“DRQ74-220-R”相匹配的价格&库存,您可以联系我们找货
DRQ74-220-R
    DRQ74-220-R
    • 5+9.79109
    • 275+9.57657
    • 550+9.37246
    库存:115
    DRQ74-220-R
    • 1100+8.613171100+1.11571
    • 2200+8.123242200+1.05225
    • 3300+7.850053300+1.01686
    • 5500+7.519275500+0.97401
    • 7700+7.387307700+0.95692
    库存:1492
    DRQ74-220-R
    • 1100+6.69842
    库存:1857
